2020 MAN TGE (VW CRAFTER2), Coding BYTE3 in Control Unit J285 can not be undone
Thor-sten
C?ID=391862
Hello VCDS community,
first I have to thank Uwe for this great tool (VCDS), which gives me so many opportunities with the car.
I love it. Thank you very much for that. :thumbs:
A short introduction to my person. My name is Thorsten and I am an electronic engineer and computer guy from Germany.
Since English is not my native language, I ask to excuse the one or other spelling mistake.
Usually I know exactly what I am doing when I change something in the vehicle coding,
but now I have a serious problem with a coding in a control unit which cannot be undone.
I am addressing all VCDS professionals, hoping that someone might be able to help me with this problem.
Here's the problem:
Coding in byte 3 of the control unit speedometer (Switch panel insert J285) cannot be reversed.
Error 22: Value range or parameter invalid
It is a car that probably isn’t available in the US but the problem could be the same across all the VW vehicles.
It is a MAN TGE (UY-VN54), which is identical to the actual VW Crafter2 (SY) VAN.
In the control unit speedometer (J285), I have already been able to change the coding with a HEX-V2 without any problems. Because I am thinking about mounting bigger wheels and tires, I have tried to adapt the speedometer display to the larger rolling circumference. Therefore I have tried to change the wheel circumference in the control unit of the BYTE3 from the standard version 1 with the HEX-coding 88 to the version 8 with the HEX-coding 8F. So it was changed from the smallest to the largest variant. The control unit accepted this and in the following test drive I also found out that the speedo now goes ahead 16% instead of the original 4%. So at first it worked as I had expected it to. But now I wanted to undo the coding again and send the old coding to the ECU. But the ECU denied me the coding with an error 22: Value range or parameter invalid. Multiple attempts were unsuccessful. It is possible to do other codings at the control unit, only the wheel circumference can no more be coded smaller and the coding is refused.
The control unit therefore in principle still accepts another HEX code, only if a different code is entered in byte 3, then the acceptance is refused.
Actually coded:
07A4118FECAC0008008A6A0F5401000000000000
Should be the old code:
07A41188ECAC0008008A6A0F5401000000000000
A theory of mine would be that the control unit allows the change to a larger wheel circumference but not to a smaller circumference and once the largest circumference was programmed there is no turning back. Can this be? Possibly it is a bug in the control unit’s firmware or it is programmed on purpose by VW or whatever.
And if so, what possibilities do I have now?
Do we have a possibility to get the wheel circumference coded back to the original value?
Thank you very much for your feedback.
Best regards
Thorsten
Attached you can find the Auto-Scan from the vehicle:
Montag,28,Mai,2020,14:23:14:60922
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 7 x64
VCDS Version: DRV 19.6.2.1  HEX-V2 CB: 0.4508.4
Datenstand: 20191020 DS308.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WMA04VUY5L90XXXXX   KFZ-Kennzeichen:
Kilometerstand: 1717km   Reparaturauftrag:
Fahrzeugtyp: UY-VN54 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 18 19 22 3C 3D 42 44 52 5F 65 A5
          BB BC 810B
Fahrzeug-Ident.-Nr.: WMA04VUY5L90XXXXX   Kilometerstand: 1717km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
22-Allrad -- Status: Fehler 0010
3C-Spurwechsel -- Status: i.O. 0000
3D-Sonderfunktionen -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
65-Reifendruck -- Status: i.O. 0000
A5-Front-/Vorfeldkamera -- Status: i.O. 0000
BB-Türelektronik hinten links -- Status: nicht erreichbar 0100
BC-Türelektronik hinten rechts -- Status: nicht erreichbar 0100
