Huracan - Not cranking
huracan2016
California, USA
C?ID=365022
Hi all,
My 2016 Huracan is currently not cranking and is stuck in "Park". I am able to unlock/lock the doors using my rekeys, place the car in acc/ign mode using the start/stop button & also illuminate the instrument cluster with no issues; however, attempting to start the car (by pushing the start button with foot on brake pedal) is not resulting in cranking as one would expect. I am able to manually shift out of "Park" and into "Neutral" using the OEM lever tool.
Some background on how I managed to arrive at this situation, if helpful:
  • While driving on the highway, my car unexpectedly sputtered to a halt (complete loss of power unlike typical limp mode). I manage to pull off onto the shoulder and attempt to restart the car - no dice. I then pulled fault codes using my Hex cable -- results below:
  • (2) Current DTC Faults
    1. 01128 - Immobilizer Pickup Coil (D2) 004/ No Signal/Communication
    2. 01330 - Central Control Module for Central Convenience (J393) / 013 - Check DTC Memory - Intermittent
  • (4) Permanent DTCs
    1. P060A: Internal control module monitoring processor performance
    2. P074A: Unable to engage gear 2
    3. P073E: Unable to engage reverse
    4. P073F: Unable to engage gear 1
  • Confirmed that the female connector (from main harness) for immobilizer pickup coil (beneath the steering wheel trim area) was loose and seated the connector correctly onto the module
  • This did not resolve the issue - the car still does not crank
Also, it's worth noting that my car has a standalone ECU. You will note that the "auto trans" module is also currently not communicating with Ross-Tech -- this is new (as of today) -- I suspect it's because a power relay was removed for testing purposes. Standalone ECU is reporting that it is receiving temperature information from the TCM as well as starter signal upon pressing the start/stop button. Also, some of the VCDS outputs below would suggested that the car is lacking adequate battery power -- the battery was changed after this incident -- the voltage-related outputs are probablly simply because the car has ben sitting idly for a couple of weeks now.
Would greatly appreciate any thoughts or opinions here! Would love to get my car back on the road ASAP! Thank you.
Auto scan
Monday,18,May,2020,01:21:56:06485
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
Chassis Type: 4T0
Scan: 01 02 03 05 08 09 11 31 14 15 16 17 19 22 3B 42 44 46 52 53
          55 56 5F 65 6C C2 D0
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine
Address 02: Auto Trans
   Part No SW: 4S0 907 379 C    HW: 4S0 907 379 C
   Component: ESP PREMIUM   H09 0220
   Coding: 2182C141844183824B00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004048
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 3D323B23AC68FB6E20-8068
   Part No SW: 4H0 907 064 GD    HW: 4H0 907 064 GD
   Component: BCM2 2.0      H37 0572
   Coding: 09803006000000000000
   VCID: 71AAD713A8B04F0EF4-8024
   Serial number: 3215000149647012
   Part No SW: 4T0 820 043 E    HW: 4T0 820 043 E
   Component: KLIMA 1 ZONE  H03 0130
   Revision: A1016000    Serial number: 01210920150022
   Coding: 4A02208000
   VCID: 2E100C6F790E10F6A9-807A
   Part No SW: 4H0 907 063 EK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H20 0367
   Revision: 25020001    Serial number: 00001159213602
   Coding: 00E9009040208F202D01C8C3002028000A1C47C8220602E10000081C0440100000400034010000
   VCID: 75A2E303DCD8632E28-8020
   Subsystem 1 - Part No SW: 4T1 955 113     HW: 955 113
   Component: WWS72x 150826  042 0015
   Serial number:         ????????????
   Coding: 0000F7
   Serial number: 20635469
   Coding: 02005D
   Subsystem 3 - Part No SW: 4T1 941 531 D    HW: 4T1 941 531 D
   Component: LCU  H02 0012
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z020D730C
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: F298CDC7000000000001
Address 11: Engine II
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 4S0 907 376 B    HW: 4S0 907 376 B
   Component: DAEMPFUNGS-SG H05 0062
   Serial number:       290815031
   ASAM Dataset: EV_AudiMagneRide 002007
   ROD: EV_AudiMagneRide.rod
   VCID: 393A2F33B840C74E0C-806C
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0002K8LR
   Coding: 303333343033303030364A55304C34543053
   VCID: 34241E079F223A26DF-8060
   Serial number: 6940000Y150001CXU90F
   Serial number: 3575HRB40692RDNMA1R4
   Serial number: 3585HRB40692RDNM3HQD
   Serial number: 3515JRB40573K174BPD%
   Serial number: 3525JRB40573K174A18D
   Serial number: 3554VRB405B3H6G49HDJ
   Serial number: 3564VRB405B3H6G499ON
   Part No SW: 4T0 953 513     HW: 4T0 953 513
   Component: Lenks.Modul   H02 0090
   Revision: C0072465    Serial number: 90815OJ100070
   VCID: 72A8D81FADB674160D-8026
   Subsystem 1 - Part No SW: 18G 959 542 B    HW: 18G 959 542 B
   Component: E221__MFL-TAS  H05 0012
   Serial number: 0008354 TAT 20150606
Address 17: Instruments
   Part No SW: 4T0 907 468 A    HW: 4S0 907 468
   Component: J533--Gateway H14 0065
   Revision: --------    Serial number: 00000002001598
   Coding: 0009071600
   ASAM Dataset: EV_GatewPkoUDS 001027
   VCID: 3B36353BB27CF55E1E-806E
   Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
   Component: J367-BDM  H08 0190
   Serial number: 62238E42183371573883
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 15257002351011200410
5186 - Second (Slave) Engine Control Module
          U0115 00 [008] - No Communication
                    Reset counter: 12
                    Mileage: xxxkm
                    Date: 2012.01.09
                    Time: 20:08:19
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 31 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 12
                    Mileage: xxxkm
                    Date: 2012.01.09
                    Time: 20:08:19
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
Address 22: AWD (J492)       Labels: None
   Part No SW: 4S0 907 160     HW: 4S0 907 160
   Component: 4 Wheel Drive H06 0207
   Revision: 00001002    Serial number: BBM1LML
   ASAM Dataset: EV_AllWheelContrBORGLB724 006012
   ROD: EV_AllWheelContrBORGLB724.rod
   VCID: 6E90CC6FB18E50F6E9-803A
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01SMZF
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373E290B8E54D13EFA-8062
   Part No SW: 4T0 959 793 H    HW: 4T0 959 793 H
   Component: TSG FA        H07 0801
   Revision: --------    Serial number: 0000166248837
   Coding: 010C4B025000620100081102
   VCID: 4AD860FFE5A65CD695-801E
   Part No SW: 4S0 909 144 G    HW: 4S0 909 144 B
   Component: EPS           H13 0904
   Revision: 00000000    Serial number:      L00106523
   Coding: 0800
   ASAM Dataset: EV_EPSZFAU72X 002010
   ROD: EV_EPSZFAU72X_002.rod
   Revision: 00002001    Serial number: 0376236015
   Coding: 011E029A18F24081A0B0C800008500470000000000000000000000000000
   Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000001053971
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor  H03 0030
00834 - Signal for Activation of Heated Rear Window
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:39
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:39
   Part No SW: 4T0 959 792 H    HW: 4T0 959 792 H
   Component: TSG BF        H07 0801
   Revision: --------    Serial number: 0000166264945
   Coding: 010C4B025000620100081100
   VCID: 49DA5FF3E0A057CE9C-801C
   Part No SW: 4S0 907 801     HW: 8K0 907 801 J
   Component: EPB-4         H02 0001
   Revision: --------    Serial number: 20000000001299
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70ACD217ABBA4606FB-8024
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4T0 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0003
   Serial number: 151008-0004-043
   Coding: 72846F6118020200
   Shop #: WSC 59627 001 1048576
   ASAM Dataset: EV_AFSLEDHELLALB72X 006131
   ROD: EV_AFSLEDHELLALB72X.rod
   VCID: 383C2A37834ADE46F3-806C
   Subsystem 1 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 1D0000
   Subsystem 2 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 1D0000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156I%0F2502885
   Coding: 020007020100000001
   VCID: 2404EE4727C2AAA64F-8070
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:41
                    Voltage: 12.00 V
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:41
                    Voltage: 12.10 V
   Part No SW: 4T0 035 664 A    HW: 4T0 035 664 A
   Component: H-BN-NA       H40 0917
   Revision: --------    Serial number: 325J/0FB001377
   Coding: 010200000001A16F0100820600000001FD0000020000000000
   VCID: 312A171368300F0EB4-8064
   Subsystem 1 - Part No: 4T0 919 859 D
   Component: NAR 2014  0801
   Subsystem 3 - Part No SW: 4T0 919 609     HW: 4T0 919 609
   Component: E380 BDT LB2  H01 0011
   Serial number: 00000000004542
   Component: CD-Database  5571
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:44
                    Bin. Bits: 00100000 00000000
                    Bin. Bits: 00000000 00000000
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000019835
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A18007F4DE67CD675-807E
8400898 - TPMS Warning; Front Left Tire
          C1054 00 [009] - Pressure too Low
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:41
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 4T0 907 441     HW: 5Q0 907 441 A
   Component: LB72x RVC Mid H07 0030
   Coding: 080004010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 71AAD713A0B04F0EF4-8024
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 4T0 927 109 A    HW: 4S0 927 109
   Component: DL800 ZSG     H11 0001
   Revision: --H11---    Serial number: 0000000025
   Coding: 000001
   ASAM Dataset: EV_TCMDL800421 001023
   ROD: EV_TCMDL800.rod
   VCID: 352223039458232EE8-8060
Address D0: Frt Axle Lift (J988)       Labels: None
   Part No SW: 4S0 959 257     HW: 4S0 959 257
   Component: Lift-VA006 1980
   Revision: 00000000    Serial number: 152580151
   Coding: 020607
   ASAM Dataset: EV_LiftVA003 001001
   ROD: EV_LiftVA003.rod
   VCID: 7CB4F627F7F2326657-8028
End----(Elapsed Time: 02:16, VBatt start/end: 11.7V/12.0V. VIgn 12.0V)-----
PLA / PLB and AFP Files
;SW:4H0-907-064-GD   HW:4H0-907-064-GD ---  Acc/Start Auth.
;Component:BCM2 2.0      H37 0572, Coding:09803006000000000000
;Sunday,17,May,2020,19:29:57:06485
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 71AAD713A8B04F0EF4-8024
;Sunday,17,May,2020,19:27:54:06485
1,0,,
1,1,,,
;SW-Stand: AUDID4_BCM2_X065 26.05.2014,,
2,0,,
2,1,,,
;11.875 V,,
2,2,,,
;11.750 V,,
2,3,,,
;11.750 V,,
2,4,,,
;0.0,,
3,0,,
3,1,,,
;Not Installed,,
3,2,,,
;Not Installed,,
3,3,,,
;Not Installed,,
3,4,,,
4,0,,
4,1,,,
;Not Installed,,
4,2,,,
;Not Installed,,
4,3,,,
;Not Installed,,
4,4,,,
5,0,,
5,1,,,
;       0,,
5,2,,,
;       1,,
5,3,,,
;       1,,
5,4,,,
6,0,,
6,1,,,
;       0,,
6,2,,,
;0.0,,
6,3,,,
6,4,,,
7,0,,
7,1,,,
;01110100,,
7,2,,,
;10011111,,
7,3,,,
;01000000,,
7,4,,,
;00000011,,
8,0,,
8,1,,,
;1.0,,
8,2,,,
;1.0,,
8,3,,,
;1.0,,
8,4,,,
;1.0,,
10,0,,
10,1,,,
10,2,,,
10,3,,,
10,4,,,
11,0,,
11,1,,,
;00000000,,
11,2,,,
;0,,
11,3,,,
;0,,
11,4,,,
12,0,,
12,1,,,
;00000000,,
12,2,,,
;0,,
12,3,,,
;0,,
12,4,,,
20,0,,
20,1,,,
;Yes,,
20,2,,,
;No,,
20,3,,,
;Yes,,
20,4,,,
;2.0,,
21,0,,
21,1,,,
;00011000,,
21,2,,,
;10000010,,
21,3,,,
;0x0040,,
21,4,,,
;218.0,,
22,0,,
22,1,,,
;3.0,,
22,2,,,
;3.0,,
22,3,,,
;2.0,,
22,4,,,
23,0,,
23,1,,,
;No,,
23,2,,,
;No,,
23,3,,,
;No,,
23,4,,,
;0.0,,
24,0,,
24,1,,,
;0xE910,,
24,2,,,
;0x4275,,
24,3,,,
;Implausible,,
24,4,,,
;Implausible,,
25,0,,
25,1,,,
;Yes,,
25,2,,,
;Yes,,
25,3,,,
25,4,,,
30,0,,
30,1,,,
;38769 km,,
30,2,,,
;000 000 000,,
30,3,,,
;0x0000,,
30,4,,,
;0x0000,,
31,0,,
31,1,,,
;18:57:15 / 09.01.2012,,
32,0,,
32,1,,,
;227.0,,
32,2,,,
32,3,,,
32,4,,,
33,0,,
33,1,,,
;Door Open,,
33,2,,,
;0.0 %,,
33,3,,,
;Unlocked,,
33,4,,,
;Not Safe,,
34,0,,
34,1,,,
;Door Open,,
34,2,,,
;0.0 %,,
34,3,,,
;Unlocked,,
34,4,,,
;Not Safe,,
35,0,,
35,1,,,
;Not Installed,,
35,2,,,
;Not Installed,,
35,3,,,
;Not Installed,,
35,4,,,
;Not Installed,,
36,0,,
36,1,,,
;Not Installed,,
36,2,,,
;Not Installed,,
36,3,,,
;Not Installed,,
36,4,,,
;Not Installed,,
37,0,,
37,1,,,
;     100,,
37,2,,,
;10.0,,
37,3,,,
37,4,,,
38,0,,
38,1,,,
;0.00 km/h,,
38,2,,,
;       0,,
38,3,,,
;Init. value,,
38,4,,,
;0.00 km/h,,
39,0,,
39,1,,,
;       0,,
39,2,,,
;    0000,,
39,3,,,
;5.0,,
39,4,,,
;       1,,
40,0,,
40,1,,,
;0,,
40,2,,,
;0,,
40,3,,,
;0,,
40,4,,,
;0,,
41,0,,
41,1,,,
;0,,
41,2,,,
;255.0,,
41,3,,,
;17,,
41,4,,,
;255.0,,
42,0,,
42,1,,,
;0,,
42,2,,,
;00010000,,
42,3,,,
;01000000,,
42,4,,,
;01111111,,
43,0,,
43,1,,,
;00000000,,
43,2,,,
;00000000,,
43,3,,,
;00000000,,
43,4,,,
;00000000,,
44,0,,
44,1,,,
;00010010,,
44,2,,,
;11001100,,
44,3,,,
;00000000,,
44,4,,,
;11000001,,
45,0,,
45,1,,,
;00000000,,
45,2,,,
;00000000,,
45,3,,,
;01110110,,
45,4,,,
;11011011,,
46,0,,
46,1,,,
;01111111,,
46,2,,,
;11100110,,
46,3,,,
;01110110,,
46,4,,,
;11011011,,
47,0,,
47,1,,,
;01000000,,
47,2,,,
;00000010,,
47,3,,,
;01000000,,
47,4,,,
;00000000,,
48,0,,
48,1,,,
;11111111,,
48,2,,,
;11111111,,
48,3,,,
;11111111,,
48,4,,,
49,0,,
49,1,,,
;00000000,,
49,2,,,
;00000000,,
49,3,,,
;00000000,,
49,4,,,
50,0,,
50,1,,,
;00000011,,
50,2,,,
;00000011,,
50,3,,,
;00000011,,
50,4,,,
51,0,,
51,1,,,
;00000011,,
51,2,,,
;00000011,,
51,3,,,
;00000011,,
51,4,,,
52,0,,
52,1,,,
;00000011,,
52,2,,,
;00000011,,
52,3,,,
;00000011,,
52,4,,,
53,0,,
53,1,,,
;00000011,,
53,2,,,
;00000011,,
53,3,,,
;00000011,,
53,4,,,
54,0,,
54,1,,,
;00000011,,
54,2,,,
;00000011,,
54,3,,,
;00000011,,
54,4,,,
55,0,,
55,1,,,
;00000011,,
55,2,,,
;00000011,,
55,3,,,
;00000011,,
55,4,,,
56,0,,
56,1,,,
;00100000,,
56,2,,,
;0,,
56,3,,,
;255.0,,
56,4,,,
;0.0,,
57,0,,
57,1,,,
;0.0,,
57,2,,,
;0.0,,
57,3,,,
;1.0,,
57,4,,,
;1.0,,
58,0,,
58,1,,,
;0,,
58,2,,,
;0,,
58,3,,,
;0.0,,
58,4,,,
;0.0,,
59,0,,
59,1,,,
;2.0,,
59,2,,,
;0.0,,
59,3,,,
;00010000,,
59,4,,,
60,0,,
60,1,,,
;MDW-MSR14.08.1550200589,,
61,0,,
61,1,,,
;H40,,
62,0,,
62,1,,,
;0046,,
63,0,,
63,1,,,
;00000001,,
63,2,,,
63,3,,,
63,4,,,
64,0,,
64,1,,,
;94,,
64,2,,,
64,3,,,
64,4,,,
65,0,,
65,1,,,
;0.0,,
65,2,,,
;0.0,,
65,3,,,
;0.0,,
65,4,,,
;0.0,,
66,0,,
66,1,,,
;       1,,
66,2,,,
;       0,,
66,3,,,
;       0,,
66,4,,,
;       0,,
67,0,,
67,1,,,
;       0,,
67,2,,,
;       0,,
67,3,,,
;       0,,
67,4,,,
;       1,,
68,0,,
68,1,,,
;       0,,
68,2,,,
;       0,,
68,3,,,
;       1,,
68,4,,,
;       1,,
69,0,,
69,1,,,
;       0,,
69,2,,,
;       0,,
69,3,,,
;       0,,
69,4,,,
;       0,,
80,0,,
80,1,,,
;1.0,,
80,2,,,
;0.0,,
80,3,,,
80,4,,,
81,0,,
81,1,,,
;00000000,,
81,2,,,
;0,,
81,3,,,
;0,,
81,4,,,
;0,,
82,0,,
82,1,,,
;00000000,,
82,2,,,
;00000000,,
82,3,,,
;00000000,,
82,4,,,
;00010000,,
83,0,,
83,1,,,
;00:00,,
83,2,,,
;00:00,,
83,3,,,
;00:00,,
83,4,,,
;00:00,,
85,0,,
85,1,,,
;0.0,,
85,2,,,
;0.0,,
85,3,,,
;0.0,,
85,4,,,
;0.0,,
86,0,,
86,1,,,
;0.0,,
86,2,,,
;0.0,,
86,3,,,
;0.0,,
86,4,,,
;0.0,,
100,0,,
100,1,,,
;40.0,,
100,2,,,
;20.0,,
100,3,,,
;20.0,,
100,4,,,
;      11,,
101,0,,
101,1,,,
;11100001,,
101,2,,,
;  000110,,
101,3,,,
;0x0000,,
101,4,,,
;0.0,,
102,0,,
102,1,,,
;0 km,,
102,2,,,
102,3,,,
;N/A,,
102,4,,,
;N/A,,
103,0,,
103,1,,,
;0 km,,
103,2,,,
103,3,,,
;N/A,,
103,4,,,
;N/A,,
104,0,,
104,1,,,
;0 km,,
104,2,,,
104,3,,,
;N/A,,
104,4,,,
;N/A,,
105,0,,
105,1,,,
;0 km,,
105,2,,,
105,3,,,
;N/A,,
105,4,,,
;N/A,,
106,0,,
106,1,,,
;0 km,,
106,2,,,
106,3,,,
;N/A,,
106,4,,,
;N/A,,
107,0,,
107,1,,,
;0 km,,
107,2,,,
107,3,,,
;N/A,,
107,4,,,
;N/A,,
108,0,,
108,1,,,
;0 km,,
108,2,,,
108,3,,,
;N/A,,
108,4,,,
;N/A,,
109,0,,
109,1,,,
;0 km,,
109,2,,,
109,3,,,
;N/A,,
109,4,,,
;N/A,,
110,0,,
110,1,,,
;2000:01:01,,
110,2,,,
;2000:01:01,,
110,3,,,
;2000:01:01,,
110,4,,,
;2000:01:01,,
111,0,,
111,1,,,
;2000:01:01,,
111,2,,,
;2000:01:01,,
111,3,,,
;2000:01:01,,
111,4,,,
;2000:01:01,,
112,0,,
112,1,,,
;S.1,,
113,0,,
113,1,,,
;1.3,,
114,0,,
114,1,,,
;0xC259,,
114,2,,,
;0xF014,,
114,3,,,
;0xE2E9,,
114,4,,,
;0xFDBF,,
115,0,,
115,1,,,
;0x4CA8,,
115,2,,,
;0xA014,,
115,3,,,
;0xF6F5,,
115,4,,,
;0xB7FD,,
116,0,,
116,1,,,
;0x12F1,,
116,2,,,
;0x74E8,,
116,3,,,
;0x51FD,,
116,4,,,
;0xFEBF,,
117,0,,
117,1,,,
;0x0B2B,,
117,2,,,
;0x9F26,,
117,3,,,
;0x1FBF,,
117,4,,,
;0xDBFD,,
118,0,,
118,1,,,
;0,,
118,2,,,
;2155,,
118,3,,,
;0,,
118,4,,,
;255,,
119,0,,
119,1,,,
;2,,
119,2,,,
;2,,
119,3,,,
;255,,
119,4,,,
120,0,,
120,1,,,
;0,,
120,2,,,
;0,,
120,3,,,
;0,,
120,4,,,
;0,,
121,0,,
121,1,,,
;0,,
121,2,,,
;0,,
121,3,,,
;0,,
121,4,,,
;0,,
122,0,,
122,1,,,
;0x0000,,
122,2,,,
;0x0000,,
122,3,,,
;0x0000,,
122,4,,,
;0x0000,,
123,0,,
123,1,,,
;0x0000,,
123,2,,,
;0x0000,,
123,3,,,
;0x0000,,
123,4,,,
;0x0000,,
124,0,,
124,1,,,
;0x0000,,
124,2,,,
;0x0000,,
124,3,,,
;0x0000,,
124,4,,,
;0x0000,,
125,0,,
125,1,,,
;0x0000,,
125,2,,,
;0x0000,,
125,3,,,
;0x0000,,
125,4,,,
;0x0000,,
128,0,,
128,1,,,
;0x0003,,
128,2,,,
;0x0000,,
128,3,,,
;0x0000,,
128,4,,,
;0x0000,,
129,0,,
129,1,,,
;00000100,,
129,2,,,
;00000100,,
129,3,,,
;00000100,,
129,4,,,
137,0,,
137,1,,,
;0.0,,
137,2,,,
;0.0,,
137,3,,,
;0.0,,
137,4,,,
;0.0,,
138,0,,
138,1,,,
;0x0000,,
138,2,,,
;0x0000,,
138,3,,,
;0x0000,,
138,4,,,
;0x0000,,
139,0,,
139,1,,,
;00000000,,
139,2,,,
;00000000,,
139,3,,,
;00000000,,
139,4,,,
;00000000,,
140,0,,
140,1,,,
;0,,
140,2,,,
;0,,
140,3,,,
;0,,
140,4,,,
;0,,
141,0,,
141,1,,,
;0x1012,,
141,2,,,
;00001000,,
141,3,,,
;00000000,,
141,4,,,
;0x0420,,
142,0,,
142,1,,,
;0.0,,
142,2,,,
;0x0000,,
142,3,,,
;0x0000,,
142,4,,,
;0x0000,,
147,0,,
147,1,,,
;01000000,,
147,2,,,
;00011001,,
147,3,,,
;00000000,,
147,4,,,
;00000000,,
148,0,,
148,1,,,
;0x00FF,,
148,2,,,
;0x00FF,,
148,3,,,
;No,,
148,4,,,
;No,,
149,0,,
149,1,,,
;0x0000,,
149,2,,,
;0x0030,,
149,3,,,
;0x0010,,
149,4,,,
150,0,,
150,1,,,
;No,,
150,2,,,
;0.0,,
150,3,,,
;0.0,,
150,4,,,
;0x0800,,
151,0,,
151,1,,,
;0x0021,,
151,2,,,
;0x018A,,
151,3,,,
;Yes,,
151,4,,,
;No,,
152,0,,
152,1,,,
;00000000,,
152,2,,,
;    0000,,
152,3,,,
152,4,,,
157,0,,
157,1,,,
;000 037 000,,
157,2,,,
;N/A,,
157,3,,,
;N/A,,
157,4,,,
;N/A,,
158,0,,
158,1,,,
;0x0000,,
158,2,,,
;0x0000,,
158,3,,,
158,4,,,
159,0,,
159,1,,,
;0x0000,,
159,2,,,
;0x0000,,
159,3,,,
;0x0000,,
159,4,,,
160,0,,
160,1,,,
;0x0000,,
160,2,,,
;0x0000,,
160,3,,,
160,4,,,
161,0,,
161,1,,,
;0.0,,
161,2,,,
161,3,,,
161,4,,,
162,0,,
162,1,,,
;     000,,
162,2,,,
;8.0,,
162,3,,,
;0.0,,
162,4,,,
166,0,,
166,1,,,
;11000000,,
166,2,,,
166,3,,,
166,4,,,
167,0,,
167,1,,,
;0.0,,
167,2,,,
;0.0,,
167,3,,,
;1.0,,
167,4,,,
;51.0,,
168,0,,
168,1,,,
;122.0,,
168,2,,,
;18.0,,
168,3,,,
;2.0,,
168,4,,,
169,0,,
169,1,,,
;11110011,,
169,2,,,
;01111111,,
169,3,,,
;11111111,,
169,4,,,
170,0,,
170,1,,,
;0.0,,
170,2,,,
;0.0,,
170,3,,,
;00000001,,
170,4,,,
171,0,,
171,1,,,
;11101110,,
171,2,,,
;215.0,,
171,3,,,
;156.0,,
171,4,,,
;11101110,,
172,0,,
172,1,,,
;00000010,,
172,2,,,
;00000000,,
172,3,,,
;1.0,,
172,4,,,
;00000011,,
173,0,,
173,1,,,
;28.0,,
173,2,,,
;5.0,,
173,3,,,
;2.0,,
173,4,,,
;00000011,,
174,0,,
174,1,,,
;255.0,,
174,2,,,
;00000001,,
174,3,,,
174,4,,,
175,0,,
175,1,,,
;100,,
175,2,,,
;0,,
175,3,,,
;0.0,,
175,4,,,
176,0,,
176,1,,,
;01111111,,
176,2,,,
;00111111,,
176,3,,,
;10010000,,
176,4,,,
;00000111,,
183,0,,
183,1,,,
;10000,,
183,2,,,
;10000,,
183,3,,,
;10000,,
183,4,,,
;10000,,
184,0,,
184,1,,,
;0,,
184,2,,,
184,3,,,
184,4,,,
185,0,,
185,1,,,
;0.0,,
185,2,,,
;0.0,,
185,3,,,
;0.0,,
185,4,,,
;0.0,,
187,0,,
187,1,,,
;No Commun.,,
187,2,,,
187,3,,,
187,4,,,
188,0,,
188,1,,,
;No Commun.,,
188,2,,,
188,3,,,
188,4,,,
189,0,,
189,1,,,
;No Commun.,,
189,2,,,
189,3,,,
189,4,,,
190,0,,
190,1,,,
;No Commun.,,
190,2,,,
;No Commun.,,
190,3,,,
;No Commun.,,
190,4,,,
;No Commun.,,
191,0,,
191,1,,,
;No Commun.,,
191,2,,,
;No Commun.,,
191,3,,,
;No Commun.,,
191,4,,,
;No Commun.,,
192,0,,
192,1,,,
;No Commun.,,
192,2,,,
;No Commun.,,
192,3,,,
;No Commun.,,
192,4,,,
;No Commun.,,
193,0,,
193,1,,,
;No Commun.,,
193,2,,,
;No Commun.,,
193,3,,,
;No Commun.,,
193,4,,,
;No Commun.,,
194,0,,
194,1,,,
;No Commun.,,
194,2,,,
;No Commun.,,
194,3,,,
;No Commun.,,
194,4,,,
;No Commun.,,
195,0,,
195,1,,,
;No Commun.,,
195,2,,,
;No Commun.,,
195,3,,,
;No Commun.,,
195,4,,,
;No Commun.,,
196,0,,
196,1,,,
;No Commun.,,
196,2,,,
;No Commun.,,
196,3,,,
;No Commun.,,
196,4,,,
;No Commun.,,
197,0,,
197,1,,,
;No Commun.,,
197,2,,,
;No Commun.,,
197,3,,,
;No Commun.,,
197,4,,,
;No Commun.,,
198,0,,
198,1,,,
;No Commun.,,
198,2,,,
;No Commun.,,
198,3,,,
;No Commun.,,
198,4,,,
;No Commun.,,
199,0,,
199,1,,,
;No Commun.,,
199,2,,,
;No Commun.,,
199,3,,,
;No Commun.,,
199,4,,,
;No Commun.,,
200,0,,
200,1,,,
;No Commun.,,
200,2,,,
;No Commun.,,
200,3,,,
;No Commun.,,
200,4,,,
;No Commun.,,
201,0,,
201,1,,,
;No Commun.,,
201,2,,,
;No Commun.,,
201,3,,,
;No Commun.,,
201,4,,,
;No Commun.,,
202,0,,
202,1,,,
;No Commun.,,
202,2,,,
;No Commun.,,
202,3,,,
;No Commun.,,
202,4,,,
;No Commun.,,
203,0,,
203,1,,,
;No Commun.,,
203,2,,,
;No Commun.,,
203,3,,,
;No Commun.,,
203,4,,,
;No Commun.,,
204,0,,
204,1,,,
;No Commun.,,
204,2,,,
;No Commun.,,
204,3,,,
;No Commun.,,
204,4,,,
;No Commun.,,
205,0,,
205,1,,,
;No Commun.,,
205,2,,,
;No Commun.,,
205,3,,,
;No Commun.,,
205,4,,,
;No Commun.,,
206,0,,
206,1,,,
;No Commun.,,
206,2,,,
;No Commun.,,
206,3,,,
;No Commun.,,
206,4,,,
;No Commun.,,
227,0,,
227,1,,,
;0,,
227,2,,,
227,3,,,
227,4,,,
229,0,,
229,1,,,
;000 054 000,,
229,2,,,
;N/A,,
229,3,,,
;N/A,,
229,4,,,
;N/A,,
230,0,,
230,1,,,
;000 016 255,,
230,2,,,
;N/A,,
230,3,,,
;N/A,,
230,4,,,
;N/A,,
231,0,,
231,1,,,
;000 037 000,,
231,2,,,
;N/A,,
231,3,,,
;N/A,,
231,4,,,
;N/A,,
232,0,,
232,1,,,
;000 037 000,,
232,2,,,
;N/A,,
232,3,,,
;N/A,,
232,4,,,
;N/A,,
233,0,,
233,1,,,
;000 037 000,,
233,2,,,
;N/A,,
233,3,,,
;N/A,,
233,4,,,
;N/A,,
234,0,,
234,1,,,
;000 037 000,,
234,2,,,
;N/A,,
234,3,,,
;N/A,,
234,4,,,
;N/A,,
235,0,,
235,1,,,
;000 037 000,,
235,2,,,
;N/A,,
235,3,,,
;N/A,,
235,4,,,
;N/A,,
236,0,,
236,1,,,
;000 037 000,,
236,2,,,
;N/A,,
236,3,,,
;N/A,,
236,4,,,
;N/A,,
;SW:4T0-035-664-A   HW:4T0-035-664-A ---  Information Electr.
