Have a look here: https://www.motor-talk.de/forum/umbau-bnstg-nach-bcm-vom-passat-b7-t4813384.html
(Use Google Chrome if Deutch is not your favorite language )
I suggest you stay a way from this and let someone who know to do that part for you , otherwise ,like I said before, you can end up with Dead car in your hand.Noo I am nt familiar with the eeprom
Gateway 7N0907530AJ
Tpms module 3AA907273F
tpms sensors 3AA907275
I already have the b7 passat instrument cluster installed if i buy and configure these parts will the tpms show up in the mfd my car came fitted with the direct tpms system from factory but since the clusters use different protocols I dont get any info on the mfd only get the tpms light on the dash
need a straight answer on this from anyone have all the parts in my cart just to click buy
The only reason for buying the entire harness + replay would be to have connectors when doing the conversion. Basically anything 15 centimeters from the 3AA BCM is not needed for this conversion project.... However it's allways nice to have some extra wiresOk thanks going to check back on scarp b7 comfortline which I took the instrument cluster from I will be able to get the bcm with the 3 big connectors(can dismantle and buy the entire harness if need be) and the relay panel from it, as well as the ccm the gateway was already sold, since the car doesn't have the tpms system, electric seats etc should I bother with taking the bcm and ccm from it as it has a limited feature set?
