2020 Skoda Octavia 1.5 TSI [NX] [SK38]
icardiag
Europe
C?ID=113031
Ladies and gentlemen, here it is - first scan ever of the latest MQB new gen platform SK38/VW38 aka Golf 8 :cool:
My comments:
-Autoscan doesn't work, says "Not supported by gateway".
-Gateway installation list identifies just the door modules (42, 52, BB and BC), nothing else
-I had to make an entry in the autoscan.txt file explicitly specifying the modules I know from previous gen Octavia NE and do the autoscan like we used to do in the old days
-Engine at address 01 is not identified at all and the connection to the unit 01 doesn't work
-BCM at address 09 has more than 3400 adaptation channels
-Still a lot of errors in modules even the PDI was finished succesfully
-Serial numbers and VIN code even from ESP coding were removed (I was asked not to disclose these to public)
Monday,06,April,2020,15:25:39:36609
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: ICarDiag
Workshop Code: 790 73430 000134
VIN: TMBJR7NX8LY0?????   License Plate:
Chassis Type: NX - Skoda Octavia (2020 >)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 4B 52 5F
          6C 6D 75 A5 D6 D7
   Part No SW: 5WA 614 517 AG    HW: 5WA 614 517 A
   Component: ESC           H09 0013
   Serial number: 6032000000?????
   Coding: 34072CA4222?447?528?500?0AC?61862DB458F052D067C0019CA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 007045
   ROD: EV_Brake1ESCEPBMQB37W_006.rod
   VCID: 8D52FA4B5CDEDFEEF9-80D8
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0662
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003019
   ROD: EV_Kessy37w_002.rod
   VCID: D4E42F2FBF74CE2676-8080
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 13 [009] - Open Circuit
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 10:57:04
                    Terminal 15 status: On
                    Voltage: 11.4 V
1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 13 [009] - Open Circuit
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 10:57:04
                    Voltage: 11.4 V
1054219 - Touch Sensor on Exterior Door Grip; Rear Left
          B116D 13 [009] - Open Circuit
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 10:57:04
                    Voltage: 11.4 V
Address 08: Auto HVAC (J979)       Labels: None
   Part No SW: 5WA 907 727 S    HW: 5WA 907 727 S
   Component: Climatronic   H01 0240
   Coding: 201000010011120000100010111011110000112100100000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005062
   ROD: N/A
   VCID: E08CF3FFFBCC2286E2-80B4
No ASAM data for: "EV_ACClimaBHBVW38X" ()
1048838 - ROD - Unknown Error Code
          - 00 [044]
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:11:40
   Part No SW: 5WA 937 086 J    HW: 5WA 937 086 J
   Component: BCM 37W BOSCH 016 0132
   Serial number: BXJ53F1401?????
   ASAM Dataset: EV_BCM37w 005001
   ROD: EV_BCM37w_004.rod
   VCID: D8FCDB1FA39CEA469A-808C
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5WA 919 294 A    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0022
   Serial number: 0000070220?????
   Coding: 0040014001
   ASAM Dataset: EV_EPHBO18VW3800000 002028
   ROD: EV_EPHBO18VW3800000.rod
   VCID: D0EC233F8B6CB20652-8084
   Part No SW: 5WA 907 572 A    HW: 5WA 907 572
   Component: ACC Bosch MQB H03 0245
   Coding: 050300770007404512474000000040054E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 003012
   ROD: EV_FRONTRADARBOSCHVW380.rod
   VCID: CCD4374F674496E62E-8098
Address 15: Airbags (J234)       Labels: None
   Part No SW: 1EA 959 655 AP    HW: 1EA 959 655 AH
   Component: VW40Airbag    009 0035
   Serial number: U037Vs?????
   Coding: 98CC000000C0C000000000000000000050540000205400000000F68000120065
   Shop #: WSC 31000 790 00241
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 8F6EE04356D2EDFE0B-80DA
Address 17: Instruments (J285)       Labels: None
   Part No SW: 5E3 920 770     HW: 5E3 920 770
   Component: KOMBI         203 1400
   Coding: 04A401006B8800080184620B2000080800300400
   VCID: E680E5E719E84CB618-80B2
No ASAM data for: "Unknown" (SK37)
16777018 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 44
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:09:13
16777020 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 44
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:09:13
16777022 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 44
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:09:13
   Part No SW: 5WA 907 530 B    HW: 5WA 907 530 B
   Component: GW2020 High   734 7068
   Revision: --------    Serial number: 1501609000?????
   Coding: 0000808D0B00000000000000010301307301600902000300030100000001010100000000000000000000000000000000
   ASAM Dataset: EV_GatewMQB2020 004003
   ROD: N/A
   VCID: C7DE08637E2275BE03-8092
No ASAM data for: "EV_GatewMQB2020" ()
1049253 - ROD - Unknown Error Code
          - 00 [046]
                    Reset counter: 39
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:22:00
1049254 - ROD - Unknown Error Code
          - 00 [046]
                    Reset counter: 39
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:21:47
8397571 - ROD - Unknown Error Code
          - 00 [046]
                    Reset counter: 39
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:20:31
12400 - ROD - Unknown Error Code
          - 00 [046]
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 10:57:04
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H08 0040
   Serial number: 200000226?????