;Component:H-BN-NA       H40 0917, Coding:010200000001A16F0100820600000001FD0000020000000000
;Sunday,17,May,2020,19:56:41:06485
;VCID: 312A171368300F0EB4-8064
A01,0,
;100
A01,1,
;N/A
A01,2,
;N/A
A01,3,
;N/A
A01,4,
;N/A
A02,0,
;15
A02,1,
;N/A
A02,2,
;N/A
A02,3,
;N/A
A02,4,
;N/A
A03,0,
;10
A03,1,
;N/A
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
;04 N/A
A05,0,
;0
A05,1,
;N/A
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
A06,0,
;0
A06,1,
;N/A
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;0
A07,1,
;N/A
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
;08 N/A
A09,0,
;0
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;0
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
A15,0,
;0
A15,1,
;27683
A15,2,
;N/A
A15,3,
;N/A
A15,4,
;N/A
;16 N/A
A17,0,
;3
A17,1,
;N/A
A17,2,
;N/A
A17,3,
;N/A
A17,4,
;N/A
A18,0,
;0
A18,1,
;N/A
A18,2,
;N/A
A18,3,
;N/A
A18,4,
;N/A
A19,0,
;1
A19,1,
;N/A
A19,2,
;N/A
A19,3,
;N/A
A19,4,
;N/A
A20,0,
;0
A20,1,
;N/A
A20,2,
;N/A
A20,3,
;N/A
A20,4,
;N/A
A21,0,
;1
A21,1,
;N/A
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
A22,0,
;0
A22,1,
;N/A
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
A31,0,
;0
A31,1,
;0
A31,2,
;0 /min
A31,3,
;N/A
A31,4,
;N/A
A32,0,
;0
A32,1,
;N/A
A32,2,
;N/A
A32,3,
;N/A
A32,4,
;N/A
A33,0,
;0
A33,1,
;0x0000
A33,2,
;0.00 %
A33,3,
;0
A33,4,
;N/A
A34,0,
;0
A34,1,
;N/A
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
;35 N/A
A36,0,
;0
A36,1,
;N/A
A36,2,
;N/A
A36,3,
;N/A
A36,4,
;N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
A47,0,
;1
A47,1,
;N/A
A47,2,
;N/A
A47,3,
;N/A
A47,4,
;N/A
A48,0,
A48,1,
;ERROR:
A48,2,
;Security
A48,3,
;access
A48,4,
;required
A49,0,
;58
A49,1,
;22.7 %
A49,2,
;1.6 %
A49,3,
;N/A
A49,4,
;N/A
A50,0,
;4
A50,1,
;22.7 %
A50,2,
;1.6 %
A50,3,
;N/A
A50,4,
;N/A
A51,0,
;0
A51,1,
;N/A
A51,2,
;N/A
A51,3,
;N/A
A51,4,
;N/A
A52,0,
;0
A52,1,
;0.0 %
A52,2,
;not available
A52,3,
;not available
A52,4,
;N/A
A53,0,
;0
A53,1,
;N/A
A53,2,
;N/A
A53,3,
;N/A
A53,4,
;N/A
A54,0,
;0
A54,1,
;N/A
A54,2,
;N/A
A54,3,
;N/A
A54,4,
;N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
A66,0,
;0
A66,1,
;N/A
A66,2,
;N/A
A66,3,
;N/A
A66,4,
;N/A
;67 N/A
;68 N/A
A69,0,
;63
A69,1,
;N/A
A69,2,
;N/A
A69,3,
;N/A
A69,4,
;N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
A81,0,
;0
A81,1,
;N/A
A81,2,
;N/A
A81,3,
;N/A
A81,4,
;N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
A96,0,
;0
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
A112,0,
;0
A112,1,
;N/A
A112,2,
;N/A
A112,3,
;N/A
A112,4,
;N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
A117,0,
;0
A117,1,
;N/A
A117,2,
;N/A
A117,3,
;N/A
A117,4,
;N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
A122,0,
;0
A122,1,
;N/A
A122,2,
;N/A
A122,3,
;N/A
A122,4,
;N/A
A123,0,
;255
A123,1,
;N/A
A123,2,
;N/A
A123,3,
;N/A
A123,4,
;N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
A128,0,
;0
A128,1,
;N/A
A128,2,
;N/A
A128,3,
;N/A
A128,4,
;N/A
A129,0,
;0
A129,1,
;N/A
A129,2,
;N/A
A129,3,
;N/A
A129,4,
;N/A
A130,0,
;0
A130,1,
;N/A
A130,2,
;N/A
A130,3,
;N/A
A130,4,
;N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
A144,0,
;0
A144,1,
;N/A
A144,2,
;N/A
A144,3,
;N/A
A144,4,
;N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Sunday,17,May,2020,19:55:19:06485
1,0,,
1,1,,,
;11.60 V,Voltage,
1,2,,,
;00010111,Bin. Bits,
1,3,,,
;0x0006,Hex Value,
1,4,,,
;N/A,,
2,0,,
2,1,,,
;0x0100,Hex Value,
2,2,,,
;0x03FF,Hex Value,
2,3,,,
;0x005F,Hex Value,
2,4,,,
;N/A,,
3,0,,
3,1,,,
;0.00,(no units),
3,2,,,
;54.0°C,Temperature,
3,3,,,
;68.0°C,Temperature,
3,4,,,
;N/A,,
4,0,,
4,1,,,
;0x0000,Hex Value,
4,2,,,
;0x000A,Hex Value,
4,3,,,
;0,Count,
4,4,,,
;N/A,,
5,0,,
5,1,,,
;0x00FF,Hex Value,
5,2,,,
;       1,Bin. Bits,
5,3,,,
;N/A,,
5,4,,,
;N/A,,
6,0,,
6,1,,,
;82.0,(no units),
6,2,,,
;23.0,(no units),
6,3,,,
;0,Count,
6,4,,,
;     110,Bin. Bits,
7,0,,
7,1,,,
;0xE300,Hex Value,
7,2,,,
;0x9771,Hex Value,
7,3,,,
;N/A,,
7,4,,,
;N/A,,
8,0,,
8,1,,,
;0x0000,Hex Value,
8,2,,,
;0x3053,Hex Value,
8,3,,,
;0x3625,Hex Value,
8,4,,,
;N/A,,
9,0,,
9,1,,,
;1940 h,ON Time,
9,2,,,
;49.0,(no units),
9,3,,,
;N/A,,
9,4,,,
;N/A,,
10,0,,
10,1,,,
;10011110 10000010,Bin. Bits,
10,2,,,
;00000000 00000000,Bin. Bits,
10,3,,,
10,4,,,
11,0,,
11,1,,,
;0x0011,Hex Value,
11,2,,,
;0x0013,Hex Value,
11,3,,,
;0x0011,Hex Value,
11,4,,,
;0x0013,Hex Value,
12,0,,
12,1,,,
;12402ALB2S12X0011,Hex Value,
13,0,,
13,1,,,
;00000000 00000110,Bin. Bits,
13,2,,,
;N/A,,
13,3,,,
;N/A,,
13,4,,,
;N/A,,
14,0,,
14,1,,,
;22.7 %,Load,
14,2,,,
;1.6 %,Load,
14,3,,,
;N/A,,
14,4,,,
;N/A,,
15,0,,
15,1,,,
15,2,,,
;00:00,Clock,
15,3,,,
;N/A,,
15,4,,,
;N/A,,
16,0,,
16,1,,,
;0x0000,Hex Value,
16,2,,,
;0x0000,Hex Value,
16,3,,,
;0.0,(no units),
16,4,,,
;0.0,(no units),
17,0,,
17,1,,,
;Not Installed, ,
17,2,,,
;Not Installed, ,
17,3,,,
;Not Installed, ,
17,4,,,
;Not Installed, ,
18,0,,
18,1,,,
;70.0°C,Temperature,
18,2,,,
18,3,,,
;0.0 %,Load,
18,4,,,
19,0,,
19,1,,,
;00000001,Bin. Bits,
19,2,,,
;0 h,ON Time,
19,3,,,
;0.0,(no units),
19,4,,,
;14.00 V,Voltage,
20,0,,
20,1,,,
;not available, ,
20,2,,,
;not available, ,
20,3,,,
;not available, ,
20,4,,,
;not available, ,
21,0,,
21,1,,,
;not available, ,
21,2,,,
;not available, ,
21,3,,,
;not available, ,
21,4,,,
;not available, ,
22,0,,
22,1,,,
;not available, ,
22,2,,,
;not available, ,
22,3,,,
;not available, ,
22,4,,,
;not available, ,
23,0,,
23,1,,,
;not available, ,
23,2,,,
;not available, ,
23,3,,,
;not available, ,
23,4,,,
;not available, ,
24,0,,
24,1,,,
;0x0001,Hex Value,
24,2,,,
;not available, ,
24,3,,,
;not available, ,
24,4,,,
25,0,,
25,1,,,
;       0,Bin. Bits,
25,2,,,
;      11,Bin. Bits,
25,3,,,
25,4,,,
26,0,,
26,1,,,
;00000000,Bin. Bits,
26,2,,,
26,3,,,
26,4,,,
27,0,,
27,1,,,
;1,Count,
27,2,,,
;1,Count,
27,3,,,
;not available, ,
27,4,,,
28,0,,
28,1,,,
;Not Possible, ,
28,2,,,
28,3,,,
28,4,,,
29,0,,
29,1,,,
;0,Count,
29,2,,,
;0 /min,RPM,
29,3,,,
;N/A,,
29,4,,,
;N/A,,
30,0,,
30,1,,,
;Not Installed, ,
30,2,,,
;Not Installed, ,
30,3,,,
;N/A,,
30,4,,,
;N/A,,
31,0,,
31,1,,,
;Not Installed, ,
31,2,,,
;Not Installed, ,
31,3,,,
;Not Installed, ,
31,4,,,
;Not Installed, ,
32,0,,
32,1,,,
;00000000 00110000,Bin. Bits,
32,2,,,
;N/A,,
32,3,,,
;N/A,,
32,4,,,
;N/A,,
33,0,,
33,1,,,
;     000,Bin. Bits,
33,2,,,
;     010,Bin. Bits,
33,3,,,
;N/A,,
33,4,,,
;N/A,,
34,0,,
34,1,,,
;18,Count,
34,2,,,
;N/A,,
34,3,,,
;N/A,,
34,4,,,
;N/A,,
35,0,,
35,1,,,
;10110011 00000111,Bin. Bits,
35,2,,,
35,3,,,
;N/A,,
35,4,,,
;N/A,,
37,0,,
37,1,,,
;0.0,(no units),
37,2,,,
;N/A,,
37,3,,,
;N/A,,
37,4,,,
;N/A,,
38,0,,
38,1,,,
;0xFFFF,Hex Value,
38,2,,,
;N/A,,
38,3,,,
;N/A,,
38,4,,,
;N/A,,
42,0,,
42,1,,,
;00000000 00000001,Bin. Bits,
42,2,,,
;1,Count,
42,3,,,
;N/A,,
42,4,,,
;N/A,,
48,0,,
48,1,,,
48,2,,,
48,3,,,
48,4,,,
49,0,,
49,1,,,
;No supported card in this slot.,Bin. Bits,
50,0,,
50,1,,,
51,0,,
51,1,,,
;0.80 V,Voltage,
51,2,,,
;1.40 V,Voltage,
51,3,,,
;N/A,,
51,4,,,
;N/A,,
52,0,,
52,1,,,
52,2,,,
52,3,,,
;N/A,,
52,4,,,
;N/A,,
53,0,,
53,1,,,
53,2,,,
53,3,,,
53,4,,,
54,0,,
54,1,,,
;not available, ,
54,2,,,
;33.0°C,Temperature,
54,3,,,
;N/A,,
54,4,,,
;N/A,,
55,0,,
55,1,,,
;not available, ,
55,2,,,
;not available, ,
55,3,,,
;not available, ,
55,4,,,
;N/A,,
56,0,,
56,1,,,
;not available, ,
56,2,,,
;not available, ,
56,3,,,
;not available, ,
56,4,,,
58,0,,
58,1,,,
;audio: ----;video: ----,,
59,0,,
59,1,,,
;20.10.7.61;20.10.7.61,,
60,0,,
60,1,,,
;5571,,
64,0,,
64,1,,,
;113,Count,
64,2,,,
;N/A,,
64,3,,,
;N/A,,
64,4,,,
;N/A,,
65,0,,
65,1,,,
;01:06,Clock,
65,2,,,
;0x0002,Hex Value,
65,3,,,
;0x00FE,Hex Value,
65,4,,,
;0x0002,Hex Value,
66,0,,
66,1,,,
;20:39,Clock,
66,2,,,
;00:01,Clock,
66,3,,,
;0x0002,Hex Value,
66,4,,,
;0x0001,Hex Value,
67,0,,
67,1,,,
;1,Count,
67,2,,,
;N/A,,
67,3,,,
;N/A,,
67,4,,,
;N/A,,
68,0,,
68,1,,,
;not available, ,
68,2,,,
;not available, ,
68,3,,,
;not available, ,
68,4,,,
;not available, ,
69,0,,
69,1,,,
;not available, ,
69,2,,,
;not available, ,
69,3,,,
;not available, ,
69,4,,,
;N/A,,
70,0,,
70,1,,,
;TOSHIBA MK6050GAC, ,
71,0,,
71,1,,,
;TJ104A, ,
72,0,,
72,1,,,
;35T4T0HMT, ,
73,0,,
73,1,,,
;56.0°C,Temperature,
73,2,,,
;69.0°C,Temperature,
73,3,,,
;N/A,,
73,4,,,
;N/A,,
94,0,,
94,1,,,
;not available, ,
94,2,,,
;N/A,,
94,3,,,
;N/A,,
94,4,,,
;N/A,,
95,0,,
95,1,,,
;    0001,Bin. Bits,
95,2,,,
;N/A,,
95,3,,,
;N/A,,
95,4,,,
;N/A,,
96,0,,
96,1,,,
;0.00 km/h,Speed,
96,2,,,
;1,Count,
96,3,,,
;0,Count,
96,4,,,
;N/A,,
97,0,,
97,1,,,
;11,Count,
97,2,,,
;10,Count,
97,3,,,
;11,Count,
97,4,,,
;10,Count,
98,0,,
98,1,,,
;not available, ,
98,2,,,
;N/A,,
98,3,,,
;N/A,,
98,4,,,
;N/A,,
99,0,,
99,1,,,
;4T0919859D ;0801;NAR 2014     , ,
100,0,,
100,1,,,
;not available, ,
100,2,,,
;N/A,,
100,3,,,
;N/A,,
100,4,,,
;N/A,,
101,0,,
101,1,,,
;5,(no units),
101,2,,,
;71,(no units),
101,3,,,
;126,(no units),
101,4,,,
;156,(no units),
102,0,,
102,1,,,
;5,Count,
102,2,,,
;N/A,,
102,3,,,
;N/A,,
102,4,,,
;N/A,,
103,0,,
103,1,,,
;Valid, ,
103,2,,,
;-117.0,(no units),
103,3,,,
;-42.0,(no units),
103,4,,,
;-10.0,(no units),
104,0,,
104,1,,,
;Valid, ,
104,2,,,
;34.0,(no units),
104,3,,,
;5.0,(no units),
104,4,,,
;31.0,(no units),
105,0,,
105,1,,,
;Valid, ,
105,2,,,
;352,(no units),
105,3,,,
;Valid, ,
105,4,,,
;200,Count,
106,0,,
106,1,,,
;Valid, ,
106,2,,,
;2020:05:18,Date,
106,3,,,
;02:55,Clock,
106,4,,,
;55.0,(no units),
107,0,,
107,1,,,
;Valid, ,
107,2,,,
;1.6, ,
107,3,,,
;4,Count,
107,4,,,
;N/A,,
108,0,,
108,1,,,
;0x0000,Hex Value,
108,2,,,
;0x0000,Hex Value,
108,3,,,
;0x0000,Hex Value,
108,4,,,
;0x0000,Hex Value,
109,0,,
109,1,,,
;0x0F2F,Hex Value,
109,2,,,
;0x152E,Hex Value,
109,3,,,
;0x0A2D,Hex Value,
109,4,,,
;0x142A,Hex Value,
110,0,,
110,1,,,
;01:05,Clock,
110,2,,,
;N/A,,
110,3,,,
;N/A,,
110,4,,,
;N/A,,
111,0,,
111,1,,,
;0x01F2,Hex Value,
111,2,,,
;0x0065,Hex Value,
111,3,,,
;N/A,,
111,4,,,
;N/A,,
144,0,,
144,1,,,
;3.0,(no units),
144,2,,,
;0.0,(no units),
144,3,,,
;N/A,,
144,4,,,
;N/A,,
145,0,,
145,1,,,
;1.0,(no units),
145,2,,,
;8.0,(no units),
145,3,,,
;N/A,,
145,4,,,
;N/A,,
146,0,,
146,1,,,
;iPhone;,(no units),
148,0,,
148,1,,,
;iPhone;0;;;,,
149,0,,
149,1,,,
;Not Recogn., ,
149,2,,,
;N/A,,
149,3,,,
;N/A,,
149,4,,,
;N/A,,
151,0,,
151,1,,,
;a0 56 b2 22 9b 67 ,,
152,0,,
152,1,,,
;not available, ,
152,2,,,
;N/A,,
152,3,,,
;N/A,,
152,4,,,
;N/A,,
153,0,,
153,1,,,
;not available, ,
153,2,,,
;not available, ,
153,3,,,
;       0,Bin. Bits,
153,4,,,
;N/A,,
154,0,,
154,1,,,
;not available, ,
154,2,,,
;N/A,,
154,3,,,
;N/A,,
154,4,,,
;N/A,,
155,0,,
155,1,,,
;not available, ,
155,2,,,
;N/A,,
155,3,,,
;N/A,,
155,4,,,
;N/A,,
175,0,,
175,1,,,
;0,,
177,0,,
177,1,,,
;iPhone,8C861EBC5592,,
180,0,,
180,1,,,
;Manpaul?s iPhone,F8E94E6DC0FD,,
183,0,,
183,1,,,
;Auvdog,68FEF7A35E1C,,
186,0,,
186,1,,,
;Victor's iPhone,F838805AE5C2,,
;SW:4T0-820-043-E   HW:4T0-820-043-E ---  Auto HVAC
;Component:KLIMA 1 ZONE  H03 0130, Coding:4A02208000
;Sunday,17,May,2020,19:30:42:06485
;VCID: 2E100C6F790E10F6A9-807A
A01,0,
;0
A01,1,
;N/A
A01,2,
;N/A
A01,3,
;N/A
A01,4,
;N/A
A02,0,
;1
A02,1,
;N/A
A02,2,
;N/A
A02,3,
;N/A
A02,4,
;N/A
A03,0,
;0
A03,1,
;N/A
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
A04,0,
;0
A04,1,
;N/A
A04,2,
;N/A
A04,3,
;N/A
A04,4,
;N/A
A05,0,
;0
A05,1,
;N/A
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
A06,0,
;0
A06,1,
;N/A
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;0
A07,1,
;N/A
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
A08,0,
;0
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;16
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;10
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
;11 N/A
A12,0,
A12,1,
;ERROR:
A12,2,
;Security
A12,3,
;access
A12,4,
;required
A13,0,
A13,1,
;ERROR:
A13,2,
;Security
A13,3,
;access
A13,4,
;required
A14,0,
;0
A14,1,
;N/A
A14,2,
;N/A
A14,3,
;N/A
A14,4,
;N/A
A15,0,
;70
A15,1,
;N/A
A15,2,
;N/A
A15,3,
;N/A
A15,4,
;N/A
;16 N/A
A17,0,
;0
A17,1,
;N/A
A17,2,
;N/A
A17,3,
;N/A
A17,4,
;N/A
;18 N/A
;19 N/A
A20,0,
;0
A20,1,
;N/A
A20,2,
;N/A
A20,3,
;N/A
A20,4,
;N/A
;21 N/A
A22,0,
;0
A22,1,
;N/A
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;0
A23,1,
;N/A
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
A24,1,
;ERROR:
A24,2,
;Security
A24,3,
;access
A24,4,
;required
A25,0,
A25,1,
;ERROR:
A25,2,
;Security
A25,3,
;access
A25,4,
;required
A26,0,
A26,1,
;ERROR:
A26,2,
;Security
A26,3,
;access
A26,4,
;required
A27,0,
;0
A27,1,
;N/A
A27,2,
;N/A
A27,3,
;N/A
A27,4,
;N/A
A28,0,
;3
A28,1,
;N/A
A28,2,
;N/A
A28,3,
;N/A
A28,4,
;N/A
A29,0,
;50
A29,1,
;N/A
A29,2,
;N/A
A29,3,
;N/A
A29,4,
;N/A
A30,0,
;60
A30,1,
;N/A
A30,2,
;N/A
A30,3,
;N/A
A30,4,
;N/A
;31 N/A
;32 N/A
A33,0,
;0
A33,1,
;N/A
A33,2,
;N/A
A33,3,
;N/A
A33,4,
;N/A
A34,0,
;1
A34,1,
;N/A
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
A35,0,
;0
A35,1,
;N/A
A35,2,
;N/A
A35,3,
;N/A
A35,4,
;N/A
A36,0,
;1
A36,1,
;N/A
A36,2,
;N/A
A36,3,
;N/A
A36,4,
;N/A
A37,0,
;2
A37,1,
;N/A
A37,2,
;N/A
A37,3,
;N/A
A37,4,
;N/A
A38,0,
;0
A38,1,
;N/A
A38,2,
;N/A
A38,3,
;N/A
A38,4,
;N/A
A39,0,
;5
A39,1,
;N/A
A39,2,
;N/A
A39,3,
;N/A
A39,4,
;N/A
;40 N/A
A41,0,
;0
A41,1,
;N/A
A41,2,
;N/A
A41,3,
;N/A
A41,4,
;N/A
A42,0,
;0
A42,1,
;N/A
A42,2,
;N/A
A42,3,
;N/A
A42,4,
;N/A
;43 N/A
A44,0,
;90
A44,1,
;N/A
A44,2,
;N/A
A44,3,
;N/A
A44,4,
;N/A
A45,0,
;5
A45,1,
;N/A
A45,2,
;N/A
A45,3,
;N/A
A45,4,
;N/A
A46,0,
;0
A46,1,
;N/A
A46,2,
;N/A
A46,3,
;N/A
A46,4,
;N/A
A47,0,
;5
A47,1,
;N/A
A47,2,
;N/A
A47,3,
;N/A
A47,4,
;N/A
;48 N/A
;49 N/A
A50,0,
;10
A50,1,
;N/A
A50,2,
;N/A
A50,3,
;N/A
A50,4,
;N/A
A51,0,
;0
A51,1,
;N/A
A51,2,
;N/A
A51,3,
;N/A
A51,4,
;N/A
A52,0,
;100
A52,1,
;N/A
A52,2,
;N/A
A52,3,
;N/A
A52,4,
;N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
A69,0,
;0
A69,1,
;N/A
A69,2,
;N/A
A69,3,
;N/A
A69,4,
;N/A
;70 N/A
A71,0,
;200
A71,1,
;N/A
A71,2,
;N/A
A71,3,
;N/A
A71,4,
;N/A
A72,0,
;0
A72,1,
;N/A
A72,2,
;N/A
A72,3,
;N/A
A72,4,
;N/A
;73 N/A
A74,0,
;10
A74,1,
;N/A
A74,2,
;N/A
A74,3,
;N/A
A74,4,
;N/A
A75,0,
A75,1,
;ERROR:
A75,2,
;Security
A75,3,
;access
A75,4,
;required
;76 N/A
A77,0,
;10
A77,1,
;N/A
A77,2,
;N/A
A77,3,
;N/A
A77,4,
;N/A
A78,0,
;120
A78,1,
;N/A
A78,2,
;N/A
A78,3,
;N/A
A78,4,
;N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
A85,0,
;0
A85,1,
;N/A
A85,2,
;N/A
A85,3,
;N/A
A85,4,
;N/A
A86,0,
;0
A86,1,
;N/A
A86,2,
;N/A
A86,3,
;N/A
A86,4,
;N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Sunday,17,May,2020,19:29:59:06485
1,0,,
1,1,,,
;0.000 A,Current,
1,2,,,
;0.000 A,Current,
1,3,,,
1,4,,,
;7.4 bar,Absolute Pres.,
2,0,,
2,1,,,
;5.0,(no units),
2,2,,,
;0.0,(no units),
2,3,,,
;0.0,(no units),
2,4,,,
;0.0,(no units),
3,0,,
3,1,,,
;0.0,(no units),
3,2,,,
;0.0,(no units),
3,3,,,
;0.0,(no units),
3,4,,,
4,0,,
4,1,,,
;11638,Count,
4,2,,,
;11638,Count,
4,3,,,
;10000,Count,
4,4,,,
;11638,Count,
5,0,,
5,1,,,
;00010101,Bin. Bits,
5,2,,,
5,3,,,
;00000111,Bin. Bits,
5,4,,,
;100.0 %,Load,
6,0,,
6,1,,,
;11045,Count,
6,2,,,
;11049,Count,
6,3,,,
;10000,Count,
6,4,,,
;11548,Count,
7,0,,
7,1,,,
7,2,,,
7,3,,,
7,4,,,
;67.5 %,Load,
8,0,,
8,1,,,
;11182,Count,
8,2,,,
;11182,Count,
8,3,,,
;10000,Count,
8,4,,,
;11182,Count,
9,0,,
9,1,,,
;00011101,Bin. Bits,
9,2,,,
9,3,,,
;10000101,Bin. Bits,
9,4,,,
;100.0 %,Load,
12,0,,
12,1,,,
;10660,Count,
12,2,,,
;10660,Count,
12,3,,,
;10000,Count,
12,4,,,
;11572,Count,
13,0,,
13,1,,,
13,2,,,
13,3,,,
;00000101,Bin. Bits,
13,4,,,
;41.5 %,Load,
14,0,,
14,1,,,
;10009,Count,
14,2,,,
;10000,Count,
14,3,,,
;10000,Count,
14,4,,,
;11235,Count,
15,0,,
15,1,,,
15,2,,,
15,3,,,
;00001101,Bin. Bits,
15,4,,,
;0.5 %,Load,
18,0,,
18,1,,,
;11262,Count,
18,2,,,
;11282,Count,
18,3,,,
;10000,Count,
18,4,,,
;11282,Count,
19,0,,
19,1,,,
19,2,,,
19,3,,,
19,4,,,
;98.0 %,Load,
20,0,,
20,1,,,
;69,Count,
20,2,,,
;67,Count,
20,3,,,
;68,Count,
20,4,,,
;67,Count,
21,0,,
21,1,,,
;68,Count,
21,2,,,
;50,Count,
21,3,,,
21,4,,,
22,0,,
22,1,,,
;2,Count,
22,2,,,
;1,Count,
22,3,,,
;3,Count,
22,4,,,
;4,Count,
23,0,,
23,1,,,
;4,Count,
23,2,,,
;22,Count,
23,3,,,
23,4,,,
24,0,,
24,1,,,
;92,Count,
24,2,,,
;43,Count,
24,3,,,
;27,Count,
24,4,,,
;40,Count,
25,0,,
25,1,,,
;40,Count,
25,2,,,
;36,Count,
25,3,,,
;39,Count,
25,4,,,
27,0,,
27,1,,,
;3,Count,
27,2,,,
;13,Count,
27,3,,,
;8,Count,
27,4,,,
;53,Count,
28,0,,
28,1,,,
;10,Count,
28,2,,,
;3087,Count,
28,3,,,
28,4,,,
32,0,,
32,1,,,
;4.90 V,Voltage,
32,2,,,
;11.90 V,Voltage,
32,3,,,
32,4,,,
;0.075 A,Current,
33,0,,
33,1,,,
;0.00 s,Time,
33,2,,,
33,3,,,
33,4,,,
34,0,,
34,1,,,
;23.0°C,Temperature,
34,2,,,
34,3,,,
;24.0°C,Temperature,
34,4,,,
35,0,,
35,1,,,
;21.0°C,Temperature,
35,2,,,
;20.0°C,Temperature,
35,3,,,
35,4,,,
36,0,,
36,1,,,
;25.0°C,Temperature,
36,2,,,
;2864 /min,RPM,
36,3,,,
;26.0°C,Temperature,
36,4,,,
;OFF, ,
37,0,,
37,1,,,
;0 /min,RPM,
37,2,,,
;0.0 km/h,Speed,
37,3,,,
;0.0,(no units),
37,4,,,
;0.0 Nm,Torque,
38,0,,
38,1,,,
38,2,,,
38,3,,,
;194.00 %, ,
38,4,,,
;55.0 %,Load,
39,0,,
39,1,,,
;0.0 %,Load,
39,2,,,
39,3,,,
;0.0,(no units),
39,4,,,
;0.0,(no units),
41,0,,
41,1,,,
;0.30 V,Voltage,
41,2,,,
;0 W,Output,
41,3,,,
;0.30 V,Voltage,
41,4,,,
;0 W,Output,
42,0,,
42,1,,,
;ON, ,
42,2,,,
;ON, ,
42,3,,,
;not available, ,
42,4,,,
;12.00 V,Voltage,
43,0,,
43,1,,,
;ERROR, ,
43,2,,,
;   00000,Bin. Bits,
43,3,,,
43,4,,,
44,0,,
44,1,,,
;0.0,(no units),
44,2,,,
;not reduced, ,
44,3,,,
44,4,,,
45,0,,
45,1,,,
;0.0,(no units),
45,2,,,
;not reduced, ,
45,3,,,
45,4,,,
46,0,,
46,1,,,
;     000,Bin. Bits,
46,2,,,
;2.0,(no units),
46,3,,,
;3.0,(no units),
46,4,,,
47,0,,
47,1,,,
;not available, ,
47,2,,,
47,3,,,
47,4,,,
48,0,,
48,1,,,
;not available, ,
48,2,,,
;not available, ,
48,3,,,
;OFF, ,
48,4,,,
;not available, ,
49,0,,
49,1,,,
;not available, ,
49,2,,,
;not available, ,
49,3,,,
49,4,,,
;not available, ,
50,0,,
50,1,,,
;not available, ,
50,2,,,
;04:00,Clock,
50,3,,,
;0.0°C,Temperature,
50,4,,,
;0.0°C,Temperature,
52,0,,
52,1,,,
;2,Count,
52,2,,,
;2,Count,
52,3,,,
;1.0,(no units),
52,4,,,
53,0,,
53,1,,,
;0.0,(no units),
53,2,,,
;0 W,Output,
53,3,,,
;0.0,(no units),
53,4,,,
;      00,Bin. Bits,
54,0,,
54,1,,,
;0.0,(no units),
54,2,,,
;0.0,(no units),
54,3,,,
54,4,,,
55,0,,
55,1,,,
;0.0,(no units),
55,2,,,
55,3,,,
55,4,,,
56,0,,
56,1,,,
56,2,,,
;0.0,(no units),
56,3,,,
56,4,,,
57,0,,
57,1,,,
;0.0,(no units),
57,2,,,
57,3,,,
57,4,,,
58,0,,
58,1,,,
;0.0,(no units),
58,2,,,
;3.0,(no units),
58,3,,,
;857,Count,
58,4,,,
;846,Count,
59,0,,
59,1,,,
;13.0°C,Temperature,
59,2,,,
;62.5 %,Load,
59,3,,,
59,4,,,
60,0,,
60,1,,,
;OFF, ,
60,2,,,
;1.0,(no units),
60,3,,,
60,4,,,
63,0,,
63,1,,,
;7.0,(no units),
63,2,,,
;Not Installed, ,
63,3,,,
;7.0,(no units),
63,4,,,
;Not Installed, ,
64,0,,
64,1,,,
;not available, ,
64,2,,,
;not available, ,
64,3,,,
64,4,,,
65,0,,
65,1,,,
65,2,,,
65,3,,,
;27.0°C,Temperature,
65,4,,,
66,0,,
66,1,,,
;0.250 A,Current,
66,2,,,
66,3,,,
;2.10 V,Voltage,
66,4,,,
;2.00 V,Voltage,
76,0,,
76,1,,,
76,2,,,
76,3,,,
;0.0,(no units),
76,4,,,
;0.0,(no units),
77,0,,
77,1,,,
;021000,Bin. Bits,
78,0,,
78,1,,,
;47.0°C,Temperature,
78,2,,,
78,3,,,
78,4,,,
79,0,,
79,1,,,
;255.0,(no units),
79,2,,,
;0,Count,
79,3,,,
79,4,,,
;0,Count,
80,0,,
80,1,,,
;537,Count,
80,2,,,
;336 h,ON Time,
80,3,,,
80,4,,,
81,0,,
81,1,,,
;202,Count,
81,2,,,
;152,Count,
81,3,,,
;0,Count,
81,4,,,
;0,Count,
82,0,,
82,1,,,
;147,Count,
82,2,,,
;not available, ,
82,3,,,
;not available, ,
82,4,,,
83,0,,
83,1,,,
;01001010,Bin. Bits,
83,2,,,
;00000010,Bin. Bits,
83,3,,,
;00100000,Bin. Bits,
83,4,,,
;10000000,Bin. Bits,
84,0,,
84,1,,,
84,2,,,
84,3,,,
84,4,,,
85,0,,
85,1,,,
;0.0,(no units),
85,2,,,
;0.0,(no units),
85,3,,,
;0.0,(no units),
85,4,,,
86,0,,
86,1,,,
;656 /min,RPM,
86,2,,,
;560 /min,RPM,
86,3,,,
;592 /min,RPM,
86,4,,,
;00110000,Bin. Bits,
87,0,,
87,1,,,
;0.0,(no units),
87,2,,,
;0 /min,RPM,
87,3,,,
;0.0 bar,Absolute Pres.,
87,4,,,
88,0,,
88,1,,,
;St. Wheel 0, ,
88,2,,,
;0,Count,
88,3,,,
88,4,,,
;0.0,(no units),
89,0,,
89,1,,,
;not available, ,
89,2,,,
;not available, ,
89,3,,,
;not available, ,
89,4,,,
;not available, ,
90,0,,
90,1,,,
;Not Installed, ,
90,2,,,
;Not Installed, ,
90,3,,,
;Not Installed, ,
90,4,,,
;Not Installed, ,
91,0,,
91,1,,,
;Not Installed, ,
91,2,,,
;Not Installed, ,
91,3,,,
;Not Installed, ,
91,4,,,
;Not Installed, ,
92,0,,
92,1,,,
;Not Installed, ,
92,2,,,
;Not Installed, ,
92,3,,,
;Not Installed, ,
92,4,,,
93,0,,
93,1,,,
;Not Installed, ,
93,2,,,
;Not Installed, ,
93,3,,,
;Not Installed, ,
93,4,,,
94,0,,
94,1,,,
;Not Installed, ,
94,2,,,
;Not Installed, ,
94,3,,,
;Not Installed, ,
94,4,,,
95,0,,
95,1,,,
;Not Installed, ,
95,2,,,
;Not Installed, ,
95,3,,,
;Not Installed, ,
95,4,,,
96,0,,
96,1,,,
;Not Installed, ,
96,2,,,
;Not Installed, ,
96,3,,,
;Not Installed, ,
96,4,,,
97,0,,
97,1,,,
;Not Installed, ,
97,2,,,
;Not Installed, ,
97,3,,,
;Not Installed, ,
97,4,,,
98,0,,
98,1,,,
;Not Installed, ,
98,2,,,
;Not Installed, ,
98,3,,,
;Not Installed, ,
98,4,,,
99,0,,
99,1,,,
;Not Installed, ,
99,2,,,
;Not Installed, ,
99,3,,,
;Not Installed, ,
99,4,,,
100,0,,
100,1,,,
;_*__84_______0__0____1_*A*_____00000___ , ,
101,0,,
101,1,,,
;0___84_______0__0____1_*A*_____00000___ , ,
102,0,,
102,1,,,
;1___72_______0__0____0_*A*_____11000___ , ,
103,0,,
103,1,,,
;not available, ,
103,2,,,
103,3,,,
103,4,,,
104,0,,
104,1,,,
;2*__84_______0__0____1_*A*_____00000___ , ,
105,0,,
105,1,,,
;not available, ,
105,2,,,
105,3,,,
105,4,,,
106,0,,
106,1,,,
;3__22,0______0__0____0_*A*_____00000___ , ,
107,0,,
107,1,,,
;not available, ,
107,2,,,
107,3,,,
107,4,,,
108,0,,
108,1,,,
;4__22,0______0__0____0_*A*_____00000___ , ,
109,0,,
109,1,,,
;not available, ,
109,2,,,
109,3,,,
109,4,,,
110,0,,
110,1,,,
110,2,,,
110,3,,,
;11001000,Bin. Bits,
110,4,,,
;10000010,Bin. Bits,
111,0,,
111,1,,,
;not available, ,
111,2,,,
;not available, ,
111,3,,,
;not available, ,
111,4,,,
112,0,,
112,1,,,
;44.5 %,Load,
112,2,,,
;2.00,(no units),
112,3,,,
112,4,,,
150,0,,
150,1,,,
;0,Count,
150,2,,,
;0.0 %,Load,
150,3,,,
;3,Count,
150,4,,,
151,0,,
151,1,,,
;not available, ,
151,2,,,
;not available, ,
151,3,,,
;not available, ,
151,4,,,
152,0,,
152,1,,,
;not available, ,
152,2,,,
;not available, ,
152,3,,,
;not available, ,
152,4,,,
;not available, ,
153,0,,
153,1,,,
;not available, ,
153,2,,,
;not available, ,
153,3,,,
153,4,,,
154,0,,
154,1,,,
;55.76, ,
154,2,,,
;50.46, ,
154,3,,,
;-5.30, ,
154,4,,,
;0.00, ,
155,0,,
155,1,,,
;14.0°C,Temperature,
155,2,,,
155,3,,,
;44.0 %,Load,
155,4,,,
156,0,,
156,1,,,
;not available, ,
156,2,,,
;not available, ,
156,3,,,
;not available, ,
156,4,,,
;not available, ,
157,0,,
157,1,,,
;OFF, ,
157,2,,,
;OFF, ,
157,3,,,
157,4,,,
158,0,,
158,1,,,
;0,Count,
158,2,,,
;0,Count,
158,3,,,
;OFF, ,
158,4,,,
;OFF, ,
159,0,,
159,1,,,
;11016,Count,
159,2,,,
;39,Count,
159,3,,,
159,4,,,
204,0,,
204,1,,,
204,2,,,
204,3,,,
204,4,,,
;N/A,,
227,0,,
227,1,,,
227,2,,,
227,3,,,
227,4,,,
;N/A,,
228,0,,
228,1,,,
228,2,,,
228,3,,,
228,4,,,
;N/A,,
229,0,,
229,1,,,
229,2,,,
229,3,,,
229,4,,,
;N/A,,
231,0,,
231,1,,,
231,2,,,
231,3,,,
231,4,,,
;N/A,,
233,0,,
233,1,,,
233,2,,,
233,3,,,
233,4,,,
;N/A,,
235,0,,
235,1,,,
235,2,,,
235,3,,,
235,4,,,
;N/A,,
;SW:4H0-907-063-EK   HW:4H0-907-063-EK ---  Cent. Elect.
;Component:BCM1 2.0      H20 0367, Coding:00E9009040208F202D01C8C3002028000A1C47C8220602E10000081C0440100000400034010000
;Sunday,17,May,2020,19:35:23:06485
;VCID: 75A2E303DCD8632E28-8020
A01,0,
A01,1,
;ERROR:
A01,2,
;Security
A01,3,
;access
A01,4,
;required
A02,0,
A02,1,
;ERROR:
A02,2,
;Security
A02,3,
;access
A02,4,
;required
A03,0,
A03,1,
;ERROR:
A03,2,
;Security
A03,3,
;access
A03,4,
;required
A04,0,
A04,1,
;ERROR:
A04,2,
;Security
A04,3,
;access
A04,4,
;required
A05,0,
A05,1,
;ERROR:
A05,2,
;Security
A05,3,
;access
A05,4,
;required
A06,0,
A06,1,
;ERROR:
A06,2,
;Security
A06,3,
;access
A06,4,
;required
A07,0,
A07,1,
;ERROR:
A07,2,
;Security
A07,3,
;access
A07,4,
;required
A08,0,
A08,1,
;ERROR:
A08,2,
;Security
A08,3,
;access
A08,4,
;required
A09,0,
A09,1,
;ERROR:
A09,2,
;Security
A09,3,
;access
A09,4,
;required
A10,0,
A10,1,
;ERROR:
A10,2,
;Security
A10,3,
;access
A10,4,
;required
A11,0,
A11,1,
;ERROR:
A11,2,
;Security
A11,3,
;access
A11,4,
;required
A12,0,
A12,1,
;ERROR:
A12,2,
;Security
A12,3,
;access
A12,4,
;required
A13,0,
A13,1,
;ERROR:
A13,2,
;Security
A13,3,
;access
A13,4,
;required
A14,0,
A14,1,
;ERROR:
A14,2,
;Security
A14,3,
;access
A14,4,
;required
A15,0,
A15,1,
;ERROR:
A15,2,
;Security
A15,3,
;access
A15,4,
;required
A16,0,
A16,1,
;ERROR:
A16,2,
;Security
A16,3,
;access
A16,4,
;required
A17,0,
A17,1,
;ERROR:
A17,2,
;Security
A17,3,
;access
A17,4,
;required
A18,0,
A18,1,
;ERROR:
A18,2,
;Security
A18,3,
;access
A18,4,
;required
A19,0,
A19,1,
;ERROR:
A19,2,
;Security
A19,3,
;access
A19,4,
;required
A20,0,
A20,1,
;ERROR:
A20,2,
;Security
A20,3,
;access
A20,4,
;required
A21,0,
A21,1,
;ERROR:
A21,2,
;Security
A21,3,
;access
A21,4,
;required
A22,0,
A22,1,
;ERROR:
A22,2,
;Security
A22,3,
;access
A22,4,
;required
A23,0,
A23,1,
;ERROR:
A23,2,
;Security
A23,3,
;access
A23,4,
;required
A24,0,
A24,1,
;ERROR:
A24,2,
;Security
A24,3,
;access
A24,4,
;required
A25,0,
A25,1,
;ERROR:
A25,2,
;Security
A25,3,
;access
A25,4,
;required
A26,0,
A26,1,
;ERROR:
A26,2,
;Security
A26,3,
;access
A26,4,
;required
A27,0,
A27,1,
;ERROR:
A27,2,
;Security
A27,3,
;access
A27,4,
;required
A28,0,
A28,1,
;ERROR:
A28,2,
;Security
A28,3,
;access
A28,4,
;required
A29,0,
A29,1,
;ERROR:
A29,2,
;Security
A29,3,
;access
A29,4,
;required
A30,0,
A30,1,
;ERROR:
A30,2,
;Security
A30,3,
;access
A30,4,
;required
A31,0,
A31,1,
;ERROR:
A31,2,
;Security
A31,3,
;access
A31,4,
;required
A32,0,
A32,1,
;ERROR:
A32,2,
;Security
A32,3,
;access
A32,4,
;required
A33,0,
A33,1,
;ERROR:
A33,2,
;Security
A33,3,
;access
A33,4,
;required
A34,0,
A34,1,
;ERROR:
A34,2,
;Security
A34,3,
;access
A34,4,
;required
A35,0,
A35,1,
;ERROR:
A35,2,
;Security
A35,3,
;access
A35,4,
;required
A36,0,
A36,1,
;ERROR:
A36,2,
;Security
A36,3,
;access
A36,4,
;required
A37,0,
A37,1,
;ERROR:
A37,2,
;Security
A37,3,
;access
A37,4,
;required
A38,0,
A38,1,
;ERROR:
A38,2,
;Security
A38,3,
;access
A38,4,
;required
A39,0,
A39,1,
;ERROR:
A39,2,
;Security
A39,3,
;access
A39,4,
;required
A40,0,
A40,1,
;ERROR:
A40,2,
;Security
A40,3,
;access
A40,4,
;required
A41,0,
A41,1,
;ERROR:
A41,2,
;Security
A41,3,
;access
A41,4,
;required
A42,0,
A42,1,
;ERROR:
A42,2,
;Security
A42,3,
;access
A42,4,
;required
A43,0,
A43,1,
;ERROR:
A43,2,
;Security
A43,3,
;access
A43,4,
;required
A44,0,
A44,1,
;ERROR:
A44,2,
;Security
A44,3,
;access
A44,4,
;required
A45,0,
A45,1,
;ERROR:
A45,2,
;Security
A45,3,
;access
A45,4,
;required
A46,0,
A46,1,
;ERROR:
A46,2,
;Security
A46,3,
;access
A46,4,
;required
A47,0,
A47,1,
;ERROR:
A47,2,
;Security
A47,3,
;access
A47,4,
;required
A48,0,
A48,1,
;ERROR:
A48,2,
;Security
A48,3,
;access
A48,4,
;required
A49,0,
A49,1,
;ERROR:
A49,2,
;Security
A49,3,
;access
A49,4,
;required
A50,0,
A50,1,
;ERROR:
A50,2,
;Security
A50,3,
;access
A50,4,
;required
A51,0,
A51,1,
;ERROR:
A51,2,
;Security
A51,3,
;access
A51,4,
;required
A52,0,
A52,1,
;ERROR:
A52,2,
;Security
A52,3,
;access
A52,4,
;required
A53,0,
A53,1,
;ERROR:
A53,2,
;Security
A53,3,
;access
A53,4,
;required
A54,0,
A54,1,
;ERROR:
A54,2,
;Security
A54,3,
;access
A54,4,
;required
A55,0,
A55,1,
;ERROR:
A55,2,
;Security
A55,3,
;access
A55,4,
;required
A56,0,
A56,1,
;ERROR:
A56,2,
;Security
A56,3,
;access
A56,4,
;required
A57,0,
A57,1,
;ERROR:
A57,2,
;Security
A57,3,
;access
A57,4,
;required
A58,0,
A58,1,
;ERROR:
A58,2,
;Security
A58,3,
;access
A58,4,
;required
A59,0,
A59,1,
;ERROR:
A59,2,
;Security
A59,3,
;access
A59,4,
;required
A60,0,
A60,1,
;ERROR:
A60,2,
;Security
A60,3,
;access
A60,4,
;required
A61,0,
A61,1,
;ERROR:
A61,2,
;Security
A61,3,
;access
A61,4,
;required
A62,0,
A62,1,
;ERROR:
A62,2,
;Security
A62,3,
;access
A62,4,
;required
A63,0,
A63,1,
;ERROR:
A63,2,
;Security
A63,3,
;access
A63,4,
;required
A64,0,
A64,1,
;ERROR:
A64,2,
;Security
A64,3,
;access
A64,4,
;required
A65,0,
A65,1,
;ERROR:
A65,2,
;Security
A65,3,
;access
A65,4,
;required
A66,0,
A66,1,
;ERROR:
A66,2,
;Security
A66,3,
;access
A66,4,
;required
A67,0,
A67,1,
;ERROR:
A67,2,
;Security
A67,3,
;access
A67,4,
;required
A68,0,
A68,1,
;ERROR:
A68,2,
;Security
A68,3,
;access
A68,4,
;required
A69,0,
A69,1,
;ERROR:
A69,2,
;Security
A69,3,
;access
A69,4,
;required
A70,0,
A70,1,
;ERROR:
A70,2,
;Security
A70,3,
;access
A70,4,
;required
A71,0,
A71,1,
;ERROR:
A71,2,
;Security
A71,3,
;access
A71,4,
;required
A72,0,
A72,1,
;ERROR:
A72,2,
;Security
A72,3,
;access
A72,4,
;required
A73,0,
A73,1,
;ERROR:
A73,2,
;Security
A73,3,
;access
A73,4,
;required
A74,0,
A74,1,
;ERROR:
A74,2,
;Security
A74,3,
;access
A74,4,
;required
A75,0,
A75,1,
;ERROR:
A75,2,
;Security
A75,3,
;access
A75,4,
;required
A76,0,
A76,1,
;ERROR:
A76,2,
;Security
A76,3,
;access
A76,4,
;required
A77,0,
A77,1,
;ERROR:
A77,2,
;Security
A77,3,
;access
A77,4,
;required
A78,0,
A78,1,
;ERROR:
A78,2,
;Security
A78,3,
;access
A78,4,
;required
A79,0,
A79,1,
;ERROR:
A79,2,
;Security
A79,3,
;access
A79,4,
;required
A80,0,
A80,1,
;ERROR:
A80,2,
;Security
A80,3,
;access
A80,4,
;required
A81,0,
A81,1,
;ERROR:
A81,2,
;Security
A81,3,
;access
A81,4,
;required
A82,0,
A82,1,
;ERROR:
A82,2,
;Security
A82,3,
;access
A82,4,
;required
A83,0,
A83,1,
;ERROR:
A83,2,
;Security
A83,3,
;access
A83,4,
;required
A84,0,
A84,1,
;ERROR:
A84,2,
;Security
A84,3,
;access
A84,4,
;required
A85,0,
A85,1,
;ERROR:
A85,2,
;Security
A85,3,
;access
A85,4,
;required
A86,0,
A86,1,
;ERROR:
A86,2,
;Security
A86,3,
;access
A86,4,
;required
A87,0,
A87,1,
;ERROR:
A87,2,
;Security
A87,3,
;access
A87,4,
;required
A88,0,
A88,1,
;ERROR:
A88,2,
;Security
A88,3,
;access
A88,4,
;required
A89,0,
A89,1,
;ERROR:
A89,2,
;Security
A89,3,
;access
A89,4,
;required
A90,0,
A90,1,
;ERROR:
A90,2,
;Security
A90,3,
;access
A90,4,
;required
A91,0,
A91,1,
;ERROR:
A91,2,
;Security
A91,3,
;access
A91,4,
;required
A92,0,
A92,1,
;ERROR:
A92,2,
;Security
A92,3,
;access
A92,4,
;required
A93,0,
A93,1,
;ERROR:
A93,2,
;Security
A93,3,
;access
A93,4,
;required
A94,0,
A94,1,
;ERROR:
A94,2,
;Security
A94,3,
;access
A94,4,
;required
A95,0,
A95,1,
;ERROR:
A95,2,
;Security
A95,3,
;access
A95,4,
;required
A96,0,
A96,1,
;ERROR:
A96,2,
;Security
A96,3,
;access
A96,4,
;required
A97,0,
A97,1,
;ERROR:
A97,2,
;Security
A97,3,
;access
A97,4,
;required
A98,0,
A98,1,
;ERROR:
A98,2,
;Security
A98,3,
;access
A98,4,
;required
A99,0,
A99,1,
;ERROR:
A99,2,
;Security
A99,3,
;access
A99,4,
;required
A100,0,
A100,1,
;ERROR:
A100,2,
;Security
A100,3,
;access
A100,4,
;required
A101,0,
A101,1,
;ERROR:
A101,2,
;Security
A101,3,
;access
A101,4,
;required
A102,0,
A102,1,
;ERROR:
A102,2,
;Security
A102,3,
;access
