2015 Audi Q7 TDI, Questions on Fault Codes
josteele00
C?ID=396254
Hi - new user, first post, novice when using scan tools. Just performed my first scan and what a great way to get to know my "new" used Q7 I purchased in August of 2019! It has had the emissions fix performed in 2018.
I'm getting four faults and find some discussion when searching, and not real specific discussion on the others. Any suggestions on where to look would be appreciated!
  • 1. Address 01: Engine - 38161 Reductant Metering Module
  • 2. Address 05: Acc/Start Auth - 002 - Lower Limit Exceeded - Intermittent
  • 3. Address 05: Acc/Start Auth, 02764 - Access/Start Authorization Switch, 008 - Implausible Signal - Intermittent
  • 4. Address 19: CAN Gateway, 02256 - Quiescent Current, 002 - Upper Limit Exceeded
Suggestions for resolving each? Please let me know if I should just clear the faults and only worry if they re-occur.
Issue 1: Sounds like it is Ad-Blue system related and I should take it to the dealer for service?
Issue 2: Is it as simple as a low battery in my Key FOB?
Issue 3: ?
Issue 4: I think I left an accessory plugged in and the car noted the battery drain?
Thanks in advance!
Jim S.
Sunday,05,April,2020,06:30:57:32288
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 4C 4F 52 55
          56 5F 62 6C 6D 6F 72
VIN: WA1LMAFE5FD024445   Mileage: 80490km-50014miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
   Component: 3.0TDI FSA    H23 0012
   Revision: 54H23---    Serial number:
   Coding: 2A2A4012252600050000
   Shop #: WSC 38609 001 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
   ROD: EV_ECM30TDI0114L2910401A.rod
   VCID: 221DEC4B7448131B656-8076
38161 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
                    Mileage: 75724 km
                    Date: 2020.01.31
                    Time: 17:30:51
                    Engine speed: 1516.00 /min
                    Normed load value: 60.8 %
                    Vehicle speed: 52 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 14.300 V
                    Unlearning counter according OBD: 6
                    Outside air temperature: 19.5 °C
                    Pressure sensor for reducing agent: measured pressure: 5100 hPa
                    SCR catalytic converter average temperature: 217.1 °C
                    Sensor for reducing agent tank temperature: temperature: 27.5 °C
                    Reducing agent pump: activation: 50.00 %
                    SCRPOD p Cns De Mon Avrg: 793 hPa
   Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
   Component: AL1000 AISIN  002 3399
   Coding: 001378
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7BA3F12FB36282D3060-802E
   Revision: 00H02001
   Coding: 0099441
   Shop #: WSC 31414 790 00001
   VCID: 34311A13D23C8DAB87A-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902202100
   Coding: 0000135
   VCID: 2517F75769E6E423004-8070
   Component: FBSAUDIC6 EZS   H05 0020
00955 - Key 1
                    Fault Status: 00110010
                    Fault Frequency: 13
                    Reset counter: 32
                    Mileage: 61695 km
                    Date: 2019.03.16
                    Time: 10:46:18
00956 - Key 2
                    Reset counter: 40
                    Mileage: 70017 km
                    Date: 2019.09.28
                    Time: 21:43:04
02764 - Access/Start Authorization Switch (E408)
                    Reset counter: 189
                    Mileage: 79392 km
                    Date: 2020.02.23
                    Time: 06:40:28
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000000472920
   Coding: 0300A036
   VCID: 2517F75765E6E423004-8070
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E85C87BFC90E77BB1E-803A
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931509702967
   Coding: 24011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 34311A13DEBC8DAB87A-8060
   Component: 73 AIRBAG AUDI8RH45 0230
   Revision: 09H45000    Serial number: 0038QD90SMYE
   Coding: 0014131
   VCID: 2B03016F0F02D253D60-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME75563F54P
   Subsystem 3 - Serial number: 6342QSME75563862I
   Subsystem 4 - Serial number: 6352QSME7C541D52Q
   Subsystem 5 - Serial number: 6362QSME75563B6CX
   Subsystem 6 - Serial number: 63734SME2B54515C3
   Subsystem 7 - Serial number: 63834SME31545678+
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026150740593
   Coding: 0012242
   VCID: 2809FE631EF4F94B3B2-807C
