New user & first scan of a 2009 Touareg TDI. Several modules have no signal.
Spacebarn
Canada
C?ID=404517
Hi everyone!
I'm new to VCDS and just did an auto-scan of my new-to-me 2009 Touareg TDI and it came up with several modules with No Signal/Communication. From what I was told the car had been sitting for awhile with a dead battery and the battery was just changed before I acquired it. I suspect with that many modules not responding that there's a connection/wire/harness that wasn't plugged back or that wires are completely severed somewhere, but again this is my first time using VCDS. Here's the auto-scan the moment I got the cable. I'm not sure if I should have cleared all DTCs or not.. I don't want to do anything I'm not supposed to lol. Many thanks in advance!
Tuesday,02,June,2020,15:17:27:21308
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVGDM67L69D035443   License Plate:
Mileage: 188370km-117047mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 36 37 46 47 55 56 68
          69 6D 6E 76
VIN: WVGDM67L69D035443   Mileage: 188370km-117047miles
1C-Position Sensing -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
68-Wiper Electr. -- Status: OK 0000
69-Trailer -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Cannot be reached 1100
6E-Ctrl Head Roof -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
   Component: 3.0TDI FSA  G004AG  0140
   Revision: 33H01---    Serial number: VWX3Z0H2826371
   Coding: 0421002A590F0968
   Shop #: WSC 64857 003 1048576
   VCID: 3C2131BDAA7E942B4F3-5184
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 HN    HW: 09D 927 750 HN
   Component: AL 750 6A           3403
   Revision: 00H75000    Serial number:
   Coding: 0004984
   VCID: 015F80498D1C39C35C5-5184
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0004354
   Shop #: WSC 31414 790 00001
   VCID: 46D55355E4E2DEFB297-8012
02781 - ASR/ESP Button (E256)
                    Fault Frequency: 9
                    Reset counter: 152
                    Mileage: 188251 km
                    Date: 2019.03.12
                    Time: 01:49:57
                    Count: 12289
                    Count: 156
                    Count: 1
                    Fault Frequency: 22
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.13
                    Time: 00:00:46
                    Count: 128
                    Count: 4353
                    Count: 294
                    Count: 1
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22071    Serial number: VWX3Z0H2826371
   Coding: 0000232
   VCID: 313F10897D6C6943EC5-8064
                    Fault Frequency: 14
                    Reset counter: 112
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 14
                    Reset counter: 112
                    Date: 2064.00.00
                    Time: 00:00:14
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101001
                    Reset counter: 149
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 149
                    Date: 2064.00.00
                    Time: 00:00:14
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AK
   Component: CLIMAtronic R/L     4337
   Coding: 0003030
   VCID: 79AFE8A9E59C6103145-802C
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2004
   Revision: -0004---    Serial number: --------------
   Coding: 230008002F00BC000000000000000000
   VCID: 0059854D864630CB53B-8054
7 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
00908 - Control Module for Wiper Motor
00061 - Footwell Lights
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7I0515179
   Coding: 0000102
   VCID: 33331A8187305B539E9-8066
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:49
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234__3V VW8T       0250
   Revision: 92012025    Serial number: 0039P0075208
   Coding: 0013142
   VCID: 7AADF7A5E09A6A1B1DF-802E
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 G
   Component: J527                3601
   Coding: 0010211
   VCID: 43D34A41D7D0EBD30E9-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 876 B    HW: 7L6 920 876 B
   Component: J285 KOMBI-INST.    9833
   Revision: KHH05V44
   Coding: 0007301
   Shop #: WSC 22526 001 1048576
   VCID: 3B2332A1AF609313469-806E
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:38
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:38
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:39
                    Fault Status: 01101011
                    Reset counter: 154
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:39
                    Fault Frequency: 41
                    Reset counter: 154
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:21:46
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 876 B
   Component: J533  GW-K-CAN TP20 9833
   Coding: 77E2EF9B6B066002
   VCID: 70B9D58DB6A6204BA3B-8024
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:38
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:38
                    Reset counter: 152
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:39
                    Reset counter: 154
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:19:39
                    Fault Frequency: 41
                    Reset counter: 154
                    Mileage: 188214 km
                    Date: 2019.03.04
                    Time: 20:21:46
02786 - Module 2 for Hatch / Trunk Lid (J756)
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.14
                    Time: 00:00:02
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
