hello all
i have a vw golf 2002 that had an accident
we replaced the autotrans but it seems there a problem when the gear changed to R and D from P
here is the autoscan
Wednesday,15,April,2020,11:49:36:04619
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1JZ2W433609 License Plate:
76
VIN: WVWZZZ1JZ2W433609 Mileage: 225480km-140106miles
Address 01: Engine Labels: 06A-906-018-AQY.lbl
Part No: 06A 906 018 GP
Component: 2.0l R4/2V MOTR AT V01
Coding: 00033
Shop #: WSC 01271
VCID: 76B5E0E3B1D61D0B79E-4B3C
17834 - EVAP Purge Valve (N80)
P1426 - 35-00 - Open Circuit
17523 - Oxygen (Lambda) Sensor Heating: B1 S1
P1115 - 35-00 - Short to Ground
Readiness: 0110 0100
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JQ
Component: AG4 Getriebe 01M 4829
Coding: 00000
VCID: 08499E1BCB221BFB1B2-0964
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 01271 785 00200
VCID: 313F13FF1D387A33ECC-5184
Part No: 6Q0 909 601
Component: 17 AIRBAG VW5 0004
Coding: 12599
Shop #: WSC 00046
VCID: 70B9D6FBD3B2333BA32-5160
33-00 - Resistance Too Low
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 826 A
Component: KOMBI+WEGFAHRS. RB8 V13
Coding: 03612
VCID: 270BFDA726FC3483328-5160
WVWZZZ1JZ2W433609 VWZ6Z0A4016163
30-00 - Open or Short to Plus
01176 - Key
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01271
Part No: 1C0 959 799 B
Component: 1C Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 01271
VCID: 363520E3F1565D0BB9E-4B3C
Component: 1K Tõrsteuer.FS KLO 0002
Component: 1B Tõrsteuer.BF 0001
Component: 1B Tõrsteuer.HL 0001
Component: 1B Tõrsteuer.HR 0001
01389 - Tailgate Open Switch (F124)
27-00 - Implausible Signal
00912 - Window Regulator Switch; Front Left (E40)
00913 - Window Regulator Switch; Front Right Driver (E81)
End----------(Elapsed Time: 04:59, VBatt start/end: 13.9V/13.8V)-----------