810B-Stand-/Zuheizer 2 -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-DAVA)       Labeldatei: Keine
   Teilenummer SW: 04L 906 056 SJ    HW: 04L 907 445 P
   Bauteil: R4 2.0l BTD   H01 9797
   Revision: 23203001
   Codierung: 002A403C6366050800000000000000000000000000000000
   Betriebsnr.: WSC 00000 000 00014
   ASAM Datensatz: EV_ECM20BTD03004L906056SJ 006003
   ROD: EV_ECM20BTD03004L906056SH.rod
   VCID: 074A601E6FA3EB9F88D-8052
Readiness: Nicht Verfügbar
Adresse 02: Getriebe (J217)       Labeldatei: 09G-927-749-V2.clb
   Teilenummer SW: 09G 927 158 EH    HW: 09G 927 168
   Bauteil: AISIN AQ8     206 3619
   Codierung: 0000000100000000010000000000000000000000
   ASAM Datensatz: EV_TCMAQ450031 001001
   ROD: EV_TCMAQ450031_VN54.rod
   VCID: 7DA602F64D7FB14FA21-8028
Adresse 03: Bremsenelektronik (J104)       Labeldatei: Keine
   Teilenummer SW: 2N0 907 379 D    HW: 2N0 907 379 C
   Bauteil: ESC_base      H02 0860
   Seriennummer: 08504730200228
   Codierung: 25AA6477483EB683A44B2664124C6D463CF721BA
   ASAM Datensatz: EV_Brake1ESP90iBOSCHVN54X 701030
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 372AD0DE5FC35C1F48D-8062
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:* Keine
   Teilenummer SW: 7C0 907 044 AJ    HW: 7C0 907 044 AJ
   Bauteil: Climatronic   H01 0401
   Codierung: A07010000804100001100820500101000000000000001400200000000000
   Betriebsnr.: WSC 00000 000 00011
   ASAM Datensatz: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_VN46.rod
   VCID: 6D8632B66D1F22CF121-8038
   Steuergerät für Luftzusatzheizung/PTC:
   Bedienungs- und Anzeigeeinheit 1 für Klimaanlage:
   Subsystem 2 - Teilenummer SW: 7C0 907 049 L    HW: 7C0 907 049 L
   Bauteil: E857  H02 0202
   Seriennummer: 00003069524800220103
Adresse 09: Zentralelektrik (J519)       Labeldatei: Keine
   Teilenummer SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
   Bauteil: BCM MQBAB M+  H42 0312
   Seriennummer: 02002005603018
   Codierung: 000000000000000000000000000000000000000000000000000000000000
   ASAM Datensatz: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_AU27.rod
   VCID: 00587B024A9DDCA8C96-8054
   Sensor für Regen- und Lichterkennung:
   Subsystem 1 - Teilenummer SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labeldatei: DRV\5Q0-955-547.CLB
   Bauteil: RLHS  052  0107
   Seriennummer: S6Y20M02D24H03M46S25
   Codierung: 0038DD
   Lenkstockschalter:
   Subsystem 2 - Teilenummer SW: 5Q1 953 521 CR    HW: 5Q1 953 569 B
   Bauteil: Lenks.Modul  H23  0170
   Seriennummer: 0100101220190C400134
Adresse 10: Einparkhilfe 2 (J791)       Labeldatei:* Keine
   Teilenummer SW: 2N0 919 300 C    HW: 2N0 919 300
   Bauteil: aFLS 16KH06 0205
   Seriennummer: 000310350620038
   Codierung: 047116D871
   ASAM Datensatz: EV_EPHVA2FVN54X0000 009035
   ROD: EV_EPHVA2FVN54X0000.rod
   VCID: 290E06A69877FDEFCE8-807C
Adresse 13: Distanzregelung (J428)       Labeldatei:| 2Q0-907-572.clb
   Teilenummer SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Bauteil: ACCCONTIMQB   H03 0372
   Codierung: 3200404240EF8448949C814D20308500000000000000000004
   ASAM Datensatz: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_AU27.rod
   VCID: 43D2B40E1B1B08BF945-8016
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5Q0-959-655.clb
   Teilenummer SW: 3Q0 959 655 CR    HW: 3Q0 959 655 CR
   Bauteil: Airbag VW21   006 0720
   Revision: --------    Seriennummer: 003Z6P2M27Y9
   Codierung: 88CCC00000000000400000CF000800000065
   ASAM Datensatz: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 10784B421BEDAC27597-8044
   Crashsensor für Seitenairbag Fahrerseite:
   Subsystem 1 - Teilenummer SW: -----------    HW: 454 002 301 20
   Bauteil: SideSensor_Df  008 0887
   Seriennummer: 35700000000D2481A46I
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag Beifahrerseite:
   Subsystem 2 - Teilenummer SW: -----------    HW: 454 002 201 20
   Bauteil: SideSensor_Pf  008 0887
   Seriennummer: 35800000000F5561A46N
