ABS not functioning
shezza
Australia
C?ID=380750
So I purchased an A6 C7 last year with 100K on it. Had the rear brakes replaced as part of the roadworthy.
I had to emergency brake and the wheels totally locked up. I have tested it multiple times and there is no sign of the ABS existing.
I have made sure the fuse is there, I have checked for faults, it says the ABS is ok. No lights, no indication there is anything wrong. So strange with such a sophisticated car!
I posted elsewhere and someone picked up that there was a fault logged that the "Changing brake lining" mode was still activated. I imagine it couldn't be driven if this was so, plus the EPB has worked fine. I figure they started the car while it was still in the mode, then ended the mode, though the fault code was already stored. Anyway, for good measure, I cycled the modes, made sure it was closed, everything looks ok. Cleared the codes, nothing coming back up.
I did have the fault "Function Restricted due to Missing Message(s)" against the ABS, though I cleared it before saving (oops) and it hasn't come back since. Here is my autoscan... Any thoughts?
Thursday,26,March,2020,12:37:28:47930
VIN: WAUZZZ4G3CN093092   License Plate:
Mileage: 122088km-75861mi   Repair Order: 01
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 42 44 46 47 52
          53 55 56 5F 62 6C 72
VIN: WAUZZZ4G3CN093092   Mileage: 122088km-75861miles
Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 F    HW: 4H0 907 551
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---
   Coding: 0A250034052701020000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551F 001006
   ROD: EV_ECM30TFS0214G0907551F.rod
   VCID: 2C010460468084C745D-8078
   Part No SW: 4G1 927 156 D    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0011
   Revision: --H10---    Serial number: 0000000510
   Coding: 000001
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 2E050E68709CF6D76B9-807A
   Coding: 44A687012265E180CB00
   VCID: 3635260888CCCE17239-8062
   Part No SW: 4H0 907 064 BT    HW: 4H0 907 064 BT
   Coding: 05B82F06000000000000
   VCID: 7CA1F420F6E0D44795D-8028
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0810
   Serial number: 25111100040548
   Coding: 6621607828
   ASAM Dataset: EV_AirCondiComfoUDS 002044
   VCID: 270BFB4C5F66A79FA8F-8072
0378 - Coolant Circulation Pump
          B10D0 04 [008] - Internal System Fault
                    Fault Frequency: 7
                    Reset counter: 176
                    Mileage: 120636 km
                    Date: 2020.03.07
                    Time: 12:00:54
                    Voltage terminal 30: 14.63 V
                    Outside air temperature: 17.0 °C
                    Interior temperature: 31.68 °C
0379 - Supply Voltage Terminal 30 for Coolant Pump
          B11D5 01 [009] - Electrical Failure
                    Reset counter: 138
                    Mileage: 106130 km
                    Date: 2019.07.22
                    Time: 16:14:24
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001311026
   Coding: 0907A01009749FE00181008380001800CF9DC3082F080101000108542F01
   VCID: 6E85CE68B09CB6D72B9-803A
   Component: WWS57X 111027  H35 0051
   Serial number:         111031140043
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11794796
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 23 11 2011  00000278
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Serial number: 00000014111100010196
   Coding: 110000
   Serial number: 00000011111100010572
   Coding: 110000
   Serial number: 38788DD5000000000001
                    Fault Status: 00101100
                    Reset counter: 170
                    Mileage: 121850 km
                    Date: 2020.03.21
                    Time: 16:44:00
                    Reset counter: 170
                    Mileage: 121850 km
                    Date: 2020.03.21
                    Time: 16:44:00
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901132503196
   Coding: 280306
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D273924ADFA1D4FE23-8068
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG005K03N
   Coding: 30323436313330303534554A305234473053
   Serial number: 3575HRB405T0TGJE8PLU
   Serial number: 3585HRB405N0VP46591H
   Serial number: 3515JRB404R0R8AAMOF7
   Serial number: 3525JRB40650TGJI1OU9
   Serial number: 3554VRB405J0QBGIE12U
   Serial number: 3564VRB40650Q4PIJ09V