A102,4,
;required
A103,0,
A103,1,
;ERROR:
A103,2,
;Security
A103,3,
;access
A103,4,
;required
A104,0,
A104,1,
;ERROR:
A104,2,
;Security
A104,3,
;access
A104,4,
;required
A105,0,
A105,1,
;ERROR:
A105,2,
;Security
A105,3,
;access
A105,4,
;required
A106,0,
A106,1,
;ERROR:
A106,2,
;Security
A106,3,
;access
A106,4,
;required
A107,0,
A107,1,
;ERROR:
A107,2,
;Security
A107,3,
;access
A107,4,
;required
A108,0,
A108,1,
;ERROR:
A108,2,
;Security
A108,3,
;access
A108,4,
;required
A109,0,
A109,1,
;ERROR:
A109,2,
;Security
A109,3,
;access
A109,4,
;required
A110,0,
A110,1,
;ERROR:
A110,2,
;Security
A110,3,
;access
A110,4,
;required
A111,0,
A111,1,
;ERROR:
A111,2,
;Security
A111,3,
;access
A111,4,
;required
A112,0,
A112,1,
;ERROR:
A112,2,
;Security
A112,3,
;access
A112,4,
;required
A113,0,
A113,1,
;ERROR:
A113,2,
;Security
A113,3,
;access
A113,4,
;required
A114,0,
A114,1,
;ERROR:
A114,2,
;Security
A114,3,
;access
A114,4,
;required
A115,0,
A115,1,
;ERROR:
A115,2,
;Security
A115,3,
;access
A115,4,
;required
A116,0,
A116,1,
;ERROR:
A116,2,
;Security
A116,3,
;access
A116,4,
;required
A117,0,
A117,1,
;ERROR:
A117,2,
;Security
A117,3,
;access
A117,4,
;required
A118,0,
A118,1,
;ERROR:
A118,2,
;Security
A118,3,
;access
A118,4,
;required
A119,0,
A119,1,
;ERROR:
A119,2,
;Security
A119,3,
;access
A119,4,
;required
A120,0,
A120,1,
;ERROR:
A120,2,
;Security
A120,3,
;access
A120,4,
;required
A121,0,
A121,1,
;ERROR:
A121,2,
;Security
A121,3,
;access
A121,4,
;required
A122,0,
A122,1,
;ERROR:
A122,2,
;Security
A122,3,
;access
A122,4,
;required
A123,0,
A123,1,
;ERROR:
A123,2,
;Security
A123,3,
;access
A123,4,
;required
A124,0,
A124,1,
;ERROR:
A124,2,
;Security
A124,3,
;access
A124,4,
;required
A125,0,
A125,1,
;ERROR:
A125,2,
;Security
A125,3,
;access
A125,4,
;required
A126,0,
A126,1,
;ERROR:
A126,2,
;Security
A126,3,
;access
A126,4,
;required
A127,0,
A127,1,
;ERROR:
A127,2,
;Security
A127,3,
;access
A127,4,
;required
A128,0,
A128,1,
;ERROR:
A128,2,
;Security
A128,3,
;access
A128,4,
;required
A129,0,
A129,1,
;ERROR:
A129,2,
;Security
A129,3,
;access
A129,4,
;required
A130,0,
A130,1,
;ERROR:
A130,2,
;Security
A130,3,
;access
A130,4,
;required
A131,0,
A131,1,
;ERROR:
A131,2,
;Security
A131,3,
;access
A131,4,
;required
A132,0,
A132,1,
;ERROR:
A132,2,
;Security
A132,3,
;access
A132,4,
;required
A133,0,
A133,1,
;ERROR:
A133,2,
;Security
A133,3,
;access
A133,4,
;required
A134,0,
A134,1,
;ERROR:
A134,2,
;Security
A134,3,
;access
A134,4,
;required
A135,0,
A135,1,
;ERROR:
A135,2,
;Security
A135,3,
;access
A135,4,
;required
A136,0,
A136,1,
;ERROR:
A136,2,
;Security
A136,3,
;access
A136,4,
;required
A137,0,
A137,1,
;ERROR:
A137,2,
;Security
A137,3,
;access
A137,4,
;required
A138,0,
A138,1,
;ERROR:
A138,2,
;Security
A138,3,
;access
A138,4,
;required
A139,0,
A139,1,
;ERROR:
A139,2,
;Security
A139,3,
;access
A139,4,
;required
A140,0,
A140,1,
;ERROR:
A140,2,
;Security
A140,3,
;access
A140,4,
;required
;141 N/A
A142,0,
A142,1,
;ERROR:
A142,2,
;Security
A142,3,
;access
A142,4,
;required
A143,0,
A143,1,
;ERROR:
A143,2,
;Security
A143,3,
;access
A143,4,
;required
A144,0,
A144,1,
;ERROR:
A144,2,
;Security
A144,3,
;access
A144,4,
;required
A145,0,
A145,1,
;ERROR:
A145,2,
;Security
A145,3,
;access
A145,4,
;required
A146,0,
A146,1,
;ERROR:
A146,2,
;Security
A146,3,
;access
A146,4,
;required
A147,0,
A147,1,
;ERROR:
A147,2,
;Security
A147,3,
;access
A147,4,
;required
A148,0,
A148,1,
;ERROR:
A148,2,
;Security
A148,3,
;access
A148,4,
;required
A149,0,
A149,1,
;ERROR:
A149,2,
;Security
A149,3,
;access
A149,4,
;required
A150,0,
A150,1,
;ERROR:
A150,2,
;Security
A150,3,
;access
A150,4,
;required
A151,0,
A151,1,
;ERROR:
A151,2,
;Security
A151,3,
;access
A151,4,
;required
A152,0,
A152,1,
;ERROR:
A152,2,
;Security
A152,3,
;access
A152,4,
;required
A153,0,
A153,1,
;ERROR:
A153,2,
;Security
A153,3,
;access
A153,4,
;required
A154,0,
A154,1,
;ERROR:
A154,2,
;Security
A154,3,
;access
A154,4,
;required
A155,0,
A155,1,
;ERROR:
A155,2,
;Security
A155,3,
;access
A155,4,
;required
A156,0,
A156,1,
;ERROR:
A156,2,
;Security
A156,3,
;access
A156,4,
;required
A157,0,
A157,1,
;ERROR:
A157,2,
;Security
A157,3,
;access
A157,4,
;required
A158,0,
A158,1,
;ERROR:
A158,2,
;Security
A158,3,
;access
A158,4,
;required
A159,0,
A159,1,
;ERROR:
A159,2,
;Security
A159,3,
;access
A159,4,
;required
A160,0,
A160,1,
;ERROR:
A160,2,
;Security
A160,3,
;access
A160,4,
;required
A161,0,
A161,1,
;ERROR:
A161,2,
;Security
A161,3,
;access
A161,4,
;required
A162,0,
A162,1,
;ERROR:
A162,2,
;Security
A162,3,
;access
A162,4,
;required
A163,0,
A163,1,
;ERROR:
A163,2,
;Security
A163,3,
;access
A163,4,
;required
A164,0,
A164,1,
;ERROR:
A164,2,
;Security
A164,3,
;access
A164,4,
;required
A165,0,
A165,1,
;ERROR:
A165,2,
;Security
A165,3,
;access
A165,4,
;required
A166,0,
A166,1,
;ERROR:
A166,2,
;Security
A166,3,
;access
A166,4,
;required
A167,0,
A167,1,
;ERROR:
A167,2,
;Security
A167,3,
;access
A167,4,
;required
A168,0,
A168,1,
;ERROR:
A168,2,
;Security
A168,3,
;access
A168,4,
;required
A169,0,
A169,1,
;ERROR:
A169,2,
;Security
A169,3,
;access
A169,4,
;required
A170,0,
A170,1,
;ERROR:
A170,2,
;Security
A170,3,
;access
A170,4,
;required
A171,0,
A171,1,
;ERROR:
A171,2,
;Security
A171,3,
;access
A171,4,
;required
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
A186,0,
A186,1,
;ERROR:
A186,2,
;Security
A186,3,
;access
A186,4,
;required
;187 N/A
;188 N/A
;189 N/A
A190,0,
;0
A190,1,
;N/A
A190,2,
;N/A
A190,3,
;N/A
A190,4,
;N/A
A191,0,
;0
A191,1,
;N/A
A191,2,
;N/A
A191,3,
;N/A
A191,4,
;N/A
A192,0,
;0
A192,1,
;N/A
A192,2,
;N/A
A192,3,
;N/A
A192,4,
;N/A
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
A224,0,
;1
A224,1,
;N/A
A224,2,
;N/A
A224,3,
;N/A
A224,4,
;N/A
;225 N/A
;226 N/A
A227,0,
;1
A227,1,
;N/A
A227,2,
;N/A
A227,3,
;N/A
A227,4,
;N/A
A228,0,
;1
A228,1,
;N/A
A228,2,
;N/A
A228,3,
;N/A
A228,4,
;N/A
A229,0,
;4
A229,1,
;N/A
A229,2,
;N/A
A229,3,
;N/A
A229,4,
;N/A
A230,0,
;4
A230,1,
;N/A
A230,2,
;N/A
A230,3,
;N/A
A230,4,
;N/A
A231,0,
;4
A231,1,
;N/A
A231,2,
;N/A
A231,3,
;N/A
A231,4,
;N/A
A232,0,
;6
A232,1,
;N/A
A232,2,
;N/A
A232,3,
;N/A
A232,4,
;N/A
A233,0,
;10
A233,1,
;N/A
A233,2,
;N/A
A233,3,
;N/A
A233,4,
;N/A
;234 N/A
;235 N/A
A236,0,
;0
A236,1,
;N/A
A236,2,
;N/A
A236,3,
;N/A
A236,4,
;N/A
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
A244,0,
A244,1,
;ERROR:
A244,2,
;Security
A244,3,
;access
A244,4,
;required
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
A250,0,
A250,1,
;ERROR:
A250,2,
;Security
A250,3,
;access
A250,4,
;required
;251 N/A
;252 N/A
;253 N/A
A254,0,
A254,1,
;ERROR:
A254,2,
;Security
A254,3,
;access
A254,4,
;required
A255,0,
A255,1,
;ERROR:
A255,2,
;Security
A255,3,
;access
A255,4,
;required
;Sunday,17,May,2020,19:34:47:06485
1,0,,
1,1,,,
;11.80 V,,
1,2,,,
;11.70 V,,
1,3,,,
1,4,,,
2,0,,
2,1,,,
;11.80 V,,
2,2,,,
;11.80 V,,
2,3,,,
;11.70 V,,
2,4,,,
3,0,,
3,1,,,
;Inactive,,
3,2,,,
;Inactive,,
3,3,,,
;Inactive,,
3,4,,,
;N/A,,
4,0,,
4,1,,,
;ON,,
4,2,,,
;ON,,
4,3,,,
;ON,,
4,4,,,
;7.10 V,,
5,0,,
5,1,,,
;100.0 %,,
5,2,,,
5,3,,,
5,4,,,
6,0,,
6,1,,,
;Not Oper.,,
6,2,,,
;0.0,,
6,3,,,
;0.0,,
6,4,,,
7,0,,
7,1,,,
;center,,
7,2,,,
;2.0,,
7,3,,,
;Not Oper.,,
7,4,,,
;Not Oper.,,
8,0,,
8,1,,,
;10.0 %,,
8,2,,,
8,3,,,
;Not Oper.,,
8,4,,,
;2.0,,
9,0,,
9,1,,,
;100.0 %,,
9,2,,,
;100.0 %,,
9,3,,,
;100.0 %,,
9,4,,,
;100.0 %,,
10,0,,
10,1,,,
;0.0 %,,
10,2,,,
;0.0 %,,
10,3,,,
10,4,,,
11,0,,
11,1,,,
11,2,,,
11,3,,,
;100.0 %,,
11,4,,,
;100.0 %,,
12,0,,
12,1,,,
;47.0 %,,
12,2,,,
;47.0 %,,
12,3,,,
;177.0,,
12,4,,,
;67.0,,
13,0,,
13,1,,,
;OFF,,
13,2,,,
;Not Oper.,,
13,3,,,
;0.0 %,,
13,4,,,
;0.0 %,,
14,0,,
14,1,,,
;28.0 %,,
14,2,,,
;28.0 %,,
14,3,,,
;100.0 %,,
14,4,,,
;100.0 %,,
15,0,,
15,1,,,
;OFF,,
15,2,,,
15,3,,,
15,4,,,
16,0,,
16,1,,,
;100.0 %,,
16,2,,,
16,3,,,
;100.0 %,,
16,4,,,
;11.0 %,,
17,0,,
17,1,,,
17,2,,,
17,3,,,
17,4,,,
18,0,,
18,1,,,
;OFF,,
18,2,,,
;0x0001,,
18,3,,,
;3.900 A,,
18,4,,,
19,0,,
19,1,,,
;OFF,,
19,2,,,
;383.0,,
19,3,,,
;not Active,,
19,4,,,
;OFF,,
20,0,,
20,1,,,
;ON,,
20,2,,,
;ON,,
20,3,,,
;0.00 km/h,,
20,4,,,
;Closed,,
21,0,,
21,1,,,
;Not Installed,,
21,2,,,
;ON,,
21,3,,,
;Inactive,,
21,4,,,
22,0,,
22,1,,,
;OFF,,
22,2,,,
;Inactive,,
22,3,,,
;1.0,,
22,4,,,
;59.0,,
23,0,,
23,1,,,
;7.43 bar,,
23,2,,,
23,3,,,
;0x0068,,
23,4,,,
;0x0002,,
24,0,,
24,1,,,
24,2,,,
;0x0005,,
24,3,,,
;Not Oper.,,
24,4,,,
;6.0,,
25,0,,
25,1,,,
;Not Oper.,,
25,2,,,
;OFF,,
25,3,,,
25,4,,,
26,0,,
26,1,,,
;0.0,,
26,2,,,
;Not Oper.,,
26,3,,,
26,4,,,
;Not Oper.,,
27,0,,
27,1,,,
27,2,,,
;0x0000,,
27,3,,,
;Not Oper.,,
27,4,,,
;Full,,
28,0,,
28,1,,,
;Full,,
28,2,,,
;Not Oper.,,
28,3,,,
;Inactive,,
28,4,,,
;Inactive,,
29,0,,
29,1,,,
;23.5°C,,
29,2,,,
;0.00 kOhm,,
29,3,,,
;0.00 kOhm,,
29,4,,,
;53.0 %,,
30,0,,
30,1,,,
30,2,,,
30,3,,,
30,4,,,
31,0,,
31,1,,,
;Closed,,
31,2,,,
31,3,,,
31,4,,,
32,0,,
32,1,,,
;Inactive,,
32,2,,,
;Inactive,,
32,3,,,
32,4,,,
33,0,,
33,1,,,
33,2,,,
;0.0 %,,
33,3,,,
;0.0 %,,
33,4,,,
34,0,,
34,1,,,
;OFF,,
34,2,,,
;0.0 mA,,
34,3,,,
;0.0 %,,
34,4,,,
37,0,,
37,1,,,
;OFF,,
37,2,,,
;0.000 A,,
37,3,,,
;0.000 A,,
37,4,,,
38,0,,
38,1,,,
38,2,,,
38,3,,,
38,4,,,
39,0,,
39,1,,,
39,2,,,
39,3,,,
39,4,,,
40,0,,
40,1,,,
;normal,,
40,2,,,
;normal,,
40,3,,,
;normal,,
40,4,,,
;normal,,
41,0,,
41,1,,,
;1.0,,
41,2,,,
;Not Oper.,,
41,3,,,
;0.0 %,,
41,4,,,
;0.0 %,,
42,0,,
42,1,,,
;1116h,,
43,0,,
43,1,,,
;29.0 %,,
43,2,,,
;56.0 %,,
43,3,,,
;15.0 %,,
43,4,,,
;0.0 %,,
44,0,,
44,1,,,
;Not Oper.,,
44,2,,,
;Not Oper.,,
44,3,,,
;0.0,,
44,4,,,
;1.0,,
45,0,,
45,1,,,
;0.0,,
45,2,,,
;0.00 km/h,,
45,3,,,
;10.0°,,
45,4,,,
46,0,,
46,1,,,
46,2,,,
46,3,,,
;Not Oper.,,
46,4,,,
;Not Oper.,,
47,0,,
47,1,,,
47,2,,,
47,3,,,
47,4,,,
48,0,,
48,1,,,
;0.0,,
48,2,,,
;0.0,,
48,3,,,
;0.0,,
48,4,,,
;1.0,,
49,0,,
49,1,,,
;0367,,
50,0,,
50,1,,,
;0.00 ms,,
50,2,,,
;6.20 ms,,
50,3,,,
;0.11 ms,,
50,4,,,
;0.02 ms,,
51,0,,
51,1,,,
;3240.0,,
51,2,,,
;0.0,,
51,3,,,
51,4,,,
52,0,,
52,1,,,
;31802-37214-4409-46272,,
53,0,,
53,1,,,
;C7500063 0060,,
54,0,,
54,1,,,
;FBL-Version: 8169.2.0.1,,
55,0,,
55,1,,,
;0.0,,
55,2,,,
55,3,,,
55,4,,,
56,0,,
56,1,,,
;0.0,,
56,2,,,
;0.0,,
56,3,,,
;0.0,,
56,4,,,
57,0,,
57,1,,,
;0.0,,
57,2,,,
;0.0,,
57,3,,,
;5.0,,
57,4,,,
58,0,,
58,1,,,
;0.0,,
58,2,,,
;0.0,,
58,3,,,
58,4,,,
59,0,,
59,1,,,
;OFF,,
59,2,,,
;OFF,,
59,3,,,
59,4,,,
60,0,,
60,1,,,
;0.0°C,,
60,2,,,
;20.5°C,,
60,3,,,
;0.0 A,,
60,4,,,
61,0,,
61,1,,,
;0.0°C,,
61,2,,,
;22.0°C,,
61,3,,,
;0.0 A,,
61,4,,,
62,0,,
62,1,,,
;0.0,,
62,2,,,
;0x0000,,
62,3,,,
;0.0,,
62,4,,,
;0x0000,,
63,0,,
63,1,,,
63,2,,,
63,3,,,
63,4,,,
64,0,,
64,1,,,
64,2,,,
64,3,,,
64,4,,,
65,0,,
65,1,,,
65,2,,,
65,3,,,
65,4,,,
66,0,,
66,1,,,
66,2,,,
66,3,,,
66,4,,,
67,0,,
67,1,,,
67,2,,,
67,3,,,
67,4,,,
68,0,,
68,1,,,
68,2,,,
68,3,,,
68,4,,,
69,0,,
69,1,,,
69,2,,,
69,3,,,
69,4,,,
70,0,,
70,1,,,
70,2,,,
70,3,,,
70,4,,,
71,0,,
71,1,,,
71,2,,,
71,3,,,
71,4,,,
72,0,,
72,1,,,
72,2,,,
72,3,,,
72,4,,,
73,0,,
73,1,,,
;0.0,,
73,2,,,
;0.0,,
73,3,,,
;0.0,,
73,4,,,
;0.0,,
74,0,,
74,1,,,
;0x0003,,
74,2,,,
;0x0003,,
74,3,,,
74,4,,,
75,0,,
75,1,,,
;20.0°C,,
75,2,,,
;64.0,,
75,3,,,
;13.1°C,,
75,4,,,
;20.2°C,,
76,0,,
76,1,,,
;0.0,,
76,2,,,
76,3,,,
76,4,,,
77,0,,
77,1,,,
;14.2°C,,
77,2,,,
;20.8°C,,
77,3,,,
;44.50 %,,
77,4,,,
;0.0,,
78,0,,
78,1,,,
;3.0,,
78,2,,,
;3.0,,
78,3,,,
;27.1°C,,
78,4,,,
;Inactive,,
79,0,,
79,1,,,
79,2,,,
79,3,,,
79,4,,,
80,0,,
80,1,,,
80,2,,,
80,3,,,
80,4,,,
81,0,,
81,1,,,
81,2,,,
81,3,,,
81,4,,,
82,0,,
82,1,,,
82,2,,,
82,3,,,
82,4,,,
83,0,,
83,1,,,
83,2,,,
83,3,,,
83,4,,,
84,0,,
84,1,,,
;0.0,,
84,2,,,
;0.0,,
84,3,,,
;0.0,,
84,4,,,
;0.0,,
85,0,,
85,1,,,
;0.0,,
85,2,,,
;0.0,,
85,3,,,
;5.0,,
85,4,,,
;4.0,,
86,0,,
86,1,,,
;0.0,,
86,2,,,
;0.0,,
86,3,,,
;0.0,,
86,4,,,
;0.0,,
87,0,,
87,1,,,
;0.0,,
87,2,,,
;0.0,,
87,3,,,
;0.0,,
87,4,,,
;0.0,,
88,0,,
88,1,,,
;0.0,,
88,2,,,
;N/A,,
88,3,,,
;N/A,,
88,4,,,
;N/A,,
89,0,,
89,1,,,
;0.0,,
89,2,,,
;0.0,,
89,3,,,
;0.0,,
89,4,,,
;0.0,,
98,0,,
98,1,,,
;0.03 kOhm,,
98,2,,,
;0.00 kOhm,,
98,3,,,
;Closed,,
98,4,,,
;OPEN,,
99,0,,
99,1,,,
;0x0034,,
99,2,,,
;0x0103,,
99,3,,,
;0.0,,
99,4,,,
;0.0,,
100,0,,
100,1,,,
;not available,,
100,2,,,
;not available,,
100,3,,,
;Occupied,,
100,4,,,
;Not Occup.,,
102,0,,
102,1,,,
;Intermed pos.,,
102,2,,,
;Inactive,,
102,3,,,
;Stage 0,,
102,4,,,
;Stage 0,,
103,0,,
103,1,,,
103,2,,,
103,3,,,
103,4,,,
104,0,,
104,1,,,
104,2,,,
104,3,,,
104,4,,,
105,0,,
105,1,,,
105,2,,,
105,3,,,
105,4,,,
106,0,,
106,1,,,
106,2,,,
106,3,,,
106,4,,,
107,0,,
107,1,,,
;Stage 0,,
107,2,,,
;Stage 0,,
107,3,,,
;24.0°C,,
107,4,,,
;25.0°C,,
108,0,,
108,1,,,
;Inactive,,
108,2,,,
108,3,,,
;Inactive,,
108,4,,,
;Inactive,,
109,0,,
109,1,,,
109,2,,,
109,3,,,
109,4,,,
110,0,,
110,1,,,
110,2,,,
110,3,,,
110,4,,,
111,0,,
111,1,,,
111,2,,,
111,3,,,
111,4,,,
112,0,,
112,1,,,
112,2,,,
112,3,,,
112,4,,,
113,0,,
113,1,,,
113,2,,,
113,3,,,
113,4,,,
114,0,,
114,1,,,
114,2,,,
114,3,,,
114,4,,,
115,0,,
115,1,,,
115,2,,,
115,3,,,
115,4,,,
116,0,,
116,1,,,
116,2,,,
116,3,,,
116,4,,,
117,0,,
117,1,,,
117,2,,,
117,3,,,
117,4,,,
120,0,,
120,1,,,
120,2,,,
120,3,,,
120,4,,,
;N/A,,
121,0,,
121,1,,,
121,2,,,
121,3,,,
;0.0,,
121,4,,,
;0.0,,
122,0,,
122,1,,,
;0.0,,
122,2,,,
;0.0,,
122,3,,,
;0.0,,
122,4,,,
;0.0,,
123,0,,
123,1,,,
;0.0,,
123,2,,,
;N/A,,
123,3,,,
;N/A,,
123,4,,,
;N/A,,
125,0,,
125,1,,,
125,2,,,
125,3,,,
125,4,,,
126,0,,
126,1,,,
126,2,,,
126,3,,,
126,4,,,
127,0,,
127,1,,,
127,2,,,
127,3,,,
127,4,,,
128,0,,
128,1,,,
128,2,,,
128,3,,,
128,4,,,
129,0,,
129,1,,,
129,2,,,
129,3,,,
129,4,,,
;N/A,,
132,0,,
132,1,,,
;68.0 %,,
132,2,,,
;60.0 %,,
132,3,,,
;N/A,,
132,4,,,
;N/A,,
133,0,,
133,1,,,
;0,,
133,2,,,
;0,,
133,3,,,
;0,,
133,4,,,
;0,,
134,0,,
134,1,,,
;0,,
134,2,,,
;0,,
134,3,,,
;0,,
134,4,,,
;0,,
135,0,,
135,1,,,
;0,,
135,2,,,
;0,,
135,3,,,
;0,,
135,4,,,
;0,,
136,0,,
136,1,,,
;0,,
136,2,,,
;0,,
136,3,,,
;0,,
136,4,,,
;0,,
137,0,,
137,1,,,
137,2,,,
137,3,,,
137,4,,,
138,0,,
138,1,,,
138,2,,,
138,3,,,
138,4,,,
139,0,,
139,1,,,
139,2,,,
139,3,,,
139,4,,,
140,0,,
140,1,,,
;0.0 V,,
140,2,,,
;not available,,
140,3,,,
;not available,,
140,4,,,
;not available,,
141,0,,
141,1,,,
;not available,,
141,2,,,
;not available,,
141,3,,,
;not available,,
141,4,,,
;not available,,
142,0,,
142,1,,,
;not available,,
142,2,,,
;not available,,
142,3,,,
;not available,,
142,4,,,
;not available,,
143,0,,
143,1,,,
;not available,,
143,2,,,
;not available,,
143,3,,,
;not available,,
143,4,,,
;not available,,
144,0,,
144,1,,,
;not available,,
144,2,,,
;not available,,
144,3,,,
;not available,,
144,4,,,
;not available,,
145,0,,
145,1,,,
;not available,,
145,2,,,
;not available,,
145,3,,,
;not available,,
145,4,,,
;not available,,
146,0,,
146,1,,,
;not available,,
146,2,,,
;not available,,
146,3,,,
;not available,,
146,4,,,
;not available,,
147,0,,
147,1,,,
;not available,,
147,2,,,
;not available,,
147,3,,,
;not available,,
147,4,,,
;not available,,
148,0,,
148,1,,,
;not available,,
148,2,,,
;not available,,
148,3,,,
;not available,,
148,4,,,
;not available,,
149,0,,
149,1,,,
;not available,,
149,2,,,
;not available,,
149,3,,,
;not available,,
149,4,,,
;not available,,
150,0,,
150,1,,,
;not available,,
150,2,,,
;not available,,
150,3,,,
;not available,,
150,4,,,
;ON,,
151,0,,
151,1,,,
;10.9°,,
151,2,,,
;10.9°,,
151,3,,,
;Inactive,,
151,4,,,
;Inactive,,
152,0,,
152,1,,,
;0.0 %,,
152,2,,,
;Inactive,,
152,3,,,
;0.0,,
152,4,,,
;not available,,
153,0,,
153,1,,,
;not available,,
153,2,,,
;not available,,
153,3,,,
;not available,,
153,4,,,
;not available,,
154,0,,
154,1,,,
;not available,,
154,2,,,
;not available,,
154,3,,,
;not available,,
154,4,,,
;not available,,
155,0,,
155,1,,,
;not available,,
155,2,,,
;not available,,
155,3,,,
;not available,,
155,4,,,
;not available,,
156,0,,
156,1,,,
;not available,,
156,2,,,
;not available,,
156,3,,,
;not available,,
156,4,,,
;not available,,
157,0,,
157,1,,,
;not available,,
157,2,,,
;not available,,
157,3,,,
;not available,,
157,4,,,
;not available,,
158,0,,
158,1,,,
;not available,,
158,2,,,
;not available,,
158,3,,,
;not available,,
158,4,,,
;not available,,
159,0,,
159,1,,,
;not available,,
159,2,,,
;not available,,
159,3,,,
;not available,,
159,4,,,
;not available,,
160,0,,
160,1,,,
;255 cm,,
160,2,,,
;255 cm,,
160,3,,,
;not available,,
160,4,,,
;not available,,
161,0,,
161,1,,,
;Reverse: No,,
161,2,,,
;Not Installed,,
161,3,,,
;0x0023,,
161,4,,,
;not available,,
162,0,,
162,1,,,
;65535 cm,,
162,2,,,
;65535 cm,,
162,3,,,
;65535 cm,,
162,4,,,
;65535 cm,,
163,0,,
163,1,,,
;65535 cm,,
163,2,,,
;65535 cm,,
163,3,,,
;65535 cm,,
163,4,,,
;65535 cm,,
164,0,,
164,1,,,
;Not Installed,,
164,2,,,
;Not Installed,,
164,3,,,
;Not Installed,,
164,4,,,
;Not Installed,,
165,0,,
165,1,,,
;0.00 ms,,
165,2,,,
;0.00 ms,,
165,3,,,
;0.00 ms,,
165,4,,,
;0.00 ms,,
166,0,,
166,1,,,
;0.00 ms,,
166,2,,,
;0.00 ms,,
166,3,,,
;0.00 ms,,
166,4,,,
;0.00 ms,,
167,0,,
167,1,,,
;Not Installed,,
167,2,,,
;Not Installed,,
167,3,,,
;Not Installed,,
167,4,,,
;Not Installed,,
168,0,,
168,1,,,
;Stage 6,,
168,2,,,
;Stage 4,,
168,3,,,
;Stage 4,,
168,4,,,
;Stage 6,,
169,0,,
169,1,,,
;OFF,,
169,2,,,
;Not Oper.,,
169,3,,,
;ON,,
169,4,,,
;not available,,
170,0,,
170,1,,,
;Not Installed,,
170,2,,,
;Not Installed,,
170,3,,,
;OPS display,,
170,4,,,
;not available,,
171,0,,
171,1,,,
;No,,
171,2,,,
;not Active,,
171,3,,,
;c.Switchoff,,
171,4,,,
;No,,
172,0,,
172,1,,,
;Not Installed,,
172,2,,,
;Not Installed,,
172,3,,,
;Yes,,
172,4,,,
;OPS display,,
173,0,,
173,1,,,
;not Active,,
173,2,,,
;OPS display,,
173,3,,,
;not available,,
173,4,,,
;not available,,
174,0,,
174,1,,,
;Stage 4,,
174,2,,,
;Stage 4,,
174,3,,,
;Stage 9,,
174,4,,,
;Stage 4,,
175,0,,
175,1,,,
;Active,,
175,2,,,
;OPS display,,
175,3,,,
;not available,,
175,4,,,
;not available,,
176,0,,
176,1,,,
;Stage 4,,
176,2,,,
;Stage 4,,
176,3,,,
;Stage 4,,
176,4,,,
;Stage 6,,
177,0,,
177,1,,,
;not Active,,
177,2,,,
;OPS display,,
177,3,,,
;not available,,
177,4,,,
;not available,,
178,0,,
178,1,,,
;Stage 4,,
178,2,,,
;Stage 4,,
178,3,,,
;Stage 4,,
178,4,,,
;Stage 6,,
179,0,,
179,1,,,
;not Active,,
179,2,,,
;OPS display,,
179,3,,,
;not available,,
179,4,,,
;not available,,
180,0,,
180,1,,,
;Stage 4,,
180,2,,,
;Stage 4,,
180,3,,,
;Stage 4,,
180,4,,,
;Stage 6,,
181,0,,
181,1,,,
;Stage 4,,
181,2,,,
;Stage 4,,
181,3,,,
;Stage 4,,
181,4,,,
;Stage 6,,
182,0,,
182,1,,,
;Not Installed,,
182,2,,,
;24.0°C,,
182,3,,,
;0.0,,
182,4,,,
;not available,,
183,0,,
183,1,,,
;0,,
183,2,,,
;0.0,,
183,3,,,
;0.0,,
183,4,,,
;0:00 h,,
184,0,,
184,1,,,
;0,,
184,2,,,
;0.0,,
184,3,,,
;0.0,,
184,4,,,
;0:00 h,,
185,0,,
185,1,,,
;0,,
185,2,,,
;0.0,,
185,3,,,
;0.0,,
185,4,,,
;0:00 h,,
186,0,,
186,1,,,
;0,,
186,2,,,
;0.0,,
186,3,,,
;0.0,,
186,4,,,
;0:00 h,,
187,0,,
187,1,,,
;0,,
187,2,,,
;0.0,,
187,3,,,
;0.0,,
187,4,,,
;0:00 h,,
188,0,,
188,1,,,
;0,,
188,2,,,
;0.0,,
188,3,,,
;0.0,,
188,4,,,
;0:00 h,,
189,0,,
189,1,,,
;0,,
189,2,,,
;0.0,,
189,3,,,
;0.0,,
189,4,,,
;0:00 h,,
190,0,,
190,1,,,
;0,,
190,2,,,
;0.0,,
190,3,,,
;0.0,,
190,4,,,
;0:00 h,,
191,0,,
191,1,,,
;0,,
191,2,,,
;0.0,,
191,3,,,
;0.0,,
191,4,,,
;0:00 h,,
192,0,,
192,1,,,
;0,,
192,2,,,
;0.0,,
192,3,,,
;0.0,,
192,4,,,
;0:00 h,,
193,0,,
193,1,,,
;Not Installed,,
193,2,,,
;Not Installed,,
193,3,,,
;Not Installed,,
193,4,,,
;Not Installed,,
194,0,,
194,1,,,
;Not Installed,,
194,2,,,
;Not Installed,,
194,3,,,
;Not Installed,,
194,4,,,
;Not Installed,,
195,0,,
195,1,,,
;Not Installed,,
195,2,,,
;Not Installed,,
195,3,,,
;Not Installed,,
195,4,,,
;Not Installed,,
196,0,,
196,1,,,
;Not Installed,,
196,2,,,
;Not Installed,,
196,3,,,
;Not Installed,,
196,4,,,
;Not Installed,,
197,0,,
197,1,,,
;Not Installed,,
197,2,,,
;Not Installed,,
197,3,,,
;Not Installed,,
197,4,,,
;Not Installed,,
198,0,,
198,1,,,
;Not Installed,,
198,2,,,
;Not Installed,,
198,3,,,
;1406,,
198,4,,,
;1406,,
199,0,,
199,1,,,
;Not Installed,,
199,2,,,
;Not Installed,,
199,3,,,
;Not Installed,,
199,4,,,
;Not Installed,,
200,0,,
200,1,,,
200,2,,,
200,3,,,
200,4,,,
201,0,,
201,1,,,
201,2,,,
201,3,,,
201,4,,,
202,0,,
202,1,,,
202,2,,,
202,3,,,
202,4,,,
203,0,,
203,1,,,
203,2,,,
203,3,,,
203,4,,,
204,0,,
204,1,,,
204,2,,,
204,3,,,
204,4,,,
205,0,,
205,1,,,
205,2,,,
205,3,,,
205,4,,,
206,0,,
206,1,,,
206,2,,,
206,3,,,
206,4,,,
207,0,,
207,1,,,
207,2,,,
207,3,,,
207,4,,,
208,0,,
208,1,,,
208,2,,,
208,3,,,
208,4,,,
209,0,,
209,1,,,
209,2,,,
209,3,,,
209,4,,,
210,0,,
210,1,,,
210,2,,,
210,3,,,
210,4,,,
211,0,,
211,1,,,
211,2,,,
211,3,,,
211,4,,,
212,0,,
212,1,,,
212,2,,,
212,3,,,
212,4,,,
213,0,,
213,1,,,
213,2,,,
213,3,,,
213,4,,,
214,0,,
214,1,,,
214,2,,,
214,3,,,
214,4,,,
217,0,,
217,1,,,
217,2,,,
217,3,,,
217,4,,,
218,0,,
218,1,,,
;511,,
218,2,,,
;511,,
218,3,,,
;not available,,
218,4,,,
;0,,
251,0,,
251,1,,,
;0.0,,
251,2,,,
;3240.0,,
251,3,,,
;0.0,,
251,4,,,
;0.0,,
252,0,,
252,1,,,
;15.0,,
252,2,,,
;1.0,,
252,3,,,
;61452.0,,
252,4,,,
;240.0,,
253,0,,
253,1,,,
;0.0,,
253,2,,,
;N/A,,
253,3,,,
;N/A,,
253,4,,,
;N/A,,
;SW:4T0-953-513   HW:4T0-953-513 ---  Steering wheel
;Component:Lenks.Modul   H02 0090, Coding:000000
;Sunday,17,May,2020,19:40:05:06485
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 72A8D81FADB674160D-8026
A01,0,
A01,1,
;ERROR:
A01,2,
;Security
A01,3,
;access
A01,4,
;required
;02 N/A
A03,0,
;2
A03,1,
;Stage 2
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
A04,0,
A04,1,
;ERROR:
A04,2,
;Security
A04,3,
;access
A04,4,
;required
A05,0,
A05,1,
;ERROR:
A05,2,
;Security
A05,3,
;access
A05,4,
;required
A06,0,
A06,1,
;ERROR:
A06,2,
;Security
A06,3,
;access
A06,4,
;required
A07,0,
A07,1,
;ERROR:
A07,2,
;Security
A07,3,
;access
A07,4,
;required
A08,0,
;0
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
;21 N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
;98 N/A
;99 N/A
;100 N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Sunday,17,May,2020,19:39:37:06485
1,0,,
1,1,,,
;Not Oper.,,
1,2,,,
;Not Oper.,,
1,3,,,
;Not Oper.,,
1,4,,,
;Not Oper.,,
2,0,,
2,1,,,
;Stage 2,,
2,2,,,
;Not Oper.,,
2,3,,,
;Not Installed,,
2,4,,,
;Not Installed,,
3,0,,
3,1,,,
;Not Oper.,,
3,2,,,
;Not Oper.,,
3,3,,,
;N/A,,
3,4,,,
;N/A,,
4,0,,
4,1,,,
;Not Installed,,
4,2,,,
;Not Installed,,
4,3,,,
4,4,,,
;Not Installed,,
5,0,,
5,1,,,
;OK,,
5,2,,,
;6.0,,
5,3,,,
;    0010,,
5,4,,,
;No,,
6,0,,
6,1,,,
;0x0000,,
6,2,,,
;0.0,,
6,3,,,
;0x0000,,
6,4,,,
;0.0,,
7,0,,
7,1,,,
;0x0000,,
7,2,,,
;0.0,,
7,3,,,
;0x0000,,
7,4,,,
;0.0,,
8,0,,
8,1,,,
;Not Installed,,
8,2,,,
8,3,,,
8,4,,,
;N/A,,
9,0,,
9,1,,,
;Not Installed,,
9,2,,,
9,3,,,
9,4,,,
10,0,,
10,1,,,
;Not Installed,,
10,2,,,
;N/A,,
10,3,,,
;N/A,,
10,4,,,
;N/A,,
11,0,,
11,1,,,
;40.0 %,,
11,2,,,
;40.0 %,,
11,3,,,
;N/A,,
11,4,,,
;N/A,,
12,0,,
12,1,,,
;Not Installed,,
12,2,,,
12,3,,,
12,4,,,
13,0,,
13,1,,,
;ON,,
13,2,,,
;ON,,
13,3,,,
;ON,,
13,4,,,
;N/A,,
14,0,,
14,1,,,
;11.98 V,,
14,2,,,
;Not Installed,,
14,3,,,
;4.95 V,,
14,4,,,
;Not Installed,,
30,0,,
30,1,,,
;OK,,
30,2,,,
;Not OK,,
30,3,,,
;OK,,
30,4,,,
;OK,,
31,0,,
31,1,,,
;10.89°,,
31,2,,,
;10.76°,,
31,3,,,
;OK,,
31,4,,,
;OK,,
32,0,,
32,1,,,
;SteerAng Init,,
32,2,,,
;calibrated,,
32,3,,,
;calibrated,,
32,4,,,
;Yes,,
33,0,,
33,1,,,
;0.0,,
33,2,,,
;0.0,,
33,3,,,
;9.19°,,
33,4,,,
;0.0°/s,,
34,0,,
34,1,,,
;34303535CBCFCACA3535CBCF34303535,,
35,0,,
35,1,,,
;-1.66°,,
35,2,,,
;2015:10:27,,
35,3,,,
;09:00,,
35,4,,,
;N/A,,
36,0,,
36,1,,,
;0 km,,
36,2,,,
;N/A,,
36,3,,,
;N/A,,
36,4,,,
;N/A,,
37,0,,
37,1,,,
;00000 000 00000,,
37,2,,,
;N/A,,
37,3,,,
;N/A,,
37,4,,,
;N/A,,
48,0,,
48,1,,,
;3.0,,
48,2,,,
;13.0,,
48,3,,,
;0.0,,
48,4,,,
;1.0,,
125,0,,
125,1,,,
;ABS 1,,
125,2,,,
;ABS 1,,
125,3,,,
;Central 1,,
125,4,,,
;N/A,,
126,0,,
126,1,,,
;Gateway 1,,
126,2,,,
;Not Installed,,
126,3,,,
;Not Installed,,
126,4,,,
;Cent. Elect. 1,,
127,0,,
127,1,,,
;Not Installed,,
127,2,,,
;Not Installed,,
127,3,,,
;Not Installed,,
127,4,,,
;Central 1,,
;SW:4T0-920-900-C   HW:4T0-920-900-C ---  Instruments
;Component:KOMBIINSTR.   013 0164, Coding:01F812949BB1C3F0020000
;Sunday,17,May,2020,19:22:37:06485
;VCID: 2F2E116B7E0419FEA2-807A
;01 N/A
A02,0,
;0
A02,1,
A02,2,
A02,3,
A02,4,
A03,0,
;100
A03,1,
;0
A03,2,
;0
A03,3,
;0
A03,4,
;N/A
A04,0,
;240
A04,1,
A04,2,
A04,3,
A04,4,
A05,0,
;120
A05,1,
A05,2,
A05,3,
A05,4,
A06,0,
;25
A06,1,
A06,2,
A06,3,
A06,4,
A07,0,
;20
A07,1,
A07,2,
A07,3,
A07,4,
A08,0,
;1
A08,1,
A08,2,
A08,3,
A08,4,
A09,0,
;3876
A09,1,
;38760 km
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;0
A10,1,
A10,2,
A10,3,
A10,4,
A11,0,
;0
A11,1,
A11,2,
A11,3,
A11,4,
A12,0,
;10
A12,1,
A12,2,
A12,3,
A12,4,
A13,0,
;500
A13,1,
A13,2,
A13,3,
A13,4,
A14,0,
;700
A14,1,
A14,2,
A14,3,
A14,4,
A15,0,
;830
A15,1,
A15,2,
A15,3,
A15,4,
A16,0,
;900
A16,1,
A16,2,
A16,3,
A16,4,
A17,0,
;950
A17,1,
A17,2,
A17,3,
A17,4,
A18,0,
;980
A18,1,
A18,2,
A18,3,
A18,4,
A19,0,
;1000
A19,1,
A19,2,
A19,3,
A19,4,
A20,0,
;1000
A20,1,
A20,2,
A20,3,
A20,4,
A21,0,
;18
A21,1,
;18:52
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
A22,0,
;52
A22,1,
;18:52
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;2012
A23,1,
;2012:01:09
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
;1
A24,1,
;2012:01:09
A24,2,
;N/A
A24,3,
;N/A
A24,4,
;N/A
A25,0,
;9
A25,1,
;2012:01:09
A25,2,
;N/A
A25,3,
;N/A
A25,4,
;N/A
;26 N/A
A27,0,
;5
A27,1,
A27,2,
A27,3,
A27,4,
A28,0,
;83
A28,1,
A28,2,
A28,3,
A28,4,
;29 N/A
;30 N/A
;31 N/A
A32,0,
;0
A32,1,
;0.0 l
A32,2,
;N/A
A32,3,
;N/A
A32,4,
;N/A
A33,0,
;5
A33,1,
A33,2,
A33,3,
A33,4,
A34,0,
;10
A34,1,
A34,2,
A34,3,
A34,4,
A35,0,
;131
A35,1,
A35,2,
A35,3,
A35,4,
A36,0,
;5
A36,1,
A36,2,
A36,3,
A36,4,
A37,0,
;10
A37,1,
A37,2,
A37,3,
A37,4,
A38,0,
;90
A38,1,
A38,2,
A38,3,
A38,4,
A39,0,
;75
A39,1,
A39,2,
A39,3,
A39,4,
A40,0,
;115
A40,1,
A40,2,
A40,3,
A40,4,
A41,0,
;119
A41,1,
A41,2,
A41,3,
A41,4,
A42,0,
;110
A42,1,
A42,2,
A42,3,
A42,4,
A43,0,
;5
A43,1,
A43,2,
A43,3,
A43,4,
A44,0,
;30
A44,1,
A44,2,
A44,3,
A44,4,
A45,0,
;9
A45,1,
A45,2,
A45,3,
A45,4,
A46,0,
;20
A46,1,
A46,2,
A46,3,
A46,4,
A47,0,
;31
A47,1,
A47,2,
A47,3,
A47,4,
A48,0,
;48
A48,1,
A48,2,
A48,3,
A48,4,
A49,0,
;100
A49,1,
A49,2,
A49,3,
A49,4,
A50,0,
;100
A50,1,
A50,2,
A50,3,
A50,4,
A51,0,
;100
A51,1,
A51,2,
A51,3,
A51,4,
A52,0,
;0
A52,1,
;0
A52,2,
;N/A
A52,3,
;N/A
A52,4,
;N/A
A53,0,
;0
A53,1,
;0.0
A53,2,
;N/A
A53,3,
;N/A
A53,4,
;N/A
A54,0,
;0
A54,1,
;0
A54,2,
;N/A
A54,3,
;N/A
A54,4,
;N/A
A55,0,
;2
A55,1,
;2.0
A55,2,
;N/A
A55,3,
;N/A
A55,4,
;N/A
A56,0,
;0
A56,1,
A56,2,
A56,3,
A56,4,
A57,0,
;16587
A57,1,
A57,2,
A57,3,
A57,4,
;58 N/A
;59 N/A
A60,0,
;13312
A60,1,
A60,2,
A60,3,
A60,4,
A61,0,
;5120
A61,1,
A61,2,
A61,3,
A61,4,
A62,0,
;1024
A62,1,
A62,2,
A62,3,
A62,4,
A63,0,
;2048
A63,1,
A63,2,
A63,3,
A63,4,
A64,0,
;1024
A64,1,
A64,2,
A64,3,
A64,4,
A65,0,
;6554
A65,1,
A65,2,
A65,3,
A65,4,
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
A73,0,
;2
A73,1,
;American
A73,2,
;N/A
A73,3,
;N/A
A73,4,
;N/A
A74,0,
;50
A74,1,
A74,2,
A74,3,
A74,4,
A75,0,
;590
A75,1,
A75,2,
A75,3,
A75,4,
;76 N/A
;77 N/A
;78 N/A
;79 N/A
A80,0,
;10
A80,1,
A80,2,
A80,3,
A80,4,
A81,0,
;4
A81,1,
A81,2,
A81,3,
A81,4,
A82,0,
;5
A82,1,
A82,2,
A82,3,
A82,4,
A83,0,
;0
A83,1,
A83,2,
A83,3,
A83,4,
;84 N/A
;85 N/A
A86,0,
;115
A86,1,
A86,2,
A86,3,
A86,4,
A87,0,
;150
A87,1,
A87,2,
A87,3,
A87,4,
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
;96 N/A
;97 N/A
A98,0,
;0
A98,1,
A98,2,
A98,3,
A98,4,
;99 N/A
A100,0,
;123
A100,1,
A100,2,
A100,3,
A100,4,
A101,0,
;321
A101,1,
A101,2,
A101,3,
A101,4,
A102,0,
;444
A102,1,
A102,2,
A102,3,
A102,4,
A103,0,
;555
A103,1,
A103,2,
A103,3,
A103,4,
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
A120,0,
;0
A120,1,
A120,2,
A120,3,
A120,4,
;121 N/A
A122,0,
;0
A122,1,
A122,2,
A122,3,
A122,4,
A123,0,
;0
A123,1,
A123,2,
A123,3,
A123,4,
A124,0,
;0
A124,1,
A124,2,
A124,3,
A124,4,
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
A140,0,
;0
A140,1,
A140,2,
A140,3,
A140,4,
A141,0,
;2
A141,1,
A141,2,
A141,3,
A141,4,
A142,0,
;2
A142,1,
A142,2,
A142,3,
A142,4,
A143,0,
;2
A143,1,
A143,2,
A143,3,
A143,4,
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
A150,0,
;128
A150,1,
A150,2,
A150,3,
A150,4,
A151,0,
;128
A151,1,
A151,2,
A151,3,
A151,4,
A152,0,
;128
A152,1,
A152,2,
A152,3,
A152,4,
A153,0,
;128
A153,1,
A153,2,
A153,3,
A153,4,
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
A160,0,
;3250
A160,1,
A160,2,
A160,3,
A160,4,
A161,0,
;3250
A161,1,
A161,2,
A161,3,
A161,4,
A162,0,
;100
A162,1,
A162,2,
A162,3,
A162,4,
A163,0,
;100
A163,1,
A163,2,
A163,3,
A163,4,
A164,0,
;3250
A164,1,
A164,2,
A164,3,
A164,4,
A165,0,
;3250
A165,1,
A165,2,
A165,3,
A165,4,
A166,0,
;100
A166,1,
A166,2,
A166,3,
A166,4,
A167,0,
;100
A167,1,
A167,2,
A167,3,
A167,4,
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Sunday,17,May,2020,19:22:07:06485
1,0,,
1,1,,,
;0.0 km/h,,
1,2,,,
;0 /min,,
1,3,,,
;Oil Pr. 2 OK,,
1,4,,,
;18:51,,
2,0,,
2,1,,,
;38760 km,,
2,2,,,
;76.8 l,,
2,3,,,
2,4,,,
3,0,,
3,1,,,
;26.0°C,,
3,2,,,
;01:01,,
3,3,,,
3,4,,,
4,0,,
4,1,,,
;9.70 V,,
4,2,,,
;24.0°C,,
4,3,,,
;0.0°C,,
4,4,,,
5,0,,
5,1,,,
;0.0,,
5,2,,,
;2.0,,
5,3,,,
;0,,
5,4,,,
;0,,
6,0,,
6,1,,,
;2012:01:09,,
6,2,,,
6,3,,,
6,4,,,
8,0,,
8,1,,,
;6.4,,
8,2,,,
;60,,
8,3,,,
;18.5,,
8,4,,,
;217,,
9,0,,
9,1,,,
;1.4,,
9,2,,,
;59,,
9,3,,,
;12.7,,
9,4,,,
;341,,
10,0,,
10,1,,,
;39.0°C,,
10,2,,,
10,3,,,
;N/A,,
10,4,,,
;N/A,,
61,0,,
61,1,,,
;     000,,
61,2,,,
61,3,,,
;      00,,
61,4,,,
62,0,,
62,1,,,
;       1,,
62,2,,,
62,3,,,
62,4,,,
90,0,,
90,1,,,
;4.0 %,,
90,2,,,
;226.1 %,,
90,3,,,
;79.7 %,,
90,4,,,
92,0,,
92,1,,,
;77.7 %,,
92,2,,,
;77.7 %,,
92,3,,,
;77.7 %,,
92,4,,,
93,0,,
93,1,,,
;0.0 %,,
93,2,,,
;0.0 %,,
93,3,,,
93,4,,,
95,0,,
95,1,,,
;0,,
95,2,,,
;0,,
95,3,,,
;0,,
95,4,,,
;0,,
96,0,,
96,1,,,
;406,,
96,2,,,
;1211,,
96,3,,,
;404,,
96,4,,,
;1673,,
100,0,,
100,1,,,
;0,,
100,2,,,
;0,,
100,3,,,
;0,,
100,4,,,
;0,,
101,0,,
101,1,,,
;0,,
101,2,,,
;0,,
101,3,,,
;0,,
101,4,,,
;0,,
102,0,,
102,1,,,
;     000,,
102,2,,,
102,3,,,
;0,,
102,4,,,
;0,,
124,0,,
124,1,,,
;00000000 00100000,,
124,2,,,
124,3,,,
124,4,,,
125,0,,
125,1,,,
;Engine 0,,
125,2,,,
;Transm. 0,,
125,3,,,
;ABS 0,,
125,4,,,
;Airbag 0,,
130,0,,
130,1,,,
;       1,,
130,2,,,
130,3,,,
130,4,,,
131,0,,
131,1,,,
;       1,,
131,2,,,
131,3,,,
131,4,,,
202,0,,
202,1,,,
;2157,,
202,2,,,
;2157,,
202,3,,,
202,4,,,
203,0,,
203,1,,,
;0,,
203,2,,,
;0,,
203,3,,,
;0,,
203,4,,,
;0,,
221,0,,
221,1,,,
;0,,
221,2,,,
;0,,
221,3,,,
221,4,,,
222,0,,
222,1,,,
;17,,
222,2,,,
;31,,
222,3,,,
;12,,
222,4,,,
;24,,
240,0,,
240,1,,,
;1,,
240,2,,,
240,3,,,
240,4,,,
252,0,,
252,1,,,
;0,,
252,2,,,
252,3,,,
252,4,,,
253,0,,
253,1,,,
;0,,
253,2,,,
;0,,
253,3,,,
;0,,
253,4,,,
;0,,
;SW:4H0-907-064-GD   HW:4H0-907-064-GD ---  Central Conv.
