- Joined
- Jan 1, 2019
- Messages
- 25
- Reaction score
- 11
- Location
- Barcelona, Catalonia
- VCDS Serial number
- C?ID=359858
VW Multivan 2008 2,5TDI 4motion
In order to prime the turbo, I need to crank the engine but do not want it to start. I have read that one can set the so called "compression mode" which disables fuel into the engine, while it allows to rotate it with the ignition.
Is this possible with VCDS?
Thanks!
Thanks!
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H133087 Mileage: 241730km-150204miles
Address 01: Engine Labels: 070-906-016-BPC.clb
Part No SW: 070 906 016 DR HW: 070 906 016 DR
Component: R5 2,5L EDC 000SG 1584
Revision: --H06--- Serial number: VWZ7Z0H6297210
Coding: 0001172
Shop #: WSC 36843 001 1048576
VCID: 6393AD448744956FB7B-5184
Address 03: ABS Brakes Labels: 7H0-907-37x-ESP.lbl
Part No SW: 7H0 907 379 R HW: 7H0 907 379 R
Component: ESP MK25E1 0104
Revision: 00H31001
Coding: 0000607
Shop #: WSC 02756 790 00000
VCID: 44D14ED8228AF257AE1-5160
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 7H5 820 045 P
Component: CLIMA/AC 0303
VCID: 372B2914635CA9CF3B3-5160
Address 09: Cent. Elect. Labels:. 7H0-937-049.lbl
Part No: 7H0 937 049 AD
Component: BORDNETZ SGVER 1.0 2101
Coding: 0000103
VCID: 74B1DE1832AA02D7DE1-5160
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 11 AIRBAG VW61 0R 0004
Coding: 12593
Shop #: WSC 02756
VCID: 270BF954B6FC394FAB3-5160
Address 17: Instruments Labels: 7Hx-920-xxx-17.lbl
Part No: 7H0 920 861 E
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 06113
Shop #: WSC 00186
VCID: 2E050C7099066807685-5160
WV2ZZZ7HZ8H133087 VWZ7Z0H6297210
Address 18: Aux. Heat Labels: 7H0-819-008.lbl
Part No: 7H0 819 008 R
Component: Standheizung 0209
VCID: 3B2335245F748DAFDFB-5160
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00022
Shop #: WSC 02756
VCID: 70B9D20843B23EF73A9-5160
Address 22: AWD Labels: None
Part No: 7H0 907 554 F
Component: HALDEX 4Motion 2110
Shop #: WSC 49856 001 1048576
VCID: 33331D04772445EF07B-5160
Address 46: Central Conv. Labels: 7H0-959-433.lbl
Part No: 7H0 959 433 B
Component: C11 Komfortger·t 0004
Coding: 00025
Shop #: WSC 02756
VCID: 323D18008D3E4CE70CD-4B1E
Address 6E: Ctrl Head Roof Labels: 7H5-919-044-W1.clb
Part No SW: 7H5 919 044 J HW: 7H5 919 044 J
Component: J702 Dachdisplay 0500
Revision: 1010007S Serial number: 00000000060769
Coding: 0000003
VCID: 392F2F2C5548BFBFCD7-5160
End----------(Elapsed Time: 06:08, VBatt start/end: 12.3V/12.3V)-----------