   Revision: 00000000    Serial number: 20141105000371
   Coding: 000034
   Shop #: WSC 52709 002 1048576
   VCID: 303910106A28E027795-8064
   Component: E221 - MFL  H08 0009
   Part No SW: 4G8 920 931 L    HW: 4G8 920 931 L
   Component: TBenRdw       H79 0416
   Revision: 28460177    Serial number: 658211111591017
   Coding: 33AF08000B010008010000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU57.rod
   VCID: 372B2B0C8FC6371F38F-8062
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000318662
   Coding: 00CD073000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 34311C009EB0DC071DD-8060
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790165884
   Voltage stabilizer:
   Serial number: 11324000529021200410
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Revision: AA001002
   Coding: 04028264747464545425363E
   VCID: 33331F1C9B3EDB3F047-8066
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0810
   Serial number: 24111100040944
   Coding: 02
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002022
   VCID: 2F3B136C7796FFDF60F-807A
   Revision: AA000000    Serial number: 00000016661804
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77ABEB0CCFC6F71FF8F-8022
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200ZBSU0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6B83C77C830E43FF0C7-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F16204E01620002080002
   Shop #: WSC 02312 785 00200
   VCID: 42DD4AD8D48462B79F1-8016
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000479077
   Coding: 101000010000
   Shop #: WSC 02263 002 1048576
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D3238BCD42A77C71-806E
   Revision: 00002001    Serial number: 0163704034
   Coding: 01000E2200B9040581300804000303000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO1413314Y
   Coding: 901E00
   Subsystem 2 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84183890
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 131
                    Mileage: 121896 km
                    Date: 2020.03.22
                    Time: 20:13:10
   Revision: CJ007001    Serial number: 00000000007609
   Coding: 030000
   VCID: 1D67D9A40DBA7D4FC23-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41DF45D4D18279AF86B-8014
   Revision: --------    Serial number: 00000000193815
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D02784C749AF7B71-807E
721152 - Brake Pad Replacement Mode Active
          C1011 00 [000] - -
   Serial number: 111027-0002-016
   Coding: 1121A6601000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227K 0B7510655
   Coding: 040003010000000001
   VCID: 211FE55431C259AFE6B-8074
   Part No SW: 4G0 035 754 G    HW: 4G0 035 754 A
   Component: H-BN-RW       H48 0484
   Revision: --------    Serial number: 430KU0B7512281
   Coding: 050A01000003E1EF45008F2E00000003FC0001020000000000
   VCID: 2A0D02784CF49AF7B71-807E
   Subsystem 1 - Part No: 8R0 060 884 AJ
   Component: ROW 2012  0403
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Serial number: AUZ8ZDB13024HVS
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Serial number: 90349KKC000B3
   Component: CD-Database  3638
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204001620002080002
   VCID: 44D14CC0CE906C87ADD-8010
   Revision: --H04---    Serial number: 525 PA8J1YG2UP
   Coding: 1080004
   VCID: 2615F64854ECBE97939-8072
   Component: TSG HR        H04 0212
End----------(Elapsed Time: 02:03, VBatt start/end: 14.7V/14.8V)-----------
Have you function-tested the ABS again on gravel road or other slippery surface since you made the adjustments described above?
shezza
Australia
C?ID=380750
With very high hopes, yes. To no avail!
Strange I see the ABS module was updated, did you try to recode and default module after resetting all then reboot with all adaptations done & run the road tests again, plus post a fresh auto-scan?
AIB Wolfgang
Hello
Please look for
Stop this function and run basic settings.
Stay healthy
Please look for
I think the OP stated he had already fixed that. :confused:
shezza
Australia
C?ID=380750
I am a VCDS newbie, that is all gibberish to me unfortunately... Could you simplify it for me please? :)
Here is my current auto-scan. Not sure what "please not just reposted with ABS defaulted" means. I don't know how to do anything really besides run the auto-scan and follow basic instructions at this stage.