;Component:BCM2 2.0      H37 0572, Coding:011E029A18F24081A0B0C800008500470000000000000000000000000000
;Sunday,17,May,2020,19:45:37:06485
;VCID: 71AAD713A8B04F0EF4-8024
A01,0,
;53344
A01,1,
;N/A
A01,2,
;N/A
A01,3,
;N/A
A01,4,
;N/A
A02,0,
;36961
A02,1,
;N/A
A02,2,
;N/A
A02,3,
;N/A
A02,4,
;N/A
A03,0,
;36961
A03,1,
;N/A
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
A04,0,
;36961
A04,1,
;N/A
A04,2,
;N/A
A04,3,
;N/A
A04,4,
;N/A
A05,0,
;0
A05,1,
;N/A
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
A06,0,
;0
A06,1,
;N/A
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;0
A07,1,
;N/A
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
A08,0,
;0
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;36961
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;0
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
;11 N/A
;12 N/A
A13,0,
;87
A13,1,
;N/A
A13,2,
;N/A
A13,3,
;N/A
A13,4,
;N/A
A14,0,
;200
A14,1,
;N/A
A14,2,
;N/A
A14,3,
;N/A
A14,4,
;N/A
A15,0,
;200
A15,1,
;N/A
A15,2,
;N/A
A15,3,
;N/A
A15,4,
;N/A
A16,0,
;5
A16,1,
;N/A
A16,2,
;N/A
A16,3,
;N/A
A16,4,
;N/A
;17 N/A
;18 N/A
;19 N/A
;20 N/A
A21,0,
;21
A21,1,
;N/A
A21,2,
;N/A
A21,3,
;N/A
A21,4,
;N/A
;22 N/A
;23 N/A
;24 N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
A30,0,
A30,1,
;ERROR:
A30,2,
;Security
A30,3,
;access
A30,4,
;required
;31 N/A
;32 N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
A60,0,
;15
A60,1,
;N/A
A60,2,
;N/A
A60,3,
;N/A
A60,4,
;N/A
A61,0,
;12288
A61,1,
;N/A
A61,2,
;N/A
A61,3,
;N/A
A61,4,
;N/A
A62,0,
;65535
A62,1,
;N/A
A62,2,
;N/A
A62,3,
;N/A
A62,4,
;N/A
A63,0,
;168
A63,1,
;N/A
A63,2,
;N/A
A63,3,
;N/A
A63,4,
;N/A
A64,0,
;40
A64,1,
;N/A
A64,2,
;N/A
A64,3,
;N/A
A64,4,
;N/A
A65,0,
;63
A65,1,
;N/A
A65,2,
;N/A
A65,3,
;N/A
A65,4,
;N/A
A66,0,
;5
A66,1,
;N/A
A66,2,
;N/A
A66,3,
;N/A
A66,4,
;N/A
A67,0,
;6425
A67,1,
;N/A
A67,2,
;N/A
A67,3,
;N/A
A67,4,
;N/A
A68,0,
A68,1,
;ERROR:
A68,2,
;Security
A68,3,
;access
A68,4,
;required
A69,0,
;0
A69,1,
;N/A
A69,2,
;N/A
A69,3,
;N/A
A69,4,
;N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
;83 N/A
;84 N/A
;85 N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
A95,0,
;3
A95,1,
;N/A
A95,2,
;N/A
A95,3,
;N/A
A95,4,
;N/A
A96,0,
;30
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
A97,0,
;50
A97,1,
;N/A
A97,2,
;N/A
A97,3,
;N/A
A97,4,
;N/A
A98,0,
;1
A98,1,
;N/A
A98,2,
;N/A
A98,3,
;N/A
A98,4,
;N/A
;99 N/A
;100 N/A
;101 N/A
A102,0,
A102,1,
;ERROR:
A102,2,
;Security
A102,3,
;access
A102,4,
;required
A103,0,
;0
A103,1,
;N/A
A103,2,
;N/A
A103,3,
;N/A
A103,4,
;N/A
A104,0,
;190
A104,1,
;N/A
A104,2,
;N/A
A104,3,
;N/A
A104,4,
;N/A
A105,0,
;23
A105,1,
;N/A
A105,2,
;N/A
A105,3,
;N/A
A105,4,
;N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
;112 N/A
;113 N/A
;114 N/A
;115 N/A
;116 N/A
;117 N/A
;118 N/A
;119 N/A
;120 N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
;128 N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
A150,0,
;0
A150,1,
;N/A
A150,2,
;N/A
A150,3,
;N/A
A150,4,
;N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
A179,0,
A179,1,
;ERROR:
A179,2,
;Security
A179,3,
;access
A179,4,
;required
A180,0,
A180,1,
;ERROR:
A180,2,
;Security
A180,3,
;access
A180,4,
;required
A181,0,
A181,1,
;ERROR:
A181,2,
;Security
A181,3,
;access
A181,4,
;required
A182,0,
A182,1,
;ERROR:
A182,2,
;Security
A182,3,
;access
A182,4,
;required
A183,0,
A183,1,
;ERROR:
A183,2,
;Security
A183,3,
;access
A183,4,
;required
A184,0,
A184,1,
;ERROR:
A184,2,
;Security
A184,3,
;access
A184,4,
;required
A185,0,
A185,1,
;ERROR:
A185,2,
;Security
A185,3,
;access
A185,4,
;required
A186,0,
A186,1,
;ERROR:
A186,2,
;Security
A186,3,
;access
A186,4,
;required
A187,0,
A187,1,
;ERROR:
A187,2,
;Security
A187,3,
;access
A187,4,
;required
A188,0,
A188,1,
;ERROR:
A188,2,
;Security
A188,3,
;access
A188,4,
;required
A189,0,
A189,1,
;ERROR:
A189,2,
;Security
A189,3,
;access
A189,4,
;required
A190,0,
A190,1,
;ERROR:
A190,2,
;Security
A190,3,
;access
A190,4,
;required
A191,0,
A191,1,
;ERROR:
A191,2,
;Security
A191,3,
;access
A191,4,
;required
A192,0,
A192,1,
;ERROR:
A192,2,
;Security
A192,3,
;access
A192,4,
;required
A193,0,
A193,1,
;ERROR:
A193,2,
;Security
A193,3,
;access
A193,4,
;required
A194,0,
;7
A194,1,
;N/A
A194,2,
;N/A
A194,3,
;N/A
A194,4,
;N/A
A195,0,
A195,1,
;ERROR:
A195,2,
;Security
A195,3,
;access
A195,4,
;required
A196,0,
A196,1,
;ERROR:
A196,2,
;Security
A196,3,
;access
A196,4,
;required
A197,0,
A197,1,
;ERROR:
A197,2,
;Security
A197,3,
;access
A197,4,
;required
A198,0,
A198,1,
;ERROR:
A198,2,
;Security
A198,3,
;access
A198,4,
;required
A199,0,
A199,1,
;ERROR:
A199,2,
;Security
A199,3,
;access
A199,4,
;required
A200,0,
A200,1,
;ERROR:
A200,2,
;Security
A200,3,
;access
A200,4,
;required
A201,0,
A201,1,
;ERROR:
A201,2,
;Security
A201,3,
;access
A201,4,
;required
A202,0,
A202,1,
;ERROR:
A202,2,
;Security
A202,3,
;access
A202,4,
;required
A203,0,
A203,1,
;ERROR:
A203,2,
;Security
A203,3,
;access
A203,4,
;required
A204,0,
A204,1,
;ERROR:
A204,2,
;Security
A204,3,
;access
A204,4,
;required
A205,0,
A205,1,
;ERROR:
A205,2,
;Security
A205,3,
;access
A205,4,
;required
A206,0,
A206,1,
;ERROR:
A206,2,
;Security
A206,3,
;access
A206,4,
;required
A207,0,
A207,1,
;ERROR:
A207,2,
;Security
A207,3,
;access
A207,4,
;required
A208,0,
A208,1,
;ERROR:
A208,2,
;Security
A208,3,
;access
A208,4,
;required
A209,0,
A209,1,
;ERROR:
A209,2,
;Security
A209,3,
;access
A209,4,
;required
A210,0,
A210,1,
;ERROR:
A210,2,
;Security
A210,3,
;access
A210,4,
;required
A211,0,
A211,1,
;ERROR:
A211,2,
;Security
A211,3,
;access
A211,4,
;required
A212,0,
A212,1,
;ERROR:
A212,2,
;Security
A212,3,
;access
A212,4,
;required
A213,0,
A213,1,
;ERROR:
A213,2,
;Security
A213,3,
;access
A213,4,
;required
A214,0,
A214,1,
;ERROR:
A214,2,
;Security
A214,3,
;access
A214,4,
;required
A215,0,
A215,1,
;ERROR:
A215,2,
;Security
A215,3,
;access
A215,4,
;required
A216,0,
A216,1,
;ERROR:
A216,2,
;Security
A216,3,
;access
A216,4,
;required
A217,0,
A217,1,
;ERROR:
A217,2,
;Security
A217,3,
;access
A217,4,
;required
A218,0,
A218,1,
;ERROR:
A218,2,
;Security
A218,3,
;access
A218,4,
;required
A219,0,
A219,1,
;ERROR:
A219,2,
;Security
A219,3,
;access
A219,4,
;required
A220,0,
A220,1,
;ERROR:
A220,2,
;Security
A220,3,
;access
A220,4,
;required
A221,0,
A221,1,
;ERROR:
A221,2,
;Security
A221,3,
;access
A221,4,
;required
A222,0,
A222,1,
;ERROR:
A222,2,
;Security
A222,3,
;access
A222,4,
;required
A223,0,
A223,1,
;ERROR:
A223,2,
;Security
A223,3,
;access
A223,4,
;required
A224,0,
A224,1,
;ERROR:
A224,2,
;Security
A224,3,
;access
A224,4,
;required
A225,0,
A225,1,
;ERROR:
A225,2,
;Security
A225,3,
;access
A225,4,
;required
A226,0,
A226,1,
;ERROR:
A226,2,
;Security
A226,3,
;access
A226,4,
;required
A227,0,
A227,1,
;ERROR:
A227,2,
;Security
A227,3,
;access
A227,4,
;required
A228,0,
A228,1,
;ERROR:
A228,2,
;Security
A228,3,
;access
A228,4,
;required
A229,0,
A229,1,
;ERROR:
A229,2,
;Security
A229,3,
;access
A229,4,
;required
A230,0,
A230,1,
;ERROR:
A230,2,
;Security
A230,3,
;access
A230,4,
;required
A231,0,
A231,1,
;ERROR:
A231,2,
;Security
A231,3,
;access
A231,4,
;required
A232,0,
A232,1,
;ERROR:
A232,2,
;Security
A232,3,
;access
A232,4,
;required
A233,0,
A233,1,
;ERROR:
A233,2,
;Security
A233,3,
;access
A233,4,
;required
A234,0,
A234,1,
;ERROR:
A234,2,
;Security
A234,3,
;access
A234,4,
;required
A235,0,
A235,1,
;ERROR:
A235,2,
;Security
A235,3,
;access
A235,4,
;required
A236,0,
A236,1,
;ERROR:
A236,2,
;Security
A236,3,
;access
A236,4,
;required
A237,0,
A237,1,
;ERROR:
A237,2,
;Security
A237,3,
;access
A237,4,
;required
A238,0,
A238,1,
;ERROR:
A238,2,
;Security
A238,3,
;access
A238,4,
;required
A239,0,
A239,1,
;ERROR:
A239,2,
;Security
A239,3,
;access
A239,4,
;required
A240,0,
A240,1,
;ERROR:
A240,2,
;Security
A240,3,
;access
A240,4,
;required
A241,0,
A241,1,
;ERROR:
A241,2,
;Security
A241,3,
;access
A241,4,
;required
A242,0,
A242,1,
;ERROR:
A242,2,
;Security
A242,3,
;access
A242,4,
;required
A243,0,
A243,1,
;ERROR:
A243,2,
;Security
A243,3,
;access
A243,4,
;required
A244,0,
A244,1,
;ERROR:
A244,2,
;Security
A244,3,
;access
A244,4,
;required
A245,0,
A245,1,
;ERROR:
A245,2,
;Security
A245,3,
;access
A245,4,
;required
A246,0,
A246,1,
;ERROR:
A246,2,
;Security
A246,3,
;access
A246,4,
;required
A247,0,
A247,1,
;ERROR:
A247,2,
;Security
A247,3,
;access
A247,4,
;required
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Sunday,17,May,2020,19:44:43:06485
1,0,,
1,1,,,
;11.90 V,,
1,2,,,
;11.90 V,,
1,3,,,
;11.90 V,,
1,4,,,
;    0000,,
2,0,,
2,1,,,
;Not Oper.,,
2,2,,,
;Not Oper.,,
2,3,,,
;Not Installed,,
2,4,,,
;OPEN,,
3,0,,
3,1,,,
;Not Installed,,
3,2,,,
;Not Installed,,
3,3,,,
;Not Installed,,
3,4,,,
;Not Installed,,
4,0,,
4,1,,,
4,2,,,
4,3,,,
4,4,,,
;Not Oper.,,
5,0,,
5,1,,,
;Not Installed,,
5,2,,,
;Not Installed,,
5,3,,,
;Not Installed,,
5,4,,,
;Not Installed,,
6,0,,
6,1,,,
;Door Open,,
6,2,,,
;Not Oper.,,
6,3,,,
;Unlocked,,
6,4,,,
;Not Safe,,
7,0,,
7,1,,,
;Door Open,,
7,2,,,
;Not Oper.,,
7,3,,,
;Unlocked,,
7,4,,,
;Not Safe,,
8,0,,
8,1,,,
;Not Installed,,
8,2,,,
;Not Installed,,
8,3,,,
;Not Installed,,
8,4,,,
;Not Installed,,
9,0,,
9,1,,,
;Not Installed,,
9,2,,,
;Not Installed,,
9,3,,,
;Not Installed,,
9,4,,,
;Not Installed,,
10,0,,
10,1,,,
;    0000,,
10,2,,,
;    0000,,
10,3,,,
;    0000,,
10,4,,,
11,0,,
11,1,,,
;0,,
11,2,,,
;0,,
11,3,,,
;Not Installed,,
11,4,,,
;Not Installed,,
12,0,,
12,1,,,
;Not Installed,,
12,2,,,
;Not Installed,,
12,3,,,
;ON,,
12,4,,,
;Not Installed,,
13,0,,
13,1,,,
;Not Installed,,
13,2,,,
;Not Installed,,
13,3,,,
;0.0,,
13,4,,,
;0.0,,
14,0,,
14,1,,,
;0.00 km/h,,
14,2,,,
;Init. value,,
14,3,,,
14,4,,,
15,0,,
15,1,,,
;Not Installed,,
15,2,,,
;Not Installed,,
15,3,,,
;0.000 A,,
15,4,,,
;25.0°C,,
16,0,,
16,1,,,
;Not Installed,,
16,2,,,
;Not Installed,,
16,3,,,
;      00,,
16,4,,,
;OFF,,
17,0,,
17,1,,,
;0.5°,,
17,2,,,
;Inactive,,
17,3,,,
;18.0°,,
17,4,,,
;Inactive,,
18,0,,
18,1,,,
;1.0,,
18,2,,,
;3.0,,
18,3,,,
;3.0,,
18,4,,,
;9.0,,
19,0,,
19,1,,,
;1.0,,
19,2,,,
;1.0,,
19,3,,,
;1.0,,
19,4,,,
;2.0,,
20,0,,
20,1,,,
;Inactive,,
20,2,,,
;Inactive,,
20,3,,,
;Inactive,,
20,4,,,
;      00,,
21,0,,
21,1,,,
;12,,
21,2,,,
;2012:01:01,,
21,3,,,
;0:00 h,,
21,4,,,
22,0,,
22,1,,,
;12,,
22,2,,,
;2012:01:01,,
22,3,,,
;0:00 h,,
22,4,,,
23,0,,
23,1,,,
;12,,
23,2,,,
;2012:01:01,,
23,3,,,
;0:00 h,,
23,4,,,
24,0,,
24,1,,,
;10,,
24,2,,,
;2012:05:04,,
24,3,,,
;9:08 h,,
24,4,,,
25,0,,
25,1,,,
;     000,,
25,2,,,
;      00,,
25,3,,,
;OFF,,
25,4,,,
;OFF,,
26,0,,
26,1,,,
;Not Oper.,,
26,2,,,
;Lid close,,
26,3,,,
;MOST Bus Static,,
26,4,,,
;Not Oper.,,
27,0,,
27,1,,,
;No,,
27,2,,,
;ON,,
27,3,,,
;Not Installed,,
27,4,,,
;    0000,,
28,0,,
28,1,,,
;  001000,,
28,2,,,
;11001100,,
28,3,,,
;11000000,,
28,4,,,
;      01,,
29,0,,
29,1,,,
;Not Installed,,
29,2,,,
;Not Installed,,
29,3,,,
;Not Installed,,
29,4,,,
30,0,,
30,1,,,
;Not Installed,,
30,2,,,
;Not Installed,,
30,3,,,
;Not Installed,,
30,4,,,
;Not Installed,,
31,0,,
31,1,,,
;Not Installed,,
31,2,,,
;Not Installed,,
31,3,,,
;Not Installed,,
31,4,,,
;Not Installed,,
32,0,,
32,1,,,
;Not Installed,,
32,2,,,
;Not Installed,,
32,3,,,
;Not Installed,,
32,4,,,
;Not Installed,,
33,0,,
33,1,,,
;Not Installed,,
33,2,,,
;Not Installed,,
33,3,,,
;Not Installed,,
33,4,,,
;Not Installed,,
34,0,,
34,1,,,
;    0000,,
34,2,,,
;     000,,
34,3,,,
;     101,,
34,4,,,
;   00000,,
35,0,,
35,1,,,
;     000,,
35,2,,,
;29 %,,
35,3,,,
;10000110,,
35,4,,,
;0.0,,
36,0,,
36,1,,,
;Not Installed,,
36,2,,,
;Not Installed,,
36,3,,,
;Not Installed,,
36,4,,,
;Not Installed,,
38,0,,
38,1,,,
38,2,,,
;Not Installed,,
38,3,,,
38,4,,,
39,0,,
39,1,,,
;00000000,,
39,2,,,
;0.0,,
39,3,,,
;0.0,,
39,4,,,
;0.0,,
41,0,,
41,1,,,
;OFF,,
41,2,,,
;OFF,,
41,3,,,
;OFF,,
41,4,,,
;OFF,,
42,0,,
42,1,,,
;      00,,
42,2,,,
;Not Installed,,
42,3,,,
;5.0,,
42,4,,,
;      11,,
43,0,,
43,1,,,
;10100111,,
43,2,,,
;00010000,,
43,3,,,
;00000000,,
43,4,,,
;      01,,
44,0,,
44,1,,,
;      00,,
44,2,,,
;Not Installed,,
44,3,,,
;OFF,,
44,4,,,
;Not Installed,,
45,0,,
45,1,,,
;ON,,
45,2,,,
;OFF,,
45,3,,,
;ON,,
45,4,,,
46,0,,
46,1,,,
;Not Installed,,
46,2,,,
;Not Installed,,
46,3,,,
;     000,,
46,4,,,
;      00,,
47,0,,
47,1,,,
;Not Installed,,
47,2,,,
;Not Installed,,
47,3,,,
;Not Installed,,
47,4,,,
;Not Installed,,
48,0,,
48,1,,,
;3.0,,
48,2,,,
;0.0,,
48,3,,,
;4.0,,
48,4,,,
;0.0,,
50,0,,
50,1,,,
;11,,
50,2,,,
;OPEN,,
50,3,,,
;Unlock,,
50,4,,,
;0,,
51,0,,
51,1,,,
;4,,
51,2,,,
;OPEN,,
51,3,,,
;Single Door,,
51,4,,,
;2,,
52,0,,
52,1,,,
;4,,
52,2,,,
;Closed,,
52,3,,,
;Lock,,
52,4,,,
;2,,
53,0,,
53,1,,,
;4,,
53,2,,,
;Closed,,
53,3,,,
;Lock,,
53,4,,,
;2,,
54,0,,
54,1,,,
;4,,
54,2,,,
;Closed,,
54,3,,,
;Lock,,
54,4,,,
;2,,
55,0,,
55,1,,,
;2012:01:09,,
55,2,,,
;18:51 h,,
55,3,,,
55,4,,,
56,0,,
56,1,,,
;2012:01:09,,
56,2,,,
;18:17 h,,
56,3,,,
56,4,,,
57,0,,
57,1,,,
;2012:01:09,,
57,2,,,
;18:17 h,,
57,3,,,
57,4,,,
58,0,,
58,1,,,
;2012:01:08,,
58,2,,,
;0:22 h,,
58,3,,,
58,4,,,
59,0,,
59,1,,,
;2012:01:08,,
59,2,,,
;0:22 h,,
59,3,,,
59,4,,,
60,0,,
60,1,,,
;0,,
60,2,,,
;   00000,,
60,3,,,
;0,,
60,4,,,
;   00000,,
61,0,,
61,1,,,
;7.0,,
61,2,,,
;  000000,,
61,3,,,
;10000110,,
61,4,,,
;10000110,,
62,0,,
62,1,,,
;Not Installed,,
62,2,,,
;Not Installed,,
62,3,,,
;Not Installed,,
62,4,,,
;Not Installed,,
63,0,,
63,1,,,
;Not Installed,,
63,2,,,
;Not Installed,,
63,3,,,
;Not Installed,,
63,4,,,
;Not Installed,,
64,0,,
64,1,,,
;Not Installed,,
64,2,,,
64,3,,,
64,4,,,
73,0,,
73,1,,,
;0,,
73,2,,,
;00011000,,
73,3,,,
;    0010,,
73,4,,,
;0.0,,
74,0,,
74,1,,,
;11000111,,
74,2,,,
;  000110,,
74,3,,,
;      00,,
74,4,,,
75,0,,
75,1,,,
;00000000,,
75,2,,,
;00100010,,
75,3,,,
;00010010,,
75,4,,,
;01111100,,
76,0,,
76,1,,,
;0.0,,
76,2,,,
;0.0,,
76,3,,,
;0.0,,
76,4,,,
;0.0,,
77,0,,
77,1,,,
;0.0,,
77,2,,,
;0.0,,
77,3,,,
;0.0,,
77,4,,,
;35.0,,
78,0,,
78,1,,,
;95.0,,
78,2,,,
;106.0,,
78,3,,,
;0.0,,
78,4,,,
;0.0,,
79,0,,
79,1,,,
;0.0,,
79,2,,,
;225.0,,
79,3,,,
;1.0,,
79,4,,,
;154.0,,
80,0,,
80,1,,,
;0.0,,
80,2,,,
;0.0,,
80,3,,,
;0.0,,
80,4,,,
;0.0,,
81,0,,
81,1,,,
;0.0,,
81,2,,,
81,3,,,
81,4,,,
85,0,,
85,1,,,
;00000000,,
85,2,,,
;00000000,,
85,3,,,
;00000000,,
85,4,,,
;00000000,,
86,0,,
86,1,,,
;0x0000,,
86,2,,,
;0x0000,,
86,3,,,
;0x0000,,
86,4,,,
;0x0000,,
87,0,,
87,1,,,
;0x0000,,
87,2,,,
;0x0000,,
87,3,,,
;0x0000,,
87,4,,,
88,0,,
88,1,,,
;0.0,,
88,2,,,
;0.0,,
88,3,,,
;0.0,,
88,4,,,
;0.0,,
89,0,,
89,1,,,
;00000101 01111100,,
89,2,,,
;10000101,,
89,3,,,
;00000000,,
89,4,,,
;00000000,,
90,0,,
90,1,,,
;Not Installed,,
90,2,,,
;Not Installed,,
90,3,,,
;Not Installed,,
90,4,,,
;Not Installed,,
91,0,,
91,1,,,
;Not Installed,,
91,2,,,
;Not Installed,,
91,3,,,
;Not Installed,,
91,4,,,
;Not Installed,,
92,0,,
92,1,,,
;Not Installed,,
92,2,,,
;Not Installed,,
92,3,,,
;Not Installed,,
92,4,,,
;Not Installed,,
93,0,,
93,1,,,
;Not Occup.,,
93,2,,,
;Not Installed,,
93,3,,,
;Not Occup.,,
93,4,,,
;00000000,,
97,0,,
97,1,,,
;Not Installed,,
97,2,,,
;Not Installed,,
97,3,,,
97,4,,,
98,0,,
98,1,,,
;0.0,,
98,2,,,
;0.0,,
98,3,,,
;38618.0,,
98,4,,,
;765.0,,
99,0,,
99,1,,,
;00000000 00000000,,
99,2,,,
99,3,,,
99,4,,,
100,0,,
100,1,,,
;2K,,
100,2,,,
100,3,,,
100,4,,,
101,0,,
101,1,,,
;0.0,,
101,2,,,
;0.0,,
101,3,,,
;0.0,,
101,4,,,
;0.0,,
102,0,,
102,1,,,
;0.0,,
102,2,,,
;0.0,,
102,3,,,
;0.0,,
102,4,,,
;0.0,,
103,0,,
103,1,,,
;0.0,,
103,2,,,
;0.0,,
103,3,,,
;0.0,,
103,4,,,
;0.0,,
104,0,,
104,1,,,
;0.0,,
104,2,,,
;0.0,,
104,3,,,
;0.0,,
104,4,,,
;0.0,,
105,0,,
105,1,,,
;0.0,,
105,2,,,
;0.0,,
105,3,,,
;0.0,,
105,4,,,
;0.0,,
106,0,,
106,1,,,
;0.0,,
106,2,,,
;0.0,,
106,3,,,
;0.0,,
106,4,,,
;0.0,,
107,0,,
107,1,,,
;0.0,,
107,2,,,
;0.0,,
107,3,,,
;0.0,,
107,4,,,
;0.0,,
108,0,,
108,1,,,
;01101111,,
108,2,,,
;0.0,,
108,3,,,
;01011011 11100111,,
108,4,,,
;1.0,,
110,0,,
110,1,,,
;Not Installed,,
110,2,,,
;Not Installed,,
110,3,,,
;Not Installed,,
110,4,,,
;Not Installed,,
111,0,,
111,1,,,
;Not Installed,,
111,2,,,
;Not Installed,,
111,3,,,
;Not Installed,,
111,4,,,
;Not Installed,,
112,0,,
112,1,,,
;Not Installed,,
112,2,,,
;Not Installed,,
112,3,,,
;Not Installed,,
112,4,,,
;Not Installed,,
113,0,,
113,1,,,
113,2,,,
113,3,,,
113,4,,,
114,0,,
114,1,,,
;Not Installed,,
114,2,,,
;Not Installed,,
114,3,,,
;Not Installed,,
114,4,,,
;Not Installed,,
119,0,,
119,1,,,
;Not Installed,,
119,2,,,
;Not Installed,,
119,3,,,
;Not Installed,,
119,4,,,
;Not Installed,,
120,0,,
120,1,,,
;Not Installed,,
120,2,,,
;Not Installed,,
120,3,,,
;Not Installed,,
120,4,,,
;Not Installed,,
128,0,,
128,1,,,
;Not Installed,,
128,2,,,
;Not Installed,,
128,3,,,
;Not Installed,,
128,4,,,
;Not Installed,,
129,0,,
129,1,,,
;Not Installed,,
129,2,,,
;Not Installed,,
129,3,,,
;Not Installed,,
129,4,,,
;Not Installed,,
130,0,,
130,1,,,
;Not Installed,,
130,2,,,
;Not Installed,,
130,3,,,
;Not Installed,,
130,4,,,
;Not Installed,,
131,0,,
131,1,,,
;Not Installed,,
131,2,,,
;Not Installed,,
131,3,,,
;Not Installed,,
131,4,,,
;Not Installed,,
132,0,,
132,1,,,
;Not Installed,,
132,2,,,
;Not Installed,,
132,3,,,
;Not Installed,,
132,4,,,
;Not Installed,,
133,0,,
133,1,,,
;Not Installed,,
133,2,,,
;Not Installed,,
133,3,,,
;Not Installed,,
133,4,,,
;Not Installed,,
134,0,,
134,1,,,
;Not Installed,,
134,2,,,
;Not Installed,,
134,3,,,
;Not Installed,,
134,4,,,
;Not Installed,,
135,0,,
135,1,,,
;Not Installed,,
135,2,,,
;Not Installed,,
135,3,,,
;Not Installed,,
135,4,,,
;Not Installed,,
136,0,,
136,1,,,
;Not Installed,,
136,2,,,
;Not Installed,,
136,3,,,
;Not Installed,,
136,4,,,
;Not Installed,,
137,0,,
137,1,,,
;Not Installed,,
137,2,,,
;Not Installed,,
137,3,,,
;Not Installed,,
137,4,,,
;Not Installed,,
138,0,,
138,1,,,
;Not Installed,,
138,2,,,
;Not Installed,,
138,3,,,
;Not Installed,,
138,4,,,
;Not Installed,,
139,0,,
139,1,,,
;Not Installed,,
139,2,,,
;Not Installed,,
139,3,,,
;Not Installed,,
139,4,,,
;Not Installed,,
140,0,,
140,1,,,
;Not Installed,,
140,2,,,
;Not Installed,,
140,3,,,
;Not Installed,,
140,4,,,
;Not Installed,,
141,0,,
141,1,,,
;Not Installed,,
141,2,,,
;Not Installed,,
141,3,,,
;Not Installed,,
141,4,,,
;Not Installed,,
142,0,,
142,1,,,
;Not Installed,,
142,2,,,
;Not Installed,,
142,3,,,
;Not Installed,,
142,4,,,
;Not Installed,,
143,0,,
143,1,,,
;Not Installed,,
143,2,,,
;Not Installed,,
143,3,,,
;Not Installed,,
143,4,,,
;Not Installed,,
144,0,,
144,1,,,
;Not Installed,,
144,2,,,
;Not Installed,,
144,3,,,
;Not Installed,,
144,4,,,
;Not Installed,,
145,0,,
145,1,,,
;Not Installed,,
145,2,,,
;Not Installed,,
145,3,,,
;Not Installed,,
145,4,,,
;Not Installed,,
146,0,,
146,1,,,
;Not Installed,,
146,2,,,
;Not Installed,,
146,3,,,
146,4,,,
147,0,,
147,1,,,
;Not Installed,,
147,2,,,
;Not Installed,,
147,3,,,
;Not Installed,,
147,4,,,
;Not Installed,,
148,0,,
148,1,,,
;Not Installed,,
148,2,,,
;Not Installed,,
148,3,,,
;Not Installed,,
148,4,,,
;Not Installed,,
150,0,,
150,1,,,
;00000000,,
150,2,,,
;Not Installed,,
150,3,,,
;Not Installed,,
150,4,,,
;Not Installed,,
151,0,,
151,1,,,
;Not Installed,,
151,2,,,
;Not Installed,,
151,3,,,
;Not Installed,,
151,4,,,
;Not Installed,,
152,0,,
152,1,,,
;Not Installed,,
152,2,,,
;Not Installed,,
152,3,,,
;Not Installed,,
152,4,,,
;Not Installed,,
153,0,,
153,1,,,
;Not Installed,,
153,2,,,
;Not Installed,,
153,3,,,
;Not Installed,,
153,4,,,
;Not Installed,,
154,0,,
154,1,,,
;Not Installed,,
154,2,,,
;Not Installed,,
154,3,,,
;Not Installed,,
154,4,,,
;Not Installed,,
155,0,,
155,1,,,
;Not Installed,,
155,2,,,
;Not Installed,,
155,3,,,
;Not Installed,,
155,4,,,
;Not Installed,,
156,0,,
156,1,,,
;Not Installed,,
156,2,,,
;Not Installed,,
156,3,,,
156,4,,,
157,0,,
157,1,,,
;Not Installed,,
157,2,,,
;Not Installed,,
157,3,,,
;Not Installed,,
157,4,,,
;Not Installed,,
158,0,,
158,1,,,
;Not Installed,,
158,2,,,
;Not Installed,,
158,3,,,
;Not Installed,,
158,4,,,
;Not Installed,,
160,0,,
160,1,,,
;Not Installed,,
160,2,,,
;Not Installed,,
160,3,,,
;Not Installed,,
160,4,,,
;Not Installed,,
161,0,,
161,1,,,
;Not Installed,,
161,2,,,
;Not Installed,,
161,3,,,
;Not Installed,,
161,4,,,
;Not Installed,,
162,0,,
162,1,,,
;Not Installed,,
162,2,,,
;Not Installed,,
162,3,,,
;Not Installed,,
162,4,,,
;Not Installed,,
163,0,,
163,1,,,
;Not Installed,,
163,2,,,
;Not Installed,,
163,3,,,
;Not Installed,,
163,4,,,
;Not Installed,,
164,0,,
164,1,,,
;Not Installed,,
164,2,,,
;Not Installed,,
164,3,,,
;Not Installed,,
164,4,,,
;Not Installed,,
165,0,,
165,1,,,
;Not Installed,,
165,2,,,
;Not Installed,,
165,3,,,
;Not Installed,,
165,4,,,
;Not Installed,,
166,0,,
166,1,,,
;Not Installed,,
166,2,,,
;Not Installed,,
166,3,,,
;Not Installed,,
166,4,,,
;Not Installed,,
167,0,,
167,1,,,
;Not Installed,,
167,2,,,
;Not Installed,,
167,3,,,
;Not Installed,,
167,4,,,
;Not Installed,,
168,0,,
168,1,,,
;Not Installed,,
168,2,,,
;Not Installed,,
168,3,,,
;Not Installed,,
168,4,,,
;Not Installed,,
169,0,,
169,1,,,
;Not Installed,,
169,2,,,
;Not Installed,,
169,3,,,
;Not Installed,,
169,4,,,
;Not Installed,,
170,0,,
170,1,,,
;Not Installed,,
170,2,,,
;Not Installed,,
170,3,,,
;Not Installed,,
170,4,,,
;Not Installed,,
171,0,,
171,1,,,
;Not Installed,,
171,2,,,
;Not Installed,,
171,3,,,
;Not Installed,,
171,4,,,
;Not Installed,,
172,0,,
172,1,,,
;Not Installed,,
172,2,,,
;Not Installed,,
172,3,,,
;Not Installed,,
172,4,,,
;Not Installed,,
173,0,,
173,1,,,
;Not Installed,,
173,2,,,
;Not Installed,,
173,3,,,
;Not Installed,,
173,4,,,
;Not Installed,,
174,0,,
174,1,,,
;Not Installed,,
174,2,,,
;Not Installed,,
174,3,,,
;Not Installed,,
174,4,,,
;Not Installed,,
175,0,,
175,1,,,
;Not Installed,,
175,2,,,
;Not Installed,,
175,3,,,
;Not Installed,,
175,4,,,
;Not Installed,,
176,0,,
176,1,,,
;Not Installed,,
176,2,,,
;Not Installed,,
176,3,,,
;Not Installed,,
176,4,,,
;Not Installed,,
177,0,,
177,1,,,
;Not Installed,,
177,2,,,
;Not Installed,,
177,3,,,
;Not Installed,,
177,4,,,
;Not Installed,,
178,0,,
178,1,,,
;Not Installed,,
178,2,,,
;Not Installed,,
178,3,,,
;Not Installed,,
178,4,,,
;Not Installed,,
179,0,,
179,1,,,
;Not Installed,,
179,2,,,
;Not Installed,,
179,3,,,
;Not Installed,,
179,4,,,
;Not Installed,,
180,0,,
180,1,,,
;Not Installed,,
180,2,,,
;Not Installed,,
180,3,,,
;Not Installed,,
180,4,,,
;Not Installed,,
181,0,,
181,1,,,
;Not Installed,,
181,2,,,
;Not Installed,,
181,3,,,
;Not Installed,,
181,4,,,
;Not Installed,,
182,0,,
182,1,,,
;Not Installed,,
182,2,,,
;Not Installed,,
182,3,,,
;Not Installed,,
182,4,,,
;Not Installed,,
183,0,,
183,1,,,
;Not Installed,,
183,2,,,
;Not Installed,,
183,3,,,
;Not Installed,,
183,4,,,
;Not Installed,,
184,0,,
184,1,,,
;Not Installed,,
184,2,,,
;Not Occup.,,
184,3,,,
;Not Occup.,,
184,4,,,
;Not Occup.,,
200,0,,
200,1,,,
;     111,,
200,2,,,
;0.0,,
200,3,,,
;0.0,,
200,4,,,
;0.0,,
201,0,,
201,1,,,
;     000,,
201,2,,,
;2.0,,
201,3,,,
;00000010,,
201,4,,,
;62475.0,,
235,0,,
235,1,,,
;10010101,,
235,2,,,
;10101000,,
235,3,,,
;00011011,,
235,4,,,
;01011001,,
236,0,,
236,1,,,
;00000101,,
236,2,,,
;0,,
236,3,,,
;0,,
236,4,,,
;01010000,,
237,0,,
237,1,,,
;10010101,,
237,2,,,
;00001000,,
237,3,,,
;00001111,,
237,4,,,
;00000000,,
238,0,,
238,1,,,
;00010011,,
238,2,,,
;0,,
238,3,,,
;0,,
238,4,,,
;00110101,,
239,0,,
239,1,,,
;0.0,,
239,2,,,
;50.0,,
239,3,,,
;0.0,,
239,4,,,
;14280,,
240,0,,
240,1,,,
;10101100 11110101,,
240,2,,,
;10101000 11110101,,
240,3,,,
;0.0,,
240,4,,,
;180.0,,
241,0,,
241,1,,,
;00001010 00100010,,
241,2,,,
;00100010 00110011,,
241,3,,,
;00001010 00001010,,
241,4,,,
242,0,,
242,1,,,
;11100010 00001010,,
242,2,,,
;00001001 00000000,,
242,3,,,
242,4,,,
;01000000 00000000,,
243,0,,
243,1,,,
;01011010 10100101,,
243,2,,,
;10100101 01011010,,
243,3,,,
;765.0,,
243,4,,,
;34.0,,
244,0,,
244,1,,,
;0.0,,
244,2,,,
;0.0,,
244,3,,,
;0.0,,
244,4,,,
;0.0,,
245,0,,
245,1,,,
;0.0,,
245,2,,,
;0.0,,
245,3,,,
;0.0,,
245,4,,,
;0.0,,
246,0,,
246,1,,,
;0.0,,
246,2,,,
;0.0,,
246,3,,,
;0.0,,
246,4,,,
;0.0,,
;SW:4T0-959-792-H   HW:4T0-959-792-H ---  Door Elect, Pass.