   Component: E0221           H03 0040
   Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2S510H4G
   Coding: 8BD664040100CF05020205
   VCID: 42DD4CCB9488331B056-8016
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M153270381
   Coding: 00C303
   VCID: 3FDB453FE77A5EF36A8-806A
   Component: J367-BDM  H07 0125
   Serial number: 42084B41074121766474
                    Fault Status: 00100001
                    Reset counter: 190
                    Mileage: 79492 km
                    Date: 2020.02.23
                    Time: 09:56:00
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000142926808
   Coding: 00581B00000011110000
   VCID: 323D1C0B2428839B956-8066
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   VCID: 2E05087B3C10A77BF1E-807A
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 3 - Serial number: 5F06.04.1500H03000AMS13514ÿ
   Subsystem 4 - Serial number: S13514ÿ
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000144056153
   Coding: 011F57205E40440004
   VCID: 48C95EE3B2B4194BDB2-801C
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82009999850000
   Coding: 3569949
   VCID: 38292E23CE5469CBAB2-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000079305
   Coding: 030000
   VCID: 290FFB6709FEC04324C-807C
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191097795
   Coding: 0758477
   VCID: 2313E94F67D21A136E0-8076
   Component: ILM Beifahrer   H17 0100
   Revision:             Serial number: 00000000228995
   Coding: 0012001
   VCID: 5EE598BB0C3077FB01E-800A
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000143129176
   VCID: 47CB5DDFBFAA1633D28-8012
   Serial number: 150415-0002-021
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DD4CCB9408331B056-8016
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156D40F8249782
   Coding: 020007010000000000
   VCID: 2411EA536EDC1D2B17A-8070
   Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 513DY0F7517181
   Coding: 180200060004E3EF510003456F632003140000000100000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130DG0F3321611
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002244545
   Component: CD-Database  5950
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000145811474
   Coding: 010E57204040230004
   VCID: 46D550DBB8A00F3B29E-8012
   Revision: --H09---    Serial number: 525PA8-JA342QJ
   Coding: 1021201
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H58 0500
   Revision: --H58001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C273CA8C156B9FA-8038
   Subsystem 2 - Serial number: 4ó
   Subsystem 3 - Serial number: RD10.04.15--H58001002E0407ÿ
   Subsystem 4 - Serial number: 2E0407ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0145638892----
   Coding: 0003595
   VCID: 2615F05B14E0EF3B09E-8072
   Component: J_245_EE16_SKB10H15 0220
   Component: J_394_EE16_SKB10H15 0220
   Component: J_392_EE16_SKB10H15 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000145811469
End----(Elapsed Time: 02:02, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
Welcome to the VCDS forum.
Clear the DTC's & see what comes back, since all sporadic.
Check charging system battery terminals and possibly change battery if weak after tested.
JPPSG
"Intermittent - Not Confirmed". But it seems it has been reported to the Gateway because we see, "01-Engine -- Status: Malfunction 0010"
Fault Frequency is 1, and it looks like the fault occurred back on 2020.01.31.
Make sure the batteries in your keys are good and fresh.
Fault frequency 1. Date: 2020.02.23 Time: 06:40:28
Fault Frequency 1. Date: 2020.02.23 Time: 09:56:00
This is a very common code, indicating that more current that expected was being pulled from the battery under what should have been "no load" conditions. It's normally not something I'd worry about unless you have problems with the battery being drained, but the fact that it ocurred only a few hours after the previous code in 05 makes me wonder if they are related.
I'm with Jack. If it were mine, I'd clear all these and then see what comes back when.
TicoQ7_TDI
Madison, AL, USA
C?ID=500969
I got a Quiescent Current 002 code with my "new" 2015 Q7 TDI. Its caused by something drawing power after the car is shutdown. In my case, since the front lighter plug remains hot after turning off the car, I had a ANKER usb power adapter that had a red led light that stayed on. That was enough to trigger the code. Unfortunately, there can be many less obvious causes.
