2005 passat b6
tomb711
Pirate
Walking the Plank
Southampton, UK
hi guys, i have an issue with a passat. it came in as a non starter with various no comms faults. i traced the fault to a fried steering column control module causing fuse 16 in the engine bay to blow. ive replaced the module with a used part with exactly the same part number but i need some help coding it. ill include autoscans with the old part fitted and the new part fitted.thanks a lot
tomb711
Pirate
Walking the Plank
Southampton, UK
new part fitted
Removed.   Data from a clone/pirate copy of VCDS is not acceptable here
tomb711
Pirate
Walking the Plank
Southampton, UK
old part fitted
tomb711
Pirate
Walking the Plank
Southampton, UK
im assuming the key fault if due to incorrect vin or no coding. the airbag and radio faults are because thryre not fitted
