Replacing CAN gateway
MAJones89
C?ID=373177
I'm replacing my current gateway for one with extended CAN to allow retrofitting of a few extra things.
The extended CAN gateway is used and has therefore previously been coded. I've changed the installation list, using the tick boxes, to the same as it was in my original gateway.
Should i copy the exact coding from the original to the new one as they’re different? All of the known items in the long coding helper are the same.
Should i copy across the battery data in the long adaptation as well?
Both module scans below.
Original:
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y152100C45
Coding: 80CF07FF00
Shop #: WSC 06325 000 00000
VCID: 4ACD6203DCB72077571-801E
Serial number: 5458155803
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 15040000605021200410
New extended CAN:
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z146190977
Coding: 80E3031600
VCID: 4CC1641BD6C33E4765D-8018
Reset counter: 234
Mileage: 75666 km
Date: 2020.03.16
Time: 13:49:03
Bin. Bits: 10111
Voltage: 11.70 V
Count: 6
Text: FF74742C00828100
Text: 0000000000000000
Raw, Form. N/A: 000 000 000
DV52
C?ID=194404
MAJones -I assume that the new module is compatible with the car - Can't tell because there is insufficient data in your autoscan (why not post-up the full UNEDITED scan result?).
Yes, replicating the values from the old module to the new Gateway module is a good first-step (both long code and adaptation channel). But this is only a first step -it won't deal with the Component Protection error in your part-autoscan result .
To delete CP DTC, you will need to visit a dealer, or a registered agent with access to FAZIT (it's a type of remote comms connection to the mothership)
MAJones89
C?ID=373177
Full scans below, i didn't think it would all be required.
My understanding of changing the battery data in the adaptation channel is that it will 'reset' the module into thinking the battery is new? Which it wont be.
I've arranged for the component protection to be removed by an authorised agent.
Original:
Saturday,29,February,2020,15:01:37:33426
VIN: WAUZZZ8T2FA048289   License Plate:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 5F 62 69
          6C 72
VIN: WAUZZZ8T2FA048289   Mileage: 74940km-46565miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 KL    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 0A254012243601080000
   Shop #: WSC 24483 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018KL 003009
   ROD: EV_ECM20TDI01103L906018KK.rod
   VCID: 7EA5FED3D07F5CD7BB9-802A
   Part No SW: 8K9 927 156 S    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0005
   Revision: --H03---
   Coding: 000001
   ROD: EV_TCMDL501021.rod
   VCID: 4DC7691F2D59374F723-8018
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 35DDCC01
   Shop #: WSC 06325 123 12345
   VCID: 094F9D0F99316B6F9EB-805C
   Part No SW: 8K0 907 064 KE    HW: 8K0 907 064 KE
   Component: BCM2 2.0      H15 0711
   Coding: 01B44040000000000000
   VCID: 7DA7F9DFDDF947CFA23-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0515000015944001
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 3215000026633001
   Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
   Revision: D1000000    Serial number: 01160220152780
   Coding: 342402E000
   VCID: 6A8DC283BC77C077771-803E
   Revision: 08016001    Serial number: 00001004059602
   Coding: 260000108034AFE00781408300001D0D039D634827090201000008004400030100000034000000
   Shop #: WSC 01211 210 01254
   VCID: 78A9E8CBF2DB62E7F15-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 090215  H13 0080
   Serial number: SWF15022095188
   Coding: 00FD31
   Serial number: 20129513
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001102150507
   Serial number: E4B88397000000000001
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC5WB1Q
   Coding: 30533938363030303030554A305238543053
   VCID: 48C9580BC23BD267415-801C
   Serial number: 6334MSME4E192A63M
   Serial number: 6344MSME4E3D7104K
   Serial number: 6352QSME764D1B66V
   Serial number: 6362QSME2E501264C
   Serial number: 63732SME7F4D21468
   Serial number: 63832SME7F4D20604
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OBD0002D
   Coding: 000036
   VCID: 48C9580BC2BBD267415-801C
   Part No SW: 8T0 920 984 K    HW: 8T0 920 984 K
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5L+3APA2G
   Coding: 33A7310003012600010400
   VCID: 47CB5B37CFA5DD1F48F-8012
   Coding: 80CF07FF00
   Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
   Component: TSG FA        H10 0305
   Coding: 011D02624001450005
   VCID: 57EB8B771F054D9FD8F-8002
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0011502315
   Coding: 100000010001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E253ED390FF9CD7FB9-806A
   Revision: 00002001    Serial number: 0360423804
   Coding: 013F0622A0B900008320043680000047
   Revision: 00005001    Serial number: 94813040423706
   VCID: 2D07099F4D19174F523-8078
   Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
   Component: TSG BF        H09 0305
   Coding: 011D02224001450005