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Subsystem 3 - Teilenummer SW: -----------    HW: 454 800 102 20
   Bauteil: SideSensor_Dr  305 0109
   Seriennummer: 35100D506E51A000000I
   Codierung: 2D2D2D
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Subsystem 4 - Teilenummer SW: -----------    HW: 454 800 102 20
   Bauteil: SideSensor_Pr  305 0109
   Seriennummer: 35200A12EE51A000000M
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Fahrerseite:
   Subsystem 5 - Teilenummer SW: -----------    HW: 454 801 901 20
   Bauteil: FrontSensor_D  305 0109
   Seriennummer: 35500DC54CA1A000000Z
   Codierung: 2D2D2D
   Crashsensor für Frontairbag Beifahrerseite:
   Subsystem 6 - Teilenummer SW: -----------    HW: 454 801 901 20
   Bauteil: FrontSensor_P  305 0109
   Seriennummer: 356008D46CA1A000000X
   Codierung: 2D2D2D
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:* Keine-SRI3
   Teilenummer SW: 7C0 920 741 C    HW: 7C0 920 741 C
   Bauteil: KOMBI         204 6700
   Codierung: 07A4118FECAC0008008A6A0F5401000000000000
   Betriebsnr.: WSC 12345 123 00011
   ASAM Datensatz: EV_DashBoardVDDMQBAB 009069
   ROD: EV_DashBoardVDDMQBAB_VN54.rod
   VCID: 24101792FE5520878DE-8070
Adresse 18: Standheizung (J364)       Labeldatei:* Keine
   Teilenummer SW: 7C0 963 272 B    HW: 7C0 963 272 B
   Bauteil: STH-VN54x     008 0079
   Codierung: 590101
   Betriebsnr.: WSC 12345 123 00030
   ASAM Datensatz: EV_AuxilHeateWOSVN54X 001003
   ROD: EV_AuxilHeateWOSVN54X.rod
   VCID: 290E06A69978FDEFBC8-807C
   Funkfernbedienung Standheizung:
   Subsystem 1 - Teilenummer SW: 3Q0 963 513     HW: 3Q0 963 513
   Bauteil: R64 D208L  004 0402
   Seriennummer: 00000000000000980599
Adresse 19: Diagnoseinterface (J533)       Labeldatei:| DRV\3Q0-907-530-V1.clb
   Teilenummer SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Bauteil: GW MQB High   442 4388
   Revision: --------    Seriennummer: 0000687679
   Codierung: 030100344F05730000000000000F00010001070000000000000000000000
   ASAM Datensatz: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70B82BC27A2DCD27397-8024
   Generator:
   Bauteil: 4-00-11-01-04
   Steuergerät für Multifunktionslenkrad:
   Subsystem 2 - Teilenummer SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labeldatei: DRV\3C8-959-537.CLB
   Bauteil: E221__MFL-MD9  H18 0052
   Seriennummer: 39200000331530090073
   Codierung: 2EFFFF
   Steuergerät für Batterieüberwachung:
   Subsystem 3 - Teilenummer SW: 2N0 915 181 A    HW: 2N0 915 181 A
   Bauteil: J367-BDMConti  H03 1051
   Seriennummer: 758851020019101606B5
Adresse 22: Allrad (J492)       Labeldatei:* DRV\0CQ-907-554.clb
   Teilenummer SW: 0CQ 907 554 N    HW: 0CQ 525 130 B
   Bauteil: Haldex4Motion H60 7322
   Seriennummer: HA1-00025.02.18
   Codierung: 0001
   ASAM Datensatz: EV_AllWheelContrHA1VW37X 004014
   VCID: 50F88B42DA6EEC27197-8004
Adresse 3C: Spurwechsel (J1086)       Labeldatei:| DRV\5Q0-907-686.clb
   Teilenummer SW: 5Q0 907 686 C    HW: 5Q0 907 686 C
   Bauteil: HRE_Master    H12 0081
   Seriennummer: 0538167065
   Codierung: 02011103
   ASAM Datensatz: EV_HREntryHella 001028
   ROD: EV_HREntryHella_SE27.rod
   VCID: 3D26C2F67DFE714FE30-8068
   Steuergerät 2 für Spurwechselassistent:
   Subsystem 1 - Teilenummer SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Bauteil: HRE_Slave  H12 0081
   Seriennummer: 0538033412
   Codierung: 020111
Adresse 3D: Sonderfunktionen (J608)       Labeldatei:* Keine
   Teilenummer SW: 2N0 907 427 Q    HW: 2N0 907 427 J
   Bauteil: KFG       H24 0306
   Seriennummer: GM24201748339
   Codierung: 00002000000000200200000820F0000000000000
   ASAM Datensatz: EV_SpeciFunctFlextVN54X 007029
   ROD: EV_SpeciFunctFlextVN54X.rod
   VCID: 3E24C5FA70F86A57FCA-806A
   Subsystem 6 - Teilenummer SW: 2N0 915 181 B    HW: 2N0 915 181 B
   Seriennummer: 75885002002001310127
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:* Umleit. fehlgeschl.!
