- Joined
- Apr 24, 2020
- Messages
- 7
- Reaction score
- 2
- Location
- Randwijk, Netherlands
- VCDS Serial number
- C?ID=393052
Good day!
I'm new to this forum! I own a VW Up! TSI 90 HP and I hope you guys can help me with below?
See screenhots and autoscan below. Both on mobile and desktop the exact same values are checked in advanced measurements.
Almost every value is different and this is measured at the exact same day and time, without the (cold) engine being started in between.
Please note that the adaptation for lower stop and upper stop are at about 35 mV higher on the desktop (same as uncond volt) than on the mobile. This is because I did a IDE03869-Test: charge pressure actuator in between the readings. The readings will go down by about 35 mV again once I start driving (is that normal btw?). Those are the only ones that are the same displayed on mobile as on desktop.
All the other values are completely different. I hope someone can help me with this. Thank you.
Friday,24,April,2020,18:27:19:18439
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZAAZHD054805 License Plate: G120BD
Mileage: 64420km-40028mi Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 03 08 09 10 15 17 19 25 44 47 5F 61 69 AD
VIN: WVWZZZAAZHD054805 Mileage: 64420km-40028miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHZA) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 HW: 04C 907 309 AG
Component: R3 1.0l TFS X22 3537
Revision: WTX22---
Coding: 00110032232401000000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM10TFS01104C906026 001004
ROD: EV_ECM10TFS01104C906026_VW12.rod
VCID: DEF03FFEC17F1276D0-808A
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 L HW: 1S0 614 517 L
Component: EBC 460 ESP H16 0023
Serial number: A01DGCG
Coding: 12BF247129B202F5480224F594AE40515FB300
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
VCID: B83C8966031B0C467A-80EC
Part No SW: 1S0 907 044 HW: 1S0 907 044
Component: Climatronic H05 0101
Revision: K0000000
VCID: EC9465360FC370E64E-80B8
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 004170826
Coding: 7AB82BA700010000090807D06CEB8ED079C0706D60CF2D602101000B0900
VCID: B620875E010FFA3668-80E2
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 110117 04 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.405 H03 0004
Serial number: 0000FST001DDIR000000
Coding: 181100
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 27160003200130016486
Coding: A4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Part No SW: 1S0 919 475 B HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0013
Revision: -------- Serial number: 32961701102569
Coding: 108004
ASAM Dataset: EV_EPHVA14VW1200000 001009
ROD: EV_EPHVA14VW1200000.rod
VCID: B93A8C623811154E85-80EC
Part No SW: 1S0 959 655 C HW: 1S0 959 655 C
Component: VW10Airbag02N H03 0007
Revision: -------- Serial number: 003UB000B2DR
Coding: 00000000000000000000000000000000324E
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: BE309F7E213F3276B0-80EA
Serial number: 3497ARB400257J239JBN
Serial number: 3507ARB401E598PARJGT
Serial number: 3557BRB405R45P4EI82D
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 870 HW: 1S0 920 870
Component: KOMBI H05 0010
Revision: X0005001 Serial number: 00000000000000
Coding: 114A010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: EE906F3E31DF82F660-80BA
Part No SW: 1S0 909 901 HW: 1S0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: BW081001
Coding: 001201
VCID: F0AC714623EB940672-80A4
Part No SW: 5K0 953 234 HW: 1S0 920 870
Component: IMMO H05 0010
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: EA98632E0D376ED63C-80BE
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AM HW: 6R1 909 144 E
Component: EPS_TRW_ALow 313 3142
Serial number: CH1L1400
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 82482B8E1547969694-80D6
Part No SW: 5K0 035 456 E HW: 5K0 035 456 E
Component: KonzernAmp 8K H09 6631
Revision: -------- Serial number: EAA101C0071191
ASAM Dataset: EV_AudioVerst8KanalSTT3 001003
ROD: EV_AudioVerst8KanalSTT3.rod
VCID: AC14A536C743B0E60E-80F8
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1S0 035 869 B HW: 1S0 035 869 B
Component: MU-E-D-EU 068 7288
Serial number: 01121600020889
Coding: 02210000AA00000041111103008002001F0005C40001010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: B52280521409F12E61-80E0
Part No SW: 1S0 907 534 HW: 1S0 937 090
Component: Batt.regelung H81 0744
Coding: 032B7856
Subsystem 1 - Part No SW: 1S0 915 181 D HW: 1S0 915 181 D
Component: J367-BDM H08 0270
Serial number: 53328750486061927980
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: B02CB146E36BD40632-80E4
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H08 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: A81C5926D3BB9CC6EA-80FC
End----------(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.4V)-----------
