2008 VW Rabbit ABS Issues
Chief05
C?ID=395290
I took my car to a shop to have my lower control bushings replaced and while there the mechanic stated that my dash panel lite up like a Christmas tree and he "shut off" my ABS module. I am trying to undo what this mechanic did.
Log below:
Friday,13,March,2020,11:08:25:14114
VIN: WVWAA71K88W055654   License Plate:
Mileage: 165590km-102892mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 08 09 15 16 17 19 25 42 44 46 52 56 65
VIN: WVWAA71K88W055654   Mileage: 165590km-102892miles
16-Steering wheel -- Status: Not registered 0001
44-Steering Assist -- Status: Not registered 0011
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BK    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1568
   Revision: 1NH01---    Serial number: VWX7Z0G63N384C
   Shop #: WSC 01279 785 00200
   VCID: 73B3D98397B65ABFC47-8026
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -
                    Mileage: 165597 km
                    Time: 20:14:24
                    Temperature: 22.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.192 V
Readiness: 0010 1101
   Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6E85C8F7FC9477572B9-803A
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007211396
   Coding: 108D0F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 03207 444 00944
   VCID: 6FBBD5F3FB9E7E5F20F-803A
   Component: Wischer 040707 021  0501
   Coding: 00038805
   Shop #: WSC 03207
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 163
                    Mileage: 165597 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D090AMV
   Coding: 0013899
   Shop #: WSC 01269 785 00200
   VCID: 6C81C2FFCA88854705D-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME193466257
   Subsystem 3 - Serial number: 6342MSME19767C51K
   Subsystem 4 - Serial number: 6352QSME2E0B392DV
   Subsystem 5 - Serial number: 6362QSME335620030
   Subsystem 6 - Serial number: 63727SME0D4748512
   Subsystem 7 - Serial number: 63827SME0D470F202
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 036 0070
   Coding: 0000022
   VCID: 74B1DA9F92B85D87DDD-8020
   Part No SW: 1K0 920 954 F    HW: 1K0 920 954 F
   Component: KOMBIINSTRUMENT VDD 1212
   Revision: V0002000    Serial number: VWX7Z0G63N384C
   Coding: 0007203
   Shop #: WSC 03170 444 84404
   VCID: 2F3B15F33B1E3E5F60F-807A
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 020707F2000573
   Coding: 198F024007000000
                    Fault Status: 01110100
                    Reset counter: 122
                    Mileage: 165597 km
                    Time: 23:46:15
                    Fault Frequency: 227
                    Reset counter: 126
                    Mileage: 165597 km
                    Time: 23:46:16
                    Fault Frequency: 192
                    Mileage: 165597 km
                    Time: 22:37:17
   Component: IMMO            VDD 1212
   Component: Tuer-SG         006 120A
   Coding: 0001077
   VCID: 38292EAFCE50F9E7315-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3537279BD942048F2A3-8060
00625 - Vehicle Speed Signal
                    Mileage: 165580 km
                    Temperature: 29.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
00750 - Warning Lamp
                    Mileage: 165580 km
                    Temperature: 26.0°C
                    Voltage: 11.60 V
                    Voltage: 11.40 V
   Coding: 139006885103281B0904058FB0080A04889C80
   Shop #: WSC 01287 785 00200
   VCID: 04518A5FC2186D07EDD-8050
   Coding: 0001076
   VCID: 392F2BABF55AE0EFCEB-806C
Address 56: Radio
   Coding: 0100101
                    Fault Status: 00111000
                    Reset counter: 162
                    Mileage: 165597 km
                    Time: 00:18:24
End----------(Elapsed Time: 00:55, VBatt start/end: 14.1V/14.2V)-----------
Sunday,03,May,2020,18:25:39:14114
   VCID: 73B3D98397B65AB35E9-8026
               U0121 - 008 -
                    Fault Frequency: 15
                    Mileage: 165597 km
                    Time: 20:14:24
                    Temperature: 22.0°C
                    Temperature: 29.0°C
                    Voltage: 12.192 V
001281 - Vehicle Speed Sensor
               P0501 - 002 - Implausible Signal
                    Fault Status: 01100010
                    Mileage: 165597 km
                    Time: 22:54:12
                    RPM: 2268 /min
                    Load: 16.1 %
                    Temperature: 85.0°C
                    Temperature: 33.0°C
                    Voltage: 14.097 V
   VCID: 6E85C8F7FC94775BB17-803A
   VCID: 6FBBD5F3FB9E7E53BA1-803A
   Coding: 00038805
   Shop #: WSC 03207
00926 - Terminal 30
                    Reset counter: 167
                    Mileage: 165597 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 5.00 V
                    Reset counter: 163
                    Mileage: 165597 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
   Coding: 0013899
   VCID: 6C81C2FFCA88854B9F3-8038
   Coding: 0000022
   VCID: 74B1DA9F92B85D8B473-8020
   Coding: 0007203
   VCID: 2F3B15F33B1E3E53FA1-807A
                    Reset counter: 122
                    Mileage: 165597 km
                    Time: 23:46:15
                    Reset counter: 127
                    Mileage: 165597 km
                    Time: 23:46:16
                    Fault Frequency: 240
                    Mileage: 165597 km
                    Time: 22:37:17
   Coding: 0001077
   VCID: 38292EAFCE50F9EBABB-806C
   VCID: 3537279BD9420483B0D-8060
                    Mileage: 165580 km
                    Temperature: 29.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
                    Mileage: 165580 km
                    Temperature: 26.0°C
                    Voltage: 11.60 V
                    Voltage: 11.40 V
   VCID: 04518A5FC2186D0B773-8050
   Coding: 0001076
   VCID: 392F2BABF55AE0E3545-806C
Address 56: Radio
   Coding: 0100101
                    Reset counter: 162
                    Mileage: 165597 km
                    Time: 00:18:24
End----------(Elapsed Time: 00:54, VBatt start/end: 14.3V/14.3V)-----------
Have you asked him what he did to "shut it off"?
