This is what I got any suggestion? Novice repair guy here just need help please
Saturday,16,May,2020,13:53:44:14419
VIN: WVWAK73C16P143472 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 53 56 62 65
72
VIN: WVWAK73C16P143472 Mileage: 104610km-65001miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 F HW: 3C0 907 115 F
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 22811 444 89524
VCID: 2313EAC417D67D236E9-8076
005715 - Please check DTC Memory of ABS Controller
P1653 - 004 -
Mileage: 104618 km
Date: 2020.05.14
Time: 13:33:17
RPM: 834 /min
Load: 25.9 %
Temperature: 79.0°C
Temperature: 66.0°C
Absolute Pres.: 930.0 mbar
Voltage: 12.700 V
Readiness: 0110 0001
Part No SW: 09G 927 750 CJ HW: 09G 927 750 CJ
Component: AQ 250 6F 0841
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 7BA3F2A4CFE6E5E3069-802E
Fault Status: 00101101
Fault Frequency: 9
Reset counter: 184
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
Component: ESP 440 C2 H015 0003
Revision: H015 Serial number: 0658241360
Coding: 0013755
VCID: 303915885620D6BBE3B-8064
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
VCID: 6889BDE8AE705E7BFBB-803C
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002296500
Coding: 14840F0340041A00400A00000F00000000285D435C0000
VCID: 372B2E94B34E0183A21-8062
Subsystem 1 - Part No: 3C1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer VW461 012 0503
Coding: 00063445
Shop #: WSC 00028
Part No SW: 8E0 035 593 D HW: 8E0 035 593 D
Component: SDAR SIRIUS H03 0060
Revision: 00000000 Serial number: AUZ4Z7E7015504
VCID: 2A0D07E070FCAC6B2DF-807E
Reset counter: 7
Mileage: 104613 km
Date: 2020.05.12
Time: 00:51:08
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0N AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3PRJVKQZ
Coding: 0012366
VCID: 2E050BF04C14C04BF17-807A
Subsystem 1 - Part No: 3C0 959 339 A
Component: BF-Gewichtsens. 006 0002
Subsystem 2 - Serial number: 00000000032V6R
Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME0D3C6722Gÿ†63
Subsystem 5 - Serial number: C6722Gÿ†6342MSME0D2F0A51Iÿ†63
Subsystem 6 - Serial number: F0A51Iÿ†6351HTS69SDAUA33Tÿ†63
Subsystem 7 - Serial number: AUA33Tÿ†6361HTS604F64NM20ÿ†63
Subsystem 8 - Serial number: 64NM20ÿ†63727TS6I2IIAMM2Sÿ†63
Subsystem 9 - Serial number: IAMM2Sÿ†63827TS6I2II6ME2Hÿ
Subsystem 10 - Serial number: I6ME2Hÿ
03032 - Supply Voltage for Seat Occupied Recognition Control Module
Part No SW: 3C0 953 549 H HW: 3C0 953 549 H
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507R
Coding: 0002013
VCID: 313F108C5D2ADFB3EC5-8064
Part No SW: 3C0 920 970 R HW: 3C0 920 970 R
Revision: X0033000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 22599 444 53828
VCID: 33331A84A736EDA39E9-8066
Fault Frequency: 11
Reset counter: 4
Mileage: 104613 km
Date: 2020.05.09
Time: 00:38:10
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C05C050232
Coding: 3FFD0E04D31002
VCID: 211FE0CC0DCA6F337C5-8074
Reset counter: 3
Mileage: 104613 km
Date: 2020.05.09
Time: 00:38:28
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TQ0Y404
VCID: 6D87CCFC81927B5388D-8038
Part No SW: 3C0 959 433 Q HW: 3C0 959 433 Q
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
VCID: 38292DA8BE500EFBABB-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 4
Mileage: 104613 km
Date: 2020.05.12
Time: 00:00:04
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2365
Coding: 0001205
VCID: 36352390B444F88BB97-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
02546 - Steering Limit Stop
Mileage: 4600 km
Temperature: 46.0°C
Voltage: 12.80 V
Voltage: 12.60 V
Component: KSG PQ46 RDK 051 0218
Coding: 13910F8801862E521804141FF00A0F0E081800
Reset counter: 4
Mileage: 104613 km
Date: 2020.05.09
Time: 00:38:29
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001204
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
000 - - - MIL ON
Fault Status: 11100000
Fault Frequency: 10
Reset counter: 219
Voltage: 7.35 V
Count: 170
Part No SW: 1K0 035 180 C HW: 1K0 035 180 C
Component: Radio PM6 016 0017
Revision: 00016000 Serial number: VWZ5Z7E2047344
Coding: 0040400
VCID: 2019E5C806C0663B73B-8074
Fault Frequency: 7
Reset counter: 3
Mileage: 104613 km
Date: 2020.05.09
Time: 00:36:44
Fault Status: 00111011
Reset counter: 3
Mileage: 104539 km
Date: 2020.05.01
Time: 14:31:55
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2432
Coding: 0000144
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Component: RDK 0420
Coding: 0100100
00667 - Ambient Temperature Signal
Reset counter: 4
00625 - Vehicle Speed Signal
Reset counter: 4
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1F80582CE4AB95F-8066
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:21, VBatt start/end: 13.0V/13.0V)-----------
