Audi A6 C7 green menu/developer mode activation
Dp41n8w
C?ID=372411
Hi. I tried to activate developer mode/green menu but vcds says that request out of range. I entered security access, it was okey, access gived. But when I try to activate develper mode then its out of range. I tried to change other channels and I got changed. Only developer mode cant do. Any Help?
Friday,08,May,2020,21:44:37:19148
Workshop Code: 358 14250 022663
VIN:    License Plate: 279TND
Mileage: 144470km-89769mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 34 36 3B 42 44 46 52 53
          55 5F 62 69 6C 6D 72 8F 90 A9 AC C0
VIN: WAUZZZ4G4FN069792   Mileage: 144470km-89769miles
Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---
   Coding: 122A4032253603030000
   Shop #: WSC 46004 002 1048576
   ASAM Dataset: EV_ECM30BTD0114G0907589F 001008
   ROD: EV_ECM30BTD0114G0907589F.rod
   VCID: 372B2BCB6FC92873A28-8062
   Part No SW: 4G0 927 158 AK    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRDW H19 1015
   Revision: --H19---
   Coding: 000001
   VCID: 77ABEBCB2F49E873628-8022
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 49A7DE4192E57B82BB00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FDB43EB47F910336A8-806A
161792 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0560
   Coding: 05A96F0E000000000000
   VCID: 7CA1F4E716EFCB2B0FA-8028
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 189
                    Mileage: 141807 km
                    Date: 2020.04.07
                    Time: 16:53:06
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 17021500040080
   Coding: 36021178210000
   VCID: 6393AF9B8BD114D32E0-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001009135702
   Coding: 0105001440349FE0C90140C3800018000F9CE7082E08020100000894E101170200400034030000
   VCID: 71BFD5D341ADB643ACC-8024
   Component: WWS57X 150128  H37 0080
   Serial number:         150209165012
   Coding: 0045F7
   Serial number: 23732256
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 13 02 2015  00001067
   Serial number: 59788397000000000001
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1003AE5I
   Coding: 30333130313730323731554A304C34473053
   VCID: 3B2337FB53E10C13460-806E
   Serial number: 3575HRB40692RDNQB8OD
   Serial number: 3585HRB405T33PKMEGUW
   Serial number: 3515JRB405J33H8Q4H16
   Serial number: 3525JRB405V35IMM2GUF
   Serial number: 3554VRB405L34H76E0KF
   Serial number: 3564VRB405L34H7648PJ
   Revision: C0068538    Serial number: 90862OBH000GF
   Coding: 000035
   VCID: 3B2337FB53610C13460-806E
   Serial number: 27 01 2015  E0080159
   Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
   Component: TDieRdw       H08 0043
   Revision: 04001037    Serial number: 658200215596031
   Coding: 13A612001B410008000000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E253EEF40F3193B61E-806A
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Component: J533--Gateway H13 0075
   Revision: --------    Serial number: 00000001741660
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001024
   VCID: 75B7E1C335459A63704-8020
   Serial number: 1916195803
   Voltage stabilizer:
   Serial number: 14121000000000000459
   Revision: AA001002
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 19021500040199
   Coding: 20
   VCID: 3D2739E34DF50223784-8068
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   Coding: 008001
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B13AB9799E0B3FA8-807A
   Revision: AA000000    Serial number: 00000135488704
   VCID: 77ABEBCB2FC9E873628-8022
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA82090SJH
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 363526CF68C3D17BB9E-8062
   Coding: 011C17015E00628002080002
   VCID: 47CB5B0B1FA958F3D28-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0026451865
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 33331FDB7BB1C4539E0-8066
   Revision: 00002001    Serial number: 0361585747
   Coding: 01000E3820B93081C320090428030F470000000000000000000000000000
03022 - Local databus 4
                    Reset counter: 189
                    Mileage: 141807 km
                    Date: 2020.04.07
                    Time: 16:30:44
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 241
                    Mileage: 141883 km
                    Date: 2020.04.07
                    Time: 21:52:51
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 238
                    Mileage: 141883 km
                    Date: 2020.04.08
                    Time: 10:10:41
   VCID: 46D5560F18A341FB29E-8012
   Revision: --------    Serial number: 00000001366394
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0709A39D9592A3C84-8078
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA02102A630200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   Coding: E01E00
   Coding: E01E00
   Part No SW: 4G1 035 043 S    HW: 4G1 035 043
   Component: MU-H-N-EU     041 0389
   Serial number: A591B0F7507827
   Coding: 017502010000000013110002000A00032F0006E5F1700100DF
   VCID: 2E050EAF9093E9BBF1E-807A
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9EY800DL1
   Multimedia Operating Unit:
   Serial number: 90349OBD00061
   Component: Gracenote2  --- 1012
   Coding: 010815004000628002080002
   VCID: 49CF5D3309BDAE83C4C-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0361519261
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW37.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010301000700
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 323D1ADF84ABCD5B956-8066
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 038500129
   Coding: 093205C031
   ROD: EV_HDSGAu571.rod
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F15D381ADF643ECC-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0007
   Serial number: 150129200737
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 143500930
   ROD: EV_RDCMA00100.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0011
   Serial number: 150211200487
   VCID: 270BFB8BBF69B8F3328-8072
End----------(Elapsed Time: 01:56, VBatt start/end: 14.5V/14.5V)-----------
TBAx
C?ID=287144
Only works in Engineering Session using the S12345 login.
