2012 VW Tiguan Rear Left Door Module
alexG
C?ID=48119
Hi guys. i've been reading through this forum and i seem to have the same problem. MY rear passenger door non responsive. however the window is work from the rear switch but not from driver switch .On the dash panel the door open all the time , interface cannot even access the door module! this is what comes up:
Pleas look on my full scan with any help pleas .
Saturday,21,March,2020,13:28:35:58365
VCDS Version: 19.6.2.2
VIN: WVGBV7AX5CW545803   License Plate:
Mileage: 84040km-52220mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 25 2B 2E 36 37 42 44 46 47
          4C 4F 52 53 55 56 69 6C 72 77
VIN: WVGBV7AX5CW545803   Mileage: 84040km-52220miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 029 P    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2    1519
   Revision: P3H07---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 39411 001 1048576
   VCID: 448CFDB00778226FC1-8010
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 84043 km
                    Date: 2014.08.12
                    Time: 03:18:30
                    RPM: 708 /min
                    Load: 21.2 %
                    Temperature: 65.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.478 V
Readiness: 1110 0101
   Part No SW: 09G 927 750 LR    HW: 09G 927 750 LR
   Component: AQ 250 6F           1971
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 0C1C15906FA8AA2FC9-8058
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VDB7 0005
   Revision: --H07---    Serial number: 00000005029145
   Coding: 0005161
   VCID: 79F25C44303AAF87E2-802C
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Revision: 00085000    Serial number: 0158565923
   Coding: 030C0C
   VCID: 346CAD709FD892EF71-8060
   Part No SW: 5K0 907 044 FE    HW: 5K0 907 044 FE
   Revision: 00001004
   Coding: 0000001002
   VCID: 73EE6E6CDA56D5D7A8-8026
13636096 - Supply voltage
          U1012 00 [008] - Voltage too High
                    Reset counter: 222
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:10:07
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0064
   Revision: BJ021001
   Coding: 6F180A1B88232EC4008800C134000D4448550006576D8DF0E4840000A040
   VCID: 3F86F25CAE9E41B79C-806A
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 21111  013 0203
   Serial number: N1955119   °203!
   Coding: 009795
   Component: RLS 091111 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 23016000    Serial number: 003GJPQ3HYU1
   Coding: 0012340
   VCID: 4A90D388255CF41F3B-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000007AZA
   Subsystem 3 - Serial number: 0013.10.110000300000630045ÿ†63
   Subsystem 4 - Serial number: 630045ÿ†6332MTS642333041 ÿ†63
   Subsystem 5 - Serial number: 33041 ÿ†6342MTS677743031 ÿ†63
   Subsystem 6 - Serial number: 43031 ÿ†6351HTS6UA8C0AKJ ÿ†63
   Subsystem 7 - Serial number: C0AKJ ÿ†6361HTS6UAIJV9KR ÿ†63
   Subsystem 8 - Serial number: JV9KR ÿ†63727TS6PSJG1AKJ ÿ†63
   Subsystem 9 - Serial number: G1AKJ ÿ†63827TS69K9O1AKJ ÿ
   Subsystem 10 - Serial number: O1AKJ ÿ
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190815100369
   Coding: 7982A00000
   Shop #: WSC 01286 386 08256
   VCID: 02003BA895ECEC5FB3-8056
   Serial number: 0713206
   Coding: 820000
147464 - Terminal 15
          B1148 29 [009] - Signal Implausible
                    Reset counter: 183
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:19:07
          B1149 13 [009] - Open Circuit
                    Reset counter: 182
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:19:07
   Part No SW: 5N0 920 972 E    HW: 5N0 920 972 E
   Coding: 211F01
   VCID: 356A907494A28BE746-8060
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 101111F2001787
   Coding: 356002
   VCID: 3D7A8854A49253A78E-8068
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4D9AD894D432E3271E-8018
   Coding: 000007
   VCID: 6AD073088D9C141F1B-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000220881002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E58BF1871F4B83F07-807A
   Revision: A1001003    Serial number: 7661315134
   VCID: 29524C04401ADF07D2-807C
   Part No SW: 561 959 760 A    HW: 561 959 760 A
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000015901790
   Coding: 00581B0000000000000001010101202020202121202020
   VCID: 21425424382A17478A-8074
00532 - Supply Voltage B+
                    Fault Status: 00100001
                    Reset counter: 222
                    Mileage: 84043 km
                    Date: 2014.08.12
                    Time: 03:10:07
   Part No SW: 3C8 035 684 E    HW: 3C0 035 684 E
   Component: RNS-MID       H61 3690
   Revision: AB001001    Serial number: VWZ6Z7L4320034
   Coding: 0405000201000086000C
   Shop #: WSC 23320 444 105100
   VCID: 2D5AB81474F2C3273E-8078
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0503
   Revision: 12110009    Serial number: 0003879431
   Coding: 0015BE
   VCID: 39729C44B8BA6F87A2-806C
65538 - Local Data Bus
          U10BA 00 [009] - No Communication
                    Reset counter: 183
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:21:48
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 1002
   Revision: 1AH03836    Serial number: 00113190504201
