2006 Passat Diesel transmission fault no drive
Shawa12002
Victoria, Australia
C?ID=370869
I bought a passat with a transmission issue. It starts and runs but the shift lever does not unlock when Bpedal is pressed.
My VIN: WVWZZZ3CZ7P046973. If I unlock the lever manually I still don't get drive or reverse. Has any1 had a similar issue before?
I intend to do the work myself so I need leads to save myself time and labour.
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ7P046973   Mileage: 144470km-89769miles
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 997 020 T    HW: 03G 906 018 CE
   Component: R4 2.0l PPD1.5 G    5159
   Revision: --H25---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 30024 959 101054
   VCID: 393A23FC70FB4D4E05-806C
005714 - Please check DTC Memory of Transmission Controller
               P1652 - 008 -
                    Reset counter: 40
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:46:29
                    RPM: 800 /min
                    Torque: 40.0 Nm
                        0.00 %
                    Voltage: 12.54 V
                    Bin. Bits: 00000001
                    Bin. Bits: 00000000
               P1652 - 008 -
                    Reset counter: 40
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:50:37
                    RPM: 768 /min
                    Torque: 72.0 Nm
                        0.00 %
                    Voltage: 11.19 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
Readiness: N/A
   Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
   Component: GSG DSG         070 1127
   Revision: 04507000    Serial number: 00000607260992
   Shop #: WSC 00028 028 00001
   VCID: 2306E194E277279E3F-8076
28775 - No Communication with Gear Selector Module
            U0103 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:44:56
00194 - Ignition Key Removal Lock
                    Reset counter: 1
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:44:58
            U0103 - 004 -
                    Reset counter: 0
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:45:01
00653 - Selector Lever/Auto Trans Plausibility
                    Reset counter: 40
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:49:29
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667841377
   Coding: 0015653
   VCID: 322814D0AD8DBE16C4-8066
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 679EB58456CF0BBEA3-8032
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000004316264
   Coding: E0808F0700041A00000A00000F00000000085D435C0000
   VCID: 302C1ED8A3818C06B2-8064
   Subsystem 1 - Part No: 3C2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     260706 014  1201
   Coding: 00208933
   Shop #: WSC 00028
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 254
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:49:00
                    Voltage: 13.25 V
                    Reset counter: 254
                    Mileage: 144473 km
                    Date: 2020.04.16
                    Time: 07:49:00
                    Voltage: 13.25 V
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 16 AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3PDYSKKR
   Coding: 0012598
   VCID: 2E1000A0B9B59AF6A0-807A
   Subsystem 1 - Serial number: 6332MSME123C756EL
   Subsystem 2 - Serial number: 6342MSME123B0E5DL
   Subsystem 3 - Serial number: 6351HTS6PLL6CPN2F
   Subsystem 4 - Serial number: 6361HTS6VARQ8552
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Revision: 00007000    Serial number: 3C5953507P
   Coding: 0001111
02413 - Switch for Selector Lever Position P Lock (F319)
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007705
   Shop #: WSC 00921 001 1048576
   VCID: 618AAB9CB8EB758E6D-8034
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P10126061A
   Coding: FD807F0E000202000003
   Shop #: WSC 30024 959 101032
   VCID: 2F2E1DA4BEBF93FEAB-807A
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   Subsystem 1 - Part No: 3C0 905 861 F
   Component:    ELV          026 0380
   3C0905861F     ELV          026 0380
   Component: J386  TUER-SG FT    1124
   Revision: 12006001    Serial number: 00000514168804
   Coding: 0000693
   VCID: 3B3639F47AC77F5E17-806E
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.136 H07 1806
   VCID: 35222FCC5CE3A92EE1-8060
   Component:    KSG PQ46 ELV 042 0472
   Coding: 00910A0001860E763004941570085F0B007800
   Shop #: WSC 30024 959 88134
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1124
   Revision: 12006001    Serial number: 00000508968729
   Coding: 0000692
   VCID: 3C343AE87FC978661E-8068
   Revision:   013
   Coding: 0000012
   VCID: 210AEB9CF86B358E2D-8074
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  041 0167
   Revision: 00000001    Serial number: VWZ1Z3L5186785
   Coding: 0100040004
   VCID: 6288A4907DED6E9674-8036
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1113
   Revision: 11005001    Serial number: 00000000425747
   Coding: 0000144
   VCID: 3D3237EC64D3716E29-8068
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1113
   Revision: 11005001    Serial number: 00000000524430
   Coding: 0000144
   VCID: 3E3030E069D56A7630-806A
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930622903028
   Coding: 0001014
   VCID: 281CF6B89B51C4C66A-807C
End----------(Elapsed Time: 01:22, VBatt start/end: 14.0V/14.1V)-----------
Shawa12002
Victoria, Australia
C?ID=370869
Thanks for the link. I will give feedback on the fix
