kwatt
New Member
- Joined
- Jun 2, 2020
- Messages
- 1
- Reaction score
- 0
- Location
- Scotland
- VCDS Serial number
- C?ID=395773 (NRRT)
I did register and got a verification email but, doesn't seem to be so in the forum as I can't post anywhere but here and pre-sales. Please feel free to move this if appropriate.
I have a Skoda Superb 3, 2018 and have now successfully got traffic sign recognition and a few other things working but the HBA has completely foxed me.
I get through the following from Briskoda:
Address 09
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent
adapted from Not Present to present
Address 09
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung
Address 09
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung
adapted from AFS: BCM-Fernlicht to AFS: FLA: BCM-Fernlicht
All good, till I get to the coding part that is:
Controller A5 (Front / front view camera)
07 - Coding
Byte 21
Change to High Beam Assist or change to "20"
And:
Controller 09 - Central Electronics
07 - Coding
Byte 2 Bit 0-2. Change to 03
On the A5 camera module I get all zeros and:
coding is not supported by this control module variant replacement control module must be parameterized by using the factory tools and software version manager
Googled that, ended up here on another post. That said rescan, did that and still get this and I can't see any faults or nothing to do with this art any rate.
VCDS reports:
The option does come up on the screen for light assist but not reflected in the dash display
Can anyone shed some light anyone this for me please and no, that's wasn't a joke even I didn't think it funny?
K.
Address 09
Address 09
Address 09
07 - Coding
Byte 21
And:
07 - Coding
VCDS reports:
Tuesday,02,June,2020,19:07:32:02419
VIN: TMBBH7NP6J7596885 License Plate:
Mileage: 15213km-9452mi Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47
4B 52 5F 6C 6D 75 A5 BB BC
VIN: TMBBH7NP6J7596885 Mileage: 15213km-9452miles
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 KD HW: 04L 907 309 P
Component: R4 2.0l TDI H25 4798
Revision: B4H25---
Coding: 02250432036405087000
Shop #: WSC 33361 790 00137
ASAM Dataset: EV_ECM20TDI01104L906026KD 005005
ROD: EV_ECM20TDI01104L906026KD_005_SK48.rod
VCID: 76B5E0BA1847AA8B797-8022
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0GC 300 042 H HW: 0GC 927 711 G
Component: GSG DQ381 H06 1404
Revision: 00H06V07
ASAM Dataset: EV_TCMDQ381061 001
ROD: EV_TCMDQ381061.rod
VCID: 2B0301CE9385A763D69-807E
Part No SW: 5Q0 614 517 DA HW: 5Q0 614 517 AH
Component: ESC H62 0753
Revision: 00000000 Serial number: 61298000000845
Coding: 1D07929C34290B72477F060860C849B8492CD0E2600692753861F0F8C2A2420B00000012121212B835351919323200
VCID: 73B3D9AE0B35BFA35E9-8026
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0479642335
Coding: 032C0C070F
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E25389A70F722CB617-806A
Subsystem 1 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84565116
U1400 00 [008] - -
Reset counter: 216
Mileage: 15211 km
Date: 2020.06.02
Time: 17:31:07
ZAT_pressed: OFF
Park selector lever position: Not engaged and not locked
Control Module Voltage: 9.256 V
Vehicle speed: 0.0 km/h
Engine speed: 132.0 /min
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RDO20379
Coding: 0014000000000500018280808080000000008181000000D400
ASAM Dataset: EV_SeatMemorPasseSide 002022
ROD: EV_SeatMemorPasseSide.rod
VCID: 3D273F967DF139D378D-8068
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 CP HW: 3V0 907 044 CP
Component: AC Automat H34 4402
Revision: 20K10000 Serial number: 00000B00944866
Coding: 11110104002410011005100D0010112A
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 04518A725E9B881B773-8050
Subsystem 2 - Part No SW: 3V0 907 049 E HW: 3V0 907 049 E
Component: E265KlimaHeck H02 0101
Serial number: 06051501850797
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001812500097
ROD: EV_BCMBOSCH_018.rod
VCID: 094F9B4679B9D573045-805C
Subsystem 1 - Part No SW: 3V2 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x RL 240218 032 0121
Serial number: 00000001802200300672
Coding: 1E4DDD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 050 0107
Serial number: S5Y18M05D04H03M06S41
Coding: 0088DF
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY181060TRL
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223981030693
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0391144
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0391503
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0878078
Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0391488
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 176
Mileage: 15213 km
Date: 2020.06.02
Time: 18:22:51
534549 - Databus
[FLA_01 Datenbus fehlende Botschaft]
Reset counter: 216
Mileage: 15211 km
Date: 2020.06.02
Time: 17:37:58
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000308417618123
Coding: 0371167851
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 50F97622DA63A4BB83B-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320067C355FFC428949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 353727B645C1E193B0D-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 09051841350576
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292E8252D31CFBABB-806C
Part No SW: 5Q0 959 655 BH HW: 5Q0 959 655 BH
Component: AirbagVW21 005 0336
Serial number: 003VVR45YJC.
