Autotrans make sound when changed
khaledabdulaziz
Israel
C?ID=394371
hello all
i have a vw golf 2002 that had an accident
we replaced the autotrans but it seems there a problem when the gear changed to R and D from P
here is the autoscan
Wednesday,15,April,2020,11:49:36:04619
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1JZ2W433609   License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: WVWZZZ1JZ2W433609   Mileage: 225480km-140106miles
Address 01: Engine        Labels: 06A-906-018-AQY.lbl
   Part No: 06A 906 018 GP
   Component: 2.0l R4/2V  MOTR AT V01
   Coding: 00033
   Shop #: WSC 01271
   VCID: 76B5E0E3B1D61D0B79E-4B3C
17834 - EVAP Purge Valve (N80)
            P1426 - 35-00 - Open Circuit
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
            P1115 - 35-00 - Short to Ground
Readiness: 0110 0100
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 JQ
   Component: AG4 Getriebe 01M    4829
   Coding: 00000
   VCID: 08499E1BCB221BFB1B2-0964
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 J
   Component: ABS FRONT MK60      0103
   Coding: 0004097
   Shop #: WSC 01271 785 00200
   VCID: 313F13FF1D387A33ECC-5184
   Part No: 6Q0 909 601
   Component: 17 AIRBAG VW5       0004
   Coding: 12599
   Shop #: WSC 00046
   VCID: 70B9D6FBD3B2333BA32-5160
            33-00 - Resistance Too Low
   Part No: 1J0 920 826 A
   Component: KOMBI+WEGFAHRS. RB8 V13
   Coding: 03612
   VCID: 270BFDA726FC3483328-5160
   WVWZZZ1JZ2W433609     VWZ6Z0A4016163
            30-00 - Open or Short to Plus
01176 - Key
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01271
   Part No: 1C0 959 799 B
   Component: 1C Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 01271
   VCID: 363520E3F1565D0BB9E-4B3C
   Component: 1K Tõrsteuer.FS KLO 0002
   Component: 1B Tõrsteuer.BF     0001
   Component: 1B Tõrsteuer.HL     0001
   Component: 1B Tõrsteuer.HR     0001
01389 - Tailgate Open Switch (F124)
            27-00 - Implausible Signal
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
            29-10 - Short to Ground - Intermittent
End----------(Elapsed Time: 04:59, VBatt start/end: 13.9V/13.8V)-----------
myounus
Northwest UK
C?ID=321059
What problem are you getting? Did you replace with a reconditioned gearbox?
khaledabdulaziz
Israel
C?ID=394371
After posting this autoscan, engine got new error which is vehicle speed sensor, is that related ?
