Transporter t5 no response from controller central lock and wipers
Turbo1
C?ID=385572
hex v2 i am having difficulty trying to access some of the controllers,i have problem with the left sliding door the door does not lock or unlock, tried accessing cent lock and the left sliding door individually but keep getting no response from controller
also need to see why my rear wipers are not working, which menu do i need to enter to access this, i found the wipers menu but again it says no response from controller, there are a few more that show no response but most of the other controllers do work
Turbo1
C?ID=385572
ill do one later on how do i post it on the forum
Turbo1
C?ID=385572
i did do one yesterday, saved bt cant find the file on my computer
Turbo1
C?ID=385572
t5 controllers not responding
here is the scan i did could someone please explain what they mean
i tried unlocking the heater but no luck itkeeps bringing the code back straight awa.
still unable to link to central locking need to check if passenger side sliding door solenoid is faulty thus the reason why it wont lock and unlock on the key all other doors are fine
unable to connect to wipers to check why rear wiper isnt working,
dont know why i have codes for bad fuses the fuses seem fine
Turbo1
C?ID=385572
found the scan file on my computer but dont know how to attach it
Turbo1
C?ID=385572
it seems from the direct scan i can save and then copy scan into the thread but how do i i add it later as i have it saved on the computer
Turbo1
C?ID=385572
codes
Tuesday,19,May,2020,17:59:08:01929
VIN: WV2ZZZ7HZ8H1   License Plate:
Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ8H1  Mileage: 358290km-222631miles
   Part No SW: 038 906 016 AJ    HW: 038 906 016 AJ
   Component: R4 1,9L EDC  000SG  9961
   Revision: --H06---    Serial number: VWZ7Z0H6424441
   Coding: 0100031
   Shop #: WSC 02756 790 00000
   VCID: 5CE1931E1A3BFF7B6F3-5184
Address 03: ABS Brakes        Labels:. 7H0-907-37x-ABS.clb
   Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
   Component: (M)ABS MK25E        0103
   Revision: 00H21001
   Coding: 0000552
   Shop #: WSC 00227 210 90083
   VCID: 45D7567A89B19EB320D-513C
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000101
   VCID: 74B1DBBE92AB573B473-513C
9 Faults Found:
01117 - Generator Terminal DF Load Signal
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
00900 - Fuse for Signal Horn (S194)
00538 - Reference Voltage
            014 - Defective
00899 - Fuse for Wiper Motor (S128)
            001 - Upper Limit Exceeded
00966 - Fuse for Blinkers (S151)
00925 - Fuse (30) for Interior Lamps (S261)
00909 - Windshield Wiper Motor (V) Stage 1/2
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0011
   Coding: 13123
   Shop #: WSC 02756
   VCID: 221DEDE67DDF898B65F-513C
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 00413
   Shop #: WSC 00072
   VCID: 3D273E9AE461D67378D-513C
   WV2ZZZ7HZ8H143635     VWZ7Z0H6424441
01304 - Radio
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 815 071 F
   Component: Standheizung        0209
   VCID: 2B0300C20F1548C3D69-513C
02251 - Heater Unit Locked
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70B9D7AEE3B36B1BA3B-513C
01304 - Radio
Address 45: Inter. Monitor        Labels: 7Hx-951-171.lbl
   Part No: 7H0 951 171 B
   Component: Innenraumueberw.    2920
   Coding: 0000022
   Shop #: WSC 02757 790 00000
   VCID: 290FFACA05E95AD3245-51A8
   Subsystem 1 - Part No: 7H5 951 178
   Component: Innenraumueberw.    1607
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00030
   Shop #: WSC 02756
   VCID: 323D1DA62D3F190B95F-4B1E
   Part No SW: 7H0 035 152 H    HW: 7H0 035 152 H
   Component: Radio 9NK           0008
   Revision: 00005000    Serial number: VWZ4Z4H1011877
   Coding: 0020200
   VCID: 270BFCF213FD6CA3321-513C
End----(Elapsed Time: 05:56, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
iichel
Netherlands, eastern part
C?ID=284912
First thing I'd suggest is to check all the fuses since there are quite a few reported to be broken. Perhaps a main fuse is gone. Did you check fuses for continuity or also for voltage?
Turbo1
C?ID=385572
i checked all the fuses for continuity
the horn and interior lights on the roof all work as does front wiper motor nut rear motor nothing
when you say a main fuse where would this be located
iichel
C?ID=284912
typically on/near the battery.
easier way to check is with a multimeter, see if there is any voltage on the fuse.
you could also clear all codes and see which return
Turbo1
C?ID=385572
the scan i have attached is a second scan after having cleared all the codes from the search screen, there is a fuse box near the battery and all fuses seemed fine on continuity, are you saying to check voltage to them is 12v with ign on,
i cant understand why a few faults for fuses are shewing when the item in question is working
also cant unlock the heater as after clearing the cod eit literally comes straight back
Turbo1
C?ID=385572
had a look at the fuses today and all had continuity but fuses 4.9.1016,17,20 and 24, found in the van below the gear stick had no power, trying to find out what these fuses are used for as some symbols are not clear as to what they are used for.