Have you asked him if he's willing to accept the liability for sending you on your way with an ABS that he shut off? If you get in an accident with this car, I'm confindent your insurance company's lawyer would make that guy's life rather miserable.
Since the ABS isn't talking to any of the other modules, I'd check power to it first. My guess is he pulled some fuses. In addition, it looks like he removed it from the Gateway's Installation List.
DrPeter
16.4905° S, 151.7375° W
I had the same thought, missing fuses, etc... You know, you maybe better off having this person put the vehicle back the way he found it. Lights and all! this could be as simple as a concern with a wheel speed sensor.. damaged, wiring concern.. etc
At least this way it may be easier to diagnoses this concern and that way he might not be getting calls from hungry lawyers. ;)
Hope this helps,
drpeter
Chief05
C?ID=395290
UWE,
I have asked that very question and he states he can't remember. I have checked the fuses and they are good. My Speedometer and steering assist doesn't work and my fuel gauge is intermittent. The VCDS states the ABS Module has no response.Any other ideas on what could he could have done and is there a way to get is back into the Gateway list? Any help is greatly appreciated.
Chief05
Sure, it's trivial to add back into the Gateway List, but that won't bring it back to life.
[Select]
[19-CAN Gateway]
Put a check-mark next to 03-ABS Brakes
[Save Coding]
Did you check to see if he simply unplugged the module and deselected the install list?
Did you report the guy to NHTSA and DMV in your respective state yet?
Chief05
C?ID=395290
All Fuses are good and the ABS is plugged in. I also don't have communication with my vehicle speed signal, my steering assist, and my databus for infotainment. Any thoughts? The mechanic that did the original work did allow my battery to go dead, would that play a factor?
Chief05
Chief05
Do you have power and ground at terminals 15, 30 and 31 plus CAN high/low twisted set at module itself of connector with DVOM using RTFB and WD?
Did you contact NHTSA to report issues & check for safety campaigns yet?
Chief05
C?ID=395290
Jack,
I have checked with NHTSA and there was a recall on the ABS module, but not for my year. What is the easiest way to get terminals 15, 30, and 31? my bentley manual is difficult to follow and it shows me having to pull my passenger side dash panel out to get to the ECM.
Chief05
Jack,
Chief05
Modelgolf 2.5
GO
Date of production17.07.2007
Model year2008
Sales type1K15S1
Engine CodeCBTA
Transmission CodeKPF
The easiest way is too RTFB.
Read the factory manual and about WD plus how to read them here or contained in RTFB yet?
https://forums.ross-tech.com/showth...ad-wiring-diagrams-the-videos-(final-version)
Did you read the JPPSG thread and all the pages yet?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Have you ruled out FOD yet and looked to see if correct part was installed?