   Teilenummer SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Bauteil: TSG FS        007 0485
   Seriennummer: 0000406468605
   Codierung: 00300B20D000020100001000
   ASAM Datensatz: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 4DC69236CD6FC1CF820-8018
Adresse 44: Lenkhilfe (J500)       Labeldatei:* Keine
   Teilenummer SW: 2N0 909 144 J    HW: 2N0 909 144 E
   Bauteil: EPS_MQB_ZFLS  732 7031
   Codierung: 1107
   ASAM Datensatz: EV_SteerAssisMNB 002009
   ROD: EV_SteerAssisMNB_VN54.rod
   VCID: 3536DAD644CFA90F3A0-8060
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:* Umleit. fehlgeschl.!
   Teilenummer SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Bauteil: TSG BFS       007 0485
   Seriennummer: 0000406103327
   ASAM Datensatz: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4CC09F324645C8C766E-8018
Adresse 5F: Informationselek. I (J794)       Labeldatei:| 5G0-035-MIB-STD2.clb
   Teilenummer SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Bauteil: MU-S-ND-ER    853 0876
   Seriennummer:
   Codierung: 084500013C00000051110101008808001F060BD401200500C7
   ASAM Datensatz: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VN54.rod
   VCID: 323CE1CAC4A1BE370E2-8066
   Anzeige- und Bedienungseinheit 1 für Informationselektronik:
   Subsystem 1 - Teilenummer SW: 5G0 919 606     HW: 5G0 919 606
   Bauteil: ABT_High  H64 0032
   Seriennummer: VWZ7Z9W3P015YL
   Datenträger:
   Subsystem 2 - Teilenummer SW: 7CE 919 866 AK    HW: -----------
   Bauteil: ECE3 2020  --- 1310
   Seriennummer: --------------------
Adresse 65: Reifendruck (J502)       Labeldatei: 3AA-907-273.clb
   Teilenummer SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Bauteil: RDKBERU30     H05 0010
   Seriennummer: 40000000384924
   ASAM Datensatz: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_VW41.rod
   VCID: 3634DDDA56C9A21733A-8062
Adresse A5: Front-/Vorfeldkamera (R242)       Labeldatei:| DRV\3Q0-980-65X-A5.clb
   Teilenummer SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Bauteil: MQB_B_MFK     H13 0610
   Seriennummer: 20022015P20316
   Codierung: 0105040300000401002213548140450092000E23002000
   Betriebsnr.: WSC 12345 123 00014
   ASAM Datensatz: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_VW12.rod
   VCID: 40D8BB021A0D1CA7596-8014
Adresse BB: Türelektronik hinten links
nicht erreichbar
Adresse BC: Türelektronik hinten rechts
nicht erreichbar
Adresse 810B: Stand-/Zuheizer 2 (J604)       Labeldatei:* Keine
   Teilenummer SW: 7C0 963 273 B    HW: 7C0 963 273 B
   Bauteil: LSH_DIESEL    006 0026
   Codierung: 6E00
   Betriebsnr.: WSC 00000 000 00030
   ASAM Datensatz: EV_LSHECCSMNB 002018
   ROD: EV_LSHECCSMNB_002.rod
   VCID: 2A0CF9AA9C71D6F7C72-807E
Ende--------(Dauer: 01:39, Batt.-Spannung Start/Ende: 12.4V/12.4V)---------
Rollux
New Zealand
C?ID=380572
I seem to recollect somewhere that changing the wheel variant was a one time deal - it was recommended to adjust the speedometer via the % correction factor. This from a discussion where people were fitting large wheels to Q7s and the like. However there are limits as to the % you can adjust by - but the theme was if at all possible leave it alone in wheel variant. I’ll try and find the forum and post (not here on RT) and update
As an extra thought, is there a wheel size also in the ABS module? I would expect they will need to match
Thor-sten
C?ID=391862
Thanks a lot for your reply. Oh, dear. That's exactly what I thought, but didn't want it to be.
