I have an 2015 e-Golf SEL Premium and found that the brake lights only come on in regenerative braking Mode "B" after letting off accelerator pedal.
I would like to have the coding so I can have the brake lights come on in modes 2 and 3 regenerative braking also after letting off accelerator pedal like in the 2016 e-Golf.
I do not feel it is safe to be braking in regenerative braking modes 2 and 3 and cars behind me cannot see my brake light on.
I have search for answers and many e-Golf owners share the same problem/complaint as myself.
https://www.myvwegolf.com/forum/viewtopic.php?t=312
Vw website https://knowyourvw.com has a video https://knowyourvw.com/model/52/videos/asset=5264
that says that regenerative braking brake lights come on in 2, 3, and B modes after letting off accelerator so there must be away to turn on as with the 2016 e-Golf.
Monday,20,April,2020,17:11:00:11757
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Artisan-Tech
VIN: WVWPP7AU4FW910714 License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
BD C0 C5 C6
VIN: WVWPP7AU4FW910714 Mileage: 30466km-18930miles
23-Brake Booster -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAGA) Labels:. 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 C HW: 0EA 907 309 A
Component: E-Vehicle H23 8073
Revision: WMH23---
Coding: 000D0016002400007000
ASAM Dataset: EV_VCU00XXX0110EA906016C 002005
ROD: EV_VCU00XXX0110EA906016C_002.rod
VCID: 2F3B133CC79F92A3FA8-807A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 907 379 AE HW: 5Q0 907 379 H
Component: ESC H31 0808
Revision: 00000000 Serial number: 60725000000723
Coding: 01FA40A12C21316C017E020181C7298002348C80408194B202810058C242
ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
ROD: EV_Brake1UDSContiMK100OMG_001.rod
VCID: 7F5B037C577FA2232A8-802A
Revision: 00021000 Serial number: 0363463688
Coding: 030C0C
Shop #: WSC 12345 123 61029
VCID: 3A2D32680CDD470B5D6-806E
Part No SW: 5GE 907 044 AD HW: 5GE 907 044 AD
Component: Climatronic H02 1105
Revision: 00001K07
Coding: 00022200100100000005004200111801
ASAM Dataset: EV_ACClimaBHBVW37X 005132
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 7EA5FE785075AB2B21E-802A
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0137
Serial number: 01011507500860
Coding: 00011A66434182E169E44000001407201C00000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 79AFED64495B8C1314C-802C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150321 043 0551
Serial number: 150323130759
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y15M04D02H08M20S05
Coding: 90A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391506403262
Coding: 2031151011
VCID: 3D2739741DF37033784-8068
Component: AirbagVW20 009 0825
Serial number: 003GCR01LJJW
Coding: 8CCCFC00002000005000001AC24800000065
VCID: 47CB5B9C4F2F2AE3D28-8012
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002JLB10$
Coding: 303139
Subsystem 2 - Part No SW: ----------- HW: 480 002 603 15
Serial number: 35700000000967DC631T
Subsystem 3 - Part No SW: ----------- HW: 480 002 603 15
Serial number: 3580000000072C59C31O
Subsystem 4 - Part No SW: ----------- HW: 480 402 003 15
Serial number: 3510002B719DB890F17H
Subsystem 5 - Part No SW: ----------- HW: 480 402 303 15
Serial number: 3520002A31A14CA501B.
Subsystem 6 - Part No SW: ----------- HW: 480 402 403 15
Serial number: 3550002A71A14CA161C4
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 403 15
Serial number: 3560002A71A14CA4E2FK
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 26031504400235
Coding: 0410
ROD: EV_SMLSKLOMQB_009_VW37.rod
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 5GE 920 855 HW: 5GE 920 855
Component: KOMBI 301 4311
Coding: 0B35181A2B80CF05020868001700030000000000
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 C HW: 5QE 907 530 A
Component: GW MQB EV 312 3203
Revision: -------- Serial number: 17031510800800
Coding: 0201001746F81000EF001200081E00000001050100030000000000000000
ASAM Dataset: EV_GatewEVConti 011020
ROD: EV_GatewEVConti_011.rod
VCID: 46D55698482533EB29E-8012
Subsystem 1 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 36150000204100115062
Coding: 30FFFF
Subsystem 2 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 7315436103
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 A HW: 5QE 909 059 A
Component: EBKV H12 0160
Serial number: 085430010671
Coding: 01720100321A02030002000500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
VCID: 4CC164B05649C9BBFFA-8018
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 A HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0140
Serial number: 05802861190315193505
239616 - Implausible Data Received from Engine Control Module
U0401 00 [047] - -
[iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
Mileage: 30466 km
Date: 2020.04.20
Time: 16:54:47
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000082241003
