- Joined
- Mar 30, 2020
- Messages
- 1
- Reaction score
- 0
- Location
- Atlanta, GA, USA
- VCDS Serial number
- C?ID=400462
First off, I am very new to using VCDS and am learning car repair as I go. I tried to search for these fault codes already but found no applicable solution. It is out of warranty so the dealership is out.
My front AC vents haven't blown air for a month or two. The defroster wasn't blowing either. I scanned for codes and cleared them. Gave the AC another test-run and the defroster now blows, but the AC vents are still a dud. I have the erWin manuals, which lead me to think it's the 'Air Distribution Door Motor V428' (interchangeably V426?). Did another scan (see below) and most the same codes came back - open circuit and stuck actuators.
Problem is it's located under the dash and I would have to take out the instrument cluster and steering wheel to access it, which seems intimidating. But how can I make sure it's this motor that needs to be replaced and not just a loose connector, or ensure that the issue is not located somewhere else? Are there any steps that I'm missing so far?
Auto-scan below.
Auto-scan below.
Monday,30,March,2020,18:48:03:55525
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUBFGFF0F1079701 License Plate:
Mileage: 67078km-41680mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 52 55 5F
6C A9 BB BC
VIN: WAUBFGFF0F1079701 Mileage: 67078km-41680miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 E HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A1D00322426000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259E 001002
ROD: EV_ECM20TFS0208V0906259E.rod
VCID: 42DD4CC7F4025F479F1-8016
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4521
Revision: 05853104 Serial number: TFK01410120018
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F1BE5B3273052AFD0F-804A
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 62734000002703
Coding: 31FF6B9254270A75017E030041C4698CD62A5080C08296B6024100D88208
ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
VCID: 48C95EEFD23E7517415-801C
Revision: 00021000 Serial number: 0350510374
Coding: 030C0C
VCID: 3A2D34279CD21787C71-806E
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000475670
Coding: 03000014010000000000000000001400
VCID: 33331903BBB8E6CF047-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: D839C557000000000001
328964 - Motor for Front Air Distribution Flap
B1091 71 [009] - Actuator stuck
Reset counter: 210
Mileage: 67078 km
Date: 2020.03.30
Time: 18:22:04
Voltage terminal 30: 12.1 V
Interior temperature: 32.8 °C
Outside air temperature: 22.5 °C
Front air distribution flap: actual value: 768
Front air distribution flap: actual value: 0.0 %
Front air distribution flap: specified value: 104
329475 - Motor for Fresh Air / Recirculated Air Flap
B108B 13 [009] - Open Circuit
Reset counter: 210
Mileage: 67078 km
Date: 2020.03.30
Time: 18:22:28
Specified value for fresh air/recirc air flow flap: 647
Actual value for fresh air/recirculation air flow flap: 768
Actual value for fresh air/recirculation air flow flap: 100.0 %
329476 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [009] - Actuator stuck
Reset counter: 210
Mileage: 67078 km
Date: 2020.03.30
Time: 18:22:03
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011428800265
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7AADF427DC52D787871-802E
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 141021 042 0585
Serial number: 141028210505
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 23359920
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 13 08 2014 00000796
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000031050821
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H02 0003
Serial number: 0000FST0000A42G00000
Coding: 101F00
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Reset counter: 205
Mileage: 66967 km
Date: 2020.03.28
Time: 11:18:08
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39331429804786
Coding: 0030150011
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 071014018
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide.rod
VCID: 41DF43CBF104445F86B-8014
Component: AirbagVW20 009 0825
Serial number: 003GCR00WE0I
Coding: 9DCCFCC0000000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47CB5DD3DF207A6F48F-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B24101440750
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B31101440603
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y170001NK010K
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 002 910 14
Serial number: 35700000000CC251911F
Subsystem 5 - Part No SW: ----------- HW: 480 002 910 14
Serial number: 358000000005D251911A
Subsystem 6 - Part No SW: ----------- HW: 480 402 210 14
Serial number: 3510002A71811BA6217X
Subsystem 7 - Part No SW: ----------- HW: 480 402 210 14
Serial number: 3520002BF1811BA221D2
Subsystem 8 - Part No SW: ----------- HW: 480 402 808 14
Serial number: 3550002C117750B5B0D2
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 808 14
Serial number: 3560002BD17750B17294
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 29101408490893
Coding: A018
ROD: EV_SMLSKLOMQB_010_AU37.rod
VCID: 0A4DA4E78CB2C707971-805E
Part No SW: 8V0 920 970 S HW: 8V0 920 970 S
Component: KOMBI H02 4291
Coding: 0BED181B3B88D7050201EA001800000000000000
VCID: 4CC162FFC646993765D-8018
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 09101410801284
Coding: 0101000830085A005B00022C980B00000001010000000000000000000000
ROD: EV_GatewConti_011.rod
VCID: 72BDDC078422AFC7CF1-8026
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 17 10 2014 F0047977
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00009.09.14
Coding: 0001
VCID: 46D550D7D82A6367B39-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000289953001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311A1FBEB6E1F71DD-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0349650714
Coding: 030211
ROD: EV_LaneChangAssis_VW51.rod
VCID: 38292E2FA2DE0597315-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0348785158
Coding: 030211
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 28101403111695
Coding: 005D1F205C00048000000002
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8106
Shop #: WSC 36712 002 1048576
ROD: EV_SteerAssisMQB_013.rod
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 01111401100021
Coding: 005D17205E00048000000002
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 0122000123200400
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FDB453387F032AFF0F-806A
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 038 G HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302J0EB005869
Coding: 017301020000000021220002041A00102F000225010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201WF5
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000002091400010296
Component: Gracenote --- 3006
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 3039160F4AAEDDD7795-8064
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 141016200108
VCID: 7DA7FF3BCD7CE0BFA23-8028
Part No SW: 5Q0 959 395 D HW: 5Q0 959 395 B
Component: TSG HFS 020 0028
Serial number: 01101401101808
Coding: 004D17204000048000000002
Component: TSG HBFS 020 0028
Serial number: 01101402091994
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.2V)-----------