Part Information
PART NUMBERLEGACY?DESCRIPTIONREMARKMODEL
1K0 907 375 PControl unit for ABS
1K0 614 117 H
1K0 614 117 J
1K0 907 379 P
PR:1AC
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation powertrains/platform parts0HAVehicle class differentiation -1K0-
Tailpipes0P1Rear side exhaust tailpipe
Hill start assistUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard7GBEmission standard ULEV 2
Trailer hitch1D0Without trailer hitch
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Activated carbon canister/gasoline particulate filter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Aerials8ZMAntenna
Exterior mirror adjustment6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
Multimedia/video/DVD/notebook connection9WLJack for external audio source
Equipment linesA8XUS comfort equipment
Rear brakes1KEDisc brakes in rear
batteriesJ0NBattery 330 A (61 Ah)
Front brakes1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacitiesNY0Standard battery/alternator capacity
Component sets for country-specific prescriptive standardsB0DComponent parts set, complying with vehicle type for USA (without California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ACAnti-lock brake system (ABS)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD-ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ0Without aluminum/chrome work package
General operating license additionsC20Operating permit, alteration
Roof rails/roof rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAWithout roof insert (standard roof)
Shock absorption in rear1JARear shock absorption, basic version 1
Shock absorption in frontG07Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Tank filler neck for unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for vehicle parts0EJInstallation differentiation for transmission MQ 250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MJDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external use UF0Without electric interface
Differentiation for manufacturing process0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
Fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Without extended pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running light -- NAR --
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category for rear axle0YCWeight range 3 installation control only, no requirement forecast
Weight category for front axleL07Suspension range 07 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage net/bag on backrest(s)4U0Without luggage nets/pockets on backrests
Luggage compartment cover3U1Folding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationG0C5-speed manual transmission
Brackets3P0Without bracket for first aid kit and warning triangle
Hand brake lever6PAHand brake lever handle in plastic
Rear spoiler5J0Without rear spoiler
Wiper and washer system for rear windows8M1Rear window wiper washer system with intermittent wipe
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating system/air conditioning system9APClimatic air-conditioning system (semi-automatic)
Main headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without customized installation
Interior lighting in footwell6T0Without interior light in footwell
Dashboard insertsU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Labels (customer specific or campaigns)0KAWithout decals and emblems
Body formsK8GHatchback
Cassette/CD storage compartment4W0without cassette / CD tray
Cool box1W2Glove compartment cooling system
Characteristic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climate zones0Y3Cold zones
Compass/road sign displayQR0Without compass
Head restraints in rear3T2Three rear head restraints
Head restraints5ZFFront head restraints
Fuel tank material treatment2LCFuel tank with special material treatment (coextrusion)
Fuel filling volume1Z2Increase in initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
License plate carrier in rear6P2Rear license plate carrier (NAR)
License plate carrier in front6W3Front license plate carrier (small, NAR)
Paint preservation/transport protection5K0Without surface protection, with additional transport protection measures
Paint finishFB0standard paint coating
Luggage/load compartment floor in rear3GAWithout luggage compartment floor
Steering system setupL0LLeft-hand drive
Reading lamp8S4Two reading lights in front, two in rear
Steering system1N3Speed-related variable steering assist (Servotronic)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Ventilation duct in frontVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support in backrests7P0Without lumbar support in seat backrests
steering wheels1MESteering wheel
Loudspeaker installation8RW10 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E0Without center armrest in front
Multi-function display/trip computer9Q0Without multi-function display/ trip computer
Engine cooling8Z6Hot country
Engine specificationD775-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
Vanity mirror on the left4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Vanity mirror on the right4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation system7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamps/additional headlamps8WAWithout fog lights
Model upgrade measuresGP0Vehicles without special upgrade measures
Rear floor panel platform module4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Wheel trims1NLTrims for alloy wheels
WheelsCM6Alloy wheels 6.5J x 16
Radios8UFRadio with CD drive (double-sized standard slot)
Smoker's/non-smoker's version9JFNon-smoker's package (NAR)
Tire pressure monitoring system7K4Tire pressure monitoring system 315 MHz High
tireH4BAll-season tires 205/55 R16 H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Steel spare wheel with original equipment tire
Restraint systems in front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
P2SGolf 16-inch alloy wheel package
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/gearshift handle6Q1Gearshift knob/handle in plastic
Special labels0SSLabels in English and French
Closing/opening mechanism tailgate/trunk lid/rear gate4E2Tailgate/trunk lid release from inside (electrically)
Seat in front, left3TBStandard seat in front, left
Seat in front, right3SBStandard seat in front, right
Nameplate for sales nameQD0Without nameplate for sales name
Seat belt reminder9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer seat belts in rear3ZD3-point seat belts, outer rear with US label
Center seat belts in rear3C83-point seat belt, center rear with US label
seat coversN4CSeat trim covers in fabric
Seat adjustment3L1Manual height adjustment for left front seat
seat heater4A0without seat heater
Safety head restraint system3K0w/o safety head restraint system
Side lamps7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B1Protective side molding
Sun blind for rear/side windows3Y0without roller blind
Supertone system and successive tone alarm switch control9J0Without supertone system and tone sequence control
Outlet7B212 volt socket in luggage compartment
Bumper2JBStandard bumpers
Rear stabilizer bar0BDRear stabilizer bar
Front stabilizer bar0ADFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Intermittent windshield wiper control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0NVNameplate set "2.5"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Counterweights for steering wheels1Q0steering wheel without balance weight
Door and tailgate/trunk lid locking mechanism4K0Central locking w/ radio remote control and interior controls
Type-approval testing countries/ countries with specific requirementsB34Legal requirements for USA
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A12 doors
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Front-end underbody cladding1SAWithout additional front underbody guard
Identification labels1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit/warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone/telematics9W0Without car phone preparation/ installation
Additional warning lamps9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Thermal energy storage system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Additional body protective covers, side 6EAWithout additional side body covers (stone guard)
Additional child seat anchorage3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heater9M0Without auxiliary heater/parking heater
