Got only one AdBlue warning from my Passat at 200 miles to go after having a CEL pop up. Took it to the shop, they ran a diagnostic and reset/"fixed" the light...got it back, it threw a CEL after about thirty miles and the warning is now down to 80mi. Before taking it back in on Monday, decided to run the AdBlue reset listed here in the forums because my legitimate RossTech cable arrived after taking it to the shop. Cleared some codes and tried to do the reset process; however, my foot slipped and stopped the process about 10mins in. I was trying to plug my phone in due to low battery (running VCDS on laptop, forum on phone) but dropped it and took my foot off the pedal accidentally. Was planning on attempting to do that same reset process again after seeing how you all manage to keep your foot on the brake AND have the accelerator depressed for thirty minutes. I'm a land surveyor and walk 20-30 miles a week and my legs hurt like hell...i assume there's a trick to it?
anyway, hopefully someone here has done this same thing or has a desire to poke through my AutoScan today. here is my very first scan after installing VCDS:
here is my most recent scan after clearing codes and finding out my right leg is weak
please be gentle, i'm a fake engineer (land surveyor)
Saturday,09,May,2020,14:23:12:38513
VIN: 1VWCN7A35CC013990 License Plate:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A35CC013990 Mileage: 123410km-76683miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H21 9981
Revision: 71H21--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 07207 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004004
ROD: EV_ECM20TDI01103L997009H.rod
VCID: 3B2332D803ECC7C3469-806E
20553 - Reductant System Performance Bank 1
P204F 00 [237] - Malfunction
Mileage: 123403 km
Date: 2020.05.08
Time: 14:15:23
Engine speed: 1759.50 /min
Normed load value: 95.7 %
Vehicle speed: 57 km/h
Coolant temperature: 93 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.220 V
Long-term adaptation of reduction agent dosage: 1.00
Calculated efficiency of NOx conversion: 0.948
Standardised airflow ratio: 1.3871
Current temperature in NOx reducing catalytic converter: 205.8 °C
NOx sensor 1: offset for correction factor: 1 ppm
15733 - SCR NOx Catalyst Bank 1
P20EE 00 [101] - Efficiency too Low
Mileage: 123403 km
Date: 2020.05.08
Time: 14:15:23
Measured NOx conversion region 1: -0.037
Efficiency threshold of NOx conversion region 1: 0.464
Readiness: 1 1 0 0 0
Part No SW: 02E 300 054 C HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9434
Revision: 05351113 Serial number: 00001106280070
Shop #: WSC 43801 002 1048576
VCID: 1675C36C548EFAAB997-8042
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 12
Reset counter: 1
Mileage: 123320 km
Date: 2014.09.28
Time: 13:32:26
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: C54BC0F5492300FDA31403ED92190042A70000
Shop #: WSC 09003 957 00200
VCID: 7BA3F2D843EC07C3069-802E
Fault Status: 00100011
Reset counter: 235
Mileage: 123322 km
Date: 2014.09.28
Time: 14:55:34
Count: 4608
Count: 67
Count: 49920
Count: 62963
Count: 64000
Reset counter: 233
Mileage: 123320 km
Date: 2014.09.28
Time: 13:32:25
Count: 16384
Count: 32768
Count: 12800
Count: 72
Count: 50434
Count: 755
Count: 2304
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:03
Count: 3
Count: 14
Count: 20480
Count: 16390
Count: 44032
Count: 64768
Count: 253
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434 A
Revision: 00085000 Serial number: 0147056923
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02014
VCID: 343119E42EB208BB873-8060
Part No SW: 561 907 044 D HW: 561 907 044 D
Component: Climatronic H01 0102
Revision: 00001001
Coding: 0010001012
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 1869CD54521ACCDB8BB-804C
Part No SW: 5K0 937 087 Q HW: 5K0 937 087 Q
Component: BCM PQ35 H+ 111 0147
Revision: BL111001
Coding: 6F200E1B982B08D408880201360085480071008645A005F064806000BC70
VCID: 43D34A387B9CBF030E9-8016
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 070911 05 54 0403
Coding: 22300A
Address 15: Airbags
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20110616301669
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DA7FCC05D7809F338D-8028
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1A6DD75CAC16DECBBDF-804E
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 16081101291431
Coding: 461000
VCID: 38292DD4325AECDBABB-806C
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:07
Component: IMMO H07 0507
Coding: 000007
VCID: 6A8DC79C3CF68E4BEDF-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000113498005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW01.rod
VCID: 2E050B8CC09E226BF17-807A
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660670831
VCID: 290FF890F9F04553245-807C
03138 - Input AUX IN
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:06
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000011718566
Coding: 00581B0000000000000021010100202020202120202020
VCID: 6099A5B4CA4AC41B33B-8034
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C0 035 684 E
Component: RNS-MID H59 3690
Revision: AB001001 Serial number: VWZ6Z7L9219066
Coding: 04090002010000A6000B
Shop #: WSC 07203 444 101400
VCID: 2D070C80CD185973C8D-8078
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:10
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0003148038
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C61D144A622A0FBAF3-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 290 3201
Revision: 00H20000
VCID: 343119E4223208BB873-8060
Fault Status: 00101101
Fault Frequency: 10
Reset counter: 21
Mileage: 123411 km
Date: 2014.09.30
Time: 14:20:56
Voltage: 12.25 V
DD
Temperature: 21.0°C
Part No SW: 3T0 035 456 B HW: 3T0 035 456 B
Component: KonzernAmp10K H06 0362
Revision: -------- Serial number: BP225309712035
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 303915F4DAAA349BE3B-8064
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 01030108
VCID: 6FBBD68807946B63BA1-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011107800316
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0002
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0003135228
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67DC40BD38A9F358D-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:10
Address 77: Telephone
End----------(Elapsed Time: 01:35, VBatt start/end: 12.2V/12.2V)-----------
Saturday,09,May,2020,16:12:36:38513
52 56 62 72 77
Revision: 00H31001
Reset counter: 236
Mileage: 123411 km
Date: 2014.09.30
Time: 15:11:02
Count: 3
Count: 14
Count: 4096
Count: 16390
Count: 44800
Count: 510
Coding: 130C0C
Revision: 00001001
Coding: 0010001012
Revision: BL111001
Coding: 22300A
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003END09BVGY
Coding: 00004D44
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FBBD68807146B63BA1-803A
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y11000072JF0C
Coding: 303252
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME31140662ZZZG
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME652D3361ZZZX
Serial number: 3516KSME14535E12ZZZO
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME592C4511ZZZT
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME04245610ZZZG
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME5E005610ZZZQ
Coding: 000A140000
Coding: E20000
Coding: 231E01
Coding: 461000
Reset counter: 236
Mileage: 123411 km
Date: 2014.09.30
Time: 15:14:30
Coding: 000007
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:06
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:10
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H20000
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
Reset counter: 233
Mileage: 123319 km
Date: 2014.09.28
Time: 13:17:10
End----------(Elapsed Time: 01:17, VBatt start/end: 13.9V/13.8V)-----------