   Coding: 0000000000000000
   Shop #: WSC 31000 790 00247
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: N/A
   VCID: B22849B7E5A0E01644-80E6
No ASAM data for: "EV_ELVMarqMQBA0" ()
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 2Q0 907 686 D    HW: 2Q0 907 686 D
   Component: HRE_Master    H25 0276
   Serial number: 000005406?????
   Coding: 5A9545D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001013
   ROD: N/A
   VCID: BB36649332EA215E97-80EE
No ASAM data for: "EV_HREntryHellaGen3Mstr" ()
2232369 - ROD - Unknown Error Code
          - 00 [046]
                    Reset counter: 40
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 12:03:09
   Part No SW: 5Q4 959 593 L    HW: 5Q4 959 593 L
   Component: TSG FS        010 0686
   Serial number: 00004032?????
   Coding: 001D8820DE00020000001100
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: CED03D479158A4F640-809A
   Part No SW: 5WA 907 146 J    HW: 5WA 907 146 A
   Component: BASGEN1MQB37  201 2032
   Serial number: 000?????
   Coding: 0000000000000000000002010100010000000101000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 006037
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: D2E829378560C01664-8086
   Part No SW: 5WA 907 338     HW: 5WA 907 338
   Component: FCM2020 Low   009 1372
   Serial number: 1501512200?????
   Coding: 00000000090001E200002F11010003000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW38X 002010
   ROD: EV_MultiModulContiVW38X.rod
   VCID: 8B56F45322CAD1DEE7-80DE
   Part No SW: 5Q4 959 592 L    HW: 5Q4 959 592 L
   Component: TSG BFS       010 0686
   Serial number: 00004045?????
   Coding: 001D8020DE00020000001100
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: CDD23A4B9C5E9FEE39-8098
   Part No SW: 5E3 035 816 A    HW: 5E3 035 816 A
   Component: MU-O-ND-EU    H56 1650
   Serial number: WG8LGM0702?????
   Coding: 33820000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: N/A
   VCID: A502A2EBA46E87AED1-80F0
No ASAM data for: "EV_MUOIMQB37w" (SK37)
1561 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 39
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:22:45
0021 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Priority: 9
                    Reset counter: 39
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 15:21:30
6725 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 39
                    Mileage: 9 km
                    Date: 2020.04.06
                    Time: 10:57:03
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 5WA 980 556 A    HW: 5WA 980 556 A
   Component: RV eCompact   H20 0193
   Serial number: FCL-K2011.?????
   Coding: 03032200843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos_004.rod
   VCID: CFEE20439652ADFE4B-809A
10489856 - No Basic Setting
          B2010 00 [046] - -
          [System not calibrated]
                    Reset counter: 40
                    Time: 00:00:00
13705496 - Databus
          U1121 00 [047] - Missing Message
          [Oldbit-monitoring Gateway_73.Getriebe_11_alt]
                    Reset counter: 40
                    Mileage: 589824 km
                    Date: 2012.09.22
                    Time: 02:32:00
13705507 - Databus
          [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
                    Reset counter: 40
                    Mileage: 589824 km
                    Date: 2012.08.05
                    Time: 31:00:00
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-?????
   Coding: 3908
   Shop #: WSC 31000 790 00309
   VCID: C8DC0B5F733C7AC60A-809C
Address 75: Telematics (J949)       Labels: None
   Part No HW: 5WA 035 284 A
   Component: OCU3HMQB37W   H12 0065
   Serial number: 0000000001?????
   Coding: 033820109069A8819005460061012E07
   ASAM Dataset: EV_OCU3HMQB37W 001039
   ROD: N/A
   VCID: D5E2D22BB48ED72E81-8080
No ASAM data for: "EV_OCU3HMQB37W" ()
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H05 3126
   Serial number: E267351112?????
   Coding: 0002088811684060509E00001030008001018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005039
   ROD: EV_MFK3ValeoMQB_004.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 572 CD    HW: 992 941 572 C
   Component: LED1L         H08 9102
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: N/A
   VCID: E79EE8E31EE255BE23-80B2
No ASAM data for: "EV_LLPGen3LKEBODPO68X" ()
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9102
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
   ROD: N/A
No ASAM data for: "EV_LLPGen3RKEBODPO68X" ()
End------(Elapsed Time: 12:19, VBatt start/end: 11.8V/14.0V, Deb=2)--------
Yeah, pretty much the same as in an Mk.8 Golf or two that we've gotten feedback from. Eric says he thinks he now understands the Gateway/GVL issues. Much has changed compared to how this was previously done. At some point, I expect we will have a new version to try that should fix this, but it's a bit of a PITA since none of those cars are available on this side of the pond yet.
Jacek
Poland
C?ID=360566
Such information appeared today on the VCP website:
"VW introduced a SFD (Schutz Fahrzeug Diagnose) in MQB2020 platform. To get access to adaptations / coding and even output checks, ECU has to be unlocked by special Token. Tokens can be currently obtained only by using offcial GeKo/partner company account.
So, if you want to work with SFD -> go ahead and apply for access. There's currently NO OTHER WAY.
Stay tuned for our news in that case.
Demo, how to use SFD unlocking -> https://youtu.be/Gy72Z3xBSLY"
wojo
Poland
C?ID=253691 (NRRT)
I recently own the new Octavia 4. Did you manage to find out what are the Security Accesses for modules?
I need up to 13 (ACC) and A5 (Front cam - line assist etc)
These modules do not require an SFD
Akkipen
Norway
C?ID=327213
I have access to a Golf 8 if you need scans of all the modules(?)