   Revision: 00001000    Serial number: 1439802T14VG02
   VCID: 46D55355E4A2DEFB297-8012
                    Reset counter: 194
                    Mileage: 188374 km
                    Date: 2019.03.14
                    Time: 14:01:14
                    Reset counter: 194
                    Mileage: 188374 km
                    Date: 2019.03.14
                    Time: 14:01:14
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77ABEE91D3D87773621-5184
Address 37: Navigation
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   Shop #: WSC 06677 004 1048576
   VCID: 40D9454DC696F0CB13B-4B1E
   Subsystem 1 - Component:    TSG FT No Answer
   Subsystem 2 - Component:    TSG BT No Answer
   Subsystem 3 - Component:    TSG HL No Answer
   Subsystem 4 - Component:    TSG HR No Answer
7 Faults Found:
00576 - Terminal 15
01134 - Alarm Horn (H12)
00985 - Right Tail Light (M2)
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No SW: 7L6 035 456 B    HW: 7L6 035 456 B
   Component: 08K Audioverst.     0008
   Revision: 00006000    Serial number: 00000008153333
   VCID: 323D1F85782A525B95F-8066
00421 - Rear Left DSP Midrange Speaker (R105)
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
   Component: AFS-Steuergeraet    0136
   Coding: 1290371
   VCID: 3B2332A1AF209313469-806E
   Coding: 00000019
   Coding: 00000019
Address 56: Radio        Labels: 7L6-035-180-56.lbl
   Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
   Component: Radio DE2           0008
   Revision: 00006000    Serial number: VWZ4Z4J7302509
   Coding: 0001010
   VCID: 2D070CF961140DA3C8D-8078
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 392F28A9A55CA103545-806C
   Component: RLS     050209 054  0402
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer
Address 6D: Trunk Elect.
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
   Component: J702  Dachdisplay   0401
   Revision: 1030006S    Serial number: 00000000108910
   VCID: 79AFE8A9E5DC6103145-802C
                    Reset counter: 194
                    Mileage: 188374 km
                    Date: 2019.03.14
                    Time: 14:01:15
                    Reset counter: 194
                    Mileage: 188374 km
                    Date: 2019.03.14
                    Time: 14:01:16
Address 76: Park Assist        Labels: Redir Fail!
   Part No: 7L0 919 283 F
   Component: 0L Einparkhilfe     1108
   VCID: 392F28A9A51CA103545-806C
End----------(Elapsed Time: 03:02, VBatt start/end: 14.5V/14.5V)-----------
Spacebarn
Canada
C?ID=404517
I cleared DTCs and ran another scan.
Tuesday,02,June,2020,17:30:22:21308
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Mileage: 188370km-117047mi   Repair Order: 530
          69 6D 6E 76
6E-Ctrl Head Roof -- Status: OK 0000
   VCID: 3C2131BDAA7E942B4F3-5185
   Coding: 0004984
   VCID: 015F80498D1C39C35C5-5185
   Revision: 00H53001
   Coding: 0004354
   VCID: 46D55355E4E2DEFB297-8013
                    Fault Frequency: 9
                    Reset counter: 152
                    Mileage: 188251 km
                    Date: 2019.03.12
                    Time: 01:49:57
                    Count: 12289
                    Count: 156
                    Count: 1
                    Fault Frequency: 28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.13
                    Time: 00:00:46
                    Count: 128
                    Count: 4353
                    Count: 294
                    Count: 1
   Coding: 0000232
   VCID: 313F10897D6C6943EC5-8065
                    Fault Frequency: 14
                    Reset counter: 114
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 14
                    Reset counter: 114
                    Date: 2064.00.00
                    Time: 00:00:14
                    Reset counter: 149
                    Date: 2064.00.00
                    Time: 00:00:14
                    Fault Frequency: 0
                    Reset counter: 149
                    Date: 2064.00.00
                    Time: 00:00:14
   Coding: 0003030
   VCID: 79AFE8A9E59C6103145-802D
   VCID: 0059854D864630CB53B-8055
7 Faults Found:
   Coding: 0000102
   VCID: 33331A8187305B539E9-8067
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:37
   Coding: 0013142
   VCID: 7AADF7A5E09A6A1B1DF-802F
   Coding: 0010211
   VCID: 43D34A41D7D0EBD30E9-8017
   Revision: KHH05V44
   Coding: 0007301
   VCID: 3B2332A1AF609313469-806F
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:27
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:27
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:28
   VCID: 70B9D58DB6A6204BA3B-8025
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:27
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:27
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:27
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 03:36:28
   VCID: 46D55355E4A2DEFB297-8013
   VCID: 77ABEE91D3D87773621-5185
   Coding: 0000085
   VCID: 40D9454DC696F0CB13B-4B1F
7 Faults Found:
00576 - Terminal 15
   VCID: 323D1F85782A525B95F-8067
   Coding: 1290371
   VCID: 3B2332A1AF209313469-806F
   Coding: 00000019
   Coding: 00000019
   Coding: 0001010
   VCID: 2D070CF961140DA3C8D-8079
   Coding: 0001397
   VCID: 392F28A9A55CA103545-806D
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer
   VCID: 79AFE8A9E5DC6103145-802D
   VCID: 392F28A9A51CA103545-806D
End----------(Elapsed Time: 03:00, VBatt start/end: 14.6V/14.7V)-----------
Yup, you've got several modules that are off-line:
46-Central Conv.
