2012 gti bulb out coding
Dommy1018
Niagara Falls, USA
C?ID=330435
Hey guys, I'm trying to code out my "Bulb Out" light on my dash. I have retrofitted headlights with halos and demon eyes with HID bulbs. And then I also have led interior and license plate lights. When I turn the car on my MFI says "check front right low beam, check front left low beam" and I believe it says check high beams. I have no lights out, I don't have resistors, I'm really just looking for a way to code out the bulb out light. Anybody know how?
We'll need to see a full unedited VCDS Auto-Scan so we can see exactly how your GTi is configured - see my sig for a How-To.
Dommy1018
Niagara Falls, USA
C?ID=330435
Friday,15,May,2020,16:16:10:34032
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWHD7AJ5CW195781   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWHD7AJ5CW195781   Mileage: 101300km-62944miles
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Component: 2.0l R4/4V TFSI     0040
   Revision: E3H26---    Serial number:
   Coding: 0403010818070160
   Shop #: WSC 45401 001 1048576
   VCID: 78A9155F4EDB04CB6BB-802C
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
               P2096 - 000 - Too Lean - Intermittent
                    Mileage: 101209 km
                    Date: 2014.10.03
                    Time: 12:53:13
                    RPM: 1491 /min
                    Load: 9.8 %
                    Speed: 13.0 km/h
                    Temperature: 93.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich) - Intermittent
                    Mileage: 101120 km
                    Date: 2008.00.01
                    Time: 16:04:00
                    Load: 0.0 %
                    Speed: 32.0 km/h
                    Temperature: -40.0°C
                    Temperature: 25.0°C
                    Voltage: 13.970 V
Readiness: 0000 0001
   Revision: 00H31001
   Coding: 114B600C492B00FE881206E9921A0041B70800
   VCID: 7BA30A5373ED2FD3069-802E
02214 - Tire Pressure Warning
                    Reset counter: 246
                    Mileage: 99255 km
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 52224
                    Count: 3
                    Count: 1278
                    Reset counter: 108
                    Mileage: 100775 km
                    Date: 2014.09.06
                    Time: 00:24:08
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 16390
                    Count: 42752
                    Count: 3328
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0404
   Revision: 00001015
   Coding: 0000001002
   VCID: 00597DBF1A8B4C0B53B-8054
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 6F180A3A90272A04008800C07000094448850386624D8D60648000200040
   VCID: 3D27C44B2D79E1E378D-8068
   Component: Wischer 16081  26  0512
   Coding: 009795
13 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 140
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:36:15
                        Term 15 On
                    Voltage: 12.55 V
                        Term 50 On
00061 - Footwell Lights
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 65
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:36:30
                        Term 15 Off
                    Voltage: 12.60 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 133
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:39:29
                        Term 15 On
                    Voltage: 12.55 V
                        Term 50 On
                    Reset counter: 133
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:39:30
                        Term 15 On
                    Voltage: 12.50 V
                        Term 50 On
                    Fault Status: 00101110
                    Reset counter: 112
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:39:41
                        Term 15 On
                    Voltage: 13.85 V
                        Term 50 On
                    Reset counter: 133
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:39:41
                        Term 15 On
                    Voltage: 13.85 V
                        Term 50 On
                    Reset counter: 133
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:39:41
                        Term 15 On
                    Voltage: 13.85 V
                        Term 50 On
                    Fault Frequency: 58
                    Reset counter: 95
                    Mileage: 100882 km
                    Date: 2014.09.16
                    Time: 00:52:53
                        Term 15 On
                    Voltage: 12.00 V
                        Term 50 On
                    Reset counter: 110
                    Mileage: 100868 km
                    Date: 2014.09.15
                    Time: 00:40:19
                        Term 15 On
                    Voltage: 11.85 V
                        Term 50 On
                    Reset counter: 110
                    Mileage: 101002 km
                    Date: 2014.09.20