;Component:TSG BF        H07 0801, Coding:010C4B025000620100081100
;Sunday,17,May,2020,19:49:59:06485
;VCID: 49DA5FF3E0A057CE9C-801C
;Sunday,17,May,2020,19:49:31:06485
1,0,,
1,1,,,
;01000000,,
1,2,,,
;00000000,,
1,3,,,
;00000111,,
1,4,,,
;11.81 V,,
2,0,,
2,1,,,
;Not Oper.,,
2,2,,,
;Not Installed,,
2,3,,,
;Not Installed,,
2,4,,,
;Not Installed,,
3,0,,
3,1,,,
;no Value,,
3,2,,,
;33.0°C,,
3,3,,,
;    0001,,
3,4,,,
;Still,,
4,0,,
4,1,,,
;Not Installed,,
4,2,,,
;Not Installed,,
4,3,,,
;Not Installed,,
4,4,,,
;N/A,,
5,0,,
5,1,,,
;0.0 km/h,,
5,2,,,
;23.0°C,,
5,3,,,
;0.0 %,,
5,4,,,
;Heater Off,,
6,0,,
6,1,,,
;Not Installed,,
6,2,,,
;Not Installed,,
6,3,,,
;Not Installed,,
6,4,,,
;00000000,,
7,0,,
7,1,,,
;no Value,,
7,2,,,
;00000000,,
7,3,,,
;Not Installed,,
7,4,,,
;0.000 A,,
8,0,,
8,1,,,
;Not Oper.,,
8,2,,,
;0.000 A,,
8,3,,,
;00100001,,
8,4,,,
;00000000,,
9,0,,
9,1,,,
;Not Installed,,
9,2,,,
;Not Installed,,
9,3,,,
;Not Installed,,
9,4,,,
;Not Installed,,
10,0,,
10,1,,,
;Not Installed,,
10,2,,,
;Not Installed,,
10,3,,,
;Not Installed,,
10,4,,,
;Not Installed,,
11,0,,
11,1,,,
;Not Installed,,
11,2,,,
;Not Installed,,
11,3,,,
;Not Installed,,
11,4,,,
;Not Installed,,
12,0,,
12,1,,,
;Not Installed,,
12,2,,,
;N/A,,
12,3,,,
;N/A,,
12,4,,,
;N/A,,
20,0,,
20,1,,,
;Not Installed,,
20,2,,,
;N/A,,
20,3,,,
;N/A,,
20,4,,,
;N/A,,
21,0,,
21,1,,,
;Not Installed,,
21,2,,,
;N/A,,
21,3,,,
;N/A,,
21,4,,,
;N/A,,
22,0,,
22,1,,,
;Not Installed,,
22,2,,,
;N/A,,
22,3,,,
;N/A,,
22,4,,,
;N/A,,
23,0,,
23,1,,,
;Not Installed,,
23,2,,,
;N/A,,
23,3,,,
;N/A,,
23,4,,,
;N/A,,
24,0,,
24,1,,,
;Not Installed,,
24,2,,,
;N/A,,
24,3,,,
;N/A,,
24,4,,,
;N/A,,
25,0,,
25,1,,,
;Not Installed,,
25,2,,,
;N/A,,
25,3,,,
;N/A,,
25,4,,,
;N/A,,
26,0,,
26,1,,,
;Not Installed,,
26,2,,,
;N/A,,
26,3,,,
;N/A,,
26,4,,,
;N/A,,
27,0,,
27,1,,,
;Not Installed,,
27,2,,,
;N/A,,
27,3,,,
;N/A,,
27,4,,,
;N/A,,
28,0,,
28,1,,,
;Not Installed,,
28,2,,,
;N/A,,
28,3,,,
;N/A,,
28,4,,,
;N/A,,
29,0,,
29,1,,,
;Not Installed,,
29,2,,,
;N/A,,
29,3,,,
;N/A,,
29,4,,,
;N/A,,
;SW:4G0-035-082-G   HW:4G0-035-082 ---  Radio
;Component:Radio U SIRIU H66 0133, Coding:020007020100000001
;Sunday,17,May,2020,19:51:00:06485
;VCID: 2404EE4727C2AAA64F-8070
;01 N/A
;02 N/A
;03 N/A
;04 N/A
;05 N/A
;06 N/A
;07 N/A
;08 N/A
;09 N/A
;10 N/A
;11 N/A
;12 N/A
;13 N/A
;14 N/A
;15 N/A
;16 N/A
A17,0,
;65535
A17,1,
;0.80
A17,2,
;44.0
A17,3,
;7.0
A17,4,
;37.0
;18 N/A
A19,0,
;65535
A19,1,
;820
A19,2,
;7.0
A19,3,
;Done
A19,4,
;N/A
;20 N/A
A21,0,
;65535
A21,1,
;184
A21,2,
;1.0
A21,3,
;3.0
A21,4,
;0x00FE
A22,0,
;0
A22,1,
;0.80
A22,2,
;8.0
A22,3,
;59.0
A22,4,
;Done
;23 N/A
A24,0,
;0
A24,1,
;820
A24,2,
;4.0
A24,3,
;Done
A24,4,
;N/A
;25 N/A
;26 N/A
;27 N/A
;28 N/A
;29 N/A
;30 N/A
;31 N/A
A32,0,
;254
A32,1,
;0x00FE
A32,2,
;N/A
A32,3,
;N/A
A32,4,
;N/A
;33 N/A
;34 N/A
;35 N/A
;36 N/A
;37 N/A
;38 N/A
;39 N/A
;40 N/A
;41 N/A
;42 N/A
;43 N/A
;44 N/A
;45 N/A
;46 N/A
;47 N/A
;48 N/A
;49 N/A
;50 N/A
;51 N/A
;52 N/A
;53 N/A
;54 N/A
;55 N/A
;56 N/A
;57 N/A
;58 N/A
;59 N/A
;60 N/A
;61 N/A
;62 N/A
;63 N/A
;64 N/A
;65 N/A
;66 N/A
;67 N/A
;68 N/A
;69 N/A
;70 N/A
;71 N/A
;72 N/A
;73 N/A
;74 N/A
;75 N/A
;76 N/A
;77 N/A
;78 N/A
;79 N/A
;80 N/A
;81 N/A
;82 N/A
A83,0,
;20
A83,1,
;0.0
A83,2,
;N/A
A83,3,
;N/A
A83,4,
;N/A
;84 N/A
A85,0,
;6
A85,1,
;0.0
A85,2,
;N/A
A85,3,
;N/A
A85,4,
;N/A
;86 N/A
;87 N/A
;88 N/A
;89 N/A
;90 N/A
;91 N/A
;92 N/A
;93 N/A
;94 N/A
;95 N/A
A96,0,
;0
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
;97 N/A
;98 N/A
A99,0,
;2
A99,1,
;N/A
A99,2,
;N/A
A99,3,
;N/A
A99,4,
;N/A
A100,0,
;0
A100,1,
;N/A
A100,2,
;N/A
A100,3,
;N/A
A100,4,
;N/A
;101 N/A
;102 N/A
;103 N/A
;104 N/A
;105 N/A
;106 N/A
;107 N/A
;108 N/A
;109 N/A
;110 N/A
;111 N/A
A112,0,
;20
A112,1,
;  000000
A112,2,
;N/A
A112,3,
;N/A
A112,4,
;N/A
A113,0,
;0
A113,1,
;TT
A113,2,
;N/A
A113,3,
;N/A
A113,4,
;N/A
A114,0,
;1000
A114,1,
;  000000
A114,2,
;N/A
A114,3,
;N/A
A114,4,
;N/A
A115,0,
;2000
A115,1,
;N/A
A115,2,
;N/A
A115,3,
;N/A
A115,4,
;N/A
A116,0,
;12
A116,1,
;N/A
A116,2,
;N/A
A116,3,
;N/A
A116,4,
;N/A
A117,0,
;500
A117,1,
;N/A
A117,2,
;N/A
A117,3,
;N/A
A117,4,
;N/A
A118,0,
;0
A118,1,
;N/A
A118,2,
;N/A
A118,3,
;N/A
A118,4,
;N/A
A119,0,
;2
A119,1,
;0.0
A119,2,
;0 /min
A119,3,
;N/A
A119,4,
;N/A
A120,0,
;0
A120,1,
;  000000
A120,2,
;N/A
A120,3,
;N/A
A120,4,
;N/A
;121 N/A
;122 N/A
;123 N/A
;124 N/A
;125 N/A
;126 N/A
;127 N/A
A128,0,
;0
A128,1,
;N/A
A128,2,
;N/A
A128,3,
;N/A
A128,4,
;N/A
;129 N/A
;130 N/A
;131 N/A
;132 N/A
;133 N/A
;134 N/A
;135 N/A
;136 N/A
;137 N/A
;138 N/A
;139 N/A
;140 N/A
;141 N/A
;142 N/A
;143 N/A
;144 N/A
;145 N/A
;146 N/A
;147 N/A
;148 N/A
;149 N/A
;150 N/A
;151 N/A
;152 N/A
;153 N/A
;154 N/A
;155 N/A
;156 N/A
;157 N/A
;158 N/A
;159 N/A
;160 N/A
;161 N/A
;162 N/A
;163 N/A
;164 N/A
;165 N/A
;166 N/A
;167 N/A
;168 N/A
;169 N/A
;170 N/A
;171 N/A
;172 N/A
;173 N/A
;174 N/A
;175 N/A
;176 N/A
;177 N/A
;178 N/A
;179 N/A
;180 N/A
;181 N/A
;182 N/A
;183 N/A
;184 N/A
;185 N/A
;186 N/A
;187 N/A
;188 N/A
;189 N/A
;190 N/A
;191 N/A
;192 N/A
;193 N/A
;194 N/A
;195 N/A
;196 N/A
;197 N/A
;198 N/A
;199 N/A
;200 N/A
;201 N/A
;202 N/A
;203 N/A
;204 N/A
;205 N/A
;206 N/A
;207 N/A
;208 N/A
;209 N/A
;210 N/A
;211 N/A
;212 N/A
;213 N/A
;214 N/A
;215 N/A
;216 N/A
;217 N/A
;218 N/A
;219 N/A
;220 N/A
;221 N/A
;222 N/A
;223 N/A
;224 N/A
;225 N/A
;226 N/A
;227 N/A
;228 N/A
;229 N/A
;230 N/A
;231 N/A
;232 N/A
;233 N/A
;234 N/A
;235 N/A
;236 N/A
;237 N/A
;238 N/A
;239 N/A
;240 N/A
;241 N/A
;242 N/A
;243 N/A
;244 N/A
;245 N/A
;246 N/A
;247 N/A
;248 N/A
;249 N/A
;250 N/A
;251 N/A
;252 N/A
;253 N/A
;254 N/A
;255 N/A
;Sunday,17,May,2020,19:50:25:06485
1,0,,
1,1,,,
;12.10 V,Voltage,
1,2,,,
;00000111,Bin. Bits,
1,3,,,
;0x0600,Hex Value,
1,4,,,
;N/A,,
2,0,,
2,1,,,
;0x0556,Hex Value,
2,2,,,
;0x03FF,Hex Value,
2,3,,,
;0x0056,Hex Value,
2,4,,,
;N/A,,
3,0,,
3,1,,,
;0.00,(no units),
3,2,,,
;36.0°C,Temperature,
3,3,,,
;59.0°C,Temperature,
3,4,,,
;N/A,,
5,0,,
5,1,,,
;0x00FF,Hex Value,
5,2,,,
;       1,Bin. Bits,
5,3,,,
;N/A,,
5,4,,,
;N/A,,
6,0,,
6,1,,,
;0xE300,Hex Value,
6,2,,,
;0x9771,Hex Value,
6,3,,,
;N/A,,
6,4,,,
;N/A,,
7,0,,
7,1,,,
;0x0000,Hex Value,
7,2,,,
;0x3053,Hex Value,
7,3,,,
;0x34E9,Hex Value,
7,4,,,
;N/A,,
8,0,,
8,1,,,
;Range OK, ,
8,2,,,
;40.0 mA,Current,
8,3,,,
;N/A,,
8,4,,,
;N/A,,
9,0,,
9,1,,,
;Range OK, ,
9,2,,,
;46.0 mA,Current,
9,3,,,
;N/A,,
9,4,,,
;N/A,,
10,0,,
10,1,,,
;30.0,(no units),
10,2,,,
;0.00 %, ,
10,3,,,
;0.0,(no units),
10,4,,,
;0.00 %, ,
11,0,,
11,1,,,
;6.0,(no units),
11,2,,,
;0.00 %, ,
11,3,,,
;N/A,,
11,4,,,
;N/A,,
17,0,,
17,1,,,
;3.0,(no units),
17,2,,,
;Yes, ,
17,3,,,
;N/A,,
17,4,,,
;N/A,,
18,0,,
18,1,,,
;0.0,(no units),
18,2,,,
;not available, ,
18,3,,,
;N/A,,
18,4,,,
;N/A,,
19,0,,
19,1,,,
;0.0,(no units),
19,2,,,
;not available, ,
19,3,,,
;00000000 00000000,Bin. Bits,
19,4,,,
;N/A,,
20,0,,
20,1,,,
;1.0,(no units),
20,2,,,
;0.0,(no units),
20,3,,,
;136.0 mA,Current,
20,4,,,
;N/A,,
21,0,,
21,1,,,
;070194357377,(no units),
22,0,,
22,1,,,
22,2,,,
;43.0°C,Temperature,
22,3,,,
;0 /min,RPM,
22,4,,,
;N/A,,
23,0,,
23,1,,,
;0.000 V,Voltage,
23,2,,,
;0.000 V,Voltage,
23,3,,,
;Connected, ,
23,4,,,
;Connected, ,
24,0,,
24,1,,,
; 0000000,Bin. Bits,
24,2,,,
;N/A,,
24,3,,,
;N/A,,
24,4,,,
;N/A,,
25,0,,
25,1,,,
; 0000001,Bin. Bits,
25,2,,,
;N/A,,
25,3,,,
;N/A,,
25,4,,,
;N/A,,
32,0,,
32,1,,,
;0.00 km/h,Speed,
32,2,,,
;0.0,(no units),
32,3,,,
;N/A,,
32,4,,,
;N/A,,
48,0,,
48,1,,,
48,2,,,
;00:00,Clock,
48,3,,,
;N/A,,
48,4,,,
;N/A,,
50,0,,
50,1,,,
;0x0001,Hex Value,
50,2,,,
;N/A,,
50,3,,,
;N/A,,
50,4,,,
;N/A,,
51,0,,
51,1,,,
;1.0,(no units),
51,2,,,
;N/A,,
51,3,,,
;N/A,,
51,4,,,
;N/A,,
64,0,,
64,1,,,
;184,Count,
64,2,,,
;0,Count,
64,3,,,
;0,Count,
64,4,,,
;N/A,,
65,0,,
65,1,,,
;1308 h,ON Time,
65,2,,,
;54.0,(no units),
65,3,,,
;N/A,,
65,4,,,
;N/A,,
;SW:4S0-907-379-C   HW:4S0-907-379-C ---  ABS Brakes
;Component:ESP PREMIUM   H09 0220, Coding:2182C141844183824B00
;EV_ESPPremiAU57X,004048,EV_ESPPremiAU57X_AU72.rod
;Sunday,17,May,2020,19:27:44:06485
;VCID: 3D323B23AC68FB6E20-8068
IDE00820-ENG100715-Activating and deactivating all development messages-ECU specific 01/02,not active ,3
IDE00820-ENG102355-Activating and deactivating all development messages-Internal System Error Number,00 00 ,3
IDE00820-ENG102411-Activating and deactivating all development messages-Message 100,not active ,3
IDE00820-ENG101646-Activating and deactivating all development messages-Message 101,not active ,3
IDE00820-ENG103687-Activating and deactivating all development messages-Message 102,not active ,3
IDE02630-ESP coasting operation,not activated ,1
IDE04159-Deactivation of start-stop function,On ,1
IDE06425-Roller test bench mode: functional-,not activated ,1
IDE06425-ENG98891-Roller test bench mode: functional-Reserved,0 ,1
ENG98365-Acoustic warning,activated ,1
ENG105251-AVH_HHC thresholds,normal ,1
ENG105345-Brake assistant,activated ,1
ENG98470-Brake disc wiper,normal ,1
ENG111872-Can Stop Tx Delay Time,200 ms,1
ENG106318-ESP_ASR,activated ,1
ENG111858-GPS Rx PDU,Motor 02 PDU ,1
ENG108268-Prefill,activated ,1
ENG111874-Reset RKA Maximal System Runtime,Unknown (0),1
ENG111873-SLC Activation,OFF ,1
ENG109396-Text Warning,activated ,1
ENG109900-VIN Monitoring,activated ,1
ENG110141-ENG101644-WSS Direction Change-Wheel FL,Original ,1
ENG110141-ENG102524-WSS Direction Change-Wheel FR,Original ,1
ENG110141-ENG99883-WSS Direction Change-Wheel RL,Original ,1
ENG110141-ENG99053-WSS Direction Change-wheel rr,Original ,1
ENG111871-XCP Activation,not activated ,1
Elapsed Time: 00:08
;Sunday,17,May,2020,19:27:29:06485
Group,Description,Actual
IDE00019,Voltage terminal 30,11.93, V
IDE00021,Engine speed,0, /min
IDE00030,Status of actuator test,not active,
IDE00150,Pressure in brake booster,963.063, mbar
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00326,Steering wheel angle,10.89375, °
IDE00450-ENG101799,Operating Instructions-Param to DOP,Stop requested,
IDE00609-MAS00811,Communication status of data bus 1-Active steering control module,detected,
IDE00609-MAS00815,Communication status of data bus 1-Steering angle sensor,detected,
IDE00920,Front left wheel speed,0, km/h
IDE00921,Front right wheel speed,0, km/h
IDE00922,Left rear wheel speed,0, km/h
IDE00923,Right rear wheel speed,0, km/h
IDE02211,Brake pressure,665.6475, bar
IDE02239-ENG101799,Rotation rate sensor 1-Param to DOP,0.0000, rad/s
IDE02241,Lateral acceleration sensor 1,0.19, m/s²
IDE02243-ENG101799,Rotation rate sensor 2-Param to DOP,-0.0021, rad/s
IDE02245,Lateral acceleration sensor 2,0.19, m/s²
IDE02305,ESP brake application information,not activated,
IDE02306,Engine brake application information,not activated,
IDE02307,Parking brake status,not activated,
IDE02308,ESP button status,not activated,
IDE02309,Valve relay status,passive,
IDE02310,Status of return pump,passive,
IDE02311,Left front wheel speed sensor installation position,Not available,
IDE02312,Right front wheel speed sensor installation position,Not available,
IDE02313,Left rear wheel speed sensor installation position,Not available,
IDE02314,Right rear wheel speed sensor installation position,Not available,
IDE02315,Direction of rotation front left wheel speed sensor,invalid,
IDE02316,Direction of rotation front right wheel speed sensor,invalid,
IDE02317,Direction of rotation rear left wheel speed sensor,invalid,
IDE02318,Direction of rotation rear right wheel speed sensor,invalid,
IDE02319-MAS02149,Hill start assistant signals-Hillside power take-off torque high wheel limit crawl torque,active,
IDE02319-MAS02150,Hill start assistant signals-Engine torque high hillside power take-off torque,passive,
IDE02319-MAS02151,Hill start assistant signals-Q bit: incline angle EPB,passive,
IDE02319-MAS02153,Hill start assistant signals-Q bit EPB clutch pedal travel,passive,
IDE02319-MAS02154,Hill start assistant signals-Q bit EPB switch position,passive,
IDE02319-MAS02155,Hill start assistant signals-EPB error status,passive,
IDE02320,Status overview ESP,active,
IDE02320-MAS02136,Status overview ESP-Trailer stabilization,passive,
IDE02320-MAS02137,Status overview ESP-Brake disc wiper,active,
IDE02320-MAS02138,Status overview ESP-Hill-start assistant,active,
IDE02320-MAS02139,Status overview ESP-SBC Hold assistant,passive,
IDE02320-MAS02140,Status overview ESP-ESP coasting operation,passive,
IDE02320-MAS02141,Status overview ESP-Monitoring VIN,active,
IDE02320-MAS02142,Status overview ESP-Function µ-split,passive,
IDE02320-MAS02143,Status overview ESP-Oversteering function,passive,
IDE02320-MAS02144,Status overview ESP-Understeering function,passive,
IDE02320-MAS02145,Status overview ESP-ESP ADS coding,passive,
IDE02320-MAS02146,Status overview ESP-RKA+,passive,
IDE02320-MAS02147,Status overview ESP-Text output,On,
IDE02320-MAS02148,Status overview ESP-Acoustic output,On,
IDE03008-MAS04511,Stop process prevented-Skidding vehicle detected,not active,
IDE03008-MAS04512,Stop process prevented-Hard deceleration to standstill,not active,
IDE03008-MAS04513,Stop process prevented-Brake control module pump operation,not active,
IDE03008-MAS04514,Stop process prevented-Button for hill descent assist operated,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03008-ENG111908,Stop process prevented-Prohibition_Reason_4_ActiveAdaption,not active,
IDE03008-ENG111907,Stop process prevented-Prohibition_Reason_5_Systemerror,not active,
IDE03009-MAS04511,Start process requested-Skidding vehicle detected,not active,
IDE03009-MAS04512,Start process requested-Hard deceleration to standstill,not active,
IDE03009-MAS04513,Start process requested-Brake control module pump operation,not active,
IDE03009-MAS04514,Start process requested-Button for hill descent assist operated,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03009-ENG111910,Start process requested-Restart_Reason_4_ActiveAdaption,not active,
IDE03009-ENG111909,Start process requested-Restart_Reason_5_Systemerror,not active,
IDE03010-MAS04511,Number of prevented stop processes-Skidding vehicle detected,0,
IDE03010-MAS04512,Number of prevented stop processes-Hard deceleration to standstill,0,
IDE03010-MAS04513,Number of prevented stop processes-Brake control module pump operation,0,
IDE03010-MAS04514,Number of prevented stop processes-Button for hill descent assist operated,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-ENG111908,Number of prevented stop processes-Prohibition_Reason_4_ActiveAdaption,0,
IDE03010-ENG111907,Number of prevented stop processes-Prohibition_Reason_5_Systemerror,0,
IDE03011-MAS04511,Number of requested start processes-Skidding vehicle detected,0,
IDE03011-MAS04512,Number of requested start processes-Hard deceleration to standstill,0,
IDE03011-MAS04513,Number of requested start processes-Brake control module pump operation,0,
IDE03011-MAS04514,Number of requested start processes-Button for hill descent assist operated,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03011-ENG111910,Number of requested start processes-Restart_Reason_4_ActiveAdaption,0,
IDE03011-ENG111909,Number of requested start processes-Restart_Reason_5_Systemerror,0,
IDE03127-IDE03008,Prevented stop processes (ring memory)-Stop process prevented,Measured value not available,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03128-IDE03009,Requested start processes (ring memory)-Start process requested,Measured value not available,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03212,Start-stop conditions,System malfunction,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03220-MAS00076,Communication status of data bus 2-Instrument cluster control module,detected,
IDE03220-MAS00657,Communication status of data bus 2-All wheel drive control module,detected,
IDE03220-MAS00661,Communication status of data bus 2-Level Control System Control Module,detected,
IDE03220-MAS00795,Communication status of data bus 2-Diagnostic interface for data bus,detected,
IDE03220-MAS00796,Communication status of data bus 2-Engine Control Module (ECM),detected,
IDE03220-MAS00798,Communication status of data bus 2-Transmission Control Module (TCM),detected,
IDE03220-MAS00799,Communication status of data bus 2-Airbag control module,detected,
IDE03220-MAS00802,Communication status of data bus 2-Control module for distance control,detected,
IDE03220-MAS00809,Communication status of data bus 2-Electro-Mechanical Parking Brake Control Module,detected,
IDE03220-MAS00821,Communication status of data bus 2-Central ctrl. unit for comfort system,detected,
IDE03220-MAS00830,Communication status of data bus 2-Towing recognition control module,detected,
IDE03220-MAS02828,Communication status of data bus 2-Comfort system central control module 2,detected,
IDE03491,Hydraulic pump run-on time,0,
IDE03493-ENG111859,Driver door status-Switch Status FlexRay,Open,
IDE03493-ENG111860,Driver door status-Switch Status HW,closed,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06752,Hill descent control button,not coded/not installed,
MAS00364-ENG98385,Shift lever / selector lever position-Back-up light,passive,
MAS00364-ENG98561,Shift lever / selector lever position-Driver door status,Open,
MAS00364-ENG100940,Shift lever / selector lever position-forward gear status,passive,
MAS00364-ENG101311,Shift lever / selector lever position-gearshift position,5,
MAS00364-ENG101302,Shift lever / selector lever position-safty belt warning,active,
MAS02117,Engine torque with external intervention,147, Nm
MAS02118,Engine torque loss,0, Nm
MAS02119,Throttle valve angle,0, %
MAS02120-ENG98653,Instrument cluster info holding time-Hour,0, H
MAS02120-ENG98739,Instrument cluster info holding time-Minute,0, min
MAS02121,ESP info EDS temperature flag,passive,
MAS02122,ESP info driver applying brakes Q bit,passive,
MAS02124-ENG101799,Steering wheel angle sub data-Param to DOP,10.8, °
MAS02134-ENG101799,Rotation rate sensor difference-Param to DOP,-0.0021, rad/s
MAS02135,Lateral acceleration difference sensor,0.00, m/s²
MAS02152,EPB clutch pedal travel,0, %
MAS02156,Button for SBC Hold assistant status,not activated,
ENG111876,actual superposition angle dynamic steering,0.00000, °
ENG111879,angle intervention esp,0,
ENG105314-ENG101167,BB-No. and SW version-Base version,1500,
ENG105314-ENG101969,BB-No. and SW version-BB-No.,66027,
ENG105314-ENG98430,BB-No. and SW version-Branch 1,0000,
ENG105314-ENG98431,BB-No. and SW version-Branch 2,0000,
ENG105366,BTM Driving with pushed brakes,4,
ENG105367-ENG98504,BTM Last occurence of driving with pushed brakes-Day,15, d
ENG105367-ENG98748,BTM Last occurence of driving with pushed brakes-Month,8, mon
ENG105367-ENG99063,BTM Last occurence of driving with pushed brakes-Year,2018, yr
ENG105368-ENG98504,BTM Last occurence of maximum temp FL-Day,1, d
ENG105368-ENG98748,BTM Last occurence of maximum temp FL-Month,1, mon
ENG105368-ENG99063,BTM Last occurence of maximum temp FL-Year,2012, yr
ENG105369-ENG98504,BTM Last occurence of temperature FL greater than temp limit-Day,0, d
ENG105369-ENG98748,BTM Last occurence of temperature FL greater than temp limit-Month,0, mon
ENG105369-ENG99063,BTM Last occurence of temperature FL greater than temp limit-Year,2000, yr
ENG105370-ENG98504,BTM Last reset of driving with pushed brakes-Day,0, d
ENG105370-ENG98748,BTM Last reset of driving with pushed brakes-Month,0, mon
ENG105370-ENG99063,BTM Last reset of driving with pushed brakes-Year,2000, yr
ENG105371-ENG98504,BTM Last reset of maximum temp FL-Day,0, d
ENG105371-ENG98748,BTM Last reset of maximum temp FL-Month,0, mon
ENG105371-ENG99063,BTM Last reset of maximum temp FL-Year,2000, yr
ENG105372-ENG98504,BTM Last reset of temperature FL greater than temp limit-Day,0, d
ENG105372-ENG98748,BTM Last reset of temperature FL greater than temp limit-Month,0, mon
ENG105372-ENG99063,BTM Last reset of temperature FL greater than temp limit-Year,2000, yr
ENG105373,BTM Maximum temp of temperature brake FL,350, °C
ENG105374,BTM Time of temperature FL greater than temp limit,0,
ENG98475,Coding dynamic steering in ESP,Value0,
ENG105902,downtilt,valid,
ENG106309,ESP Sensor unit 2: turn rate: confidence factor,0,
ENG106310,ESP Sensor unit: lateral acceleration: confidence factor,0,
ENG106311,ESP Sensor unit: longitudinal acceleration,0.00, m/s²
ENG106312,ESP Sensor unit: longitudinal acceleration: confidence factor,0,
ENG106313,ESP Sensor unit: turn rate: confidence factor,0,
ENG106552,FIBEX Version,0608_00,
ENG98615,Forward gear engaged,passive,
ENG98753,Maximum gradient dynamic steering,0,
ENG111878,nominal angle esp,0.00000, °
ENG111877,nominal superposition angle dynamic steering,0.00000, °
ENG108404,Reached elasticity,0,
ENG108464,Reverse Light Switch,passive,
ENG98935,Status dynamic steering,0,
ENG111880,status esp of dynamic steering,Value0,
ENG109112-MAS02126,steering angle sensor data-Steering angle sensor: status,active,
ENG109112-MAS02127,steering angle sensor data-Q bit: steering wheel angle sub data,active,
ENG109112-MAS02128,steering angle sensor data-Q bit: steering wheel angle,active,
ENG111881,steering intervention esp of dynamic steering,passive,
ENG100575-ENG101799,Switch status Electronic Park Brake-Param to DOP,Not operated,
ENG109448-MAS01143,TimeStamp Faultmemory Deletion-Device number,2097151,
ENG109448-MAS01144,TimeStamp Faultmemory Deletion-Importer number,1023,
ENG109448-MAS01145,TimeStamp Faultmemory Deletion-Dealership number,131071,
ENG109448-ENG98504,TimeStamp Faultmemory Deletion-Day,9,
ENG109448-ENG98653,TimeStamp Faultmemory Deletion-Hour,18,
ENG109448-ENG98672,TimeStamp Faultmemory Deletion-km,38769,
ENG109448-ENG98739,TimeStamp Faultmemory Deletion-Minute,47,
ENG109448-ENG98748,TimeStamp Faultmemory Deletion-Month,1,
ENG109448-ENG102365,TimeStamp Faultmemory Deletion-Second,23,
ENG109448-ENG99063,TimeStamp Faultmemory Deletion-Year,2012,
ENG109899,VIN last coding,ZF04055,
ENG110108-ENG103252,WAU Info KL15-FlexRay Transceiver PIN,active,
ENG110108-ENG102268,WAU Info KL15-Klemme 15 PIN,active,
Elapsed Time: 00:15
;SW:4G0-907-637-L   HW:4G0-907-637-G ---  Sensor Elect.
;Component:SARA 6D red   H04 0056, Coding:
;EV_SARA2,005012,EV_SARA2.rod
;Sunday,17,May,2020,19:44:02:06485
;VCID: 373E290B8E54D13EFA-8062
IDE00820-ENG102736-Activating and deactivating all development messages-Development Messages ECU specific 01 / (02),not activated ,1
IDE00820-ENG102044-Activating and deactivating all development messages-Development Messages ECU specific 03 / 10,not activated ,1
IDE00820-ENG102308-Activating and deactivating all development messages-Development Messages S100,not activated ,1
IDE00820-ENG103617-Activating and deactivating all development messages-Development Messages S101,not activated ,1
IDE00820-ENG104084-Activating and deactivating all development messages-Development Messages S102,not activated ,1
IDE00820-ENG99301-Activating and deactivating all development messages-XCP ECU specific,not activated ,1
ENG104037-VIN Monitoring CF6 Setting,activated ,1
Elapsed Time: 00:01
;Sunday,17,May,2020,19:43:57:06485
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
IDE00019,Voltage terminal 30,11.7, V
IDE00019-ENG98933,Voltage terminal 30-Status,valid,
IDE00020-MAS05359,Terminal 15 status-bus,On,
IDE00020-MAS05360,Terminal 15 status-Discreet wire,On,
IDE02240-ENG98646,Lateral acceleration sensor 1: status-Initializing,No,
IDE02240-ENG101274,Lateral acceleration sensor 1: status-Not assembled,No,
IDE02240-ENG101756,Lateral acceleration sensor 1: status-Permanent Error,No,
IDE02240-ENG102842,Lateral acceleration sensor 1: status-Sporadic Error,No,
IDE02241,Lateral acceleration sensor 1,0.25, m/s²
IDE02244-ENG98646,Lateral acceleration sensor 2: status-Initializing,No,
IDE02244-ENG101274,Lateral acceleration sensor 2: status-Not assembled,No,
IDE02244-ENG101756,Lateral acceleration sensor 2: status-Permanent Error,No,
IDE02244-ENG102842,Lateral acceleration sensor 2: status-Sporadic Error,No,
IDE02245,Lateral acceleration sensor 2,0.26, m/s²
IDE02538,Longitudinal acceleration sensor,0.04, m/s²
IDE02539,Longitudinal acceleration sensor: temperature,44, °C
IDE02540-ENG98646,Longitudinal acceleration sensor: status-Initializing,No,
IDE02540-ENG101274,Longitudinal acceleration sensor: status-Not assembled,No,
IDE02540-ENG101756,Longitudinal acceleration sensor: status-Permanent Error,No,
IDE02540-ENG102842,Longitudinal acceleration sensor: status-Sporadic Error,No,
IDE02541,Transverse acceleration sensor 1: temperature,44, °C
IDE02542,Transverse acceleration sensor 2: temperature,40, °C
IDE02543,Body acceleration sensor,9.81, m/s²
IDE02544,Body acceleration sensor: temperature,44, °C
IDE02545-ENG98646,Body acceleration sensor: status-Initializing,No,
IDE02545-ENG101274,Body acceleration sensor: status-Not assembled,No,
IDE02545-ENG101756,Body acceleration sensor: status-Permanent Error,No,
IDE02545-ENG102842,Body acceleration sensor: status-Sporadic Error,No,
IDE02546,Roll rate sensor,0.00, rad/s
IDE02547,Roll rate sensor: temperature,47, °C
IDE02548-ENG98646,Roll rate sensor: status-Initializing,No,
IDE02548-ENG101274,Roll rate sensor: status-Not assembled,No,
IDE02548-ENG101756,Roll rate sensor: status-Permanent Error,No,
IDE02548-ENG102842,Roll rate sensor: status-Sporadic Error,No,
IDE02549,Pitch rate sensor,0.00, rad/s
IDE02550,Pitch rate sensor: temperature,44, °C
IDE02551-ENG98646,Pitch rate sensor: status-Initializing,No,
IDE02551-ENG101274,Pitch rate sensor: status-Not assembled,No,
IDE02551-ENG101756,Pitch rate sensor: status-Permanent Error,No,
IDE02551-ENG102842,Pitch rate sensor: status-Sporadic Error,No,
IDE02552,Yaw rate sensor,0.00, rad/s
IDE02553,Yaw rate sensor: temperature,44, °C
IDE02554-ENG98646,Yaw rate sensor: status-Initializing,No,
IDE02554-ENG101274,Yaw rate sensor: status-Not assembled,No,
IDE02554-ENG101756,Yaw rate sensor: status-Permanent Error,No,
IDE02554-ENG102842,Yaw rate sensor: status-Sporadic Error,No,
IDE02555,Yaw rate sensor 2,N/A---,
IDE02556,Yaw rate sensor 2: temperature,40, °C
IDE02557-ENG98646,Yaw rate sensor 2: status-Initializing,No,
IDE02557-ENG101274,Yaw rate sensor 2: status-Not assembled,No,
IDE02557-ENG101756,Yaw rate sensor 2: status-Permanent Error,No,
IDE02557-ENG102842,Yaw rate sensor 2: status-Sporadic Error,No,
IDE04553,VIN received,xxx,
IDE04554,VIN stored,xxx,
IDE06755-MAS05234,Inclination display-Value range: steering wheel angle 1 message,valid,
IDE06755-MAS05235,Inclination display-Initial range monitoring: steering wheel angle 1 message,No initial value,
IDE06755-MAS05236,Inclination display-Message counter: steering wheel angle 1 message,valid,
IDE06755-MAS05237,Inclination display-Checksum: steering wheel angle 1 message,valid,
IDE06755-MAS05242,Inclination display-Value range: ESP 3 message,Not exceeded,
IDE06755-MAS05243,Inclination display-Initial value monitoring: ESP 3 message,No initial value,
IDE06755-MAS05244,Inclination display-Message counter: ESP 3 message,valid,
IDE06755-MAS05245,Inclination display-Checksum: ESP 3 message,valid,
IDE06755-MAS05246,Inclination display-Value range: ESP 4 message,Not exceeded,
IDE06755-MAS05247,Inclination display-Initial value monitoring: ESP 4 message,No initial value,
IDE06755-MAS05250,Inclination display-Value range: ESP 5 message,Not exceeded,
IDE06755-MAS05251,Inclination display-Initial value monitoring: ESP 5 message,No initial value,
IDE06755-MAS05252,Inclination display-Message counter: ESP 5 message,valid,
IDE06755-MAS05253,Inclination display-Checksum: ESP 5 message,valid,
IDE06755-MAS05254,Inclination display-Value range: terminal status 1 message,Not exceeded,
IDE06755-MAS05255,Inclination display-Initial value monitoring: terminal status 1 message,No initial value,
IDE06755-MAS05256,Inclination display-Message counter: terminal status 1 message,valid,
IDE06755-MAS05257,Inclination display-Checksum: terminal status 1 message,valid,
IDE06755-MAS05258,Inclination display-Value range: engine 1 message,Not exceeded,
IDE06755-MAS05259,Inclination display-Initial value monitoring: engine 1 message,No initial value,
IDE06755-MAS05260,Inclination display-Message counter: engine 1 message,valid,
IDE06755-MAS05261,Inclination display-Checksum: engine 1 message,valid,
IDE06755-MAS05262,Inclination display-Value range: engine code 1 message,Not exceeded,
IDE06755-MAS05263,Inclination display-Initial value monitoring: engine code 1 message,No initial value,
IDE06755-MAS05264,Inclination display-Message counter: engine code 1 message,valid,
IDE06755-MAS05265,Inclination display-Checksum: engine code 1 message,valid,
IDE06755-MAS05266,Inclination display-Value range: engine 3 message,Not exceeded,
IDE06755-MAS05267,Inclination display-Initial value monitoring: engine 3 message,No initial value,
IDE06755-MAS05268,Inclination display-Message counter: engine 3 message,valid,
IDE06755-MAS05269,Inclination display-Checksum: engine 3 message,valid,
IDE06755-MAS05270,Inclination display-Value range: SCU 1 message,Not exceeded,
IDE06755-MAS05271,Inclination display-Initial value monitoring: SCU 1 message,No initial value,
IDE06755-MAS05272,Inclination display-Message counter: SCU 1 message,valid,
IDE06755-MAS05273,Inclination display-Checksum: SCU 1 message,valid,
IDE06755-MAS05274,Inclination display-Value range: QSP 2 message,Not exceeded,
IDE06755-MAS05275,Inclination display-Initial value monitoring: QSP 2 message,No initial value,
IDE06755-MAS05276,Inclination display-Message counter: QSP 2 message,valid,
IDE06755-MAS05277,Inclination display-Checksum: QSP 2 message,valid,
IDE06755-MAS05278,Inclination display-Value range: BAP_inclination display message,Not exceeded,
IDE06755-MAS05279,Inclination display-Initial value monitoring: BAP_inclination display message,No initial value,
IDE06755-MAS05282,Inclination display-Status: longitudinal speed: input,00,
IDE06755-MAS05283,Inclination display-Status: roll angle,OK,
IDE06755-MAS05284,Inclination display-Status: pitch angle,OK,
IDE06755-MAS05285,Inclination display-Inclination display in MMI,not activated,
IDE06755-MAS05286,Inclination display-Roll angle,0.0, °
IDE06755-MAS05287,Inclination display-Pitch angle,0.0, °
IDE06755-MAS05288,Inclination display-Estimated error in roll angle,0.0, °
IDE06755-MAS05289,Inclination display-Estimated error in pitch angle,0.0, °
IDE06755-MAS05290,Inclination display-Estimated offset error of roll rate sensor,0.00, °/s
IDE06755-MAS05292,Inclination display-Estimated offset error of yaw rate sensor,0.00, °/s
IDE06755-MAS05293,Inclination display-Estimated offset error of longitudinal acceleration sensor,0.00, m/s²
IDE06755-MAS05294,Inclination display-Estimated offset error of transverse acceleration sensor,0.00, m/s²
IDE06755-MAS05295,Inclination display-Estimated offset error of vertical acceleration sensor,0.00, m/s²
IDE06755-MAS05296,Inclination display-Inclination display activation request,00,
IDE06755-MAS05298,Inclination display-Longitudinal acceleration: input,36.5, m/s
IDE06755-MAS05299,Inclination display-Angle calculation: status 1,00,
IDE06755-MAS05300,Inclination display-Angle calculation: status 2,00,
IDE06755-MAS05301,Inclination display-Angle calculation: status 3,00,
IDE06755-MAS05302,Inclination display-Angle calculation: status 4,00,
IDE06755-MAS05391,Inclination display-Average time between DPF regenerations,0.00, °/s
IDE06755-MAS05782,Inclination display-Value range: EPB 1 message,Not exceeded,
IDE06755-MAS05783,Inclination display-Initial value monitoring: EPB 1 message,No initial value,
IDE06755-MAS05784,Inclination display-Message counter: EPB 1 message,valid,
IDE06755-MAS05785,Inclination display-Checksum: EPB 1 message,valid,
IDE06755-MAS05786,Inclination display-Value range: transmission 3 message,Not exceeded,
IDE06755-MAS05787,Inclination display-Initial value monitoring: transmission 3 message,No initial value,
IDE06755-MAS05788,Inclination display-Message counter: transmission 3 message,valid,
IDE06755-MAS05789,Inclination display-Checksum: transmission 3 message,valid,
IDE06755-MAS05790,Inclination display-Estimated installation error in direction of roll angle,0.00, °
IDE06755-MAS05791,Inclination display-Estimated installation error in direction of pitch angle,0.00, °
IDE06755-MAS06248,Inclination display-Status reset adaptation values,OK,
ENG109846,VBG2 (Internal 2.54V bandgap reference voltage of NCV33161),2.5, V
ENG109846-ENG98933,VBG2 (Internal 2.54V bandgap reference voltage of NCV33161)-Status,valid,
Elapsed Time: 00:04
;SW:4T0-907-441   HW:5Q0-907-441-A ---  Back-up Cam.
;Component:LB72x RVC Mid H07 0030, Coding:080004010201000300
;EV_CamSysRearPANAAU914,002002,EV_CamSysRearPANAAU914.rod
;Sunday,17,May,2020,20:02:47:06485
;VCID: 71AAD713A0B04F0EF4-8024
Elapsed Time: 00:08
;Sunday,17,May,2020,20:02:44:06485
IDE00019,Voltage terminal 30,11.88, V
IDE00075,Vehicle speed,0.00, km/h
IDE00303-MAS00222,Status of doors/lids 1-Rear lid,Open,
IDE00303-MAS00223,Status of doors/lids 1-Hood,closed,
IDE00303-MAS01374,Status of doors/lids 1-Trailer,detected,
IDE00322,Status of basic setting,was not yet started,
IDE00773,Terminal 15 status via CAN,On,
IDE00924-MAS02983,Steering angle-Steering wheel angle,11.200, °
IDE00924,Steering angle,0.600, °
IDE01164,Park assist button,Not available,
IDE01714,Status reverse gear,not selected,
IDE02322,Parking aid indicator light,Not available,
IDE02486,Data logger triggering,not active,
IDE03619,System status,passive,
IDE04515,Supply voltage for camera,6.14, V
IDE07199-IDE00787,Calculation of runtime data for assistance line representation-Cause for cancellation,no error,
IDE07199-MAS01632,Calculation of runtime data for assistance line representation-Status,locked,
IDE07199-MAS04389,Calculation of runtime data for assistance line representation-Number of repeat attempts,0,
IDE07199-MAS05634,Calculation of runtime data for assistance line representation-Progress,0, %
IDE07402,External activation,Not available,
MAS00037-MAS05746,Calibration status-Rearview camera calibration status,Calibration ended,
MAS00037-MAS05747,Calibration status-Side camera calibration status,not coded/not installed,
MAS00037-MAS05748,Calibration status-Rearview camera calibration progress,0, %
MAS00037-MAS05749,Calibration status-Side camera calibration progress,0, %
MAS00037-MAS05750,Calibration status-Rearview camera calibration repeat attempts,0,
MAS00037-MAS05751,Calibration status-Side camera calibration repeat attempts,0,
MAS00037-MAS05753,Calibration status-Cause of rearview camera calibration error,no error,
MAS00037-MAS05754,Calibration status-Cause of side camera calibration error,Calibration not yet performed,
MAS00037-MAS05802,Calibration status-Side camera calibration resumption,No resumption,
MAS00037-MAS05803,Calibration status-Rearview camera calibration resumption,No resumption,
MAS00464-MAS00106,Standard - ambient data 1-Year,2012,
MAS00464-MAS00107,Standard - ambient data 1-Month,1,
MAS00464-MAS00108,Standard - ambient data 1-Day,9,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,32,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,1,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,227, counts
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,38769, km
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 20 41 00 00 20 41 00 00 20 41 00 00 48 42 00 00 48 42 00 00 48 42 00 00 80 40,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,0, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,5,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,4,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,0, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,1109393408, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,full size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,0, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,0, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,1165529088, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,0, mm
ENG119197-ENG119083,camera_calibration_parameters-Cam1 Calibration Result judgment,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG119197-ENG119073,camera_calibration_parameters-Cam1 Changing default data - Ground to Camera Z,0, mm
ENG119197-ENG119074,camera_calibration_parameters-Cam1 Changing default data - Ground to wheel arch Z,0, mm
ENG119197-ENG119081,camera_calibration_parameters-Cam1 division counts horizontal,0,
ENG119197-ENG119082,camera_calibration_parameters-Cam1 division counts vertical,0,
ENG119197-ENG119075,camera_calibration_parameters-Cam1 Fixed value input - Ground to Camera Z,0, mm
ENG119197-ENG119076,camera_calibration_parameters-Cam1 Fixed value input - Ground to wheel arch Z,0, mm
ENG119197-ENG119080,camera_calibration_parameters-Cam1 height of marker,0, mm
ENG119197-ENG119077,camera_calibration_parameters-Cam1 Marker size Full-size or Half-size,full size,
ENG119197-ENG119071,camera_calibration_parameters-Cam1 Transversal position front axle,0, mm
ENG119197-ENG119072,camera_calibration_parameters-Cam1 Transversal position rear axle,0, mm
ENG119197-ENG119078,camera_calibration_parameters-Cam1 X direction of marker red ribbon,0, mm
ENG119197-ENG119079,camera_calibration_parameters-Cam1 Y direction of marker,0, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,1050362447, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,3209147546, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,3196227262, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,1066525965, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,3238563168, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,3213268183, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,1093970629, mm
ENG119196-ENG119097,camera_calibration_tolerance-SV_Calibration_Result,0, px
ENG119196-ENG119091,camera_calibration_tolerance-SV_Calibration_Tolerance_alpha,0, °
ENG119196-ENG119092,camera_calibration_tolerance-SV_Calibration_Tolerance_beta,0, °
ENG119196-ENG119093,camera_calibration_tolerance-SV_Calibration_Tolerance_gamma,0, °
ENG119196-ENG119094,camera_calibration_tolerance-SV_Calibration_Tolerance_x,0, mm
ENG119196-ENG119095,camera_calibration_tolerance-SV_Calibration_Tolerance_y,0, mm
ENG119196-ENG119096,camera_calibration_tolerance-SV_Calibration_Tolerance_z,0, mm
Elapsed Time: 00:03
;SW:4S0-907-376-B   HW:4S0-907-376-B ---  Susp. Elect.