Would be great if you can find the discussion.
But I still hope that this can be fixed.
Otherwise it would be a complete new control unit which costs over 1000€$
I haven’t looked or done anything in the ABS Module. This was too hot for me to change anything in this controller.
But I can have a look, if I can find anything about the wheel size in there.
It's quite unusual for a coding change to be irreversible, but of course it's possible to implement such a "feature" in the control module's firmware. Historically, stuff like that has been limited to a few Adaptation channels, for example a speed-limiter channel.
Unfortunately, I do not have any further info regarding this instrument cluster.
Rollux
New Zealand
C?ID=380572
Sorry I cannot find the posting I was referring to.
As an interim, can you use the % calibration feature to ‘undo’ the issue?
Thor-sten
C?ID=391862
Too bad, I would have been very interested in that posting. But it's good to know that the problem didn't only occur to me.
I would have tried the % correction before, if it was available. But I could not find a setting for it anywhere.
I can only adjust the average consumption and range in % but I can't find anything for the speed display.
Where should I find this and what is it called exactly?
General question how to proceed now:
So if I can't solve the problem by myself, is there any chance that anyone can reset the controller to factory defaults?
(Except the firmware programmer from VW who will certainly not help me with this)
I mean, technically it should be possible to reset the controller to the factory settings.
Or is it unnecessary to search for it and I have to sadly replace the complete Combi-instrument (speedo display unit)?
NEtech
C?ID=56995
I have experienced several circumference coding could be changed once and then not anymore.
Especially older cars, new instrument installed and after one coding, you better have made the circumference coding digit correct!
Have you tested any of the Secure Access numbers (maybe use English VCDS) ?
I have doubt this can help, but just for testing, can you change [Adaptation-10], search: IDE00845
For example change Maximum wheel circumference to a bigger number.
Thor-sten
C?ID=391862
I have just installed the newest english Version 20.4.11 of VCDS.
I have tried to test the Secure Access numbers but I don’t have the 5-digit code for it.
Then I tried the 7-digit PIN/SKC. I think this is probably the code that I got with my keys on a key-tag? (right or wrong?) But this code also didn’t work.
In the [Adaptation-10] there is no option to change the IDE00845
I can only display it via the Adv.Meas. Values:
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2490, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2580, mm
The following List are the only available IDE’s in the [Adaptation-10]
IDE00001-Production mode-,No ,3
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,1929 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,German ,1
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,18 H,1
IDE00501-Minute,40 min,1
IDE00502-Year,2020 yr,2
IDE00503-Month,6 mon,1
IDE00504-Day,2 d,1
IDE00510-ESI: distance driven from inspection,1929 km,3
IDE00511-ESI: time from inspection,82 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,50000 km,2
IDE00514-ESI: maximum value of time between inspections,730 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,3300 km,2
IDE00518-ESI: thermal load,1200 km,2
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,81 d,2
IDE00827-ESI: minimum value of time between inspections,365 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 d,2
IDE02332-Deactivate production mode,Deactivating ,3
IDE02489-Display depiction,Version 1 ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,8.7 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS02957-Units adjusted-Time,24h ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
IDE03348-MAS01456-Speed warning-Speed,200 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-Speed warning-,not active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,50000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,1900 km,2
IDE03352-FIX: Time since last time-dependent inspection,82 d,2
IDE03372-Source for synchronization of time,GPS ,1
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE03867-Deactivate seat belt warning,Yes ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE06588-Ignition active message: actuator,No display ,1
IDE06922-No-voltage display,Unknown (2),1
IDE07221-Cylinder shut-off,Display ,1
IDE11086-Service notification,30 d,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE14184-Active participant personalization,Yes ,1
IDE14220-Vehicle speed warning for India-,No ,1
IDE14220-Vehicle speed warning for India-,60 s,1
IDE14986-ACC illustration China,No display ,1
IDE15113-Shift exit warning,No ,1
MAS03685-Digital speedometer,Display ,1
ENG253348-3D_speed,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,02 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,02 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,10 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1D ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0E ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 41 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0E ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG119833-Display_Save_CP,Yes ,1
ENG119874-Gas_functionality,not active ,1
ENG251650-GPS_speed,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG119876-Service_Key_Clear_All_Counter,Yes ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
NEtech
C?ID=56995
No 7-digit is not used anymore.