6D-Trunk Elect.
72-Door, Rear Right
Got wiring diagrams?
See where those modules get their power from. If you find a common point (a fuse or a relay?) that may very well be the source of the problem.
Spacebarn
Canada
C?ID=404517
Thanks for the help! I checked the fuses and they all look fine. I then checked the voltage to the connectors for modules J393, J389, j345 based on the wiring diagrams and they all have 12v.
Potential break in the other wires? Is it safe to check continuity on CAN bus wires between module connectors?
Have you checked continuity between their "ground" pins and the chassis?
Do they share a common earthing point on the chassis?
Spacebarn
Canada
C?ID=404517
I should have mentioned that, I did check the ground pins on the connectors as well and they have continuity. I haven't confirmed if they share the same ground point though.
I'll be checking the resistance on the can bus shortly.
Spacebarn
Canada
C?ID=404517
I just checked resistance on PIN 14 and 6 on the OBD2 connector and get 67 ohms. I guess that means the can bus wires are fine?
That tells us the CAN bus wires between the OBD-II connector and the CAN gateway are OK. It tells us nothing about any of the vehicle's internal CAN buses. ;)
Spacebarn
Canada
C?ID=404517
Oh good to know. I'll look into that then.
Did you check twisted sets to gateway for CAN High/Low and termination resistors for filter and add up values if LIN supported?
Thanks Jack, this is all new to me so I didn't quite understand what you meant. Looks like I can check the CAN Gateway from VCDS and read the MVBs for those modules. I'll give that a shot.
MartinsX
Riga, Latvia
C?ID=268515
Check CAN wires, pay special attention to connection point/splice on the floor near right B pillar. (You have to remove front right seat and some plastic trim parts and lift up floor cover to get free access to that place) ;)
Ja ja........That is very good advice X is too kind!
Spacebarn
Canada
C?ID=404517
I did some continuity tests on the CAN bus wires and I get nothing after the rear right door. Looks like I'll be removing the passenger side interior like you suggested. Thanks for the tip!
Spacebarn
Canada
C?ID=404517
MartinsX was right, the issue was at the bottom of the B-pillar the "weld points" on the can bus wires were corroded. What's the best way to fix this? Solder or crimp? I thought I read somewhere that the wires shouldn't be soldered.
Spacebarn
Canada
C?ID=404517
This are looking much better now.
Thursday,04,June,2020,20:33:27:21308
Mileage: 188370km-117047mi   Repair Order: 4-6-20-8-30
          69 6D 6E 76
   Coding: 0004984
   VCID: 015F80498D1C39C35C5-5161
   Revision: 00H53001
   Coding: 0004354
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 01:07:40
                    Count: 128
                    Count: 4353
                    Count: 294
                    Count: 1
   Coding: 0000232
   Coding: 0003030
   Coding: 0000102
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 00:07:08
   Coding: 0013142
   Coding: 0010211
   Revision: KHH05V44
   Coding: 0007301
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 01:07:28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 01:07:30
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 01:07:28
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 01:07:30
   Coding: 0000085
   Subsystem 1 - Part No: 7L0 959 701 N
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 N
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 C
   Subsystem 4 - Part No: 7L0 959 704 C
   Coding: 1290371
   Coding: 00000019
   Coding: 00000019
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 154
                    Mileage: 188374 km
                    Date: 2019.03.23
                    Time: 01:02:06
                    Voltage: 11.79 V
                        ABS 1
   Coding: 0001010
   Coding: 0001397
   Coding: 00208941
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A008002    Serial number: 00000117332790
   Coding: 0016386
   VCID: 3FDB46B1BB388F336A1-806B
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
   Component: J605  HECKKLAPPE    1310
   Revision: --H05---    Serial number: --------043726
   Coding: 0122110
   VCID: 3A2D37A5A01AAA1B5DF-806F
End----------(Elapsed Time: 02:33, VBatt start/end: 12.1V/12.1V)-----------
It looks like I have the same issue on the driver side. According to the MVBs the rear right door electronics and driver memory module are running on 1 wire.
Regarding the missing navigation module and Radio 01044 - Control Module Incorrectly Coded. I'm suspecting the previous owner had an upgraded headunit with nav, or they downgraded before getting rid of the car. Is that possible? Would it be normal for it to look for the navigation when it's not present in the car? I don't have the owners manual so I can't find the build specs.
