MY16 Golf R - fuel gauge issues
dontuan
C?ID=232367
Hello all,
Was hoping someone could shed some light on this before I pull what's left of my hair out :banghead:
I recently upgraded the LPFP in my car and tried running an "Adaptation of Fuel Pump (FP)" (not sure if related), but afterwards I noticed my fuel gauge showing empty and 0 range left when I know for a fact there's at least 1/4 tank left. I swapped the stock pump/basket back over and it's still showing empty now, so I put the new pump/basket back in and went out to fill up. On my way to the gas station I get "Error: Fuel tank system! Service Vehicle." After filling up the tank my gauge moved to 1/2 :facepalm:
Below is the scan:
Monday,18,May,2020,17:25:26:58744
VCDS Version: 20.4.1.0 (x64)
VIN: WVWLF7AU0GW146427   License Plate: MK7 R_STG 3 FUEL
Mileage: 78553km-48810mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
VIN: WVWLF7AU0GW146427   Mileage: 78553km-48810miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 UME1
   Revision: --H13---
   Coding: 091D00122426000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 45816251C4449EAE78-8010
23086 - Fuel Level Sensor Circuit
          P0463 00 [039] - Signal too High
                    Mileage: 78553 km
                    Date: 2020.05.18
                    Time: 17:13:23
                    Coolant temperature: 80 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 12.324 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 97 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 7800.0 kPa
22063 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [039] - -
                    Mileage: 78553 km
                    Date: 2020.05.18
                    Time: 17:13:13
                    Voltage terminal 30: 12.363 V
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 82.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 10 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Status: OK
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Coding: plausible
                    Cruise control switch actuation-Limit function: not selected
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    Cruise control switch actuation-Control component verified: Yes
                    ECU_STATE: ENG_STOP
22092 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [039] - -
                    Mileage: 78553 km
                    Date: 2020.05.18
                    Time: 17:13:13
                    Voltage terminal 30: 12.343 V
                    ECU_STATE: ENG_STOP
                    T_ES: 10 min
                    ECU_STATE: ENG_STOP
Readiness: 1110 0101
   Part No SW: 0D9 300 014 Q    HW: 02E 927 770 AQ
   Component: DQ250-UM 661s H53 4523
   Revision: 06253104    Serial number: TFK01509211628
   ROD: EV_TCMDQ250021.rod
   VCID: 2643C5DD590275B651-8072
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 62665000003949
   Coding: 01FA6BA154240972057B030241CA6980D62A90A0C08296B700400058C208
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 79F9DEA1F83C2A4E4C-802C
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Fault Frequency: 12
                    Reset counter: 199
                    Mileage: 78544 km
                    Date: 2020.05.09
                    Time: 00:27:58
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 246
                    Mileage: 67961 km
                    Date: 2019.04.14
                    Time: 16:43:32
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 198
                    Mileage: 78544 km
                    Date: 2020.05.09
                    Time: 00:28:08
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 198
                    Mileage: 78544 km
                    Date: 2020.05.09
                    Time: 00:28:08
   Revision: 00021000    Serial number: 0380555746
   Coding: 030C0C
   VCID: 3A7B01ADBDBAE15605-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00020004200100000005000012111402
   VCID: 6ADBF1ED8D9A91D6B5-803E
   Air quality sensor:
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061526800809
   Coding: 00011A46C041A2F169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0109B64190EC728E04-8054
   Component: WWS    150913  043 0551
   Serial number:         150923103511
   Component: RLHS  037 0059
   Serial number: S5Y15M10D12H15M18S22
   Coding: 06A8DD
   Serial number: 003GCR03K2SP
   VCID: 479D6859FE488CBE8A-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003B8KWY
   Coding: 303058
   Subsystem 2 - Part No SW: -----------    HW: 480 002 809 15
   Serial number: 3570000000006AC0B61I
   Subsystem 3 - Part No SW: -----------    HW: 480 002 809 15
   Serial number: 3580000000096690B61L
   Subsystem 4 - Part No SW: -----------    HW: 480 403 009 15
   Serial number: 3510002A71CCEA01C048
   Subsystem 5 - Part No SW: -----------    HW: 480 403 009 15
   Serial number: 3520002B91CF2DA5D30K
   Subsystem 6 - Part No SW: -----------    HW: 480 403 009 15
   Serial number: 35500029D1CF2D70E20H
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 403 009 15
   Serial number: 3560002B11CF2D7561DH
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 01101504220458
   Coding: 0410
   ROD: EV_SMLSKLOMQB_009_VW37.rod
   VCID: 071DA859BEC84CBE4A-8052
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
   Component: KOMBI         303 6420
   Coding: 0BAD081A2B80CF0502086A001400000000000000
   VCID: 2E533DFD71F23DF6A9-807A
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Reset counter: 157
                    Mileage: 78544 km
                    Date: 2020.05.07
                    Time: 16:10:30
9459739 - Fuel Level Sensor 2
