hello all
i hope you are doing well.
im trying to adapt a remote control for this car but there is no channel 01 nor 21
i entered wiki.rosstech on this link "https://www.ross-tech.com/vag-com/cars/vw-remote-matching.html"
If the above procedure does not work (neither Channel 01 nor Channel 21 are available), follow this procedure:
Insert a working (old) key in the ignition and turn to the ON position (do not start car).
[Select]
[46 - Cent. Conv.] or [35 - Cent. Locking] (whichever is applicable to the car, as found here)
[Meas. Blocks - 08]
Enter group "003" (may be group "007" in some vehicles)
[Go!]
The value in field 2 shows how many remotes have been matched and in which memory positions (for example, "0001" indicates 1 transmitter in position 1).
and tried the second way, but on this car all basic settings says not available,field 2 says "not oper"
could be something wrong with the 46.central conv. itself, 35 central locking is not installed.
thanks
[Select]
[Meas. Blocks - 08]
[Go!]
thanks