   Coding: 0000258
   Shop #: WSC 46140 001 1048576
   VCID: 3C7C85507F885AAFB9-8068
   Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
   Component: KonzernAmp 8K H07 0368
   Revision: --------    Serial number: EAA085A0003230
   VCID: 29524C04481ADF07D2-807C
9463315 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 182
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:10:08
13893888 - Function Restricted due to Excessive Voltage
          U1401 00 [008] - -
                    Reset counter: 222
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:10:06
   Component: EZE_2         H40 1623
   Coding: 050B0500
   VCID: 6FE6621CBE7EF1374C-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0503
   Revision: 14110009    Serial number: 0003853095
   Coding: 0015BE
   VCID: 3A708348BDBC649FAB-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1504
   Serial number: 00000006142734
   Coding: 000490
66821 - Position Sensor for Mirror Adjustment
          B11FA 29 [009] - Signal Implausible
                    Reset counter: 183
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:23:09
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000424438
   Coding: 0026156
   VCID: 356A90745CA28BE746-8060
   Component: AFS-ECU       H04 0111
   Coding: 041A00010B000400
   ROD: EV_HeadlRegulVWAFSPt_VW32.rod
   VCID: 37769A7C8EAE79F754-8062
   Subsystem 1 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
   Subsystem 2 - Part No: 4H0 941 329   Labels: 3D0-941-329.CLB
5275927 - Power Output Module for Left Headlamp
          C1081 17 [008] - Voltage Too High
                    Reset counter: 222
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:10:07
5276183 - Power Output Module for Right Headlamp
          C1082 17 [008] - Voltage Too High
                    Reset counter: 222
                    Mileage: 84043 km
                    Date: 2020.03.21
                    Time: 03:10:07
   Revision: 3A001001    Serial number: 00000162080663
   Coding: 420D000100000000
   VCID: 3064A16063C0AECF15-8064
   Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
   Revision: 00H09000    Serial number: 525PA8-J196566
   Coding: 0110010
   VCID: 2D5AB814B4F2C3273E-8078
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661332690
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 27564A3C5E0EE977C4-8072
End-------------------------(Elapsed Time: 04:09)--------------------------
Hi and welcome.
Rear door modules on this vehicle are not directly addressable; instead they are "slaves" of the respective front door modules. See for example your right (passenger) side:
   Coding: 0015BE
   Slave Passenger:
   Coding: 000490
I've highlighted the rear module on that side. But on the other side you've got:
   Coding: 0015BE
This means the front module has no communications with the rear module. Since you say the rear window works from the switch in that door, it would seem the module is not "dead", but that the most likely problem is a break in the LIN bus wire that the front module uses to communicate with the rear.
Danners74
C?ID=273244
Hi and welcome.
   Coding: 0015BE
   Slave Passenger:
   Coding: 000490
   Coding: 0015BE
Spot on. These are getting to that age where the door harnesses are breaking up.
alexG
C?ID=48119
Thanks my friends .will check all wires on the doors .
alexG
C?ID=48119
Hello. No luck steel the problem .
Can you guys tell me , if the latch is bad ,can it make can bus communication problems?
I tried on the passenger front door change the coding .then i getting same code like on the left door Powertrain Data Bus .
Dana
Western PA, USA
No, I can't say I've ever had bad door latch take down Comfort CAN. I think you have a wiring issue as per Danners74's suggestion.
You will need to check a wiring diagram as per Jack's suggestion but I want to make sure I understand your testing correctly. You removed the Right Front #52-Passenger module and plugged in into the Left (Driver) front door harness. The scan in that condition showed the same Local Data Bus DTC under address 52 at that point correct?
If so, the problem is not with the #42 front module IMO. Rather, there is likely an issue with the LIN from front to rear and that could be in either harness but I would check the front closely since that gets opened and closed far more frequently. Another possibility is that the left rear module is faulty.
Edit; If in fact you have swapped the left/right front modules and still have door panels removed you might plug the #42 module into the right side of the car to verify the rear slave communicates. Doing so should confirm that the 42 module is OK in regards to LIN. You could even do the same with the rears but I don't know if you want to pull all 4 panels.
alexG
C?ID=48119
Thanks . I have 3 rear door modules from recycle cars and all 3 modules akting the same Window working but lock is dad on rear left and not showing door open on the dush
Dana
Western PA, USA
OK, as long as they were all compatible then it sounds like you have ruled out a left rear module specific problem.
Swapping the front units left/right is still an option but your time may be better spent checking that LIN wiring in each left side door.