;Component:DAEMPFUNGS-SG H05 0062, Coding:
;EV_AudiMagneRide,002007,EV_AudiMagneRide.rod
;Sunday,17,May,2020,19:39:15:06485
;VCID: 393A2F33B840C74E0C-806C
IDE00820-ENG119636-Activating and deactivating all development messages-DEV_Unit_0103,not activated ,4
IDE00820-ENG119637-Activating and deactivating all development messages-DEV_Unit_0104,not activated ,4
IDE00820-ENG110578-Activating and deactivating all development messages-S_100,not activated ,4
IDE00820-ENG110579-Activating and deactivating all development messages-S_101,not activated ,4
IDE00820-ENG110580-Activating and deactivating all development messages-S_102,not activated ,4
IDE00820-ENG119638-Activating and deactivating all development messages-Set_internal_fault_code,00 00 00 ,4
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,Development ,4
IDE04891-IDE02001-Adapting high values-Body height left front wheel house edge,376 mm,8
IDE04891-IDE02002-Adapting high values-Body height right front wheel house edge,377 mm,8
IDE04891-IDE02003-Adapting high values-Body height left rear wheel house edge,402 mm,8
IDE04891-IDE02004-Adapting high values-Body height right rear wheel house edge,403 mm,8
ENG119639-Enable Constant current on all dampers,not activated ,1
ENG119640-Enable Damper test mode,not activated ,1
Elapsed Time: 00:01
;Sunday,17,May,2020,19:39:10:06485
IDE00019,Voltage terminal 30,12.1, V
IDE00102-MAS05627,Control Module temperature-Activation front axle,34, °C
IDE00102-MAS05628,Control Module temperature-Activation rear axle,34, °C
IDE00767-MAS01478,No. of unscheduled ECU resets-Insuff. voltage,50,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE00773,Terminal 15 status via CAN,Terminal 15 on,
IDE03055-MAS00816,Currently set shock absorber code-normal,active,
IDE03055-MAS01439,Currently set shock absorber code-reduced,not active,
IDE03055-MAS05624,Currently set shock absorber code-Constant current,not active,
IDE03055-MAS05625,Currently set shock absorber code-without current,not active,
IDE03055-MAS05626,Currently set shock absorber code-Damping test,not active,
IDE04434,Damping adjustment indicator lamp,OFF,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE04805-MAS05375,Driving profile selection-Driving profile,performed,
IDE04805-MAS05629,Driving profile selection-Driving profile: specified value,1,
IDE04805-MAS05630,Driving profile selection-Driving profile: actual value,1,
IDE04805-MAS05631,Driving profile selection-System status,Available,
IDE04805-MAS13138,Driving profile selection-Driving profile: actual value in the RAM,1,
IDE05437,Outside air temperature via CAN,23.5, °C
IDE06425,Roller test bench mode: functional,0,
IDE07141-MAS01853,Wiring resistance-Left front,0.40, Ohm
IDE07141-MAS01854,Wiring resistance-Right front,0.32, Ohm
IDE07141-MAS01855,Wiring resistance-Left rear,0.38, Ohm
IDE07141-MAS01856,Wiring resistance-Right rear,0.28, Ohm
IDE07142,Time since terminal 15 off,3700, s
IDE07143-MAS03096,Vehicle level sensor: supply voltage-Voltage 1,5.0, V
IDE07143-MAS03097,Vehicle level sensor: supply voltage-Voltage 2,5.0, V
IDE07144,ESP automatic engagement,not activated,
IDE07146-MAS01853,Dampening adjustment valve: resistance-Left front,1.70, Ohm
IDE07146-MAS01854,Dampening adjustment valve: resistance-Right front,1.64, Ohm
IDE07146-MAS01855,Dampening adjustment valve: resistance-Left rear,1.68, Ohm
IDE07146-MAS01856,Dampening adjustment valve: resistance-Right rear,1.58, Ohm
IDE07147-MAS01853,Dampening adjustment: current Highside-Left front,-3, mA
IDE07147-MAS01854,Dampening adjustment: current Highside-Right front,-8, mA
IDE07147-MAS01855,Dampening adjustment: current Highside-Left rear,-16, mA
IDE07147-MAS01856,Dampening adjustment: current Highside-Right rear,3, mA
IDE07148-MAS01853,Dampening adjustment valve: current Lowside-Left front,-11, mA
IDE07148-MAS01854,Dampening adjustment valve: current Lowside-Right front,-14, mA
IDE07148-MAS01855,Dampening adjustment valve: current Lowside-Left rear,-8, mA
IDE07148-MAS01856,Dampening adjustment valve: current Lowside-Right rear,-5, mA
IDE07149-MAS01853,Vehicle level sensor: frequency-Left front,790, Hz
IDE07149-MAS01854,Vehicle level sensor: frequency-Right front,790, Hz
IDE07149-MAS01855,Vehicle level sensor: frequency-Left rear,800, Hz
IDE07149-MAS01856,Vehicle level sensor: frequency-Right rear,790, Hz
IDE07150-MAS01853,Dampening adjustment valve: temperature-Left front,25, °C
IDE07150-MAS01854,Dampening adjustment valve: temperature-Right front,24, °C
IDE07150-MAS01855,Dampening adjustment valve: temperature-Left rear,23, °C
IDE07150-MAS01856,Dampening adjustment valve: temperature-Right rear,23, °C
IDE07150-MAS05618,Dampening adjustment valve: temperature-Front left: calculated,46, °C
IDE07150-MAS05619,Dampening adjustment valve: temperature-Front right: calculated,45, °C
IDE07150-MAS05620,Dampening adjustment valve: temperature-Rear left: calculated,43, °C
IDE07150-MAS05621,Dampening adjustment valve: temperature-Rear right: calculated,43, °C
IDE07151-MAS01853,Vehicle level sensor: raw value-Left front,73.6, %
IDE07151-MAS01854,Vehicle level sensor: raw value-Right front,73.6, %
IDE07151-MAS01855,Vehicle level sensor: raw value-Left rear,75.2, %
IDE07151-MAS01856,Vehicle level sensor: raw value-Right rear,79.6, %
IDE07152,Fall-back level,00 00 00 00,
IDE07153,End-of-line Status,0F,
IDE07154,ESP status,0,
IDE07162,Dampening adjustment valve: Temperature at terminal 15 on,26, °C
IDE07177-MAS01632,Status Output DTM damper front left-Status,not active,
IDE07177-MAS05584,Status Output DTM damper front left-Result,Unknown status,
IDE07178-MAS01632,Status Output DTM damper front right-Status,not active,
IDE07178-MAS05584,Status Output DTM damper front right-Result,Unknown status,
IDE07179-MAS01632,Status Output DTM damper rear left-Status,not active,
IDE07179-MAS05584,Status Output DTM damper rear left-Result,Unknown status,
IDE07180-MAS01632,Status Output DTM damper rear right-Status,not active,
IDE07180-MAS05584,Status Output DTM damper rear right-Result,Unknown status,
IDE07187-MAS01853,Level control system sensor-Left front,301, mm
IDE07187-MAS01854,Level control system sensor-Right front,300, mm
IDE07187-MAS01855,Level control system sensor-Left rear,328, mm
IDE07187-MAS01856,Level control system sensor-Right rear,321, mm
IDE07187-MAS05610,Level control system sensor-Calibration,calibrated,
IDE08127-MAS01853,Vehicle level sensor: offset-Left front,4.8, %
IDE08127-MAS01854,Vehicle level sensor: offset-Right front,5.2, %
IDE08127-MAS01855,Vehicle level sensor: offset-Left rear,5.6, %
IDE08127-MAS01856,Vehicle level sensor: offset-Right rear,4.0, %
IDE11646,Front axle lifting system: status,depth level,
Elapsed Time: 00:04
;SW:4G0-959-655-B   HW:4G0-959-655-B ---  Airbags
;Component:Airbag10.43   H62 0086, Coding:303333343033303030364A55304C34543053
;EV_AirbaAU10BPAAU64X,001014,EV_AirbaAU10BPAAU64X_VW51.rod
;Sunday,17,May,2020,19:39:33:06485
;VCID: 34241E079F223A26DF-8060
MAS00975-IDE00947-Airbag adaptations-driver side rear curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Frt.passenger side rear curtain airbag igniter,not defined ,8
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,not defined ,8
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,not defined ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,activated ,8
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,activated ,8
MAS00975-MAS00023-Airbag adaptations-Driver side active head restraint igniter,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined ,8
Elapsed Time: 00:01
;Sunday,17,May,2020,19:39:19:06485
IDE00821-ENG102113,Safety belt switch 2nd row driver side-Measured values,not installed,
IDE00822-ENG102113,Safety belt switch 2nd row frt.passenger side-Measured values,not installed,
IDE00823-ENG102113,Safety belt switch 2nd row center-Measured values,not installed,
IDE00919-ENG102168,Driver side airbag igniter ohm value-Measured Value Resistance,3.1, Ohm
IDE00956,Occupation status: frt.passenger seat,Adult,
IDE01099-ENG102168,Driver side airbag igniter 2 ohm value-Measured Value Resistance,3.1, Ohm
IDE01100-ENG102168,Passenger side airbag igniter ohm value-Measured Value Resistance,2.2, Ohm
IDE01101-ENG102168,Passenger side airbag igniter 2 ohm value-Measured Value Resistance,2.1, Ohm
IDE01102-ENG102168,Driver's side airbag igniter ohm value-Measured Value Resistance,2.4, Ohm
IDE01103-ENG102168,Passenger side side airbag igniter ohm value-Measured Value Resistance,2.3, Ohm
IDE01104-ENG102168,driver side rear airbag igniter ohm value-Measured Value Resistance,too High,
IDE01105-ENG102168,Ft. pass.side rear airbag igniter ohm value-Measured Value Resistance,too High,
IDE01106-ENG102168,Driver side head curtain airbag igniter ohm value-Measured Value Resistance,too High,
IDE01107-ENG102168,Frt.pass. side head curtain airbag igniter ohm value-Measured Value Resistance,too High,
IDE01108-ENG102168,Driver side knee airbag igniter ohm value-Measured Value Resistance,2.2, Ohm
IDE01109-ENG102168,Frt.pass. side knee airbag igniter ohm value-Measured Value Resistance,2.1, Ohm
IDE01110-ENG102168,Driver side belt tensioner igniter ohm value-Measured Value Resistance,2.3, Ohm
IDE01111-ENG102168,Frt.pass. side belt tensioner igniter ohm value-Measured Value Resistance,2.3, Ohm
IDE01114-ENG102168,Driver side belt force limiter igniter ohm value-Measured Value Resistance,2.2, Ohm
IDE01115-ENG102168,side belt force limiter igniter ohm value-Measured Value Resistance,2.2, Ohm
IDE01116-ENG102168,driver side rear belt tensioner igniter ohm value-Measured Value Resistance,too High,
IDE01117-ENG102168,Passenger side rear belt tensioner igniter ohm value-Measured Value Resistance,too High,
IDE01118-ENG102168,Rear center belt tensioner igniter ohm value-Measured Value Resistance,too High,
IDE01119-ENG102168,Battery open circuit igniter ohm value-Measured Value Resistance,2.3, Ohm
IDE01120-ENG102168,Driver side active head restraint igniter ohm value-Measured Value Resistance,no measured value present,
IDE01121-ENG102168,Passenger side active head restraint igniter ohm value-Measured Value Resistance,no measured value present,
IDE01193-ENG101856,Driver belt tensioner ohm value-Measured Value Resistance 2,408.0, Ohm
IDE01194-ENG101856,Frt.pass. belt tensioner ohm value-Measured Value Resistance 2,408.0, Ohm
IDE01195-ENG101856,Front passenger side seat occupancy detection: Ohm value-Measured Value Resistance 2,no measured value present,
IDE01197-ENG100392,Key switch contact 1 ohm value-Measured Value Resistance 3,too High,
IDE01198-ENG100392,Key switch contact 2 ohm value-Measured Value Resistance 3,too High,
IDE01200-ENG102389,Driver seat position sensor current value-Current  measured value:,5.7, mA
IDE01201-ENG102389,Frt.pass. seat position sensor current value-Current  measured value:,5.7, mA
IDE01205-ENG101856,Safety belt switch 2nd row driver side ohm value-Measured Value Resistance 2,no measured value present,
IDE01206-ENG101856,Safety belt switch 2nd row frt.pass. side ohm value-Measured Value Resistance 2,no measured value present,
IDE01207-ENG101856,Safety belt switch center 2nd row ohm value-Measured Value Resistance 2,no measured value present,
IDE01357-ENG102113,Auslöser für Fußgängerschutz links-Measured values,correct,
IDE01358-ENG102113,Auslöser für Fußgängerschutz rechts-Measured values,correct,
IDE01555,Number of frontal crashes,0,
IDE01556,Number of side crashes driver side,0,
IDE01557,Number of side crashes frt.pass. side,0,
IDE01558,Number of rear crashes,0,
IDE01559,Number of rollover crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE01634-ENG102168,Pedestrian protection trigger: driver side ohmic value-Measured Value Resistance,too High,
IDE01635-ENG102168,Pedestrian protection trigger: frt.pass. side ohmic value-Measured Value Resistance,too High,
IDE02246,Number of activations of pedestrian protection,0,
IDE02852-ENG102113,Igniter for battery interrupt: high voltage battery-Measured values,cannot be measured currently,
IDE02853-ENG102168,Igniter for batt. interrupt: high volt. batt. ohm value-Measured Value Resistance,no measured value present,
IDE03730-ENG102168,Igniter for driver side air bag release valve: ohm value-Measured Value Resistance,too High,
IDE03731-ENG102168,Igniter for frt.pass. side air bag release valve: ohm value-Measured Value Resistance,2.2, Ohm
IDE03800-ENG102113,Driver airbag release valve igniter-Measured values,correct,
IDE03801-ENG102113,Frt.pass. airbag release valve igniter-Measured values,correct,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,00,
IDE03871-ENG99733,Seat occupied recognition real part-Measured Value Capacitance,1.3, pF
IDE03872-ENG99733,Seat occupied recognition imaginary part-Measured Value Capacitance,60.3, pF
IDE03873-ENG99733,Seat occupied recognition compensated imaginary part-Measured Value Capacitance,60.3, pF
IDE03874-ENG101058,Seat occupied recognition loop resistance-Measured Value Resistance 4,24.5, Ohm
IDE06034-ENG102113,Rollover protection trigger: driver side-Measured values,cannot be measured currently,
IDE06035-ENG102113,Rollover protection trigger: frt.pass. side-Measured values,cannot be measured currently,
IDE06036-ENG102168,Rollover protection trigger: driver side ohm value-Measured Value Resistance,no measured value present,
IDE06038-ENG102168,Rollover protection trigger: frt.pass. side ohm value-Measured Value Resistance,no measured value present,
MAS00001-ENG102113,Driver airbag igniter-Measured values,correct,
MAS00002-ENG102113,Driver airbag igniter 2-Measured values,correct,
MAS00003-ENG102113,Passenger airbag igniter-Measured values,correct,
MAS00004-ENG102113,Front passenger airbag igniter 2-Measured values,correct,
MAS00005-ENG102113,Driver thorax airbag igniter-Measured values,correct,
MAS00006-ENG102113,Front passenger side airbag igniter-Measured values,correct,
MAS00007-ENG102113,Driver side rear thorax airbag igniter-Measured values,correct,
MAS00008-ENG102113,Passenger side rear thorax airbag igniter-Measured values,correct,
MAS00009-ENG102113,Driver head curtain airbag igniter-Measured values,correct,
MAS00010-ENG102113,Front passenger head curtain airbag igniter-Measured values,correct,
MAS00011-ENG102113,Driver knee airbag igniter-Measured values,correct,
MAS00012-ENG102113,Front passenger knee airbag igniter-Measured values,correct,
MAS00013-ENG102113,Driver side seat belt tension igniter-Measured values,correct,
MAS00014-ENG102113,Front passenger side seat belt tension igniter-Measured values,correct,
MAS00017-ENG102113,Driver side belt force limiter igniter-Measured values,correct,
MAS00018-ENG102113,Front passenger side belt force limiter igniter-Measured values,correct,
MAS00019-ENG102113,Driver side rear safety belt tension igniter-Measured values,correct,
MAS00020-ENG102113,Passenger side rear safety belt tension igniter-Measured values,correct,
MAS00021-ENG102113,Center rear seat belt tensioner igniter-Measured values,correct,
MAS00022-ENG102113,Igniter for battery interrupt-Measured values,correct,
MAS00023-ENG102113,Driver side active head restraint igniter-Measured values,cannot be measured currently,
MAS00024-ENG102113,Igniter for active head restraint on frt. passenger side-Measured values,cannot be measured currently,
MAS00025-ENG102113,Driver seat belt switch-Measured values,not connected,
MAS00026-ENG102113,Front passenger side safety belt switch-Measured values,not connected,
MAS00030-ENG102113,Seat occupied recognition-Measured values,assigned,
MAS00031-ENG102113,Airbag deactivation status-Measured values,On,
MAS00032-ENG102113,Key switch terminal 1-Measured values,not installed,
MAS00033-ENG102113,Key switch terminal 2-Measured values,not installed,
MAS00035-ENG102113,Seat position sensor: driver side-Measured values,Rear,
MAS00036-ENG102113,Seat position sensor: front passenger side-Measured values,Rear,
MAS00037,Calibration status,0,
MAS00044-ENG101458,Supply voltage: Terminal 15-Measured Value Voltage,11.9, V
MAS01634-ENG102113,Supply voltage-Measured values,correct,
Elapsed Time: 00:13
;SW:4T0-907-468-A   HW:4S0-907-468 ---  CAN Gateway
;Component:J533--Gateway H14 0065, Coding:0009071600
;EV_GatewPkoUDS,001027,EV_GatewPkoUDS_001_AU57.rod
;Sunday,17,May,2020,19:26:58:06485
;VCID: 3B36353BB27CF55E1E-806E
IDE00001-Production mode,not active ,3
IDE00002-Transport mode,not active ,1
IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1
IDE00859-Counter of sporadic MOST-ring disruptions,356 ,3
IDE00860-Timer of sporadic MOST-ring disruptions,15000 ,3
IDE01211-Static current measuring mode,not active ,1
IDE01457-Energy management deactivation stage,- ,1
IDE01847-Auxiliary heater activation restriction request-,- ,2
IDE01847-ENG100234-Auxiliary heater activation restriction request-park_heater_target_time,not active ,2
IDE01862-Switch-over LIN flash mode,normal ,1
IDE01863-MOST light performance,Decrease 0 dB ,1
IDE03256-IDE00010-Battery adaptation-Serial number,---------- ,12
IDE03256-MAS03159-Battery adaptation-Manufacturer,MLA ,12
IDE03256-MAS04490-Battery adaptation-Size,Unknown ,12
IDE03903-Production process data 1,BB 00 00 00 ,4
IDE03904-Production process data 2,00 00 00 00 ,4
IDE03905-Production process data 3,00 00 00 00 ,4
IDE04159-Deactivation of start-stop function,OFF ,1
IDE06417-IDE00010-Battery adaptation 2-Serial number,---------- ,12
IDE06417-MAS03159-Battery adaptation 2-Manufacturer,Unknown ,12
IDE06417-MAS04490-Battery adaptation 2-Size,Unknown ,12
IDE06425-Roller test bench mode: functional,0 ,1
IDE06748-Pause recommendation,active ,1
IDE06753-ENG152429-Efficiency program display-Climate control,Yes ,4
IDE06753-ENG152461-Efficiency program display-Fahrstufe D verwenden,Yes ,4
IDE06753-ENG152460-Efficiency program display-Gaspedal im Stand nicht betätigen,Yes ,4
IDE06753-ENG152482-Efficiency program display-Klima Ein Fenster schliessen,Yes ,4
IDE06753-ENG152484-Efficiency program display-Klima Ein Fenster und Schiebedach,Yes ,4
IDE06753-ENG152483-Efficiency program display-Klima Ein Schiebedach schliessen,Yes ,4
IDE06753-ENG152485-Efficiency program display-Klima Ein Verdeck offen,Yes ,4
IDE06753-ENG152432-Efficiency program display-Left heated seat,Yes ,4
IDE06753-ENG152434-Efficiency program display-Left seat ventilation,Yes ,4
IDE06753-ENG152478-Efficiency program display-LuftWD Fenster u Schiebedachsc,Yes ,4
IDE06753-ENG152476-Efficiency program display-LuftWD Fensterschliessen,Yes ,4
IDE06753-ENG152477-Efficiency program display-LuftWD Schiebedachschliessen,Yes ,4
IDE06753-ENG152437-Efficiency program display-Mirror heater,Yes ,4
IDE06753-ENG152431-Efficiency program display-Motorbremse,Yes ,4
IDE06753-ENG152458-Efficiency program display-Motorstart ohne Gaspedal,Yes ,4
IDE06753-ENG152459-Efficiency program display-Motorwarmlauf vermeiden,Yes ,4
IDE06753-ENG152472-Efficiency program display-Nebel_Scheinwerfer,Yes ,4
IDE06753-ENG152473-Efficiency program display-Nebel_Schlussleuchte,Yes ,4
IDE06753-ENG152436-Efficiency program display-Parking heater,Yes ,4
IDE06753-ENG152427-Efficiency program display-Rear window defogger,Yes ,4
IDE06753-ENG152433-Efficiency program display-Right heated seat,Yes ,4
IDE06753-ENG152435-Efficiency program display-Right seat ventilation,Yes ,4
IDE06753-ENG152479-Efficiency program display-Schaltanzeige beachten,Yes ,4
IDE06753-ENG152475-Efficiency program display-Sitzheizung_Sitzlueftung_im_Fond,Yes ,4
IDE06753-ENG152474-Efficiency program display-Standheizung_Verbrauch,Yes ,4
IDE06753-ENG152481-Efficiency program display-Start-Stopp einschalten,Yes ,4
IDE06753-ENG152480-Efficiency program display-Start-Stopp nutzen,Yes ,4
IDE06753-ENG152430-Efficiency program display-Steering wheel heater,Yes ,4
IDE06753-ENG152426-Efficiency program display-Windshield defogger,Yes ,4
IDE08528-MAS07123-Service-key: extended settings-Distance for activation,50 km,3
IDE08528-MAS07124-Service-key: extended settings-Lower speed threshold,40 km/h,3
IDE08528-MAS07125-Service-key: extended settings-Upper speed threshold,100 km/h,3
MAS00468-Unlearning counter,227 ,1
ENG105057-Activate_ECU_Monitor,not active ,1
ENG105321-ENG101306-BEM KM Boundary Setting-qrsmode_deactivation_border_BEM KM Boundary Setting,2 ,6
ENG105321-ENG103942-BEM KM Boundary Setting-transportmode_deactivation_border_BEM KM Boundary Setting,50 ,6
ENG113394-EPS Leistungsanforderung neu,- ,1
ENG106577-Flexray Tx-Konflikt Detection,active ,1
ENG113395-Hybrid_Zustart,- ,1
ENG110998-Lokal Aktiv Chronik,not active ,1
ENG107871-ENG98417-NWDF Control-Anpassung,not active ,3
ENG107871-ENG103325-NWDF Control-NWDF-Bit,1 ,3
ENG107871-ENG101466-NWDF Control-NWDF-QBit,1 ,3
ENG108152-ENG99814-Parametrization_ECU_Monitor-AdaptiveOpenFilter_CountDelay,1800 s,43
ENG108152-ENG101074-Parametrization_ECU_Monitor-AdaptiveOpenFilterTime,6000 s,43
ENG108152-ENG102686-Parametrization_ECU_Monitor-Max_MMI_Off_Time,11 s,43
ENG108152-ENG99272-Parametrization_ECU_Monitor-Max_MMI_On_Time,1800 s,43
ENG108152-ENG99340-Parametrization_ECU_Monitor-Max_MMI_Standby_Time,90 s,43
ENG108152-ENG100899-Parametrization_ECU_Monitor-Max_MOST_Shutdowm_Query_Time,3 s,43
ENG108152-ENG100287-Parametrization_ECU_Monitor-Max_Num_Car_WakeUp_Events,10 ,43
ENG108152-ENG99074-Parametrization_ECU_Monitor-Max_Num_Keeping_Awake_Events,100 ,43
ENG108152-ENG103057-Parametrization_ECU_Monitor-Max_Num_Logical_WakeUp_Events,40 ,43
ENG108152-ENG104006-Parametrization_ECU_Monitor-Max_Num_Physical_WakeUp_Events,10 ,43
ENG108152-ENG103606-Parametrization_ECU_Monitor-Max_Time_Clamp15_Off_To_Shutdown_Query.,1901 s,43
ENG108152-ENG101206-Parametrization_ECU_Monitor-Max_Time_Light_On_After_Shutdown_Execute,3 s,43
ENG108152-ENG103242-Parametrization_ECU_Monitor-Max_Time_Shutdown_Query_To_Shutdown_Query,13 s,43
ENG108152-ENG101904-Parametrization_ECU_Monitor-Open_Filter_Wake_Time,60 s,43
ENG108152-ENG103852-Parametrization_ECU_Monitor-Sample_Time_Keeping_Awake_Events,12 s,43
ENG108152-ENG103196-Parametrization_ECU_Monitor-WakeUp_Monitor_Start_Delay,0 ms,43
ENG136921-MAS11289-Service_key_2_settings_CWU-Waiting time wake vehicle bus,15.00 s,3
ENG136921-MAS11290-Service_key_2_settings_CWU-Timeout time wake vehicle bus,1 s,3
ENG122797-ENG122802-Service_Key_Entwicklung-Retrycounter_Nrc,3 ,2
ENG122797-ENG122801-Service_Key_Entwicklung-Retrycounter_Timeout,3 ,2
ENG101693-Set_Diagnostic_Baudrate,500 kBaud ,1
ENG109015-ENG101259-Spiegelung von CCP / Entwicklungsbotschaften-messagetyp_Spiegelung von CCP / Entwicklungsbotschaften,Mirroring_of_all_CAN_messages ,2
ENG109015-ENG100981-Spiegelung von CCP / Entwicklungsbotschaften-source-bus_Spiegelung von CCP / Entwicklungsbotschaften,No_mirroring ,2
ENG109395-ENG101403-Testing Display BEM-alternator_diagnosis_Testing Display BEM,- ,4
ENG109395-ENG102609-Testing Display BEM-batterie_diagnosis_Testing Display BEM,- ,4
ENG109395-ENG101924-Testing Display BEM-batterie_status_Testing Display BEM,- ,4
ENG109395-ENG103309-Testing Display BEM-mmi_prewarning_Testing Display BEM,- ,4
Elapsed Time: 00:19
;Sunday,17,May,2020,19:26:20:06485
IDE00018,Voltage terminal 15,11.7, V
IDE00056,History data 1,2012-01-09-18:31*18.0*00*00042***
2012-01-09-00:30*24.0*00**
2000-01-01-00:00*00.0*00**
2000-01-01-00:00*00.0*00*00000***
2000-01-01-00:00*00.0*00**,
IDE00057,History data 2,2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00*00000**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**
2000-01-01-00:00*0000*000*+00.00*0-0-0-0-0-0*0*00**,
IDE00058,History data 3,2000-01-01-00:00*0*0*000*000*+00.00*0-0-0-0-0-0*0*0*00.0*00.0**
2000-01-01-00:00*0*0*000*000*+00.00*0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00059,History data 4,2000-01-01-00:00*00*---*---*----------*09983*07029*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**
2000-01-01-00:00*00*---*---*----------*00000*00000*0000*0000*0000**,
IDE00060,History data 5,2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**
2000-01-01-00:00*+00.00*+00.00*+00.00*00.00*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0*0*00.0*00.0*000.0*00*00*00**,
IDE00061,History data 6,2012-01-08-00:10*037*+23*-000.1*00.00**
2012-01-07-23:49*038*+23*-000.1*00.00**
2012-01-07-23:00*044*+23*-000.1*00.00**
2012-01-07-22:42*047*+23*-000.1*00.00**
2012-01-07-21:27*045*+23*-000.1*00.00**
2000-01-01-00:00*000*+00*+000.0*00.00**
2000-01-01-00:00*000*+00*+000.0*00.00**,
IDE00062,History data 7,2012-01-08-00:10*037*-000.4*042.5*00.2*00.2**
2012-01-08-00:00*037*-000.4*000.1*00.1*00.1**
2012-01-07-23:49*038*-000.7*000.1*00.1*00.1**
2012-01-07-23:00*038*-005.7*000.7*00.7*00.7**
2012-01-07-22:42*044*-003.5*000.2*00.2*00.2**
2012-01-07-22:36*047*-000.8*000.0*00.0*00.0**
2012-01-07-22:08*048*+001.1*000.4*00.4*00.4**
2012-01-07-22:07*047*+000.0*000.0*00.0*00.0**
2012-01-07-22:04*047*+000.2*000.0*00.0*00.0**
2012-01-07-21:58*047*+000.0*000.0*00.0*00.0**
2012-01-07-21:50*047*+000.1*000.1*00.1*00.1**
2012-01-07-21:48*047*+000.0*000.0*00.0*00.0**
2012-01-07-21:30*047*+002.1*000.2*00.1*00.1**
2012-01-07-21:28*045*+000.1*000.0*00.0*00.0**
2012-01-04-00:57*045*+001.0*092.9*01.7*01.6**
2000-01-01-00:00*044*+516.7*000.8*00.8*00.8**
2000-01-01-00:00*000*+000.0*000.0*00.0*00.0**
2000-01-01-00:00*000*+000.0*000.0*00.0*00.0**,
IDE00063,History data 8,2012-01-09-18:21*1*06*00*00*01*00*00*00*2000-01-01-00:00*00**
2012-01-08-00:11*1*05*00*00*01*00*00*00*2000-01-01-00:00*00**
2012-01-07-23:37*1*04*00*00*01*00*00*00*2000-01-01-00:00*00**
2012-01-07-20:40*1*03*00*00*01*00*00*00*2000-01-01-00:00*00**
2012-01-04-01:57*1*02*00*00*01*00*00*00*2000-01-01-00:00*00**,
IDE00064,History data 9,2012-01-04-00:09*074*084*077*042*07006*12.50*+19*00*12.70*00000*00000**
2000-01-01-00:00*000*000*000*000*00000*00.00*+00*00*00.00*00000*00000**
2000-01-01-00:00*000*000*000*000*00000*00.00*+00*00*00.00*00000*00000**,
IDE00065,History data 10,2000-01-01-00:00*0*000.0*0*000.0*0*000.0*00.00**
2000-01-01-00:00*0*0*0*00.00**
2000-01-01-00:00*0*000.0*00.00**
2000-01-01-00:00*00*00.00*00.00*00.00**
2000-01-01-00:00*00*00.00*00.00*00.00**,
IDE00066,History data 11,2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00*00000*00000*00000*00000*00000**
2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00**
2000-01-01-00:00*000*000*000*000*0000*000*00.0*00.0*000*000*000*000*00**,
IDE00067,History data 12,2000-01-01-00:00*0*000*000*+00*00*+00.0*+00.0*00.0*0**
00000*00000*00000**,
IDE00068,History data 13,2000-01-01-00:00*0-0-0-0-0*000.0*00000**
2000-01-01-00:00*0-0-0-0-0*000.0**
2000-01-01-00:00*0-0-0-0-0*000.0**,
IDE00069,History data 14,2000-01-01-00:00*00*---*---*----------*00000*00000**
2000-01-01-00:00*0*00*00*00*00*00**
00000*00000*00000**
2000-01-01-00:00*0-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**
2000-01-01-00:00*0*000*000*00*00000*00000**
IDE00070,History data 15,2000-01-01-00:00*000*00*00*000*00*00*000*00*00**
2000-01-01-00:00*000*00*00*000*00*00*000*00*00**,
IDE00071,History data 16,038769**
00000*00008*00008*00000*00000**
00006*00005*00001*00003**
00026*00000*00000*00000**
00000*00000*00000**
00006*00009*00003*00001**
00024*00004*00001**
00000*00000*00000**
00000*00000*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**
00004*00003*00000*00002*00007**,
IDE00102,Control Module temperature,33, °C
IDE00276,Position in MOST Ring,02,
IDE01803,History data 17,2000-01-01-00:00*0000*00*0**
0*0000*0000*00*00*0000*00**
0000*00*0000*00*0000*0000**
2000-01-01-00:00*+000*0000*000*0000*00*0000*00**
2000-01-01-00:00*+000*0000*000*0000*00*0000*00**,
IDE01807,History data 21,07080*2012-01-01-01:40*0000.4*05*0000.4*00*0000.0*00*0000.0*00*0000.0*00*0000.0**
06479*2012-09-10-03:22*0000.3*02*0000.3*c2*0000.3*00*0000.0*00*0000.0*00*0000.0**
06266*2012-06-28-23:11*0000.3*02*0000.3*c2*0000.3*00*0000.0*00*0000.0*00*0000.0**
06232*2012-06-10-18:08*0000.3*02*0000.3*c2*0000.3*00*0000.0*00*0000.0*00*0000.0**
06038*2012-04-23-20:08*0000.3*02*0000.3*c2*0000.3*00*0000.0*00*0000.0*00*0000.0**,
IDE01808,History data 22,19*00002*02*00002*05*00002*d0*00001*17*00001*ff*00001*c2*00001*53*00001*09*00001*42*00001**,
IDE01809,History data 23,05973*2012-04-10-21:10*0039.1*K*00041*06e2*0*06e3*0*06e3*1*06e3*1*06e3*1**
05893*2012-03-21-04:52*0018.5*K*00041*06e1*0*06e2*0*06e3*1*06e1*0*06e2*0**
05056*2019-05-08-19:02*0007.2*K*00042*06e3*0*06e3*0*06e3*0*06e3*0*06c2*0**
04802*2019-03-08-16:15*0006.2*P*00052*06d9*0*06c4*0*06d9*0*06c4*0*06d9*0**
04796*2019-03-07-18:40*0000.5*P*00049*06e1*1*06d9*0*06c4*0*06d9*0*06c4*0**,
IDE01810,History data 24,00000*2000-00-00-00:00*0000.0*0*00000*00000000*000*00000000*000*00000000*000*00000000*000*00000000*000**
00000*2000-00-00-00:00*0000.0*0*00000*00000000*000*00000000*000*00000000*000*00000000*000*00000000*000**,
IDE01811,History data 25,07229*2012-01-03-23:02*0024.9**
07229*2012-01-03-03:15*0005.0**
07214*2012-01-01-00:02*0000.0**
07211*2012-01-01-00:04*0000.0**
07211*2012-01-01-00:04*0000.0**,
IDE01812,History data 26,16512*02421*00134*00005*12402*00220*00771*01743**,
IDE01813,History data 27,16528*00581*00408*12351*01822*00000*00261**,
IDE01814,History data 28,07583*00100*00005*07593*00010**,
IDE01815,History data 29,00012*00000*00000*00000*00008*00000*00000*00004**,
IDE01816,History data 30,00008*00000*00001*00007*00000*00000*00000**,
IDE01817,History data 31,00004*00000*00000*00004*00000**,
IDE01818,History data 32,07246*2012-01-09-18:18*0042.3*06e1*1**
07246*2012-01-09-18:17*0042.3*06e2*0**
07246*2012-01-09-18:17*0042.3*06e1*0**
07246*2012-01-08-00:22*0000.1*06e1*0**,
IDE01819,History data 33,00000*2000-00-00-00:00*0000.0*00000000*0**
00000*2000-00-00-00:00*0000.0*00000000*0**,
IDE01820,History data 34,07246*2012-01-09-18:18*0042.3*06e1**
07246*2012-01-08-00:22*0000.1*06e2**
07246*2012-01-08-00:15*0000.0*06e1**
07246*2012-01-08-00:14*0000.0*06e1**
07242*2012-01-07-22:08*0000.0*06e1**,
IDE01821,History data 35,00011*00007*01144*00001*00000*00013*00000*00361*00110**,
IDE01822,History data 36,07132*2012-01-01-00:10*0000.0*00000*00092*00000*00000*00000*00000*00000**
07129*2012-01-01-00:01*0000.0*00000*00000*00034*00000*00000*00000*00000**
07080*2012-01-01-01:40*0000.4*00000*00963*00000*00000*00000*00000*00000**
07079*2012-01-01-01:11*0000.0*00000*00000*00023*00000*00000*00000*00000**
07078*2012-01-01-00:53*0000.0*00000*00000*00023*00000*00000*00000*00000**,
IDE01823,History data 37,07248*2000-00-00-00:00*0000.0*0000.3**,
IDE01827,Generator specified voltage value,10.6, V
IDE01828,Generator DF Signal,0.025, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,Electrical OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Hitachi,
IDE01831-MAS04490,Generator variant-Size,140 - 210 ETA,
IDE01831-ENG113380,Generator variant-alternator identification_regulator,4,
IDE01831-ENG113379,Generator variant-alternator manufacture_regulator,Infineon Technologies AG,
IDE01833-MAS03159,Battery variant-Manufacturer,Moll,
IDE01833-MAS04490,Battery variant-Size,INIT (110Ah),
IDE01834,Battery voltage,12.036, V
IDE01835,Battery current filtered,-14.900, A
IDE01836,Battery current,-14.749, A
IDE01837,Temperature of battery sensor,24, °
IDE01838,Battery temperature,24, °
IDE01839,Battery charge condition,64, %
IDE01840,Battery condition for display,60, %
IDE01841,Battery internal resistance,3.6, mOhm
IDE01842,Usable battery charge,32, Ah
IDE01843,Battery voltage at rest,12.3, V
IDE01844,Increase idle speed request,not active,
IDE01845,Reduce internal fan request,not active,
IDE01846,Static current shutdown level,not active,
IDE01847,Auxiliary heater activation restriction request,-,
IDE01847-ENG100234,Auxiliary heater activation restriction request-park_heater_target_time,not active,
IDE01848,Previous journey energy summary,0.0, Ah
IDE01849,Previous journey duration,0.00, H
IDE01850,Total energy summary,9983.1, Ah
IDE01851,Total energy throughput,7029.8, Ah
IDE01852,Static current measurement: result,0.01, A
IDE01853,Static current measurement: status,Measurement end,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,0.0, A
IDE01856,Battery acid stratification,0, %
IDE01864-MAS03173,Status of current bus communication-Databus drivetrain,active,
IDE01864-MAS03174,Status of current bus communication-Comfort data bus,active: local wakeup event,
IDE01864-MAS03175,Status of current bus communication-Databus extended,active,
IDE01864-MAS03176,Status of current bus communication-Display and control head databus,active,
IDE01864-MAS03177,Status of current bus communication-Databus Infotainment,active,
IDE01864-MAS03178,Status of current bus communication-Suspension data bus,active,
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,not installed,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active,
IDE01864-MAS03181,Status of current bus communication-Flexray databus,active,
IDE01864-MAS07380,Status of current bus communication-Data bus Sensor/Hybrid,Sleep mode,
IDE01865-MAS03182,Status flex ray communication-Branch 1,active,
IDE01865-MAS03183,Status flex ray communication-Branch 2,active,
IDE01865-MAS03184,Status flex ray communication-Branch 3,active,
IDE01865-MAS03185,Status flex ray communication-Branch 4,active,
IDE01865-MAS03186,Status flex ray communication-Branch 5,not installed,
IDE01865-MAS03187,Status flex ray communication-Branch 6,not installed,
IDE01865-MAS03188,Status flex ray communication-Branch 7,not installed,
IDE01865-MAS03189,Status flex ray communication-Branch 8,not installed,
IDE01866,MOST system condition,Configuration OK,
IDE01867-IDE01863,MOST hardware parameter-MOST light performance,Decrease 0 dB,
IDE01867-MAS03121,MOST hardware parameter-Ring break diagnostic line status,1,
IDE01867-MAS03122,MOST hardware parameter-Ring break diagnostic line voltage,25.5, V
IDE01867-ENG100178,MOST hardware parameter-HW Instance (MP1-4)_MOST hardware value,0,
IDE01868,Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01948,Battery internal resistance not normed,3.8, mOhm
IDE01979,Stored key for component protection participants,04 81 08 00 02 40 00 00 00 04 00 00,
IDE01980,Component protection participant currently wrongly authent.,00 00 00 00 00 00 00 00 00 00 00 00,
IDE01981,Comp. protect participant occasionally wrongly authent.,00 00 00 00 00 00 00 00 00 00 00 00,
IDE01982,Transport protocol used for component protection,00 01 00 00 00 00 00 00 00 00 00 00,
IDE01983,Number of successfully repaired keys,0,
IDE01984,Number of successful key downloads,0,
IDE01985-ENG101043,FAZIT identification test sum-Checksum,A9 95 16 23,
IDE01985-ENG99027,FAZIT identification test sum-Version,1,
IDE01992-ENG16230,Installation list: current installations-ECU present Bit 0,can be reached,
IDE01992-ENG45410,Installation list: current installations-ECU present Bit 1,cannot be reached,
IDE01992-ENG45396,Installation list: current installations-ECU present Bit 2,can be reached,
IDE01992-ENG45402,Installation list: current installations-ECU present Bit 3,can be reached,
IDE01992-ENG45430,Installation list: current installations-ECU present Bit 4,can be reached,
IDE01992-ENG45377,Installation list: current installations-ECU present Bit 5,can be reached,
IDE01992-ENG21674,Installation list: current installations-ECU present Bit 6,can be reached,
IDE01992-ENG16217,Installation list: current installations-ECU present Bit 7,can be reached,
IDE01993-ENG20451,Control module reference number-ECU ID,01,
IDE01993-ENG20480,Control module reference number-ECU Name,Engine Control Module 1,
IDE01995-ENG16990,Control module protocol information-Ethernet,No,
IDE01995-ENG16987,Control module protocol information-ISO-TP,Yes,
IDE01995-ENG16989,Control module protocol information-K Line,No,
IDE01995-ENG16988,Control module protocol information-TP 1.6,No,
IDE01995-ENG16991,Control module protocol information-TP 2.0,No,
IDE01996-ENG20493,Installation list: specified installations-ECU coded Bit 0,Yes,
IDE01996-ENG45436,Installation list: specified installations-ECU coded Bit 1,No,
IDE01996-ENG45421,Installation list: specified installations-ECU coded Bit 2,Yes,
IDE01996-ENG45358,Installation list: specified installations-ECU coded Bit 3,Yes,
IDE01996-ENG45367,Installation list: specified installations-ECU coded Bit 4,Yes,
IDE01996-ENG45433,Installation list: specified installations-ECU coded Bit 5,Yes,
IDE01996-ENG45401,Installation list: specified installations-ECU coded Bit 6,Yes,
IDE01996-ENG45426,Installation list: specified installations-ECU coded Bit 7,Yes,
