I have a 2016 Audi A7 3.0d (272PS). Purchased needing a bit of work as had been standing for a while after repairs. Car had performance issues due to blocked DPF, forced to Regen successfully using VCDS. This resolved the restricted performance issues, however I keep getting the MIL triggered anywhere between 10 & 50 miles of driving. Have replaced downstream NOx sensor (4G0907807H) after some internet research, but MIL still triggering. No obvious change in performance when MIL is active, however looking to sell soon so need to resolve. Any help appreciated
Autoscan below;
Autoscan below;
Wednesday,13,May,2020,19:06:13:55459
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G4GN048331 License Plate:
Mileage: 59407km-36913mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 30 36 3B 42 44 46 52 53 55
5F 62 6D 72 82 85 AC
VIN: WAUZZZ4G4GN048331 Mileage: 59407km-36913miles
Address 01: Engine (J623-CRTD) Labels:. 059-907-401-V2.clb
Part No SW: 4G2 907 401 B HW: 4G2 907 401
Component: 3.0TDI EDC17 H34 0002
Revision: 92H34---
Coding: 1A254012042601030800
ASAM Dataset: EV_ECM30TDI0114G2907401B 001002
ROD: EV_ECM30TDI011_AU57.rod
VCID: 2404F2B42F035CA64F-8070
9569 - NOx Sensor 2 Bank 1
P229E 00 [104] - Electrical Malfunction
Fault Frequency: 11
Mileage: 59263 km
Date: 2020.04.18
Time: 17:41:15
Engine speed: 838.00 /min
Normed load value: 16.9 %
Coolant temperature: 58 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.160 V
NOx sensor 2: NOx concentration: 1650 ppm
Com r Lam Lin Rec Cat2 Ds: -0.2000
NOx sensor 2: feed voltage: 13760 mV
Target value of heating temperature of NOx sensor 2-Bits 0-7: 0
Com st N Ox Vld Cat2 Ds-Bits 0-7: 0
Exh st Lam Stat No Cat2 Ds-Bits 0-7: 1
Exh.gas temp.sen 4: 102.3 °C
9570 - NOx Sensor 2 Bank 1
P229E 00 [237] - Electrical Malfunction
Fault Frequency: 19
Mileage: 59263 km
Date: 2020.04.18
Time: 17:41:15
Engine speed: 771.00 /min
Normed load value: 16.5 %
Coolant temperature: 80 °C
Intake air temperature: 42 °C
Voltage terminal 30: 14.420 V
NOx sensor 2: feed voltage: 13920 mV
Exh st Lam Stat No Cat2 Ds-Bits 0-7: 0
Exh.gas temp.sen 4: 118.0 °C
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 166 C HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 100001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2D1217907CC99DEE90-8078
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 17A69E43E86579C29B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 41CA5B20D051698E44-8014
161024 - Tire Pressure Warning
C102D 00 [040] - -
Mileage: 58948 km
Date: 2020.03.20
Time: 23:24:53
VzRef: 44
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: BC
Unlearning counter according OBD: 14
161280 - Tire Pressure Warning
C102D 00 [032] - -
Part No SW: 4H0 907 064 GN HW: 4H0 907 064 GN
Component: BCM2 2.0 H37 0572
Coding: 01BA704E000000000000
VCID: 7BB6E9C8FA3DC35E5E-802E
Serial number: 3215000107593001
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 02071500041497
Coding: 36231178350000
VCID: 6386B1A86A8D1B9E76-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001109033901
Coding: 0105C01540349FE041014083800018000F9DC30A2F080201000008946100130200400024030000
VCID: 71AACBE0A871B90EF4-8024
Component: WWS57X 150605 H37 0080
Serial number: 150616135229
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 24065737
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 24 06 2015 00001399
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8D69C5B7000000000001
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1005F107
Coding: 30333046313130313235554A305234473853
VCID: 3B3629C8B2BD035E1E-806E
Serial number: 3575HRB401852UQOK1F$
Serial number: 3585HRB404R0H9226GRI
Serial number: 3515JRB405L3E6SCP0Q0
Serial number: 3525JRB401E5340AKI4Q
Serial number: 3554VRB406531O5IL8EN
Serial number: 3564VRB405V3GQ1SB074
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862OFS0003M
Coding: 000034
VCID: 3B3629C8BABD035E1E-806E
Serial number: 15 06 2015 E0039269
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 986 M HW: 4G8 920 986 M
Component: TDieGb H10 0104
Revision: 06001087 Serial number: 658010715596061
Coding: 33A702020B432600010100
ASAM Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 42C8542CD55772965D-8016
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Revision: -------- Serial number: 00000001906148
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001028
Serial number: 7572377103
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 15032000000000000150
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 01071500041486
Coding: 22
VCID: 3D3227D0ACA90D6E20-8068
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 214
Mileage: 58968 km
Date: 2020.03.21
Time: 23:21:38
Outside air temperature: 9.5 °C
Left rear vent temperature: 47.0 °C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000079418
Coding: 01010101000000000001000202
VCID: 6484B2B467831CA68F-8030
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000153755304
VCID: 77BEF5F8C615E73E3A-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H04 0056
Revision: -------- Serial number: EJ1BPA8209SKN+
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 362038FC899FDE36E1-8062
Component: TSG FA H03 0507
Coding: 011C56034E21620002080402
VCID: 47DE4538F67557BE8A-8012
02123 - Door Warning Light / Entry Light
Reset counter: 148
Mileage: 58470 km
Date: 2020.03.01
Time: 17:40:14
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0017953534
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
VCID: 393A33C0B881314E0C-806C
Revision: 00002001 Serial number: 0372417451
Coding: 013B0622A0B9B880C3200A0400010D470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 3 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA121127000014044909
Component: TSG BF H03 0507
VCID: 46C0483CF17F4EB671-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001524138
ROD: EV_ParkiBrake_VW51.rod
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 05FE02202A130200
VCID: 342402F49FE3CC26DF-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E02100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E02100
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E02100
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E02100
5353456 - Fog mode active
C118E 00 [008] - -
Reset counter: 195
Mileage: 58651 km
Date: 2020.03.08
Time: 18:22:07
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 D HW: 4G1 035 021
Component: MU-H-LND-EU 042 0389
Serial number: A588F0F7522304
Coding: 017503010000000013111102000A00132F000CE7F1700100DF
VCID: 1B76C948127D635EFE-804E
Subsystem 1 - Part No SW: V03 959 801 F HW: -----------
Component: ECE 2015/2016 --- 0122
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY801UES
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349OFQ000D3
Component: Gracenote2 --- 1012
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
Coding: 010814024021620002080002
VCID: 49DA4300E061A1CE9C-801C
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
Component: HDSG-Modul H14 0049
Revision: 11014001 Serial number: 179500642
Coding: 0A3305C002
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 45C24F30C47945AE78-8010
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
Component: HeadUpDisplay H07 0304
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 3E3020DCA1AF167639-806A
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: 60140000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C141A9447D394E687-8078
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 151400250
ROD: EV_RDCMA00100.rod
End----(Elapsed Time: 02:04, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
