Multivan T5 2.5TDI. How to set "compression mode"?
jsola
Barcelona, Catalonia
C?ID=359858
VW Multivan 2008 2,5TDI 4motion
In order to prime the turbo, I need to crank the engine but do not want it to start. I have read that one can set the so called "compression mode" which disables fuel into the engine, while it allows to rotate it with the ignition.
Is this possible with VCDS?
Thanks!
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H133087   Mileage: 241730km-150204miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 DR    HW: 070 906 016 DR
   Component: R5 2,5L EDC  000SG  1584
   Revision: --H06---    Serial number: VWZ7Z0H6297210
   Coding: 0001172
   Shop #: WSC 36843 001 1048576
   VCID: 6393AD448744956FB7B-5184
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
   Component: ESP MK25E1          0104
   Revision: 00H31001
   Coding: 0000607
   Shop #: WSC 02756 790 00000
   VCID: 44D14ED8228AF257AE1-5160
   Part No: 7H5 820 045 P
   Component: CLIMA/AC            0303
   VCID: 372B2914635CA9CF3B3-5160
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000103
   VCID: 74B1DE1832AA02D7DE1-5160
   Part No: 1C0 909 605 F
   Component: 11 AIRBAG VW61 0R   0004
   Coding: 12593
   Shop #: WSC 02756
   VCID: 270BF954B6FC394FAB3-5160
   Part No: 7H0 920 861 E
   Coding: 06113
   Shop #: WSC 00186
   VCID: 2E050C7099066807685-5160
   WV2ZZZ7HZ8H133087     VWZ7Z0H6297210
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 819 008 R
   Component: Standheizung        0209
   VCID: 3B2335245F748DAFDFB-5160
   Part No: 6N0 909 901
   Coding: 00022
   Shop #: WSC 02756
   VCID: 70B9D20843B23EF73A9-5160
   Part No: 7H0 907 554 F
   Component: HALDEX 4Motion      2110
   Shop #: WSC 49856 001 1048576
   VCID: 33331D04772445EF07B-5160
   Part No: 7H0 959 433 B
   Component: C11 Komfortger·t     0004
   Coding: 00025
   Shop #: WSC 02756
   VCID: 323D18008D3E4CE70CD-4B1E
Address 6E: Ctrl Head Roof        Labels: 7H5-919-044-W1.clb
   Part No SW: 7H5 919 044 J    HW: 7H5 919 044 J
   Component: J702  Dachdisplay   0500
   Revision: 1010007S    Serial number: 00000000060769
   Coding: 0000003
   VCID: 392F2F2C5548BFBFCD7-5160
End----------(Elapsed Time: 06:08, VBatt start/end: 12.3V/12.3V)-----------
Please post at least enough scan data for people to see what ECU this van has; preferably an Auto-Scan.
I do not see any obvious way to do that in this ECU.
jsola
C?ID=359858
Thanks Uwe. Nevermind, I´ll go the classic way and idle the engine for a couple of minutes.