IDE02384-ENG16210,Status of event memory-ECU Dtc Bit 0,OK,
IDE02384-ENG45352,Status of event memory-ECU Dtc Bit 1,OK,
IDE02384-ENG45386,Status of event memory-ECU Dtc Bit 2,OK,
IDE02384-ENG45404,Status of event memory-ECU Dtc Bit 3,OK,
IDE02384-ENG45387,Status of event memory-ECU Dtc Bit 4,OK,
IDE02384-ENG45440,Status of event memory-ECU Dtc Bit 5,OK,
IDE02384-ENG21671,Status of event memory-ECU Dtc Bit 6,ERROR,
IDE02384-ENG16227,Status of event memory-ECU Dtc Bit 7,OK,
IDE03008-ENG98388,Stop process prevented-Battery charge condition too low,0,
IDE03008-ENG98389,Stop process prevented-Battery temperature,0,
IDE03008-ENG99012,Stop process prevented-Consumer current too high,0,
IDE03008-ENG103231,Stop process prevented-Entnehmbare Ladung zu gering,0,
IDE03008-ENG98719,Stop process prevented-Idle speed increase active,0,
IDE03008-ENG122800,Stop process prevented-Intermittierender Betrieb aktiv,0,
IDE03008-ENG98746,Stop process prevented-Possible service life too short,0,
IDE03008-ENG103267,Stop process prevented-Sonderveto aktiv,0,
IDE03008-ENG104139,Stop process prevented-Veto DC/DC Wandler,0,
IDE03009-ENG98388,Start process requested-Battery charge condition too low,0,
IDE03009-ENG104067,Start process requested-Charging contingent,0,
IDE03009-ENG99104,Start process requested-Entnehmbare Ladung,0,
IDE03009-ENG99021,Start process requested-Insuff. voltage,0,
IDE03009-ENG101118,Start process requested-Stromverbrauch,0,
IDE03009-ENG102869,Start process requested-Zielzeit abgelaufen,0,
IDE03127,Prevented stop processes (ring memory),2000-01-01-00:00*0-0-0-0-0-0-0-0**
00000*00000*00000*00000*00000*00000*00000*00000**,
IDE03128,Requested start processes (ring memory),2000-01-01-00:00*0-0-0-0-0-0-0-0**
IDE03150-ENG20495,Readiness for bus sleep mode-ECU SleepReady Bit0,cannot be reached,
IDE03150-ENG45365,Readiness for bus sleep mode-ECU SleepReady Bit1,can be reached,
IDE03150-ENG45382,Readiness for bus sleep mode-ECU SleepReady Bit2,cannot be reached,
IDE03150-ENG45417,Readiness for bus sleep mode-ECU SleepReady Bit3,cannot be reached,
IDE03150-ENG45441,Readiness for bus sleep mode-ECU SleepReady Bit4,cannot be reached,
IDE03150-ENG45422,Readiness for bus sleep mode-ECU SleepReady Bit5,can be reached,
IDE03150-ENG45372,Readiness for bus sleep mode-ECU SleepReady Bit6,cannot be reached,
IDE03150-ENG45428,Readiness for bus sleep mode-ECU SleepReady Bit7,cannot be reached,
IDE03151,TP CAN identifier,00 00,
IDE03212,Start-stop conditions,Stop release,
IDE03213,Start-stop enabling,No release by coordinator,
IDE03897,Generator: status communication,active,
IDE03898,Voltage stabilizer: status communication,active,
IDE03899,Battery monitoring control module: status communication,active,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE06747-IDE01834,Battery monitoring control unit 2-Battery voltage,4.000, V
IDE06747-IDE01836,Battery monitoring control unit 2-Battery current,-32.768, A
IDE06747-IDE01838,Battery monitoring control unit 2-Battery temperature,-40, °
IDE06747-IDE01839,Battery monitoring control unit 2-Battery charge condition,0, %
IDE06747-IDE01841,Battery monitoring control unit 2-Battery internal resistance,0.0, mOhm
IDE06747-IDE01948,Battery monitoring control unit 2-Battery internal resistance not normed,0.0, mOhm
IDE06747,Battery monitoring control unit 2,not active,
IDE06747-ENG113366,Battery monitoring control unit 2-battery current puls,0,
IDE06747-ENG113365,Battery monitoring control unit 2-battery voltage puls,9.000, V
IDE06747-ENG113367,Battery monitoring control unit 2-BZE_Min_puls_duration,0, ms
IDE06747-ENG113368,Battery monitoring control unit 2-BZE_Min_trigger,0,
IDE06747-ENG101157,Battery monitoring control unit 2-BZE_Q_Elad,0.0, Ah
IDE06747-ENG100159,Battery monitoring control unit 2-BZE_Q_Lad,0.0, Ah
IDE06747-ENG106125,Battery monitoring control unit 2-EM_blBatteryDisconnected,connected,
IDE06747-ENG98970,Battery monitoring control unit 2-Temperature of battery sensor,-40, °
IDE08529-MAS01632,Service-key: query status-Status,not active,
IDE08529-MAS07126,Service-key: query status-Standard query,not active,
IDE08529-MAS07127,Service-key: query status-Immediate query,not active,
IDE08529-MAS07128,Service-key: query status-Control module in except. handling 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08529-MAS07129,Service-key: query status-Control module in except. handling 2,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107689-IDE01868,Automatic loop break diagnosis-Ring break diagnostic result,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG107689-MAS00043,Automatic loop break diagnosis-Supply voltage: Terminal 30,0.0, V
ENG107689-MAS00711,Automatic loop break diagnosis-Odometer reading,0, km
ENG107689-MAS01230,Automatic loop break diagnosis-Date,00.00.2000,
ENG107689-MAS02957,Automatic loop break diagnosis-Time,00:00,
ENG105315-ENG103971,BCmE_Versionnumber-Patch,2,
ENG105315-ENG98889,BCmE_Versionnumber-Release,5,
ENG105771-ENG102240,DCDC_First_Branch-DC_STST1_Bypassrelais_defekt_TW1,0,
ENG105771-ENG102373,DCDC_First_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW1,0,
ENG105771-ENG104027,DCDC_First_Branch-DC_STST1_Lastabschaltung_TW1,0,
ENG105771-ENG101272,DCDC_First_Branch-DC_STST1_Uebertemperatur_TW1,0,
ENG105771-ENG100694,DCDC_First_Branch-DC_STST1_Unterspannung_Eingang_TW1,0,
ENG105772-ENG102945,DCDC_Second_Branch-DC_STST1_Bypassrelais_defekt_TW2,0,
ENG105772-ENG99327,DCDC_Second_Branch-DC_STST1_El_Fehler_Ausgang_KS_TW2,0,
ENG105772-ENG100692,DCDC_Second_Branch-DC_STST1_Lastabschaltung_TW2,0,
ENG105772-ENG100445,DCDC_Second_Branch-DC_STST1_Uebertemperatur_TW2,0,
ENG105772-ENG101117,DCDC_Second_Branch-DC_STST1_Unterspannung_Eingang_TW2,0,
ENG105773-ENG100371,DCDC_STST_Status-DC_STST1_Boost,0,
ENG105773-ENG101192,DCDC_STST_Status-DC_STST1_Defekt,0,
ENG105773-ENG101605,DCDC_STST_Status-DC_STST1_ErrorGueltigkeit,1,
ENG105773-ENG103583,DCDC_STST_Status-DC_STST1_Fail,0,
ENG105773-ENG103918,DCDC_STST_Status-DC_STST1_Fktbereit,1,
ENG105773-ENG102020,DCDC_STST_Status-DC_STST1_Lokalaktiv,0,
ENG105773-ENG103598,DCDC_STST_Status-DC_STST1_Stromgrenze,0,
ENG105773-ENG99195,DCDC_STST_Status-DC_STST1_Uebertemperatur,0,
ENG113398,EM Produktionsmodus Freigabe,1,
ENG113397,EM RSM Freigabe,1,
ENG106120,EM_battery identification known,Unknown,
ENG106121-ENG101157,EM_Battery_charge_discharge-BZE_Q_Elad,6891.5, Ah
ENG106121-ENG100159,EM_Battery_charge_discharge-BZE_Q_Lad,7396.6, Ah
ENG106122,EM_battery_identification,0,
ENG106123,EM_blAlternator On,OFF,
ENG106124,EM_blAlternator Valid,Yes,
ENG106125,EM_blBatteryDisconnected,connected,
ENG106126,EM_blBemSleepRdy,0,
ENG106127,EM_blBoostRecognised,not recognized,
ENG106128,EM_blCanMostActive,1,
ENG106129,EM_blControlKFan,0,
ENG106130,EM_blDisconnectionAdeptChannel,0,
ENG106131,EM_blMmi Advance Warning,0,
ENG106132,EM_blMmi Advance Warning Diag,0,
ENG106133,EM_blParkHeatingEncoded,Not coded,
ENG106134,EM_blRecuperation Encoded,coded,
ENG106135,EM_blRecuperation Enforce,Not coded,
ENG106136,EM_blSleepIndication,1,
ENG106137,EM_blStabilisation EBalance,0,
ENG106138,EM_blStabilisation EPowerSystem,0,
ENG106139,EM_blVnaActive,0,
ENG106140,EM_Current_Control_Recu,not active,
ENG121181,EM_Energiebilanz_2,10000.0, Ah
ENG106141,EM_errEBalanceDiag,0,
ENG106142,EM_errEPowerSystem,0,
ENG106143,EM_errOverVoltage,0,
ENG113400-ENG113369,EM_Hybrid_Info-Hybrid_Info,Motorstart_ueber_12V_Starter_nur_bei_0kmh_moeglich,
ENG106144,EM_IAlternator L1,0.0, A
ENG106145,EM_IAlternator Reserve,0.0, A
ENG106146,EM_IInternalFan,0.00, A
ENG106147,EM_IKmStandTm Active,0, km
ENG106148,EM_IKmStandTmActiveIn,93, km
ENG106149,EM_INeutralBem,3.265, A
ENG106150,EM_IParkHeatingRequirements,10, A
ENG121178,EM_Ladestrombegrenzung,not active,
ENG106151,EM_Load Response Time,6.00, s
ENG106160-ENG102785,EM_loss_of_voltage / param_specified_capacity-Battery technology,Batterietechnologie unbekannt,
ENG106160-ENG100745,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Aktuell,12.70, V
ENG106160-ENG101482,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Mittel,12.70, V
ENG106160-ENG102509,EM_loss_of_voltage / param_specified_capacity-BZE_DeltaUStart_Trigger,1,
ENG106160-ENG102743,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart,14.70, V
ENG106160-ENG101108,EM_loss_of_voltage / param_specified_capacity-BZE_MinUStart_Trigger,1,
ENG106160-ENG100156,EM_loss_of_voltage / param_specified_capacity-BZE_Q_Nom,98, Ah
ENG106160-ENG100059,EM_loss_of_voltage / param_specified_capacity-Nenn Kapazität,Init,
ENG106152,EM_MAlternator,0.0, Nm
ENG106153,EM_NDisconnectionEngineSpeed,5990, /min
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG99338,EM_prcSoh-prc SohP,84, %
ENG106155-ENG101494,EM_prcSoh-prc SohQ,74, %
ENG106156,EM_PReserveFilter,0, W
ENG106157-ENG101729,EM_RecuMode_Engine-Modus Rekuperation (Motor),Acc.,
ENG106159-ENG102920,EM_Recuperation_Prerequisite-Auslastung des Generators,1,
ENG106159-ENG100983,EM_Recuperation_Prerequisite-Batteriealterung (Ladung),1,
ENG106159-ENG99619,EM_Recuperation_Prerequisite-Batteriealterung (Leistung),1,
ENG106159-ENG102670,EM_Recuperation_Prerequisite-Batterieregeneration,1,
ENG106159-ENG103895,EM_Recuperation_Prerequisite-Energie Netz,1,
ENG106159-ENG99263,EM_Recuperation_Prerequisite-Energiedurchsatz,1,
ENG106159-ENG99104,EM_Recuperation_Prerequisite-Entnehmbare Ladung,1,
ENG106159-ENG99756,EM_Recuperation_Prerequisite-Generatordiagnose,1,
ENG106159-ENG103581,EM_Recuperation_Prerequisite-Ladezustand der Batterie,0,
ENG106159-ENG100106,EM_Recuperation_Prerequisite-Leerlaufanhebung,1,
ENG106159-ENG104009,EM_Recuperation_Prerequisite-LIN-Kommunikation,1,
ENG106159-ENG98425,EM_Recuperation_Prerequisite-Outside air temperature,1,
ENG106159-ENG102570,EM_Recuperation_Prerequisite-Säureschichtung,1,
ENG106159-ENG101873,EM_Recuperation_Prerequisite-Sonderveto,1,
ENG106159-ENG103261,EM_Recuperation_Prerequisite-Spannung der Batterie,1,
ENG106159-ENG103394,EM_Recuperation_Prerequisite-Temperatur der Batterie,1,
ENG106158-ENG104224,EM_Recuperation_Restriction-Abblendlicht Aktiv,1,
ENG106158-ENG99969,EM_Recuperation_Restriction-Auslastung Innegeblaese Hoch,0,
ENG106158-ENG103587,EM_Recuperation_Restriction-Bauteilschutz BDM,0,
ENG106158-ENG102567,EM_Recuperation_Restriction-Bauteilschutz Fernlicht,0,
ENG106158-ENG101156,EM_Recuperation_Restriction-Blinker links Aktiv,0,
ENG106158-ENG101146,EM_Recuperation_Restriction-Blinker rechts Aktiv,0,
ENG106158-ENG113355,EM_Recuperation_Restriction-EPS Leistunsanforderung,0,
ENG106158-ENG101898,EM_Recuperation_Restriction-ESP-Anforderung,0,
ENG106158-ENG99511,EM_Recuperation_Restriction-Innenlicht Aktiv,1,
ENG106158-ENG102650,EM_Recuperation_Restriction-Motor-Anforderung,0,
ENG121180-ENG121171,EM_Rekuperation_Sonderveto-Sonderveto_Anhaenger,No,
ENG121180-ENG121172,EM_Rekuperation_Sonderveto-Sonderveto_Klima,No,
ENG121180-ENG121174,EM_Rekuperation_Sonderveto-Sonderveto_Motor_Spannungsanforderung,No,
ENG121180-ENG121170,EM_Rekuperation_Sonderveto-Sonderveto_Produktion,No,
ENG121180-ENG121169,EM_Rekuperation_Sonderveto-Sonderveto_Transportmodus,No,
ENG121180-ENG121173,EM_Rekuperation_Sonderveto-Sonderveto_Zustart_Batterie,No,
ENG106161-ENG102992,EM_Start_Stop_State-Mögliche Stoppzeit,15,
ENG106161-ENG100942,EM_Start_Stop_State-Start Stopp Phase,ERROR,
ENG106161-ENG103632,EM_Start_Stop_State-Status Motorstopp,not active,
ENG106161-ENG102878,EM_Start_Stop_State-Status Wiederstart,not active,
ENG106161-ENG100005,EM_Start_Stop_State-Stromverbrauchsschätzung Stoppphase,30, A
ENG106162-ENG102635,EM_Start_Stop_System_Error / system fault DC-Alternator failure,0,
ENG106162-ENG101997,EM_Start_Stop_System_Error / system fault DC-Batterie zyklisch verbraucht,0,
ENG106162-ENG103373,EM_Start_Stop_System_Error / system fault DC-Battery malfunction,0,
ENG106162-ENG99392,EM_Start_Stop_System_Error / system fault DC-Fehler Diagnosesignal DC/DC-Wandler,0,
ENG106162-ENG101407,EM_Start_Stop_System_Error / system fault DC-Start/Stopp-Koordinator unplausibel,0,
ENG106162-ENG122799,EM_Start_Stop_System_Error / system fault DC-Systemfehler BDM Defekt,0,
ENG106162-ENG100042,EM_Start_Stop_System_Error / system fault DC-Systemfehler DC/DC-Wandler,0,
ENG106163-ENG99559,EM_tSgErrors-tSgError IO Duration tSgErrors,0, min
ENG106163-ENG100405,EM_tSgErrors-tSgError NIO Duration tSgErrors,0, min
ENG106163-ENG100563,EM_tSgErrors-tSgErrorDuration In tSgErrors,0, s
ENG106163-ENG103494,EM_tSgErrors-tSgErrorDuration tSgErrors,0, s
ENG106164,EM_UControlUnit,11.734, V
ENG106165,EM_Ustart,6.5, V
ENG106166,EM_valBdm LinTableSwitch,Terminal 15 on,
ENG106167,EM_valBdm WakeUpReason,0,
ENG106168,EM_valEngineId,4,
ENG106169,EM_valHlkLevelRequirement,1,
ENG106170,EM_valStatusHlk,0,
ENG106171-ENG103971,EM_Versionnumber-Patch,0,
ENG106171-ENG98889,EM_Versionnumber-Release,19,
ENG113401-ENG113374,EM_Zustart Freigabe-Freigabe Aussentemperatur,Yes,
ENG113401-ENG113370,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat1),Yes,
ENG113401-ENG113372,EM_Zustart Freigabe-Freigabe Batterietemperatur (Bat2),Yes,
ENG113401-ENG113371,EM_Zustart Freigabe-Freigabe Entnehmbare Ladung (Bat1),Yes,
ENG113401-ENG113373,EM_Zustart Freigabe-Freigabe Leistungsfähigkeit Zustart,No,
ENG121179-ENG121165,EM_Zustart_Systemfehler-EM_BatterieAb_BDM1,No,
ENG121179-ENG121166,EM_Zustart_Systemfehler-EM_BatterieAb_BDM2,No,
ENG121179-ENG121167,EM_Zustart_Systemfehler-EM_LIN1_ungueltig,No,
ENG121179-ENG121168,EM_Zustart_Systemfehler-EM_LIN2_ungueltig,No,
ENG113402-ENG113377,GW_Bap_Status-Lifecycle,Shutdown,
ENG113402-ENG99775,GW_Bap_Status-MOST,On,
ENG113402-ENG113378,GW_Bap_Status-PE_Freigabe,0,
ENG106825,GW_SYS_BEM_SleepReady,EM active,
ENG106826,GW_SYS_BM_Run-on,0, s
ENG106827-ENG100038,GW_SYS_CPU_Load-CPU Load,0, %
ENG106827-ENG113384,GW_SYS_CPU_Load-Task Level 1,0, %
ENG106827-ENG113383,GW_SYS_CPU_Load-Task Level 2,0, %
ENG106827-ENG113382,GW_SYS_CPU_Load-Task Level 3,0, %
ENG106827-ENG113381,GW_SYS_CPU_Load-Task Level 4,0, %
ENG106828,GW_SYS_EEPROM Repair,0,
ENG106832-ENG100323,GW_SYS_LastWakeupReason-Car WakeUp Reason,Comfort data bus,
ENG106832-ENG99403,GW_SYS_LastWakeupReason-Gateway WakeUp Reason,Comfort data bus,
ENG106833,GW_SYS_Reset_Count,0,
ENG106834,GW_SYS_ResetReason,Power On Reset,
ENG100548-MAS00049,GW_SYS_State-Component protection,not active,
ENG100548-MAS00795,GW_SYS_State-Diagnostic interface for data bus,active,
ENG100548-MAS01468,GW_SYS_State-Terminal 15,active,
ENG100548-MAS01490,GW_SYS_State-Energy management,not active,
ENG100548-MAS03173,GW_SYS_State-Databus drivetrain,active,
ENG100548-MAS03174,GW_SYS_State-Comfort data bus,active,
ENG100548-MAS03175,GW_SYS_State-Databus extended,active,
ENG100548-MAS03176,GW_SYS_State-Display and control head databus,active,
ENG100548-MAS03177,GW_SYS_State-Databus Infotainment,active,
ENG100548-MAS03178,GW_SYS_State-Suspension data bus,active,
ENG100548-MAS03180,GW_SYS_State-Local data bus,active,
ENG100548-MAS03181,GW_SYS_State-Flexray databus,active,
ENG100548-ENG102839,GW_SYS_State-A-Can Flexray F-Can SubMaster,active,
ENG100548-ENG100518,GW_SYS_State-Busmonitor,active,
ENG100548-ENG98571,GW_SYS_State-EEPROM,active,
ENG100548-ENG99046,GW_SYS_State-Emergency signal flashing,not active,
ENG100548-ENG100049,GW_SYS_State-K-Can Dash-Can SubMaster,active,
ENG100548-ENG102799,GW_SYS_State-Mindestaktivzeit,active,
ENG106837,GW_SYS_TP20_Counter,0,
ENG110999,GW_Watchdog_Version,0,
ENG100189,IN ESP_standstill flag,1,
ENG100411,IN ESP_v_Signal,0, km/h
ENG100786,IN HW terminal 15,1,
ENG101017,IN KBI_odometer_reading,38769,
ENG101398,IN MO_engine_speed_01,0.00, /min
ENG103286,IN MO_Motor_running,0,
ENG106958-MAS00106,IN time_01-Year,2012,
ENG106958-MAS00107,IN time_01-Month,1,
ENG106958-MAS00108,IN time_01-Day,9,
ENG106958-MAS00109,IN time_01-Hours,18,
ENG106958-MAS00110,IN time_01-Minutes,56,
ENG106958-MAS00111,IN time_01-Seconds,12,
ENG106958-MAS00690,IN time_01-Daylight saving time,Winter time,
ENG106958-ENG103328,IN time_01-type of clock,Unknown (0),
ENG101569,IN ZAS_Te_15,1,
ENG103048,IN ZAS_Te_X,1,
ENG107685-ENG103912,MOST Deattaches-deatatch counter_MOST Deatatches,0,
ENG107685-ENG99643,MOST Deattaches-present deatatch counter_MOST Deatatches,0,
ENG107685-ENG100756,MOST Deattaches-present status_MOST Deatatches,connected,
ENG102460-ENG20471,MOST Notifications-Function ID,00 00,
ENG102460-ENG20429,MOST Notifications-Target Adress 1,00 00,
ENG102460-ENG20454,MOST Notifications-Target Adress 2,00 00,
ENG102460-ENG20421,MOST Notifications-Target Adress 3,00 00,
ENG107869-ENG102318,NW_MOST Addressing-diag inst-id,19,
ENG107869-ENG101908,NW_MOST Addressing-groupadress,03 FF,
ENG107869-ENG101657,NW_MOST Addressing-logical adress,05 19,
ENG107869-ENG99161,NW_MOST Addressing-vehicle inst-id,01,
ENG107870-ENG100752,NW_MOST net mngmt status-Configuration_NW_MOST Networkmanagment.Status,New,
ENG107870-ENG99305,NW_MOST net mngmt status-MMI_State_NW_MOST Networkmanagment.Status,MMI_On,
ENG107870-ENG103488,NW_MOST net mngmt status-ShutDownState_NW_MOST Networkmanagment.Status,normal operation,
ENG107870-ENG104176,NW_MOST net mngmt status-Systemstate_NW_MOST Networkmanagment.Status,normal operation,
ENG107948,OUT_Alternator_reference_voltage_value,10.6, V
ENG107949,OUT_GW_Aging_counter_DIAG_01_message,227,
ENG102605,outside_temperature,24.0, °C
ENG111625-MAS00106,Pause recommendation-Year,2000,
ENG111625-MAS00107,Pause recommendation-Month,0,
ENG111625-MAS00108,Pause recommendation-Day,0,
ENG111625-MAS00109,Pause recommendation-Hours,0,
ENG111625-MAS00110,Pause recommendation-Minutes,0,
ENG111625-ENG20549,Pause recommendation-Deaktiviert durch EEPROM-Wert,No,
ENG111625-ENG20548,Pause recommendation-Deaktiviert durch falschen Datensatz,Yes,
ENG111625-ENG113361,Pause recommendation-PE_Art_der_Meldung,Initializing,
ENG111625-ENG113357,Pause recommendation-PE_Einstellung,active,
ENG111625-ENG113359,Pause recommendation-PE_Fehlercode,not installed,
ENG111625-ENG113362,Pause recommendation-PE_Index_HFC_TP,1.000,
ENG111625-ENG113358,Pause recommendation-PE_Stufe,0,
ENG113399-ENG113364,PE_Version-DS_Version,.,
ENG113399-ENG109174,PE_Version-SW_VERSION,5.1,
ENG107686-IDE00317,Reset date for counter: sporadic loop breaks-Date,00.00.2000,
ENG125408,SK2_AnpassungStatus,1,
ENG122798-ENG103971,Sk2_Version-Patch,3,
ENG122798-ENG98889,Sk2_Version-Release,2,
ENG110089,Warm-Up-Cycle Counter (zVZ),0,
Elapsed Time: 00:38
;SW:4S0-907-160   HW:4S0-907-160 ---  AWD
;Component:4 Wheel Drive H06 0207, Coding:
;EV_AllWheelContrBORGLB724,006012,EV_AllWheelContrBORGLB724.rod
;Sunday,17,May,2020,19:43:54:06485
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 6E90CC6FB18E50F6E9-803A
IDE00820-ENG137181-Activating and deactivating all development messages-ECU_Specific_01_02,not active ,1
IDE00820-ENG137180-Activating and deactivating all development messages-ECU_Specific_03_10,not active ,1
IDE00820-ENG137184-Activating and deactivating all development messages-Message_S100,not active ,1
IDE00820-ENG137183-Activating and deactivating all development messages-Message_S101,not active ,1
IDE00820-ENG137182-Activating and deactivating all development messages-Message_S102,not active ,1
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not active ,1
IDE09092-Read and write oil aging values,79 6E 68 E2 EA 47 ,6
Elapsed Time: 00:01
;Sunday,17,May,2020,19:43:52:06485
Group,Description,Actual
IDE00019,Voltage terminal 30,11.90, V
IDE00075,Vehicle speed,0.28, km/h
IDE00102,Control Module temperature,28, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00556,Outside air temperature,23.40, °C
IDE00924,Steering angle,10.90, °
IDE02955-IDE00240,System status-Coolant pump,not active,
IDE02955-IDE07154,System status-ESP status,not active,
IDE03498,Status of check light in instrument panel,OFF,
IDE04604,Accelerator pedal travel,0.00, %
IDE05609,Cooling fin temperature,26, °C
IDE05707,Haldex clutch pump current,0.00, A
IDE05710,Haldex clutch pump voltage,0.00, V
IDE08625,Torque specifications: front axle,1.00, Nm
IDE08626,Torque: front axle,2, Nm
IDE08627,Hydraulic pressure sensor 1,0.00, bar
IDE08628,Hydraulic temperature sensor,26, °C
ENG06104,First internal failure number,0,
ENG119393,Haldex_Locking_State,Init,
ENG06105,Last internal failure number,0,
ENG06102,SW Version BSW,0121,
ENG06101,SW Version FDR,R084,
ENG06103,SW Version KR,0207,
Elapsed Time: 00:01
;SW:4S0-909-144-G   HW:4S0-909-144-B ---  Steering Assist
;Component:EPS           H13 0904, Coding:0800
;EV_EPSZFAU72X,002010,EV_EPSZFAU72X_002.rod
;Sunday,17,May,2020,19:44:40:06485
IDE00820-ENG137195-Activating and deactivating all development messages-Development CAN-Message S100,OFF ,1
IDE00820-ENG137196-Activating and deactivating all development messages-Development CAN-Message S101,OFF ,1
IDE00820-ENG137197-Activating and deactivating all development messages-Development CAN-Message S102,OFF ,1
IDE00820-ENG137198-Activating and deactivating all development messages-Development CAN-Message SG-spez. 01 / (02),OFF ,1
IDE00820-ENG137199-Activating and deactivating all development messages-Development CAN-Message SG-spez. 03 bis 10,OFF ,1
IDE00820-ENG100126-Activating and deactivating all development messages-XCP SG-spez.,OFF ,1
ENG100341-Productionmode,not active ,3
Elapsed Time: 00:01
;Sunday,17,May,2020,19:44:36:06485
IDE00019,Voltage terminal 30,12.00, V
IDE00020,Terminal 15 status,active,
IDE00075-MAS01456,Vehicle speed-Speed,0, km/h
IDE00075-MAS11025,Vehicle speed-Status,valid,
IDE00322,Status of basic setting,Basic setting not active,
IDE00924,Steering angle,7.50, °
IDE02202,End stage temperature,26, °C
IDE02955,System status,ready for operation,
IDE03527-MAS00371,CAN signals-Engine speed,0.00, /min
IDE03527-MAS02489,CAN signals-Vehicle Identification Number (VIN),------ZF---------,
IDE03527-MAS03679,CAN signals-Terminal 15 status,Terminal 15 on,
IDE03527-MAS04462,CAN signals-Steering angle sensor angular value,10.90, °
IDE03527-MAS08206,CAN signals-CAN ESP speed,0.00, km/h
IDE03527-MAS11657,CAN signals-ESC function DSR: steering torque offset,5.00, Nm
IDE03527,CAN signals,Comfort,
IDE03735,Steering torque,0.01, Nm
IDE05162-MAS11513,Software end stop-End stop left,Adapted,
IDE05162-MAS11514,Software end stop-End stop right,Adapted,
IDE05228,Operating hour counter,1243, H
IDE07152-MAS03553,Fall-back level-Warning light,not active,
IDE07152-MAS04449,Fall-back level-Output stage status,not active,
IDE10860,Electro-mechanical power steering motor: maximum torque,0.00, Nm
IDE10865-MAS05631,Software limit stop: pre-condition for programming-System status,Condition not met,
IDE10865-MAS09388,Software limit stop: pre-condition for programming-Engine running,Condition not met,
IDE10865-MAS11515,Software limit stop: pre-condition for programming-Steering angle calibrated,Condition not met,
IDE10900-MAS11659,Software limit stop: conditions during programming-Rotor speed during steering angle to left,valid,
IDE10900-MAS11660,Software limit stop: conditions during programming-Rotor speed during steering angle to right,valid,
IDE10900-MAS11661,Software limit stop: conditions during programming-Steering torque with steering angle to left,valid,
IDE10900-MAS11662,Software limit stop: conditions during programming-Steering torque with steering angle to right,valid,
IDE10900-MAS11663,Software limit stop: conditions during programming-Engine torque with steering angle to left,invalid,
IDE10900-MAS11664,Software limit stop: conditions during programming-Engine torque with steering angle to right,invalid,
IDE10900-MAS11696,Software limit stop: conditions during programming-At least one adaptation condition not satisfied,Yes,
IDE10902-IDE03619,Expanded ambient data 1-System status,ready for operation,
IDE10902-IDE04185,Expanded ambient data 1-Terminal 30 voltage filtered,12.00, V
IDE10902-IDE06401,Expanded ambient data 1-Internal voltage supply 5V,4.90, V
IDE10902-IDE07543,Expanded ambient data 1-Vehicle speed,0, km/h
IDE10902-IDE09004,Expanded ambient data 1-Control module temp: internal sensor,34, °C
IDE10902-MAS01209,Expanded ambient data 1-Speed source,CAN ESP speed,
IDE10902-MAS03950,Expanded ambient data 1-Combustion engine: status,Motor not running,
IDE10902-MAS11609,Expanded ambient data 1-AD converter reference voltage,1.50, V
IDE10902-MAS11626,Expanded ambient data 1-Voltage terminal 30 unfiltered,12.05, V
IDE10902-MAS11665,Expanded ambient data 1-AD converter reference voltage 2,1.50, V
IDE10902-MAS11667,Expanded ambient data 1-Switched voltage terminal 30 unfiltered,11.94, V
IDE10902-ENG120717,Expanded ambient data 1-KFA,00 00,
IDE10902-ENG120716,Expanded ambient data 1-KFC,00 00,
IDE10903-IDE03619,Expanded ambient data 2-System status,ready for operation,
IDE10903-IDE04185,Expanded ambient data 2-Terminal 30 voltage filtered,12.00, V
IDE10903-MAS03950,Expanded ambient data 2-Combustion engine: status,Motor not running,
IDE10903-MAS11668,Expanded ambient data 2-EEPROM emulation: address,73 2C,
IDE10903-MAS11669,Expanded ambient data 2-EEPROM emulation: identification,00 14,
IDE10903-MAS11670,Expanded ambient data 2-EEPROM emulation: length,00 08,
IDE10903-MAS11671,Expanded ambient data 2-EEPROM emulation: offset,00 00,
IDE10903-MAS11672,Expanded ambient data 2-EEPROM emulation: command,02,
IDE10903-MAS11673,Expanded ambient data 2-EEPROM emulation: error,00,
IDE10903-ENG120717,Expanded ambient data 2-KFA,00 00,
IDE10903-ENG120716,Expanded ambient data 2-KFC,00 00,
IDE10904-IDE00613,Expanded ambient data 3-Phase current phase U,0.00, A
IDE10904-IDE00614,Expanded ambient data 3-Phase current phase V,0.00, A
IDE10904-IDE03735,Expanded ambient data 3-Steering torque,0.01, Nm
IDE10904-IDE04185,Expanded ambient data 3-Terminal 30 voltage filtered,12.00, V
IDE10904-MAS03841,Expanded ambient data 3-Engine steering torque: limited required torque,0.00, Nm
IDE10904-MAS11610,Expanded ambient data 3-Rotor speed,0, /min
IDE10904-MAS11623,Expanded ambient data 3-Hall sensors for position detection: current position,284.50, °
IDE10904-ENG120717,Expanded ambient data 3-KFA,00 00,
IDE10904-ENG120716,Expanded ambient data 3-KFC,00 00,
IDE10905-IDE03619,Expanded ambient data 4-System status,ready for operation,
IDE10905-IDE04185,Expanded ambient data 4-Terminal 30 voltage filtered,12.00, V
IDE10905-MAS11674,Expanded ambient data 4-First byte address after last LV share block,00 00 23 A8,
IDE10905-MAS11675,Expanded ambient data 4-Address of incorrect DAMOS variable,00 00,
IDE10905-MAS11676,Expanded ambient data 4-Processor RAM ECC error: address register,8E 98,
IDE10905-MAS11677,Expanded ambient data 4-Processor RAM ECC error: register content,0C,
IDE10905-MAS11678,Expanded ambient data 4-NVRAM share data checksum: result,00,
IDE10905-MAS11679,Expanded ambient data 4-NVRAM share data checksum: test status,01,
IDE10905-ENG120717,Expanded ambient data 4-KFA,00 00,
IDE10905-ENG120716,Expanded ambient data 4-KFC,00 00,
IDE10906-IDE03735,Expanded ambient data 5-Steering torque,0.01, Nm
IDE10906-IDE04185,Expanded ambient data 5-Terminal 30 voltage filtered,12.00, V
IDE10906-MAS11612,Expanded ambient data 5-Steering torque: cosine,-47.66,
IDE10906-MAS11680,Expanded ambient data 5-ASIC system: LA register content,43,
IDE10906-MAS11681,Expanded ambient data 5-ASIC system: INIT register content,1A,
IDE10906-MAS11693,Expanded ambient data 5-Sensor for steering torque: internal undervoltage status,00,
IDE10906-MAS11694,Expanded ambient data 5-Steering torque sensor: fault status,00,
IDE10906-MAS11695,Expanded ambient data 5-Steering torque sensor: current radius,914,
IDE10906,Expanded ambient data 5,-74.71,
IDE10906-ENG120717,Expanded ambient data 5-KFA,00 00,
IDE10906-ENG120716,Expanded ambient data 5-KFC,00 00,
IDE10907-IDE04185,Expanded ambient data 6-Terminal 30 voltage filtered,12.00, V
IDE10907-MAS11683,Expanded ambient data 6-Comparator: ID of current input signals (Level 1),00 00,
IDE10907-MAS11684,Expanded ambient data 6-Comparator: ID of current input signals (Level 2),00 00,
IDE10907-MAS11685,Expanded ambient data 6-Comparator: input signal 1,0,
IDE10907-MAS11686,Expanded ambient data 6-Comparator: input signal 2,0,
IDE10907-MAS11687,Expanded ambient data 6-Comparator: upper limit value,0,
IDE10907-MAS11688,Expanded ambient data 6-Comparator: lower limit value,0,
IDE10907-ENG120717,Expanded ambient data 6-KFA,00 00,
IDE10907-ENG120716,Expanded ambient data 6-KFC,00 00,
IDE10908-IDE04185,Expanded ambient data 7-Terminal 30 voltage filtered,12.00, V
IDE10908-MAS11613,Expanded ambient data 7-PWM value 1,1050,
IDE10908-MAS11614,Expanded ambient data 7-PWM value 2,1051,
IDE10908-MAS11615,Expanded ambient data 7-PWM value 3,1051,
IDE10908-MAS11616,Expanded ambient data 7-PWD value 1,1040,
IDE10908-MAS11617,Expanded ambient data 7-PWD value 2,1032,
IDE10908-MAS11618,Expanded ambient data 7-PWD value 3,1040,
IDE10908-ENG120717,Expanded ambient data 7-KFA,00 00,
IDE10908-ENG120716,Expanded ambient data 7-KFC,00 00,
IDE10909-IDE03619,Expanded ambient data 8-System status,ready for operation,
IDE10909-IDE04185,Expanded ambient data 8-Terminal 30 voltage filtered,12.00, V
IDE10909-MAS03950,Expanded ambient data 8-Combustion engine: status,Motor not running,
IDE10909-MAS11656,Expanded ambient data 8-Control module temp: internal sensor,34, °C
IDE10909-MAS11680,Expanded ambient data 8-ASIC system: LA register content,43,
IDE10909-MAS11681,Expanded ambient data 8-ASIC system: INIT register content,1A,
IDE10909,Expanded ambient data 8,00,
IDE10909-ENG120717,Expanded ambient data 8-KFA,00 00,
IDE10909-ENG120716,Expanded ambient data 8-KFC,00 00,
IDE10910-IDE04185,Expanded ambient data 9-Terminal 30 voltage filtered,12.00, V
IDE10910-MAS11611,Expanded ambient data 9-Current rotor position,284.50, °
IDE10910-MAS11619,Expanded ambient data 9-Engine position sensor: voltage cosine,2.22, V
IDE10910-MAS11620,Expanded ambient data 9-Engine position sensor: voltage sine,0.58, V
IDE10910-MAS11621,Expanded ambient data 9-Hall sensor 1 for position detection: voltage,0.74, V
IDE10910-MAS11622,Expanded ambient data 9-Hall sensor 2 for position detection: voltage,2.30, V
IDE10910-MAS11623,Expanded ambient data 9-Hall sensors for position detection: current position,285.38, °
IDE10910-ENG120717,Expanded ambient data 9-KFA,00 00,
IDE10910-ENG120716,Expanded ambient data 9-KFC,00 00,
IDE10923,Drive profile selection: act. charac. curve,Comfort,
Elapsed Time: 00:04
;SW:4S0-907-801   HW:8K0-907-801-J ---  Parking Brake
;Component:EPB-4         H02 0001, Coding:
;EV_ParkiBrake,001027,EV_ParkiBrake_AU72.rod
;Sunday,17,May,2020,19:50:06:06485
;VCID: 70ACD217ABBA4606FB-8024
IDE00820-ENG101710-Activating and deactivating all development messages-development message ECU specific 01 / (02),not active ,1
IDE00820-ENG100731-Activating and deactivating all development messages-development message ECU specific 03 to 10,not active ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,not active ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,not active ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,not active ,1
IDE00820-ENG99301-Activating and deactivating all development messages-XCP ECU specific,not active ,1
IDE07959-Automatic parking brake for selector lever position P,not activated ,1
IDE08134-MAS00162-Automatic parking brake-automatic,not activated ,2
IDE08134-MAS01094-Automatic parking brake-Man.trans.,not activated ,2
ENG102467-Auto Apply due to engine stall,activated ,1
ENG101858-Auto Apply due to switch failure,not activated ,1
ENG103839-Drive Away Assist,activated ,1
ENG99283-Drive Away Assist Sensitivity,normal ,1
ENG105907-Drive_away_assist_without_gas,activated ,1
ENG111690-Driver Out Apply-,activated ,5
ENG111690-ENG122739-Driver Out Apply-Evaluation of brake pedal,not activated ,5
ENG111690-ENG122740-Driver Out Apply-Evaluation of seatbelt,not activated ,5
ENG111690-ENG122738-Driver Out Apply-Velocity for Reset,3.0 km/h,5
ENG100578-Emergency Braking,front and rear ,1
ENG99371-Emergency Braking intensity,6 ,1
ENG101137-Manual release,with button and brake pedal depressed ,1
ENG108402-RDL,not activated ,1
ENG111691-MAS06033-Reduced Clampforce-Reduced tensioning force during start/stop,not activated ,4
ENG111691-ENG111687-Reduced Clampforce-Reduced Clampforce Automatic Transmission,not activated ,4
ENG111691-ENG111689-Reduced Clampforce-Reduced Clampforce Inclination Treshold,0 %,4
ENG111691-ENG111688-Reduced Clampforce-Reduced Clampforce Manual Transmission,not activated ,4
ENG101131-Seat belt buckle detection,activated ,1
ENG122736-Shift P to EPB,not activated ,1
ENG100416-VIN Check,not activated ,1
Elapsed Time: 00:04
;Sunday,17,May,2020,19:50:02:06485
IDE00019,Voltage terminal 30,11.9, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine speed,0, /min
IDE00031,Torque transmitting function,0.0,
IDE00075,Vehicle speed,0.0, km/h
IDE00086,Accelerator position,0.0, %
IDE00100,Engine torque,147, Nm
IDE00608,Type of fuel,Petrol,
IDE02211,Brake pressure,0.0, bar
IDE02611,Incline angle of parking brake,0,
IDE02613,Status of parking brake button,Not operated,
IDE02614,Reversing light switch,OFF,
IDE02656-IDE04944,System condition of parking brake-Brake pedal evaluation,not activated,
IDE02656-MAS00128,System condition of parking brake-Distance Regulation,coded,
IDE02656-MAS01090,System condition of parking brake-Transmission,automatic,
IDE02656-MAS02138,System condition of parking brake-Hill-start assistant,active,
IDE02656-MAS02141,System condition of parking brake-Monitoring VIN,activated,
IDE02656-MAS02575,System condition of parking brake-Start of operations,performed,
IDE02656-MAS02578,System condition of parking brake-Parking brake off,with button and brake pedal depressed,
IDE02656-MAS02663,System condition of parking brake-Type of braking,front and rear,
IDE02656-MAS02664,System condition of parking brake-Braking intensity,6,
IDE02656-MAS02665,System condition of parking brake-Automatic closing at button malfunction,not active,
IDE02656-MAS02666,System condition of parking brake-Seat belt buckle scan,active,
IDE02656-MAS02668,System condition of parking brake-Automatic closing with engine off,active,
IDE02656-MAS02670,System condition of parking brake-Gradual release of brake,not active,
IDE02656-MAS02671,System condition of parking brake-Brake release,normal,
IDE02656-MAS04937,System condition of parking brake-Reduced tensioning force: parking brake: automatic transmission,not activated,
IDE02656-MAS04938,System condition of parking brake-Reduced tensioning force: parking brake: manual transmission,not activated,
IDE02656-MAS04939,System condition of parking brake-Reduced tensioning force: threshold with vehicle inclination,0, %
IDE02656-MAS04940,System condition of parking brake-Release of brake without gas pedal actuation,activated,
IDE02656-MAS06031,System condition of parking brake-Close if ignition off: automatic transmission,not activated,
IDE02656-MAS06032,System condition of parking brake-Close if ignition off: manual transmission,not activated,
IDE02656-MAS06033,System condition of parking brake-Reduced tensioning force during start/stop,not activated,
IDE02656-ENG111690,System condition of parking brake-Driver Out Apply,activated,
IDE02656-ENG122740,System condition of parking brake-Evaluation of seatbelt,not activated,
IDE02656-ENG122737,System condition of parking brake-Shift-P to EPB,not activated,
IDE02656-ENG122738,System condition of parking brake-Velocity for Reset,3.0, km/h
IDE02659-MAS01849,Parking brake status-Left,Open,
IDE02659-MAS01850,Parking brake status-Right,Open,
IDE02713,Brake Light Switch,not activated,
IDE03312,Calculated brake temperature,32, °C
IDE03313-MAS01849,Cut-off current for parking brake motors-Left,0.0, A
IDE03313-MAS01850,Cut-off current for parking brake motors-Right,0.0, A
IDE03315-MAS01000,Warnings-Warning text,0,
IDE03315-MAS01911,Warnings-Tone sensor,OFF,
IDE03315-MAS02590,Warnings-Red warning light,OFF,
IDE03315-MAS02591,Warnings-Yellow warning light,OFF,
IDE03315-MAS02592,Warnings-Red operating lamp,OFF,
IDE03315-MAS02593,Warnings-Green operating lamp,OFF,
IDE03315-MAS02594,Warnings-Indicator light in switch,OFF,
IDE03316-MAS02595,Deceleration: setpoint-Deceleration,0.000, m/s²
IDE03317,Transmission range gear recognition switch,Neutral,
IDE03318-MAS00106,Highest brake temperature reached-Year,2016,
IDE03318-MAS00107,Highest brake temperature reached-Month,10,