                    Time: 02:31:60
                        Term 15 On
                    Voltage: 12.25 V
                        Term 50 On
                    Fault Frequency: 55
                    Reset counter: 95
                    Mileage: 101002 km
                    Date: 2014.09.20
                    Time: 02:32:02
                        Term 15 On
                    Voltage: 12.30 V
                        Term 50 On
                    Reset counter: 110
                    Mileage: 101002 km
                    Date: 2014.09.22
                    Time: 21:12:04
                        Term 15 On
                    Voltage: 11.20 V
                        Term 50 On
                    Reset counter: 110
                    Mileage: 101002 km
                    Date: 2014.09.22
                    Time: 21:12:04
                        Term 15 On
                    Voltage: 11.20 V
                        Term 50 On
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA0HYPY
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3FDBBE4327F5F3F36A1-806A
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00060VCK00
   Serial number: 3572MSME63207163ZZZL
   Serial number: 3582MSME5B0B2463ZZZ-
   Serial number: 3512QSME78255D0EZZZ2
   Serial number: 3522QSME70445B28ZZZX
   Serial number: 35527SME4F0F1728ZZZS
   Serial number: 35627SME5F5E0D28ZZZ$
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90422KHG000HD
   Coding: 108A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72BD277724276E9B55F-8026
   Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0428748
   Coding: 820000
   Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
   Coding: 270F01
   VCID: 3635DB6708CF32BBB97-8062
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 230811F1000811
   Coding: 350000
   VCID: 3537DC6B154939A3B0D-8060
   Revision: 00001000    Serial number: 1225223RE4H906
   VCID: 7EA503476CFF3AFB217-802A
   Component: IMMO          H03 0607
   VCID: 6A8D3F170CF7A65BEDF-803E
   Revision: A1001003    Serial number: 7660670876
   VCID: 290F001BC9F16D43245-807C
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2103
   Coding: 0001076
   VCID: 372BD6630345CBB3A21-8062
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 3431E16F123320AB873-8060
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 323DE777E8272E9B95F-8066
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L1130714
   Coding: 01000400040005
   VCID: 63935233EB5DF7132E9-8036
                    Fault Frequency: 6
                    Reset counter: 57
                    Mileage: 95331 km
                    Date: 2014.01.19
                    Time: 20:39:27
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660674196
   Coding: 0A10040000010100
   Shop #: WSC 01814 444 28888
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 3537DC6B15C939A3B0D-8060
End----------(Elapsed Time: 00:57, VBatt start/end: 12.2V/12.2V)-----------
Moving to Retrofits.
Dana
Western PA, USA
I suspect the factory coding of 09 was something like:
6F180A1A90272AC4008800C17000054448010386434D8D60648020200040
Since this BCM probably doesn't have shutter terminals like a BCM with factory Xenon lights would, and there isn't a diagnostic capable 55-Xenon module installed, I would use whatever the factory coding was as a baseline. Doing so should resolve issues such as the Headlight washers (which were not factory installed in our market). Using that string and tweaking
17/7 License Plate Light w/o Pulse Width Modulation (PWM) [LED Light] ON
23/6 Lamp Monitoring (Cold) License Plate Lamps active OFF
25/3 Monitoring: Footwell Lights inactive (LED Footwell Lights) ON
.. results in:
6F180A1A90272AC4008800C17000054448810386434D8D20648820200040
That should resolve a handful of the faults.
Next, we can't offer much assistance with aftermarket headlight and HIDs but if you haven't rewired the headlight connectors like a factory equipped Xenon GTI and the typical diagnostic capable components aren't installed I don't believe any of the Xenon coding helper options are going to work. The only one that may be worth tinkering with is 14/4 Xenon Headlights (w/o Shutter) installed but that depends on the hardware in the lights.
On a side note, aftermarket HIDs can burn up BCMs and we have a brief explanation here:
http://wiki.ross-tech.com/wiki/index.php/Retrofitting#Xenon_Headlight_Retrofitting
If you end up with BCM issues or need to upgrade the BCM so shutters signal wires can be added that page may be helpful.
Dommy1018
Niagara Falls, USA
C?ID=330435
Thanks for the reply! So what it sounds like from what you've said there's no way to really just turn the light off with coding? Like actually just disable that one specifically?
Dana
Western PA, USA
No, per my explanation via email the vast majority of cold lamp diagnosis bits are controlled by Byte 18 and that's not going to resolve the aftermarket HID light issues. Instead, changing that byte will likely result in an entirely new batch of fault codes.