          B1058 1B [008] - Resistance Too High
                    Reset counter: 197
                    Mileage: 78544 km
                    Date: 2020.05.07
                    Time: 16:10:30
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1223
   Revision: --------    Serial number: 0004017700
   Coding: 0101000830085900FB00022A1C0F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75E1D291D4244E2E28-8020
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 29150001859120085386
   Coding: 31FFFF
   Component: Haldex4Motion H52 UM01
   Serial number: HA1-00027.07.15
   Coding: 0001
   VCID: 4A9B516DED5A71D695-801E
   Revision: 00000000    Serial number: 15000217469009
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34672F959FDE1726DF-8060
   Serial number: 220915BIL04347
   Coding: 001F1320D000040000000000
   VCID: 43857C49CA70A09E56-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007484243
   Coding: 111000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   VCID: 39791EA1B8BCEA4E0C-806C
   Serial number: 250915BIO17929
   Coding: 001F1320DE00040000800000
   VCID: 428B794DD56AA9965D-8016
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007592489
   Coding: 091000
65588 - Motor for Window Regulator
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 177
                    Mileage: 77982 km
                    Date: 2020.04.19
                    Time: 12:32:29
   Coding: 022A01010B000400
   VCID: 408F7345DB66BB864B-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     H25 0245
   Serial number: VWZAZ2R0459001
   Coding: 02730000FF00000051220001001808001F0207D40120010002
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6CD7F7F5876E8FE6C7-8038
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H50 8130
   Serial number: VWZ6ZJT1845672
          B201A 00 [009] - -
                    Reset counter: 177
                    Mileage: 64691 km
                    Date: 2019.03.20
                    Time: 18:29:07
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name: D
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 150909200614
   VCID: 2F6D20F976F834FEA2-807A
End-------------------------(Elapsed Time: 04:36)--------------------------
HMC
C?ID=28246
Hi dontuan,
I take it the DTC's about fuel sensors in 17 Instruments do not clear? Have you checked the connector for bent pins or damaged wiring, does the connector fit properly?
Regards HMC
dontuan
C?ID=232367
Hi dontuan,
Regards HMC
At first they would not clear when the needle was below empty, but after I filled up all the way the needle moved to 1/2 tank I was then able to clear it.
Perhaps there are some clues in the IDE03473 series of measuring values for the fuel tank sensors.
Does the Golf R have 2 fuel level sensors?
dontuan
C?ID=232367
That’s what I was hoping it was, but don’t know where to start with that.
Yes, but the only one I touched was the main pump in the passenger side.
Dana
Western PA, USA
dontuan
C?ID=232367
Advanced Measuring Values are explained here:
https://www.ross-tech.com/vcds/tour/adv-meas-blocks.php
Although we'd want to see data from this car you might find my 17-Instruments control module map from a dual level sender wagon helpful. There's an entire chunk of IDE03473 Adv measuring value groups with sensor 1 and 2 data and the tank was nearly full.
If you purchased VCDS new (rather than used) I believe you fall into #2 here.
Dana - appreciate the assistance and yes, I did purchase my cable new and fall into the #2 category. I will start there by registering it and will report back.
DV52
C?ID=194404
don: Hi. I don't have details for your specific NAR model vehicle in my database but based on cobbling together information from other Golf mk7s, perhaps you might consider this:
The 3 x wires shown as "1" in the upper part of the picture are the fuel gauge sender wires for a transducer in the WD on the lower part of the picture. Now clearly, the WD in my picture is not the same as your car because the arrangement above shows a single integrated unit for both fuel gauge senders - but keep an open mind for a while longer, please!
Again, I could be trying to join dots that don't exist - but if you needed to re-connect the 3 x wires shown in the top part of the picture as part of the pump replacement exercise - maybe there was an error in positioning the colours (no offence intended in suggesting this - I'm just hypothesizing)? If this happened, the measurement parameters for KX2 in the lower part of the picture would be incorrect - potentially producing the type of measurement errors that you have observed - perhaps?
If you consider my musings to be worthy of further investigation - I suggest that you grab a copy of the actual WD for your model vehicle and confirm the wire colour/pin positions on the housing connector
Masterivanpr
New Member
Florida, USA
Hate to bump an old thread but I’m having an identical issue but for fuel leve sender 2 high resistance. I know I got my in tank wiring wrong and the only way for me to figure this out is based on resistance values on the 3 wire connector going from the driver side sender.
I have a North American car and was wondering if anyone is able to assist me with the correct values I should have for each wire. So I can fix my wiring mistake.
All the wires are blue and I must’ve mixed them up when splicing in the correct connector for the RS3 pump. Any help would be great. I only have resistance value for an s3 from 16 to reference but don’t know if that’s correct.
jjcarnut72
Utah, USA
C?ID=519865
I was curious if you resolved the problem on your fuel gauge and what it ended up being?