Dp41n8w
C?ID=372411
Yes I know. But there is problem. It dont let me enter the code. There isnt coming yellow tick box. I got yellow tick box yesterday, then it accepted the code. But today there isnt that box and it says that code must be 5 letters, not 6. Do you know or anybody know why?
golfi_vend
Tartu, Estonia
C?ID=195131
Because there isn't label file for it containing script to change session.
We'll need input from RT team to make redirection for Your unit.
Dp41n8w
C?ID=372411
How did I get yesterday activate DM?
Dp41n8w
C?ID=372411
Why there isnt coming yellow tick box when I open security access?
Dp41n8w
C?ID=372411
If I rename label file can I get access? Is It possible?
TBAx
C?ID=287144
Just search the forum. Solution has been posted many times before. :)
Dp41n8w
C?ID=372411
I Found your answers from few posts but you had send PM To op To correct the problem 😊
Dana
Western PA, USA
Thanks guys. I'll make sure we get that 5F part number into the next redirect file.
jakubx80
CT, USA
C?ID=402990
I've the same problem with 2017 Audi S7. Can't Activate Developer Mode as it is out of range.
Is there a solution to this by any chance?
Wednesday,17,June,2020,14:24:05:02783
VIN: WAUWFAFC3HN075819   License Plate: AT89965
Mileage: 45555km-28306mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 BA
VIN: WAUWFAFC3HN075819   Mileage: 45555km-28306miles
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0002
   Revision: NCH63---
   Coding: 1A2500326546010E3000
   Shop #: WSC 62103 001 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 2313EA903B5555E36E9-8076
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H05 0007
   Revision: --H05---
   Coding: 000001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 303915DC7AA3FE7BE3B-8064
   Coding: 65BED44BA67D2BD21B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4018C10967F31C5-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0825
   Coding: 0DAA6F4E000000000000
   VCID: 0059851C8A03AEFB53B-8054
   Serial number: 3216000243935009
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 09111600040302
   Coding: 688330B84D0000
   VCID: 6A8DC7B49CFF44ABEDF-803E
0315 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Sensor für Luftfeuchte innen: kein Signal / Kommunikation]
                    Reset counter: 104
                    Mileage: 44693 km
                    Date: 2020.04.10
                    Time: 15:52:42
                    Voltage terminal 30: 11.88 V
                    Outside air temperature: 11.0 °C
                    Engine speed: 0 /min
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 21020001    Serial number: 00001517656102
   Coding: 01050011043C9FF2F90048C780007800CF9CC208AE0802218000089C710017020060002D0B0000
   VCID: 79AFE8F8E9D9FF33145-802C
   Component: WWS57X 160921  H38 0080
   Serial number:         161004162510
   Coding: 0045F7
   Serial number: 20027162X81A955547A0
   Coding: 02006E
   Serial number: 13 11 2016  00000134
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z027E5526
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA125581000026234449
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 0709475800PAG0MUFU03
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 104
                    Mileage: 44693 km
                    Date: 2020.04.10
                    Time: 15:47:00
                    Reset counter: 104
                    Mileage: 44693 km
                    Date: 2020.04.10
                    Time: 15:47:00
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010101
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 290FF8B859798FB3245-807C
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0003N5W$
   Coding: 303331333131303134334A55304C34473853
   VCID: 343119CC8EBBC25B873-8060
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y160001JT1T0A
   Serial number: 3575HRB405747OGUDPFA
   Serial number: 3585HRB406946HMU9OF7
   Serial number: 3515JRB400G579TI6HMW
   Serial number: 3525JRB401E579TGKOL7
   Serial number: 3554VRB400M57HS6M18Y
   Serial number: 3564VRB400O57HS68PFB
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372PKD00078
   Coding: 0004FC
   VCID: 38292DFC9253263BABB-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 26 07 2016  A0052558
   Part No SW: 4G8 920 988 M    HW: 4G8 920 988 M
   Component: TBenUsaAccNv  H15 0225
   Revision: 15001307    Serial number: 658111116596017
   Coding: 0BC70107BF53D705020300
   ASAM Dataset: EV_RBD4K 004060
   VCID: 44D1490CDE1B72DB373-8010
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Component: J533--Gateway H15 0096
   Revision: --------    Serial number: 00000002436708
   Coding: C0ED074814
   VCID: 3D273CE8BDF1031378D-8068
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 4068032104
   Voltage stabilizer:
   Serial number: 160906000000000009B1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Coding: 0E0100
   VCID: 3A2D37F4AC5F342B5DF-806E
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04018E64747464545425363E00