Coding: 7900000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311C502EB9B17B87A-8060
Part No SW: 5Q0 959 393 D HW: 5Q0 959 393 B
Component: TSG FS 020 0028
Serial number: 240315BCO09214
Coding: 003013208000040000000000
VCID: 40D940806A011DDB132-8014
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005663835
Coding: 111000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: C102
VCID: 43D34F8C7B1706C30E0-8016
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5QE 907 080 C HW: 5QE 907 080 C
Component: VW370E2615010 H06 2461
Revision: 00H06000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM09550115QE907080C 001020
ROD: EV_DMCM09550115QE907080C.rod
Part No SW: 5Q0 959 392 D HW: 5Q0 959 392 B
Component: TSG BFS 020 0028
Serial number: 150315BCF04831
Coding: 003013208C00040000000000
VCID: 3FDB437C17FF62236A8-806A
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005685172
Coding: 091000
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 83
Mileage: 30466 km
Date: 2020.04.16
Time: 15:51:57
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 051A000101000000
VCID: 75B7E1546543E873704-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 R025
Serial number: V7B01203153393
Coding: 02737002FF00000021220001001800001F0100140100010546
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 698FBD2439FB3C93E4C-803C
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS600LEG
Subsystem 2 - Part No SW: 5G0 919 866 S HW: -----------
Component: NAR 2015 --- 0022
B11CF 53 [009] - Deactivated
Reset counter: 83
Mileage: 30466 km
Date: 2020.04.16
Time: 15:51:04
Voltage terminal 30: 13.1 V
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0564
Coding: 02737002C2829A017FFE06000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 5QE 915 227 M HW: 5QE 915 227 H
Component: K8C H13 0722
Serial number: VWADFDA001
ASAM Dataset: EV_BECM08820215QE915227M 003016
ROD: EV_BECM08820215QE915227H.rod
VCID: 52FD7AC8B46D9F4BB56-8006
Address BD: Hi Volt. Batt. Charg. (J966) Labels:| 5QE-915-022.clb
Part No SW: 5QE 915 022 G HW: 12E 915 022 C
Component: LMSG H08 1075
Serial number: 00920051020339
Coding: 4A4904
ASAM Dataset: EV_HVChargManagVWMQB 001001
ROD: EV_HVChargManagVWMQB_001.rod
VCID: 45D75194752338F3204-8010
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 H HW: 5QE 035 335 H
Component: E_SOUND_SG H07 0198
Serial number: EN151201090000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 005012
ROD: EV_ENoiseS1NNVW3707_005.rod
Address C5: Therm. mgt. (J1024) Labels: None
Part No SW: 5GE 907 458 HW: 5GE 907 458
Component: TME-Min H03 0108
Serial number: 0007641
ASAM Dataset: EV_ThermContrVISAU49X 001009
ROD: EV_ThermContrVISAU49X_VW37.rod
VCID: 025D8A88248DCFCB456-8056
Subsystem 1 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G395 pT-Sens1 H61 0006
Subsystem 2 - Part No SW: 12E 963 231 E HW: 12E 963 231 E
Component: J848 HV-PTC H09 0205
Serial number: T150863003805000145
Subsystem 3 - Part No SW: 5QE 820 803 HW: 5QE 820 803
Component: J842 eKK H03 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 2:
Subsystem 4 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G826 pT-Sens2 H61 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 3:
Subsystem 5 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G827 pT-Sens3 H61 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 4:
Subsystem 6 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G828 pT-Sens4 H61 0006
Geber für Kältemitteldruck/Kältemitteltemperatur 5:
Subsystem 7 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G829 pT-Sens5 H61 0006
Refrigerant Expansion Valve 1:
Subsystem 8 - Part No SW: 4M0 816 682 HW: 4M0 816 682
Component: N636 EV1_KaMi H09 0102
Serial number: 00000000000020038311
Refrigerant Expansion Valve 2:
Subsystem 9 - Part No SW: 4M0 816 682 HW: 4M0 816 682
Component: N637 EV2_KaMi H09 0102
Serial number: 00000000000020038312
Refrigerant Expansion Valve 3:
Subsystem 10 - Part No SW: 4M0 816 682 HW: 4M0 816 682
Component: N638 EV3_KaMi H09 0102
Serial number: 00000000000020038313
Refrigerant Shut Off Valve 1:
Subsystem 11 - Part No SW: 4M0 816 703 HW: 4M0 816 703
Component: V424 AV1_KaMi H09 0102
Serial number: 00000000000040038551
Refrigerant Shut Off Valve 4:
Subsystem 12 - Part No SW: 4M0 816 703 HW: 4M0 816 703
Component: N642 AV4_KaMi H09 0102
Serial number: 00000000000040036930
Refrigerant Shut Off Valve 5:
Subsystem 13 - Part No SW: 4M0 816 703 HW: 4M0 816 703
Component: N643 AV5_KaMi H09 0102
Serial number: 00000000000040036212
32837 - HV Electronics Coolant Pump Control
P0CEB 00 [032] - Short to GND
Mileage: 30466 km
Date: 2020.04.17
Time: 17:25:54
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 5QE 915 681 B HW: 5QE 915 681 B
Component: OBC Delta-ES H52 1550
ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
ROD: EV_OBCTwoPhaseDT2VW3707.rod
VCID: 4BC367AC5347CE83F60-801E
End----------(Elapsed Time: 01:56, VBatt start/end: 14.7V/14.7V)-----------
