2H Amarok Cruise, highline cluster and MFSW Retrofit
kamold
Australia
C?ID=241363
Hi All,
This is a bit of a naughty post from me, apologies in advance...
I had to rush off so make full admissions that I haven't yet done the basic 1st lot of checks with respect to confirming wiring etc
I did do continuity checks between the steering connector plugs at pins T41/26 and T41/29 to ECU pin T94/45. Have not yet had a chance to check measuring blocks in ECU when cruise stalk buttons are pressed.
Nonetheless I would appreciate any advice from any PQ25 experts (iichel ;) )
So I have helped a friend with his 2014 2HA Amarok install some basic comfort features.
He got a cluster and highline BCM from a Polo, got stalks with cruise again from a Polo and MK6 GTI MFSW.
Original scan:
Wednesday,17,June,2020,11:54:39:58930
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: WV1ZZZ2HZEA009865   License Plate: CSM82F
Mileage: 51880km-32236mi   Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 25 56
VIN: WV1ZZZ2HZEA009865   Mileage: 51880km-32236miles
Address 01: Engine (------CFPA)       Labels: None
   Part No SW: 2H0 907 115     HW: 2H0 907 115
   Component: 2.0l R4/4V TF H06 0002
   Revision: P8H06---    Serial number: 00000000000000
   Coding: 01190012430500010000
   Shop #: WSC 07456 000 09999
   ASAM Dataset: EV_ECM20TFS0112H0907115 004001
   ROD: EV_ECM20TFS0112H0907115_004.rod
   VCID: 619F5B4F71C7C9233C5-8034
Readiness: 0000 0001
Address 03: ABS Brakes (-----)       Labels: None
   Part No SW: 2H0 907 379 M    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0111
   Revision: 00H44001
   Coding: B07324B689940D9E24AA91A9AF55F0
   Shop #: WSC 07456 790 49164
   VCID: 3A2DCC23BC51FAFB5DF-806E
   Part No SW: 2H0 907 047 E    HW: 2H0 907 047 E
   Component: Climatic-T5   H20 0505
   Revision: 00001009
   Coding: 0000000002
   Shop #: WSC 07456 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 2A0DFC634C714A7B2DF-807E
   Part No SW: 6R7 937 086 P    HW: 6R7 937 086 P
   Component: PQ25 BCM      H30 0561
   Revision: -3------    Serial number: --------------
   Coding: 640000380C210000002008102C4B84C40040410E60020000300000000003
   VCID: 50F98E8B0AED50AB83B-8004
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3323
   Coding: 050000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3323
   Coding: 050000
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00H H07 0013
   Revision: --------    Serial number: 003HN00D0HRE
   Coding: 000000000000000000000000000000003048
   Shop #: WSC 07446 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3333E1079BBB0BB39E9-8066
   Serial number: 3495RRB400O50JHIB8L+
   Serial number: 3505RRB400K50JB27HG7
   Serial number: 3555YRB400E50GQ0G9MU
   Serial number: 3565YRB400E50GQ0EGLZ
   Part No SW: 2H0 920 860 D    HW: 2H0 920 860 D
   Component: KOMBI         H04 0709
   Coding: 170200
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 270B05575F637713321-8072
   Part No SW: 6N0 909 901     HW: 6R7 937 086 P
   Component: GW-K-CAN TP20 H30 0561
   Revision: -3------
   Coding: 742100
   Shop #: WSC 07462 790 50316
   VCID: 70B92E0BAAAD70ABA3B-8024
   Component: IMMO          H04 0709
   VCID: 6A8D3C638CF18A7BEDF-803E
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4H6244611
   Coding: 16000400040005
   Shop #: WSC 00078 790 00206
   VCID: 46D5A8D3F8A98E1B297-8012
End----------(Elapsed Time: 00:36, VBatt start/end: 12.1V/12.1V)-----------
More to follow...
kamold
Australia
C?ID=241363
Scan after initial install and coding:
Wednesday,17,June,2020,16:13:43:58930
Scan: 01 03 08 09 15 17 19 25 56 77
VIN: WV1ZZZ2HZEA009865   Mileage: 51870km-32230miles
   Coding: 01190012432500010000
   Shop #: WSC 07456 123 09999
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:09
                    Engine speed: 0.00 /min
                    Coolant temperature: 15 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 12.133 V
Readiness: 1110 0101
   Revision: 00H44001
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:07
                    Count: 16384
                    Count: 4097
                    Count: 8214
                    Count: 1020
   Revision: 00001009
   Coding: 0000000002
   Part No SW: 6R0 937 087 M    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H32 0407
   Revision: BF032001    Serial number: 0540 106131209
   Coding: 640000380C210000002808102C4B84D100C0410E60020000300000000000
   Shop #: WSC 124697 483 00190
   VCID: 47CBA5D7FFA39713D21-8012
   Coding: 050000
   Coding: 050000
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:10
          B1000 1B [137] - Resistance Too High
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:11
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:11
   Part No SW: 6R0 920 870 B    HW: 6R0 920 870 B
   Component: KOMBI         H05 0607
   Coding: 151A00
   Shop #: WSC 00788 648 00255
   VCID: 3431E21B9EB50C8B873-8060
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:07
10485825 - Internal Control Module Memory Check Sum Error
          B2000 41 [137] - General checksum failure
          [Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H32 0407
   Revision: BF032001
   Coding: 002300
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:10
   Component: IMMO          H05 0607
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:31
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:31
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:31
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 147
                    Mileage: 51873 km
                    Date: 2020.06.17
                    Time: 00:18:31
Address 77: Telephone
End----(Elapsed Time: 00:55, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
Steering angle sensor error has been fixed by putting the correct clockspring with integrated steering angle sensor onto the stalks.
The multifunction steering wheel buttons do not work at all. Have checked that the power wire from the the fuse box to steering wheel connector has continuity.
HOWEVER I still have the trip computer stalk installed. So need to remove that and install a regular wiper stalk.
If I press the trip stalk buttons to change MFD data it also changes radio stations....seems like some crossed wires there ;)
I changed ECU byte 5 bit 5 to enable for cruise, but there is no label file for this ECU so I'm unsure if this is valid to enable cruise at the ECU.
The cluster faults are known, I haven't yet corrected the eeprom from original Polo configuration.
It seems like this engine is a bit of a rarity, so I'm having trouble finding the cruise coding for it without a label file.
With byte 5, bit 5 in ECU back to disabled there are no faults in ECU.
kamold
Australia
C?ID=241363
So cruise coding in ECU is in fact byte 5 bit 5 same as 6R Polo.
Now my friend doesn't need to take a piece of wood for the throttle to go for a long drive...