IDE03318-MAS00108,Highest brake temperature reached-Day,9,
IDE03318-MAS00109,Highest brake temperature reached-Hours,14, H
IDE03318-MAS00110,Highest brake temperature reached-Minutes,45, min
IDE03318-MAS00711,Highest brake temperature reached-Odometer reading,7055, km
IDE03318-MAS02201,Highest brake temperature reached-Temperature,518, °C
IDE03998,Clutch Position Sensor,not installed,
MAS00025-ENG100607,Driver seat belt switch-Micro-Belt-Switch Driver Side,not connected,
ENG105199-ENG103056,Apply Counter-left Brake,1781,
ENG105199-ENG100874,Apply Counter-right Brake,1778,
ENG105239,Auto Adjust counter,0,
ENG106873,High temparature reclamp counter,26,
ENG106962,Index Parameter Table,0,
ENG107059,Internal ParkingBrake state,static,
ENG107352-ENG98504,Last Auto Adjust information-Day,0,
ENG107352-ENG98653,Last Auto Adjust information-Hour,255, H
ENG107352-ENG103063,Last Auto Adjust information-Mileage,0, km
ENG107352-ENG98758,Last Auto Adjust information-Minutes,255, min
ENG107352-ENG98748,Last Auto Adjust information-Month,0,
ENG107352-ENG99063,Last Auto Adjust information-Year,2000,
ENG107586-MAS00106,Maximum brake temperature development-Year,2016,
ENG107586-MAS00107,Maximum brake temperature development-Month,10,
ENG107586-MAS00108,Maximum brake temperature development-Day,9,
ENG107586-MAS00109,Maximum brake temperature development-Hours,14, H
ENG107586-MAS00110,Maximum brake temperature development-Minutes,45, min
ENG107586-MAS00711,Maximum brake temperature development-Odometer reading,7055, km
ENG107586-MAS02201,Maximum brake temperature development-Temperature,518, °C
ENG101040,Network management state,normal,
ENG109003-ENG101773,Software version second microncontroller-FSMC SW Version,X024,
Elapsed Time: 00:04
;SW:4T0-907-357-A   HW:4H4-907-357-A ---  Headlight Range
;Component:....AFS13.... H01 0003, Coding:72846F6118020200
;EV_AFSLEDHELLALB72X,006131,EV_AFSLEDHELLALB72X.rod
;Sunday,17,May,2020,19:50:17:06485
;VCID: 383C2A37834ADE46F3-806C
IDE03638-static AFS light,active ,1
IDE03639-Static AFS light when driving in reverse,active ,1
IDE03640-Dynamic AFS light,active ,1
IDE03641-Presentation run dynamic AFS light,active ,1
IDE03642-Presentation mode,active ,1
IDE03643-variable front lighting,Unknown (255),1
IDE03644-Highway light,active ,1
IDE03645-Speed-dependent city lights,active ,1
IDE03646-Intersection light with route data,Unknown (255),1
IDE03647-City light with route data,Unknown (255),1
IDE03648-Highway light with route data,Unknown (255),1
IDE03671-Variable front lighting: strategy,Unknown (255),1
IDE03672-Intersection light actuator selection,Unknown (255),1
IDE03673-Intersection light strategy,Unknown (254),1
IDE03674-Fog light assistance,not active ,1
IDE03787-Activate left/right hand drive switch-over,Unknown (255),1
ENG105082-Adaptive_Motorway_Light_Control_Strategy_Selection_Development,E0 ,1
ENG105994-Dynamic_Curve_Light_Control_Strategy_Selection_Development,Dynamic ,1
ENG105995-Dynamic_Curve_Light_Swivelling_Model_Selection_Development,sliding swivelling ,1
ENG107491-LWR_Control_Strategy_Selection_Development,AUTO ,1
ENG107492-LWR_Function_Activation_Development,active ,1
ENG107494-LWR_Vehicle_Niveau_Sensor_External_Power_Supply_Explicit_Activation_Development,not active ,1
ENG108439-Reference_Run_Start_Condition_Selection_Development,Reference run is carried out from an engine speed of 500 rpm ,1
ENG109092-Static_Curve_Light_Control_Strategy_Selection_Development,Dynamic ,1
ENG109095-Static_Curve_Light_Turn_Indicator_Offset_Activation_Development,active ,1
Elapsed Time: 00:06
;Sunday,17,May,2020,19:50:13:06485
IDE00018-ENG111630,Voltage terminal 15-Supply Voltage Clamp 15,11.7, V
IDE00027-ENG101022,Status of brake signals-breaking signal,not activated,
IDE00030-ENG98503,Status of actuator test-Data record,not active,
IDE00086,Accelerator position,0, %
IDE00322-ENG98503,Status of basic setting-Data record,not active,
IDE00326,Steering wheel angle,Unknown (65535),
IDE00925,Yaw rate,Unknown (65532),
IDE01232,Supply voltage for external components,Unknown (255),
IDE01268-ENG99744,Windshield wiper-wiper status signal,OFF,
IDE01588,Driving direction,Stop,
IDE01714-ENG103780,Status reverse gear-CAN signal gear status,Not available,
IDE01759-ENG103446,Audi drive select-charisma status signal,AUTO,
IDE01943-MAS01849,Turn signal-Left,Unknown (255),
IDE01943-MAS01850,Turn signal-Right,Unknown (255),
IDE02743-ENG100073,High Beam-high beam signal,OFF,
IDE03602,Left front level control system sensor,Unknown (254),
IDE03604,Left rear level control system sensor,Unknown (254),
IDE03615-MAS01632,Version-Status,SteeringWheelOnLeftSide,
IDE03616-ENG99860,Motor status-Engine status signal,On,
IDE03617-ENG102110,Fog light signal status-front fog light status,Unknown (255),
IDE03618-ENG99984,Rear fog light signal status-rear fog light status,Unknown (255),
IDE03620,Front jounce travel,-74, mm
IDE03621,Rear jounce travel,-76, mm
IDE03622-MAS01632,Left headlight beam adjusting motor: status-Status,no error,
IDE03623-MAS01632,Right headlight beam adjusting motor: status-Status,no error,
IDE03624,Left dynamic AFS light motor: specified value,Unknown (65530),
IDE03625,Right dynamic AFS light motor: specified value,Unknown (65530),
IDE03626-MAS01632,Left dynamic AFS light motor: status-Status,NOT-DEFINED,
IDE03627-MAS01632,Right dynamic AFS light motor: status-Status,NOT-DEFINED,
IDE03628-MAS01632,Adjusting motor for variable left front lighting: status-Status,NOT-DEFINED,
IDE03629-MAS01632,Adjusting motor for variable right front lighting: status-Status,NOT-DEFINED,
IDE03630,Left headlight beam adjusting motor: specified value,0, mm
IDE03631,Right headlight beam adjusting motor: specified value,0, mm
IDE03632-ENG102821,Left-/right hand driving switch-over-BCM Signal Tourist mode,OFF,
IDE03669-MAS01632,Light distribution status-Status,Unknown (255),
IDE03670-MAS02921,Light functions with route data-Crossover light,Unknown (3),
IDE03670-MAS02922,Light functions with route data-City light,Unknown (3),
IDE03670-MAS02923,Light functions with route data-Highway light,Unknown (3),
IDE03727-ENG114634,Variable left front lighting specified position-GLW Actuator Step Textual,Unknown (255),
IDE03728-ENG114634,Variable right front lighting specified position-GLW Actuator Step Textual,Unknown (255),
IDE03788-IDE00072,Status of basic headlamp setting-ASAM/ODX file identification,no request,
ENG105537-ENG103989,Coding_fail_reason_Development-Calculated_Headlamp_Power_Module_Varinat_Coding_Value,3A,
ENG105537-ENG103218,Coding_fail_reason_Development-Country_Variant,OK,
ENG105537-ENG104003,Coding_fail_reason_Development-ECU,OK,
ENG105537-ENG100788,Coding_fail_reason_Development-Light_actuator,OK,
ENG105537-ENG103450,Coding_fail_reason_Development-Light_function,OK,
ENG105537-ENG103811,Coding_fail_reason_Development-PSD,OK,
ENG105537-ENG98886,Coding_fail_reason_Development-sensor,OK,
ENG105537-ENG99522,Coding_fail_reason_Development-Start_Stop,OK,
ENG105537-ENG100643,Coding_fail_reason_Development-SUBCAN,OK,
ENG105537-ENG101245,Coding_fail_reason_Development-Tester_Repairshop_Code,OK,
ENG105537-ENG99614,Coding_fail_reason_Development-Variant_Coding_Status,OK,
ENG105537-ENG100776,Coding_fail_reason_Development-Vehicle_type,OK,
ENG105537-ENG99886,Coding_fail_reason_Development-Vehicle_Variant,OK,
ENG106042,ECU_Acceleration_Calculated_Development,-8,
ENG107493-ENG101661,LWR_Time_Constant_Index_Development-Time constant index,7,
ENG109093,Static_Curve_Light_Dimming_Left_Target_Value_Development,Unknown (254),
ENG109094,Static_Curve_Light_Dimming_Right_Target_Value_Development,Unknown (254),
ENG109844,Variable_front_ligthing_target_value_Development,OFF,
ENG109844,Variable_front_ligthing_target_value_Development,Not available,
ENG109844,Variable_front_ligthing_target_value_Development,Unknown (65152),
ENG109844,Variable_front_ligthing_target_value_Development,Unknown (65535),
ENG109844-ENG100284,Variable_front_ligthing_target_value_Development-Left Headlamp GLW Actuator Step,Unknown (255),
ENG109844-ENG101809,Variable_front_ligthing_target_value_Development-Left Right Hand Traffic,Unknown (255),
ENG109844-ENG101134,Variable_front_ligthing_target_value_Development-Right Headlamp GLW Actuator Step,Highway light,
Elapsed Time: 00:03
;SW:4H0-907-273-B   HW:4H0-907-273-B ---  Tire Pressure
;Component:RDKBERU25     H10 0820, Coding:
;EV_RDKBERU25,003014,EV_RDKBERU25_AU57.rod
;Sunday,17,May,2020,20:02:39:06485
;VCID: 2A18007F4DE67CD675-807E
IDE03508-SPECIFIED pressure line selection (end of assembly line),1 ,1
IDE03509-Front-axle SPECIFIED pressure partially loaded,255 ,1
IDE03510-Rear-axle SPECIFIED pressure partially loaded,255 ,1
IDE03511-Front-axle SPECIFIED pressure fully loaded,255 ,1
IDE03512-Rear-axle SPECIFIED pressure fully loaded,255 ,1
IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID),0 ,5
IDE03513-Write sensor identification number-,Left front ,5
Elapsed Time: 00:01
;Sunday,17,May,2020,20:02:37:06485
IDE00002,Transport mode,OFF,
IDE03521-IDE03525,Left front tire pressure monitoring sensor-Sensor identification number (sensor ID),1279979281,
IDE03521-MAS02818,Left front tire pressure monitoring sensor-CURRENT pressure,1.8, bar
IDE03521-MAS02819,Left front tire pressure monitoring sensor-CURRENT temperature,22, °C
IDE03521-MAS02820,Left front tire pressure monitoring sensor-SPECIFIED pressure,3.0, bar
IDE03521-ENG111627,Left front tire pressure monitoring sensor-Restlebensdauer,120,
IDE03521-ENG114743,Left front tire pressure monitoring sensor-Status der Radelektronik,51,
IDE03522-IDE03525,Right front tire pressure monitoring sensor-Sensor identification number (sensor ID),1279979328,
IDE03522-MAS02818,Right front tire pressure monitoring sensor-CURRENT pressure,3.1, bar
IDE03522-MAS02819,Right front tire pressure monitoring sensor-CURRENT temperature,21, °C
IDE03522-MAS02820,Right front tire pressure monitoring sensor-SPECIFIED pressure,3.1, bar
IDE03522-ENG111627,Right front tire pressure monitoring sensor-Restlebensdauer,120,
IDE03522-ENG114743,Right front tire pressure monitoring sensor-Status der Radelektronik,51,
IDE03523-IDE03525,Left rear tire pressure monitoring sensor-Sensor identification number (sensor ID),1279979142,
IDE03523-MAS02818,Left rear tire pressure monitoring sensor-CURRENT pressure,3.1, bar
IDE03523-MAS02819,Left rear tire pressure monitoring sensor-CURRENT temperature,21, °C
IDE03523-MAS02820,Left rear tire pressure monitoring sensor-SPECIFIED pressure,3.0, bar
IDE03523-ENG111627,Left rear tire pressure monitoring sensor-Restlebensdauer,120,
IDE03523-ENG114743,Left rear tire pressure monitoring sensor-Status der Radelektronik,51,
IDE03524-IDE03525,Right rear tire pressure monitoring sensor-Sensor identification number (sensor ID),1279979343,
IDE03524-MAS02818,Right rear tire pressure monitoring sensor-CURRENT pressure,3.1, bar
IDE03524-MAS02819,Right rear tire pressure monitoring sensor-CURRENT temperature,22, °C
IDE03524-MAS02820,Right rear tire pressure monitoring sensor-SPECIFIED pressure,3.1, bar
IDE03524-ENG111627,Right rear tire pressure monitoring sensor-Restlebensdauer,120,
IDE03524-ENG114743,Right rear tire pressure monitoring sensor-Status der Radelektronik,51,
IDE03527-IDE00019,CAN signals-Voltage terminal 30,11.9, V
IDE03527-IDE00075,CAN signals-Vehicle speed,0, km/h
IDE03529-IDE03525,Last received tire pressure sensor in reception range-Sensor identification number (sensor ID),1279979343,
IDE03529-MAS02818,Last received tire pressure sensor in reception range-CURRENT pressure,3.1, bar
IDE03529-MAS02819,Last received tire pressure sensor in reception range-CURRENT temperature,22, °C
IDE03529-ENG111627,Last received tire pressure sensor in reception range-Restlebensdauer,120,
IDE03529-ENG114743,Last received tire pressure sensor in reception range-Status der Radelektronik,51,
IDE03530-IDE03531,Monitoring status-Wheel/tire description,FMVSS           ,
IDE03530-IDE03532,Monitoring status-Load status selected,Partially loaded,
IDE03530-IDE03533,Monitoring status-Front-axle SPECIFIED pressure,2.4, bar
IDE03530-IDE03534,Monitoring status-Rear-axle SPECIFIED pressure,2.2, bar
IDE03530,Monitoring status,1,
IDE03535-IDE02955,System information-System status,active,
IDE03535-IDE03526,System information-Radio interference,No,
IDE03535-MAS01853,System information-Left front,no warning,
IDE03535-MAS01853,System information-Left front,Warning,
IDE03535-MAS01854,System information-Right front,no warning,
IDE03535-MAS01855,System information-Left rear,no warning,
IDE03535-MAS01856,System information-Right rear,no warning,
IDE03535-MAS02821,System information-Check tire pressure,---,
IDE03535-MAS02822,System information-Flat tire,---,
IDE03535-MAS02823,System information-Tire pressure too low,---,
IDE80001,Analysis 1,OFF,
MAS00138-IDE03509,1-Front-axle SPECIFIED pressure partially loaded,2.4, bar
MAS00138-IDE03510,1-Rear-axle SPECIFIED pressure partially loaded,2.2, bar
MAS00138-IDE03511,1-Front-axle SPECIFIED pressure fully loaded,2.6, bar
MAS00138-IDE03512,1-Rear-axle SPECIFIED pressure fully loaded,2.4, bar
MAS00138-IDE03531,1-Wheel/tire description,FMVSS           ,
Elapsed Time: 00:02
;SW:4T0-927-109-A   HW:4S0-927-109 ---  Auto Trans 2
;Component:DL800 ZSG     H11 0001, Coding:000001
;EV_TCMDL800421,001023,EV_TCMDL800.rod
;Sunday,17,May,2020,20:03:16:06485
;VCID: 352223039458232EE8-8060
IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1
ENG122022-ENG122080-Manual setting of Ist PS-Manuelle Vorgabe Istwert Parksperre,OFF ,2
ENG122022-ENG122081-Manual setting of Ist PS-Vorgabe Istwert Parksperre,Intermediate position ,2
ENG122021-ENG122078-Manual setting of Soll PS-Manuelle Vorgabe Sollwert Parksperre,OFF ,2
ENG122021-ENG122079-Manual setting of Soll PS-Vorgabe Sollwert Parksperre,Initializing ,2
ENG122020-ENG122076-Manual setting of Valve KUV current-Schalter Vorgabe Sollstrom,AUTO ,3
ENG122020-ENG122077-Manual setting of Valve KUV current-Vorgabe Sollstrom,0 mA,3
ENG122024-ENG122076-Manual setting of Valve PAV current-Schalter Vorgabe Sollstrom,AUTO ,3
ENG122024-ENG122077-Manual setting of Valve PAV current-Vorgabe Sollstrom,0 mA,3
ENG122025-ENG122076-Manual setting of Valve PEV current-Schalter Vorgabe Sollstrom,AUTO ,3
ENG122025-ENG122077-Manual setting of Valve PEV current-Vorgabe Sollstrom,0 mA,3
ENG122026-ENG122076-Manual setting of Valve PHM current-Schalter Vorgabe Sollstrom,AUTO ,3
ENG122026-ENG122077-Manual setting of Valve PHM current-Vorgabe Sollstrom,0 mA,3
ENG122023-ENG122097-Signal generator 1-Flag_Hold,OFF ,29
ENG122023-ENG122098-Signal generator 1-Flag_Reset,OFF ,29
ENG122023-ENG122083-Signal generator 1-Index_Max_Sprung,0 ,29
ENG122023-ENG122087-Signal generator 1-Signal_Down_Time,100 ms,29
ENG122023-ENG122085-Signal generator 1-Signal_Hold_Time_Sprung,0 ms,29
ENG122023-ENG122088-Signal generator 1-Signal_Max_Rampen_Treppen,0 ,29
ENG122023-ENG122089-Signal generator 1-Signal_Min_Rampen_Treppen,0 ,29
ENG122023-ENG122092-Signal generator 1-Signal_Period_Frequency,Period ,29
ENG122023-ENG122095-Signal generator 1-Signal_Sinus_Amplitude,0.0 ,29
ENG122023-ENG122093-Signal generator 1-Signal_Sinus_Frequency,1.00 Hz,29
ENG122023-ENG122096-Signal generator 1-Signal_Sinus_Offset,0 ,29
ENG122023-ENG122094-Signal generator 1-Signal_Sinus_Period,1000 ms,29
ENG122023-ENG122084-Signal generator 1-Signal_Startwert_Sprung,0 ,29
ENG122023-ENG122090-Signal generator 1-Signal_T_High,100 ms,29
ENG122023-ENG122091-Signal generator 1-Signal_T_Low,100 ms,29
ENG122023-ENG122086-Signal generator 1-Signal_Up_Time,100 ms,29
ENG122023-ENG122082-Signal generator 1-Signalform,Konstant ,29
ENG122027-ENG122097-Signal generator 2-Flag_Hold,OFF ,29
ENG122027-ENG122098-Signal generator 2-Flag_Reset,OFF ,29
ENG122027-ENG122083-Signal generator 2-Index_Max_Sprung,0 ,29
ENG122027-ENG122087-Signal generator 2-Signal_Down_Time,100 ms,29
ENG122027-ENG122085-Signal generator 2-Signal_Hold_Time_Sprung,0 ms,29
ENG122027-ENG122088-Signal generator 2-Signal_Max_Rampen_Treppen,0 ,29
ENG122027-ENG122089-Signal generator 2-Signal_Min_Rampen_Treppen,0 ,29
ENG122027-ENG122092-Signal generator 2-Signal_Period_Frequency,Period ,29
ENG122027-ENG122095-Signal generator 2-Signal_Sinus_Amplitude,0.0 ,29
ENG122027-ENG122093-Signal generator 2-Signal_Sinus_Frequency,1.00 Hz,29
ENG122027-ENG122096-Signal generator 2-Signal_Sinus_Offset,0 ,29
ENG122027-ENG122094-Signal generator 2-Signal_Sinus_Period,1000 ms,29
ENG122027-ENG122084-Signal generator 2-Signal_Startwert_Sprung,0 ,29
ENG122027-ENG122090-Signal generator 2-Signal_T_High,100 ms,29
ENG122027-ENG122091-Signal generator 2-Signal_T_Low,100 ms,29
ENG122027-ENG122086-Signal generator 2-Signal_Up_Time,100 ms,29
ENG122027-ENG122082-Signal generator 2-Signalform,Konstant ,29
ENG122028-ENG122097-Signal generator 3-Flag_Hold,OFF ,29
ENG122028-ENG122098-Signal generator 3-Flag_Reset,OFF ,29
ENG122028-ENG122083-Signal generator 3-Index_Max_Sprung,0 ,29
ENG122028-ENG122087-Signal generator 3-Signal_Down_Time,100 ms,29
ENG122028-ENG122085-Signal generator 3-Signal_Hold_Time_Sprung,0 ms,29
ENG122028-ENG122088-Signal generator 3-Signal_Max_Rampen_Treppen,0 ,29
ENG122028-ENG122089-Signal generator 3-Signal_Min_Rampen_Treppen,0 ,29
ENG122028-ENG122092-Signal generator 3-Signal_Period_Frequency,Period ,29
ENG122028-ENG122095-Signal generator 3-Signal_Sinus_Amplitude,0.0 ,29
ENG122028-ENG122093-Signal generator 3-Signal_Sinus_Frequency,1.00 Hz,29
ENG122028-ENG122096-Signal generator 3-Signal_Sinus_Offset,0 ,29
ENG122028-ENG122094-Signal generator 3-Signal_Sinus_Period,1000 ms,29
ENG122028-ENG122084-Signal generator 3-Signal_Startwert_Sprung,0 ,29
ENG122028-ENG122090-Signal generator 3-Signal_T_High,100 ms,29
ENG122028-ENG122091-Signal generator 3-Signal_T_Low,100 ms,29
ENG122028-ENG122086-Signal generator 3-Signal_Up_Time,100 ms,29
ENG122028-ENG122082-Signal generator 3-Signalform,Konstant ,29
ENG122029-ENG122097-Signal generator 4-Flag_Hold,OFF ,29
ENG122029-ENG122098-Signal generator 4-Flag_Reset,OFF ,29
ENG122029-ENG122083-Signal generator 4-Index_Max_Sprung,0 ,29
ENG122029-ENG122087-Signal generator 4-Signal_Down_Time,100 ms,29
ENG122029-ENG122085-Signal generator 4-Signal_Hold_Time_Sprung,0 ms,29
ENG122029-ENG122088-Signal generator 4-Signal_Max_Rampen_Treppen,0 ,29
ENG122029-ENG122089-Signal generator 4-Signal_Min_Rampen_Treppen,0 ,29
ENG122029-ENG122092-Signal generator 4-Signal_Period_Frequency,Period ,29
ENG122029-ENG122095-Signal generator 4-Signal_Sinus_Amplitude,0.0 ,29
ENG122029-ENG122093-Signal generator 4-Signal_Sinus_Frequency,1.00 Hz,29
ENG122029-ENG122096-Signal generator 4-Signal_Sinus_Offset,0 ,29
ENG122029-ENG122094-Signal generator 4-Signal_Sinus_Period,1000 ms,29
ENG122029-ENG122084-Signal generator 4-Signal_Startwert_Sprung,0 ,29
ENG122029-ENG122090-Signal generator 4-Signal_T_High,100 ms,29
ENG122029-ENG122091-Signal generator 4-Signal_T_Low,100 ms,29
ENG122029-ENG122086-Signal generator 4-Signal_Up_Time,100 ms,29
ENG122029-ENG122082-Signal generator 4-Signalform,Konstant ,29
ENG109348-TCM_VMS,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 ,16
Elapsed Time: 00:04
;Sunday,17,May,2020,20:02:58:06485
IDE00018-ENG122066,Voltage terminal 15-KL 15 Voltage,11.7, V
IDE00019-ENG122107,Voltage terminal 30-Module Voltage,11662, mV
IDE00024-ENG122073,Transmission fluid temperature-Sump temperature,29.0, °C
IDE00025,Coolant temperature,90, °C
IDE00075,Vehicle speed,0, km/h
IDE00085,Normed load value,49.0, %
IDE00086,Accelerator position,14.9, %
IDE00103-IDE00018,Snapshot-Voltage terminal 15,11.8, V
IDE00103-IDE00019,Snapshot-Voltage terminal 30,11.9, V
IDE00103-IDE00020,Snapshot-Terminal 15 status,On,
IDE00103-IDE00021,Snapshot-Engine speed,0, /min
IDE00103-IDE00024,Snapshot-Transmission fluid temperature,28.0, °C
IDE00103-IDE00102,Snapshot-Control Module temperature,46.0, °C
IDE00103-IDE00107,Snapshot-System time in normal operation,797,
IDE00103-IDE00108,Snapshot-System time in after-run,0,
IDE00103-IDE00301,Snapshot-Distance,38769,
IDE00103-IDE00611,Snapshot-Malfunction that has caused the ambient data to be stored,00 4B A5,
IDE00103-MAS00106,Snapshot-Year,2012,
IDE00103-MAS00107,Snapshot-Month,1,
IDE00103-MAS00108,Snapshot-Day,7,
IDE00103-MAS00109,Snapshot-Hours,23,
IDE00103-MAS00110,Snapshot-Minutes,51,
IDE00103-MAS00111,Snapshot-Seconds,57,
IDE00103-ENG122114,Snapshot-BLS,active,
IDE00103-ENG122115,Snapshot-BTS,active,
IDE00103-ENG122102,Snapshot-Iststrom KUV,0.0, mA
IDE00103-ENG122100,Snapshot-Iststrom PAV,0.0, mA
IDE00103-ENG122099,Snapshot-Iststrom PEV,0.0, mA
IDE00103-ENG122101,Snapshot-Iststrom PHM,0.0, mA
IDE00103-ENG122047,Snapshot-Parking lock sensor,Intermediate position,
IDE00103-ENG06561,Snapshot-PSM_State 0,Engaged Locked Motor Off (0x12),
IDE00103-ENG06562,Snapshot-PSM_State 1,not valid,
IDE00103-ENG06563,Snapshot-PSM_State 2,not valid,
IDE00103-ENG06564,Snapshot-PSM_State 3,not valid,
IDE00103-ENG06565,Snapshot-PSM_State 4,not valid,
IDE00103-ENG06566,Snapshot-PSM_State 5,not valid,
IDE00103-ENG122103,Snapshot-Sollstrom KUV,0, mA
IDE00103-ENG122104,Snapshot-Spannung HS1,6431, mV
IDE00103-ENG122105,Snapshot-Spannung HS2,6498, mV
IDE00103-ENG122049,Snapshot-Specification parking lock,Selecting,
IDE00103-ENG122048,Snapshot-Status parking lock,Parksperre eingelegt halten,
IDE00103-ENG98606,Snapshot-Vehicle speed,0.0, km/h
IDE00445,Unlearning counter according OBD,255,
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE08465-ENG122047,Parking lock: actual state-Parking lock sensor,selected,
IDE08466-ENG122116,Parking lock: target state-Sollwert Parksperre,Selecting,
IDE08467-ENG122124,Clutch cooling valve 2: actual value-Iststrom,1, mA
IDE08468-ENG112384,Clutch cooling valve 2: target value-Specified current,0, mA
IDE08469-ENG112384,Solen.val. 2 for parking lock: current target value-Specified current,0, mA
IDE08470-ENG122124,Solen.val. 2 for parking lock: current actual value-Iststrom,0, mA
IDE08471-ENG112384,Solen.val. for parking lock: current target value-Specified current,0, mA
IDE08472-ENG122124,Solen.val. for parking lock: current actual value-Iststrom,0, mA
IDE08473-ENG112384,Solen.val. 2 for parking lock: current maximum target value-Specified current,0, mA
IDE08474-ENG122124,Solen.val. 2 for parking lock: current maximum actual value-Iststrom,0, mA
IDE08475-ENG112384,Solenoid for parking lock: current target value-Specified current,0, mA
IDE08476-ENG122124,Solenoid for parking lock: current actual value-Iststrom,0, mA
IDE08477-ENG122119,Clutch temperature sensor 2-Kupplungsoeltemperatur,30.0, °C
IDE08478-ENG122118,Transmission coolant pump: activation-Tastverhältnis Pumpe,10, %
IDE10711-ENG06142,Downshift paddle switch: status-Upshift_downshift_paddle_status,not activated,
IDE10712-ENG06142,Upshift paddle switch: status-Upshift_downshift_paddle_status,not activated,
IDE10713-ENG122046,Downshift paddle switch: voltage-Voltage output driver,2.4, V
IDE10714-ENG122046,Upshift paddle switch: status-Voltage output driver,2.4, V
IDE10715-ENG06143,Button P for tiptronic in center console: status-Tiptronic_button_status,not activated,
IDE10716-ENG06143,Button M for tiptronic in center console: status-Tiptronic_button_status,not activated,
IDE10717-ENG06143,Button R for tiptronic in center console: status-Tiptronic_button_status,not activated,
IDE10718-ENG122046,Button P for tiptronic in center console: voltage-Voltage output driver,2.1, V
IDE10719-ENG122046,Button P for tiptronic in center console: voltage-Voltage output driver,2.1, V
IDE10720-ENG122046,Button R for tiptronic in center console: voltage-Voltage output driver,2.1, V
IDE13060-IDE00018,Snapshot 2-Voltage terminal 15,6.9, V
IDE13060-IDE00019,Snapshot 2-Voltage terminal 30,6.8, V
IDE13060-IDE00020,Snapshot 2-Terminal 15 status,On,
IDE13060-IDE00021,Snapshot 2-Engine speed,0, /min
IDE13060-IDE00024,Snapshot 2-Transmission fluid temperature,30.0, °C
IDE13060-IDE00102,Snapshot 2-Control Module temperature,57.0, °C
IDE13060-IDE00107,Snapshot 2-System time in normal operation,1,
IDE13060-IDE00108,Snapshot 2-System time in after-run,0,
IDE13060-IDE00301,Snapshot 2-Distance,1048574,
IDE13060-IDE00611,Snapshot 2-Malfunction that has caused the ambient data to be stored,00 4B 83,
IDE13060-MAS00106,Snapshot 2-Year,2000,
IDE13060-MAS00107,Snapshot 2-Month,0,
IDE13060-MAS00108,Snapshot 2-Day,0,
IDE13060-MAS00109,Snapshot 2-Hours,0,
IDE13060-MAS00110,Snapshot 2-Minutes,0,
IDE13060-MAS00111,Snapshot 2-Seconds,0,
IDE13060-ENG122114,Snapshot 2-BLS,not active,
IDE13060-ENG122115,Snapshot 2-BTS,not active,
IDE13060-ENG122102,Snapshot 2-Iststrom KUV,0.0, mA
IDE13060-ENG122100,Snapshot 2-Iststrom PAV,0.0, mA
IDE13060-ENG122099,Snapshot 2-Iststrom PEV,0.0, mA
IDE13060-ENG122101,Snapshot 2-Iststrom PHM,0.0, mA
IDE13060-ENG122047,Snapshot 2-Parking lock sensor,selected,
IDE13060-ENG06561,Snapshot 2-PSM_State 0,Engaged Locked Motor Off (0x12),
IDE13060-ENG06562,Snapshot 2-PSM_State 1,not valid,
IDE13060-ENG06563,Snapshot 2-PSM_State 2,not valid,
IDE13060-ENG06564,Snapshot 2-PSM_State 3,not valid,
IDE13060-ENG06565,Snapshot 2-PSM_State 4,not valid,
IDE13060-ENG06566,Snapshot 2-PSM_State 5,not valid,
IDE13060-ENG122103,Snapshot 2-Sollstrom KUV,1200, mA
IDE13060-ENG122104,Snapshot 2-Spannung HS1,6414, mV
IDE13060-ENG122105,Snapshot 2-Spannung HS2,6489, mV
IDE13060-ENG122049,Snapshot 2-Specification parking lock,Initializing,
IDE13060-ENG122048,Snapshot 2-Status parking lock,Parksperre eingelegt halten,
IDE13060-ENG98606,Snapshot 2-Vehicle speed,0.0, km/h
IDE80001-ENG104031,Analysis 1-Number,1942,
IDE80002-ENG104031,Analysis 2-Number,1942,
IDE80003-ENG104031,Analysis 3-Number,0,
IDE80004-ENG101695,Analysis 4-System Supplier Boot Identification,0214      ,
IDE80004-ENG101202,Analysis 4-System Supplier Calibration Data Identification,DL800_ZSG                                         ,
IDE80004-ENG101224,Analysis 4-System Supplier HW Version,39  ,
IDE80004-ENG103214,Analysis 4-System Supplier HW Version 2,Series,
IDE80004-ENG99311,Analysis 4-System Supplier Software Identification,LF00                                              ,
ENG122055-ENG122124,Actual current KUV-Iststrom,1, mA
ENG122057-ENG122124,Actual current PAV-Iststrom,0, mA
ENG122056-ENG122124,Actual current PEV-Iststrom,0, mA
ENG122058-ENG122124,Actual current PHM-Iststrom,0, mA
ENG101413,Calibration Identification,4T0927109A  0001,
ENG99697,Calibration Verification Number,00 00 76 53,
ENG122063-ENG122119,Cooling oil temperature-Kupplungsoeltemperatur,30.0, °C
ENG122071-ENG122120,Developer Message Receive-Param to DOP_36370,00 00 00 00 00 00 00 00,
ENG122072-ENG122120,Developer Message Transmit-Param to DOP_36370,22 01 B4 60 29 00 00 00,
ENG100152-ENG104003,ECUNAME-ECU,TCM2,
ENG100152,ECUNAME,TransmisCtrl2,
ENG122074-ENG122114,Engine and brake-BLS,not active,
ENG122074-ENG122115,Engine and brake-BTS,not active,
ENG122074-ENG122050,Engine and brake-Motor on flag,OFF,
ENG122068,Engine Coding Information,57,
ENG104986,Engine speed,0, /min
ENG122042-ENG122109,HS SPT Error Flags and internal status-HSB Error,not active,
ENG122042-ENG122110,HS SPT Error Flags and internal status-SPT Internal Status,0,
ENG122039-ENG122108,HS voltage SPT Failed-Valve Voltage,0.0, mV
ENG122041-ENG122108,HS voltage SPT start-Valve Voltage,0.0, mV
ENG122040-ENG122108,KL 30 voltage SPT start-Valve Voltage,0.0, mV
ENG122059-ENG122124,Max actual current PAV-Iststrom,0, mA
ENG122060-ENG122124,Max specified current PAV-Iststrom,0, mA
ENG122050,Motor on flag,OFF,
ENG122067-ENG102813,OBD Cycle and MIL state-Driving Cycle,not active,
ENG122067-ENG98734,OBD Cycle and MIL state-mil,not active,
ENG122067-ENG99968,OBD Cycle and MIL state-WarmUp Cycle,not active,
ENG100218,Occurrence_counter_over_length_of_life,255,
ENG122061-ENG122117,Parking lock Hall 1-Status Hall Sensor,00000000 ,
ENG122062-ENG122117,Parking lock Hall 2-Status Hall Sensor,00000001 ,
ENG122047,Parking lock sensor,selected,
ENG127477-ENG122046,Spannung Schaltwippe M-Voltage output driver,2.4, V
ENG127476-ENG122046,Spannung Schaltwippe P-Voltage output driver,2.4, V
ENG127480-ENG122046,Spannung Waehlhebel M-Voltage output driver,2.1, V
ENG127478-ENG122046,Spannung Waehlhebel P-Voltage output driver,2.1, V
ENG127479-ENG122046,Spannung Waehlhebel R-Voltage output driver,2.1, V
ENG122049-ENG122116,Specification parking lock-Sollwert Parksperre,Selecting,
ENG122051-ENG112384,Specified current KUV-Specified current,0, mA
ENG122053-ENG112384,Specified current PAV-Specified current,0, mA
ENG122052-ENG112384,Specified current PEV-Specified current,0, mA
ENG122054-ENG112384,Specified current PHM-Specified current,0, mA
ENG122065-ENG122118,Specified signal ratio auxiliary water pump-Tastverhältnis Pumpe,10, %
ENG122064-ENG122118,Specified signal ratio oil pump-Tastverhältnis Pumpe,0, %
ENG122043-ENG122111,Specified voltage output driver-Sollspannung HSB1,6350.0, mV
ENG122043-ENG122112,Specified voltage output driver-Sollspannung HSB2,6350.0, mV
ENG122075-ENG127481,Status L2-PAV_Ueb,not active,
ENG122075-ENG122123,Status L2-PEV_Ueb,not active,
ENG122075-ENG122122,Status L2-RAM Check,not active,
ENG122075-ENG122121,Status L2-ROM Check,not active,
ENG98934-ENG122114,Status of brakes-BLS,not active,
ENG98934-ENG122115,Status of brakes-BTS,not active,
ENG122048,Status parking lock,Parksperre eingelegt halten,
ENG127472-ENG06142,Status Schaltwippe M-Upshift_downshift_paddle_status,not activated,
ENG127471-ENG06142,Status Schaltwippe P-Upshift_downshift_paddle_status,not activated,
ENG127475-ENG06143,Status Waehlhebel M-Tiptronic_button_status,not activated,
ENG127473-ENG06143,Status Waehlhebel P-Tiptronic_button_status,not activated,
ENG127474-ENG06143,Status Waehlhebel R-Tiptronic_button_status,not activated,
ENG109839-ENG122108,Valve_voltage-Valve Voltage,11700.0, mV
ENG122045-ENG122113,Variant configured-Variante codiert,03,
ENG122044,Variant received,00,
ENG99010,Vehicle speed,0.0, km/h
ENG122046,Voltage output driver,11.7, V
Elapsed Time: 00:17
iichel
Netherlands, eastern part
C?ID=284912
So, first things first, I'm just using my (as we Dutchies call it) boerenverstand - Farmersmind. Thinking simple, not knowing the specifics and certainly not into Lamborghini-Rocket-Science.
5186 - Second (Slave) Engine Control Module
          U0115 00 [008] - No Communication
                    Reset counter: 12
                    Mileage: xxxkm
                    Date: 2012.01.09
                    Time: 20:08:19
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 31 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 12
                    Mileage: xxxkm
                    Date: 2012.01.09
                    Time: 20:08:19
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
I can imagine this might be a cause of no crank. No communication with both engine ECUs simultaneously (intermittent but confirmed).
The funny thing is, it seems that it happened/started with terminal 15 OFF.
Furthermore I can imagine that the automatic gearbox being unhappy could also prevent any cranking.
Immobiliser coil failure could also stop the engine from starting. BUT first I'd suspect the engine to go vroom-vroom-dead and secondly I think it has kessy so the reader coil should not matter that much.
PS
nice car
huracan2016
California, USA
C?ID=365022
                    Reset counter: 12
                    Mileage: xxxkm
                    Date: 2012.01.09
                    Time: 20:08:19
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U0100 00 [008] - -
                    Reset counter: 12
                    Mileage: xxxkm
                    Date: 2012.01.09
                    Time: 20:08:19
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
PS
nice car
Thanks for the quick response! This piece was buried in my original post -- just to clarify, my car has a standalone ECU (Syvecs), so those ECU communication faults you noted are nothing to worry about and normal course. My OEM ECUs are in a cardboard box somewhere.
huracan2016
California, USA
C?ID=365022
Would it be possible to place back the original ECU's and see if it cranks? Just to rule out some things.
Yeah, that's the next step if there's no smoking gun based on the scans above. Unfortunately, the process is time consuming, so I was hoping to identify the issue without having to go there.
I'm of the opinion that there's another loose connector somewhere, as all of this happened after a super bone-jarring/bumpy stretch of highway (my suspension setup certainly a contributor here...)
That, paired with the fact that much of my interior has been customized (interior, boost gauge, radar detector, audio stuff, etc.) over the course of my 2 year ownership, I don't think it would be out of the question for another connector or two to have become loose. Few things that caught my eye in the scans below...
00834 - Signal for Activation of Heated Rear Window
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:39
This is strange as I barely have a rear window let alone a rear window heater. Could this fault be "mapped" to something that isn't a rear window heater?
                    Reset counter: 227
                    Mileage: xxx km
                    Date: 2012.01.09
                    Time: 20:00:44
                    Bin. Bits: 00100000 00000000
                    Bin. Bits: 00000000 00000000
Not sure what to make of the above. Loose connector? Bad module?
Would I still be better off just plugging in the ECUs before tackling the above random faults?
iichel
C?ID=284912
Well, I'm sort-of hoping that your original ECU's could perhaps tell why the car isn't starting. It seems like the replacement ECU isn't telling us anything of interest as to why it's not starting.
Could be engine related, could be gearbox related, could be something completely different.
I think it's reasonable to expect the car reporting something that would prevent it from starting. A loose connector should show up somewhere.
Did you already check the car for any blown fuses?
DrPeter
16.4905° S, 151.7375° W
I think the first step is to establish communication to the ECM's and verify they are online and communicating to the other controllers. In order for a control module to communicate, it needs power, ground and a communication connection.
For example, on this vehicle, the ECM 1 (J623) needs*:
Power for the ECM 1 = Pins 3, 5 and 6 (red/yellow) (D182)-Connection 3 (87a)
Ground for ECM 1 = Pins 1, 2, and 4 (brown) (708)-Earth point 2 on rear right longitudinal member
CAN-Bus (H)/(L) = Pins 77/80 (CAN Low) Pins 60/79 (CAN High)​
* The following are deemed accurate, but not 100% guaranteed. (We recommend the Official Factory Repair manuals)
On a stock vehicle, there are two starter relays on this vehicle that are controlled by the J623, [J53-Starter Motor Relay 1] and [J695-Starter Motor Relay 2] needed to activate the starter.
Both relays receive power from the (D52)-15 Power connection. The same 15-power goes into the J53's 30-terminal, when activated, it the comes out of the J53 and then into the J695 and then when activated the J695 sends power to the starter motor.
The J53 is activated when the ECM's terminal T91/70(brown/green) sends a ground signal. The J695 relay is also activated by a ground from the ECM from terminal T91/52(brown/red).
I would check the ground signals from the ECM on the J53 and the J695 when the start is requested.
These relays are located in the electronics box, in right engine compartment (645 relays closest to the coolant reservoir).
You could also ground the two starter relay coils and see if the starter activates with the ignition on.
The above is the stock set up with the stock ECMs installed. Not too sure how the stand-alone ECM controls the starter relays and is wired in to the vehicle, but with the stock ECM, you should be able to see above.
Also using VCDS, when and if you can communicate to the ECM, use the Advanced Measuring Value to view the [Status of starter activation], that is a feedback connection from the 50-Power out of the J53 to the starter relay.
Hope this helps.
drpeter
HMC
C?ID=28246
Hi Huracan2016,
"all of this happened after a super bone-jarring/bumpy stretch of highway (my suspension setup certainly a contributor here...)".
Have you checked underneath for any damage?
Regards HMC