Thursday,02,April,2020,16:44:00:47930
Mileage: 122411km-76062mi   Repair Order:
VIN: WAUZZZ4G3CN093092   Mileage: 122411km-76062miles
   Revision: --H07---
   VCID: 2C010460468084CBDFA-8078
   Coding: 000001
   VCID: 2E050E68709CF6DBF1E-807A
   VCID: 3635260888CCCE1BB9E-8062
   VCID: 7CA1F420F6E0D44B0FA-8028
   Coding: 6621607828
   VCID: 270BFB4C5F66A793328-8072
                    Fault Frequency: 9
                    Reset counter: 151
                    Mileage: 122199 km
                    Date: 2020.03.28
                    Time: 14:34:04
                    Voltage terminal 30: 13.64 V
                    Outside air temperature: 25.0 °C
                    Interior temperature: 28.00 °C
   VCID: 6E85CE68B09CB6DBB1E-803A
   Coding: 0045F7
   Coding: 02512B
   Coding: 110000
   Coding: 110000
   Coding: 280306
   VCID: 3D273924ADFA1D43784-8068
   Coding: 000034
   VCID: 303910106A28E02BE32-8064
   VCID: 372B2B0C8FC63713A28-8062
   Coding: 00CD073000
   VCID: 34311C009EB0DC0B87A-8060
   Voltage stabilizer:
   Revision: AA001002
   VCID: 33331F1C9B3EDB339E0-8066
   Coding: 02
   VCID: 2F3B136C7796FFD3FA8-807A
   VCID: 77ABEB0CCFC6F713628-8022
   VCID: 6B83C77C830E43F3960-803E
   VCID: 42DD4AD8D48462BB056-8016
   VCID: 3A2D3238BCD42A7B5D6-806E
   Coding: 901E00
                    Reset counter: 142
                    Mileage: 122199 km
                    Date: 2020.03.28
                    Time: 16:01:04
   Coding: 030000
   VCID: 1D67D9A40DBA7D43584-8048
   VCID: 41DF45D4D18279A31CC-8014
   VCID: 2A0D02784C749AFB2D6-807E
   VCID: 211FE55431C259A37CC-8074
   VCID: 2A0D02784CF49AFB2D6-807E
   VCID: 44D14CC0CE906C8B37A-8010
   Coding: 1080004
   VCID: 2615F64854ECBE9B09E-8072
End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Did you read about default of control units & "battery Jesus" reboots?
Did you power down reboot entire car?
Did you recode the ABS module with same coding and different WSC & tester number yet with VCDS?
shezza
Australia
C?ID=380750
I honestly have no idea where to start.
Where would I read about the default of control units and battery jesus reboots? My searches are coming up empty...
What is a power down reboot? And what effect am I trying to gain? What is prompting me to do it?
I don't know how to recode the ABS module and I wouldn't be doing it as I have no idea what I am doing.
Absolute VCDS newbie, I really need functional ABS though... It has saved me once before on another car.
PetrolDave
Westbury, UK
C?ID=1423
Think like a company IT person - what do they recommend when something strange happens with a PC? Turn it off and back on.
Well to do that with the modules in a car you have to disconnect the battery, wait for all the capacitors in the modules to discharge (say 5 minutes) and reconnect the battery.
shezza
Australia
C?ID=380750
I'll give it a go! I've read about people going to great lengths to avoid the reset when changing their battery. What would be the reason? Save having to modify their settings again? 🤔
PetrolDave
Westbury, UK
C?ID=1423
I'll give it a go! I've read about people going to great lengths to avoid the reset when changing their battery. What would be the reason? Save having to modify their settings again? 樂
Some things, like the yaw sensor, may need recalibrating (usually a simple process of just turning the steering wheel lock to lock sometimes while driving round in a circle) - but that's a small "price to pay" if it clears DTCs that won't go away despite the conditions that caused them having been corrected.