Is there not an yellow Pop-up showed with 3 different Security Access showed, after a little while ?
I guess the Variant 8, changed it to 2490 / 2580 mm
All Crafter/MAN logs I have, show 2190 / 2278 mm
Have you tested to change to for example Variant 07 first ?
Thor-sten
C?ID=391862
No in this controller unit, there shows up no Pop-Up with the Security Access code.
Yes I know the Variant 8 changed it to this huge circumference.
I had it changed only once from Variant 1 to Variant 8.
I just wanted to quickly test it and see the biggest difference.
If I would have changed it first to Variant 4 or 5 then it would be no deal,
because this would correspond to the tyres I would like to mount.
But the Variant 8 is much too huge for the vehicle.
And now I have had tested every possible combination, but nothing is accepted anymore.
Won’t be accepted:
07A41188ECAC0008008A6A0F5401000000000000 (Variant 1)
07A41189ECAC0008008A6A0F5401000000000000 (Variant 2)
07A4118AECAC0008008A6A0F5401000000000000 (Variant 3)
07A4118BECAC0008008A6A0F5401000000000000 (Variant 4)
07A4118CECAC0008008A6A0F5401000000000000 (Variant 5)
07A4118DECAC0008008A6A0F5401000000000000 (Variant 6)
07A4118EECAC0008008A6A0F5401000000000000 (Variant 7)
The Following are the Variants with manual shifter
They are also not accepted:
07A41180ECAC0008008A6A0F5401000000000000 (Variant 1)
07A41181ECAC0008008A6A0F5401000000000000 (Variant 2)
07A41182ECAC0008008A6A0F5401000000000000 (Variant 3)
07A41183ECAC0008008A6A0F5401000000000000 (Variant 4)
07A41184ECAC0008008A6A0F5401000000000000 (Variant 5)
07A41185ECAC0008008A6A0F5401000000000000 (Variant 6)
07A41186ECAC0008008A6A0F5401000000000000 (Variant 7)
But it accepts the
07A41187ECAC0008008A6A0F5401000000000000
This is the Variant 8 with manual transmission.
So in principle, the Byte can be changed, but it did no longer accept a code that changes the variant 8 to a smaller variant.
Rollux
New Zealand
C?ID=380572
Would a factory/dealer software update/restore and reconfigure via VIN work I wonder? Cheaper than a new cluster
DV52
C?ID=194404
Thor-stern: Hi. I'm not sure how MQB -ish the MAN GTE is, but I'm emboldened by the "3Q0" response in your auto-scan to suggest the following:
Apropo of NEtech's suggestion regarding SA for the hex17 module - there are a bunch of these for MQB platform vehicles HERE. For post MY16 models, the generally accepted SA for J285 is 47115 - but if this doesn't work, try 25327 (I'm less sure about this SA).
Again, these are MQB platform SA s
Thor-sten
C?ID=391862
This is also my question. Is this possible? This would be great.
Because I already talked to the MAN dealer.
But they seem to have no idea.
The technicians at my local dealer looked at me with huge eyes (like I'm from another planet and speaking martian) as I told them what my problem is.
They have no technical understanding when it goes deeper in electronic and coding.
One played for over 2 hours, with their own software, on the CAN-BUS. It seemed that he doesn’t know what he’s doing.
More than checking the fault codes is normally not their job. So the result was nothing.
Then they talked with the MAN support and tried something out. But again with no positive result.
So the MAN support was at his end and the MAN support approached the VW support.
Over one week later I got the short reply that such changes are not planned and are not carried out by VW.
They only told me to buy a complete new combi-instrument for round about 1000€$
First class customer support ;-)
So I am sure that it is technically possible, but such changes are simply not desired by VW.
But I don’t know who is capable of doing a factory reset to this controller.
@Don: Thank you very much for the list with security codes. :thumbs: The 47115 was correct and accepted.