   VCID: 678BBE808F6D79C3F21-8032
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 003110160001009
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   VCID: 2809FDBC4273B6BB3BB-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0113
   Serial number: 13111600040473
   Coding: 20
   VCID: 3E253BE4B0F7180B617-806A
   Coding: 008006
   VCID: 2F3B16A0679DE183FA1-807A
   Revision: AA000000    Serial number: 00000226712521
   VCID: 77ABEEC0DFCDE943621-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02GX5S
   ROD: EV_SARA2.rod
   VCID: 372B2EC09FCD2943A21-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0421327065
   Coding: 040211
   VCID: 392F28F8A9D93F33545-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0422160250
   Coding: 040211
262148 - Databus
          [Rain/light-sensor - no signal/no communication]
                    Reset counter: 104
                    Mileage: 44693 km
                    Date: 2020.04.10
                    Time: 15:52:36
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F57035E00628002000413
   VCID: 45D75408D5A14BD320D-8010
   Component: RCevo         H54 0202
   Revision: 00000001    Serial number: 0000396764
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D37F4ACDF342B5DF-806E
   Revision: 00002001    Serial number: 0423087287
   Coding: 0126063A20BAF08580B00A8402030D470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000376808
   Subsystem 2 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST001ACWYH00000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00027019664
   Subsystem 5 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
   Component: HSP-SG  H11 0031
   Serial number: WA125827000026785125
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93936196
   Coding: 011F57035E00628002000402
   VCID: 46D55304E8A740CB297-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002030413
   VCID: 323D1FD474AFCC6B95F-8066
   Coding: 05FA0A1122600400
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E02000
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E02000
13705736 - Databus
          [Timeout CAN-Message RLS_01 (0x50A)]
                    Reset counter: 104
                    Mileage: 44693 km
                    Date: 2020.04.10
                    Time: 15:52:39
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 025 D    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   053 0902
   Serial number: A741K0G7528742
   Coding: 017553020000000013220002041A00102F000DE5F17001047E
   VCID: 1F1BE660173D71034A1-804A
   Subsystem 1 - Part No SW: V03 959 802 DM    HW: -----------
   Component: NAR 2019/2020  --- 0072
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9GY806PB9
   Serial number: 90349PKA00082
   Component: Gracenote2---  --- 3011
          B11CF 53 [009] - Deactivated
                    Reset counter: 93
                    Mileage: 45413 km
                    Date: 2020.05.25
                    Time: 12:40:15
                    Voltage terminal 30: 14.9 V
                    Satellite radio tuner status-Audio Signal: Available
                    Satellite radio tuner status-Reception quality: optimum_signal
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
0007 - Connection between Antenna Amp 1 for Radio and Antenna
          B1272 13 [009] - Open Circuit
                    Reset counter: 218
                    Mileage: 43964 km
                    Date: 2020.01.24
                    Time: 11:33:29
                    Voltage terminal 30: 12.2 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
   Coding: 010F17024000628002000002
   VCID: 49CF5838F9B9AFB3C45-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0380
   Revision: 11001001    Serial number: 82330JG0208222
   Coding: 0217000101010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI.rod
   Part No SW: 4G8 959 107 T    HW: 4G8 959 107 J
   Component: HDSG-Modul    H14 0049
   Revision: 12014001    Serial number: 314600609
   Coding: 0A3305C122
   ASAM Dataset: EV_HDSGAu573 001022
   VCID: 46D55304E82740CB297-8012
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H28 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C0101AC568B9A9BDF3-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   ROD: EV_AdaptCruisContr2AU57X_002.rod
   VCID: 270BFE804F6DB9C3321-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002451511167
   Coding: 03C1BA1B0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C0010000
   VCID: 313F10D871A9F773EC5-8064
   Component: RGS-VR        H16 0080
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 161015200969
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813007687401
   ASAM Dataset: EV_AEMLearAU64X 002016
   ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:41, VBatt start/end: 12.3V/12.3V)-----------
TBAx
C?ID=287144
You need to use the special Security Access code S12345, which should be displayed in a tooltip, prior to changing the developer mode channel.
