2000 vw beetle 1.9tdi instrument cluster
Thanksue
C?ID=402008
Instrument cluster was not working. replaced with a used one from gasoline model.
Gages now work. Vin # doesn't match.
Immobilizer has been turned off.
Not sure what some of the codes are.
Saturday,09,May,2020,17:02:49:52893
VIN: 3VWCK21C32M413734   License Plate:
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCK21C32M413734   Mileage: 265300km-164849miles
Address 01: Engine        Labels: 038-906-012-AGR.clb
   Part No: 038 906 012 N
   Component:  1,9l R4 EDC G000SG  2509
   Coding: 00002
   Shop #: WSC 00066
   VCID: 1B63D1915AB92903A60-4B1E
Readiness: 0 0 1 0 1
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E253805E96B5C2B61E-4B1E
            35-00 - -
   Part No: 6Q0 909 605 A
   Component: 06 AIRBAG VW5       0003
   Coding: 12342
   Shop #: WSC 00066
   VCID: 35372729DC5D9F73B04-4B3C
            32-00 - Resistance Too High
01217 - Side Airbag Igniter; Driver Side (N199)
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 921 C
   Component: KOMBI+WEGFAHRS. M73 V07
   Coding: 03232
   VCID: 1E65D88549AB3C2B41E-4B1E
   3VWCK21C32M413734     VWZ5Z0Z6191672
01176 - Key
            65-10 - Unauthorized - Intermittent
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V072
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9D63DE3BFFA5BA32-4B1E
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AJ
   Component: 5X Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00066
   VCID: 065590E5F13BC4EB69E-4B1E
   Subsystem 1 - Part No: 1J2959802C
   Component: 5X Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J2959801D
   Component: 5X Tõrsteuerger. BF0002r
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 - -
            53-10 - Supply Voltage Too Low - Intermittent
            35-00 - -
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1C0 035 180 E
   Component:  RADIO 3CP         0001
   Coding: 00401
   Shop #: WSC 00066
   VCID: 1A6DD4955583500BBD6-4B1E
End----------(Elapsed Time: 03:34, VBatt start/end: 12.1V/12.1V)-----------