They are surely quiet useful for the future.
But sadly, even with the SA, the change of the wheel circumference variant coding is still denied. :cry:
DV52
C?ID=194404
Thor-sten: Changing Byte3, Bit 0-2 on the hex17 module to "adjust" speedometer is a mature tweak on MQB platform cars - so lots of folks have used it multiple times to experiment with the various options. But then I've not known of its application to an MY20 MAN GTE.
1000€$ to buy a new module seems a bit steep - even by VW's exorbitant standards. If the Crafter is like other MQB platform vehicles, retrofitting a new J285 will trigger Component Protection DTCs which will necessitate another visit to your friendly dealer (and it will mean a further drain on your funds)! Of course, you could always find someone to hack the CP errors, but this can be problematic depending on how it's done.
As a very long-shot based on nothing more than a hunch, I wonder if pulling the battery lead for a brief period of time is worth trying? @jyoung8607 has suggested this in the past (see here) as a possible fix for strange VCDS problems on MQB vehicles and it has worked.
It's an easy try, so give it a shot - and it costs nothing (the DTCs generated after the battery lead is replaced should clear after a brief drive)
NEtech
C?ID=56995
You can test label file, copy this file to c:\Ross-Tech\VCDS\Labels\User
Thor-sten
C?ID=391862
I would like to thank again everyone who’s trying to help me with this problem.
I realy realy appreciate your help.
I have disconnected the battery for an hour
Reconnected it and tried the coding again.
But as always I get the Error22: Conditions not correct or request sequence error.
I also have tested the label file. But I’ve seen no difference. What should it change?
D
Deleted member 37631
Guest
Hallo Thorsten, ich bin auf deinen Beitrag gestoßen, da ich aktuell vor dem selben Problem stehe, konntest du es mittlerweile lösen?
Thor-sten
C?ID=391862
Hello Xaver.
Sorry, I have tried so many things, but I could not solve the problem so far.
I guess that this is so wanted on the side of VW, that this setting can only be made once and then is permanently locked.
I'm still driving around with a very early speedometer and have resigned myself to it in the meantime.
If you find a solution, please give me feedback.
Seriously, please remember and give me a feedback if you find a way.
Many greetings
Thorsten
Hallo Xaver,
sorry ich habe so vieles ausprobiert, aber ich konnte das Problem bislang noch nicht lösen. Ich vermute, dass dies seitens VW so gewünscht ist, dass diese Einstellung nur einmalig vorgenommen werden kann und dann dauerhaft gesperrt wird.
Ich fahre halt immer noch mit einem stark voreilenden Tacho durch die Gegend und habe mich mittlerweile irgendwie damit abgefunden.
Falls du eine Lösung finden solltest, gib mir bitte eine Rückmeldung.
Ernsthaft, bitte denk dran und gib mir eine Rückinfo falls du eine Möglichkeit finden solltest.
Viele Grüße
Thorsten
audiobull
C?ID=184184
I am unable to see my abs coding BUT I have seen the circumferance referance somewhere where I thought was a strange place to have it. I think it was possibly in the Steer assist.
44: Steering Assist (J500)
D
Guest
Hallo Thorsten,
Ich hatte bei meinem die Nachtankmenge, Gurtwarner und Warnung bei Zündung und offener Türe codiert. Die Rkz von hab ich zwei mal verändert, konnte sie aber nicht mehr auf den original Wert einstellen.
Meiner war die Tage bei VW und die haben versucht die Werkscodierung auf das Kombi Instrument aufzuspielen, dabei wurde aber lediglich der Gurtwarner rückgängig gemacht. Weißt nicht ob die nur den Gurtwarner codiert haben oder alles.
Mein Händler fragt jetzt bei VW an, da muss es ja eine Lösung geben, kann ich irgendwie nicht akzeptieren, dass man etwas ändert und niemand kann das rückgängig machen.
Bin auch bereit hier ein neues Kombi zu kaufen, denn durch die Änderung habe ich Probleme mit meinem ACC bzw. Notbremsfunktion. Hast du Infos ob es durch den Austausch vom KI behoben werden kann?
Gibt bis dato nur wenige Fälle, aber soweit ich das mitbekommen habe sind wir nicht die einzigen, nur eine Lösung hat noch keiner.
Ich halte dich auf dem laufenden!
Gruß