Coding: 98CCC0C0000000005C5400CF00C800000065
VCID: 074B9D7E6FADA303121-8052
Subsystem 1 - Part No SW: ----------- HW: 480 000 205 18
Serial number: 35700000000879245E2N
Subsystem 2 - Part No SW: ----------- HW: 480 000 505 18
Serial number: 358000000004E4D44E2W
Subsystem 3 - Part No SW: ----------- HW: 480 402 704 18
Serial number: 3510001AD298DB44F60J
Subsystem 4 - Part No SW: ----------- HW: 480 400 505 18
Serial number: 35200019B29E65D11657
Subsystem 5 - Part No SW: ----------- HW: 480 402 804 18
Component: FrontSensor_D 000 6149
Serial number: 3550001B329BCD522727
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 LA HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0245
Revision: FF036036 Serial number: 20180514500514
Coding: 6414
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CA1F292266BF0DB0F3-8028
Part No SW: 3V0 920 911 B HW: 3V0 920 911 B
Component: KOMBI 301 0310
Coding: 27A5011A7F84A600018B6B0B5001000800000000
Shop #: WSC 73430 031 00137
VCID: 313F13A6B1A9CDB3EC5-8064
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuerger‰t keine oder falsche Grundeinstellung]
Reset counter: 176
Mileage: 15211 km
Date: 2020.06.02
Time: 17:11:23
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 27041810800519
Coding: 030100045F087300EB00025A9C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00160
ROD: EV_GatewNF_VW37.rod
Subsystem 2 - Part No SW: 3V0 919 719 D HW: 3V0 919 719 D
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000E0066010518
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 1995637604
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000137438017
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 333319AE4BB5FFA39E9-8066
Address 36: Seat Mem. Drvr (J810) Labels:* None
Serial number: Y0006RE211558
ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0478966237
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0478796935
Coding: 020112
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000320107823
Coding: 001D8820DE01040000001100
VCID: 47CB5D7E2F2D6303D21-8012
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Coding: 93170000
ROD: EV_SteerAssisMQB_015.rod
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1JJE04JSGV
Coding: 0384010000AA002FAA0000000000
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 59EF8B068999E5F3745-800C
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 06051811601595
Coding: 000000020100066E06003F01000000000000000000000000000000000000
VCID: 72BDDCAA742FB6AB55F-8026
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: Leimo links H01 0006
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: Leimo rechts H01 0006
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000318602551
Coding: 001D0220DE01040000001100
VCID: 46D5507A28277A0B297-8012
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 565 035 021 B HW: 565 035 021
Component: MU-H-LND-EU H54 1240
Serial number: A853E0JS049577
Coding: 038401010000000041111202008808102F0103E601200500DE
VCID: 0D47AF560DD1C95328D-8058
Subsystem 1 - Part No SW: 3V0 919 606 D HW: 3V0 919 606 D
Component: ABT_High-2 H50 9130
Serial number: SKZ6ZHV1293869
Subsystem 2 - Part No SW: V03 959 803 TF HW: -----------
Component: ECE 2019/2020 --- 0177
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1017
7201 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 216
Mileage: 15211 km
Date: 2020.06.02
Time: 17:11:29
Voltage terminal 30: 11.8 V
BAP-BAP_Function_ID: 02
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 04840101A600201F000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: 392F2B8669D905F3545-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 P HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0266
Revision: -------- Serial number: 31939346100000
Coding: 1008
ASAM Dataset: EV_DeckLidCONTIAU736 001016
VCID: 45D757761521711320D-8010
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0718
Revision: --------
Coding: 03840101EA421A0D3B1C9E000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3C21329266EB30DB4F3-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 12031841P10325
Coding: 020408010000040100062354C150A90098000E100020
VCID: 08499E4262B3AC7B1BB-805C
Part No SW: 5Q4 959 595 E HW: 5Q4 959 595 B
Component: TSG HFS 012 0032
Serial number: 0000318880683
Coding: 001C80208001040000001100
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
VCID: 49CF5B4639399573C45-801C
Component: TSG HBFS 012 0032
Serial number: 0000319513268
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End----(Elapsed Time: 02:05, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Address 09: DTCs cleared
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 4B
Revision: B4H25---
Revision: 00H06V07
Coding: 032C0C070F
U1400 00 [008] - -
Coding: 1E4DDD
Coding: 0088DF
534549 - Databus
Coding: 0371167851
Coding: 6414
B2010 00 [009] - -
Coding: 02011203
Coding: 020112
Coding: 93170000
U1111 00 [008] - -
Coding: 1008
Revision: --------
End----(Elapsed Time: 01:59, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
K.