shezza
Australia
C?ID=380750
Thanks Dave, the car seemed to save everything somewhere. Even did 8 minutes for good measure! So I took it for a drive and did a heap of skidding stops on the wet road. Who would of guessed it, I feel pretty sick now:facepalm:
Though some interesting results! So the ABS would kick in (id feel what I call a grinding under the pedal) and then a second later, total lock on the wheels. Some extra bits in my auto-scan, but I suppose thats related with the battery disconnect.
So partial ABS activity, but not total... :confused:
Saturday,04,April,2020,17:43:14:47930
VIN: WAUZZZ4G3CN093092   Mileage: 122503km-76119miles
   Revision: --H07---
   Coding: 000001
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 197
                    Mileage: 122502 km
                    Date: 2020.04.04
                    Time: 17:32:10
   Coding: 6621607828
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 197
                    Mileage: 122498 km
                    Date: 2020.04.04
                    Time: 00:01:46
                    Voltage terminal 30: 12.16 V
                    Reset counter: 196
                    Mileage: 122490 km
                    Date: 2020.04.03
                    Time: 23:50:37
                    Voltage terminal 30: 14.34 V
                    Outside air temperature: 15.5 °C
                    Interior temperature: 26.00 °C
                    Fault Frequency: 24
                    Reset counter: 157
                    Mileage: 122199 km
                    Date: 2020.03.28
                    Time: 14:34:04
   Coding: 0045F7
   Coding: 02512B
   Coding: 110000
   Coding: 110000
   Coding: 280306
   Coding: 000034
   Coding: 00CD073000
   Voltage stabilizer:
   Revision: AA001002
   Coding: 02
   Coding: 901E00
                    Reset counter: 142
                    Mileage: 122199 km
                    Date: 2020.03.28
                    Time: 16:01:04
   Coding: 030000
   Coding: 1080004
End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.5V. VIgn 11.5V)-----
Is there air in system or a mechanical error with a caliper?
shezza
Australia
C?ID=380750
The braking seems perfectly ok though. They are great brakes to be accurate! So if there was air in the system, wouldn't it affect my braking performance? I guess it can't hurt cracking the bleeder on the master cylinder and see if I get a steady flow. Though as far as a mechanical fault, I wouldn't even know where to start!
shezza
Australia
C?ID=380750
So I recently painted all my calipers, removed the front brakes, only to find the sliding pins were not attached very well. Seems the caliper was just hanging there, shocker mechanics! Anyway, I cleaned up the thread, bolted it back on, my squealing has gone which is nice, though the issue is still there. I have been trying a variety of braking and have found the following. Under heavy braking, I get full lock, no ABS. If I release during the lockup and go back on the brake, I get full ABS. If I brake juuust hard enough to break traction, light abs involvement, no lock up unless I apply more pressure.
I started thinking, I changed a few settings in the VCDS, though anything I was messing around with, I changed back. That is how I recall it... Though I figure, worth asking the question. Any idea whether or not messing around with the wrong setting could cause such issues? I was modifying in the Long coding helper. I suppose the only way to reset my settings is through the dealership?
PetrolDave
Westbury, UK
C?ID=1423
Not so, VCDS keeps log files of coding and adaptation changes - so you can look at those and revert back to the previous settings yourself.
shezza
Australia
C?ID=380750
Thank you Dave, that was very helpful! After I made all the changes and closed the app, I checked the logs and they had not been updated. Why might this be? I have verified that I did make changes...
While we are here. There is an emergency braking channel which looks to be active, even though I don't have any of the additional sensors to sense an impending collision. Any idea when it might be used? Intensity is at 6 and it is braking front and rear (even though I only have the powered brake in the rear by the EPB). Is it simply a seemingly active channel, but it isn't actually of any purpose?