   VCID: 56F58673180F7497C39-8002
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000333833
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D32C38CD7B0F7C71-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109BK0F8010341
   Coding: 010103010000000001
   VCID: 2B030787730D197F4C7-807E
   Part No SW: 8R2 035 666 J    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 0941
   Revision: --------    Serial number: 515BS0F7512306
   Coding: 130101040006A1ED0180AB5E00000403E40000020000000000
   Shop #: WSC 55837 003 1048576
   VCID: 40D9402BEA8BEA27895-8014
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Component: DU7 High  H42 0104
   Serial number: A130BT0F3261668
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002127159
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C02224001450005
   VCID: 59EF8D4F69115BEFEEB-800C
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Component: Anhaenger     H12 0100
   Revision: 1A001001    Serial number: 00000360403068
   Coding: 010D000000000000
   Shop #: WSC 25381 000 00000
   VCID: 363526F3B84F5497239-8062
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J3940QN
   Coding: 1032010
   VCID: 34311CFBA23346871DD-8060
   Component: TSG HR        H08 0305
End----------(Elapsed Time: 01:53, VBatt start/end: 12.2V/12.2V)-----------
Extended CAN:
Monday,16,March,2020,13:54:17:33426
          6C 72
VIN: WAUZZZ8T2FA048289   Mileage: 75660km-47012miles
   Revision: 45H25---
   Revision: --H03---
   Coding: 000001
   Coding: 35DDCC01
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:30
   Coding: 342402E000
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:36
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:36
   Coding: 00FD31
   Coding: 02005D
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:35
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:35
13697280 - Component Protection
          U1101 00 [137] - Active
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:36
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:41:01
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:41:03
   Coding: 000036
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:35
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:35
   Coding: 80E3031600
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:49:03
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Fault Frequency: 7
                    Reset counter: 92
                    Mileage: 75414 km
                    Date: 2020.03.06
                    Time: 14:21:31
02615 - Fuel Tank Cap; Lock
                    Reset counter: 92
                    Mileage: 75414 km
                    Date: 2020.03.06
                    Time: 15:00:54
03219 - Access and Start Authorization
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:30
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:41
                    Voltage: 11.80 V
                    Temperature: 31.0°C
                    Temperature: 33.0°C
                    Bin. Bits: 00000100
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:42
                    Voltage: 11.80 V
                    Temperature: 31.0°C
                    Temperature: 33.0°C
                    Bin. Bits: 00000100
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:39
   Coding: 130101040006A1EF0580AB5E00000403E40000020000000000
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 19
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:45:29
                    Voltage: 11.90 V
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:41
                    Reset counter: 234
                    Mileage: 75666 km
                    Date: 2020.03.16
                    Time: 13:46:41
   Coding: 1032010
End----(Elapsed Time: 01:57, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
DV52
C?ID=194404
^^^^^ hmm........ so here's the thing - IMHO, you face a situation that's akin in some ways to the "prisoner's dilemma" in game theory (down here in the Antipodes we call it "f#cked if you do and f#cked if you don't" - please forgive my use of expletives!!) :)
As I understand (and I'm more than happy to be advised otherwise), the way that the CAN Gateway monitors battery charging - is that the adaptation channel variables establish the starting point for subsequent surveillance over time.
It is also my understanding (again, happy to be corrected) that what happens if the adaptation channels related to battery data are modified- is that the historic information is reset. If my understanding is correct, your new hex19 module will contain the historic battery profile of the car from which the module was extracted.
If you replace the battery information from the hex19 module in your car into the new module - you will cause the new module to reset its historic data related to the "other" car. Importantly, replicating the base battery information from your car into the retrofitted hex19 module won't (of itself) carry-in the historic usage data since that information resides in non-volatile memory in the firmware of the old hex19 module (which VCDS can't access)
So "f#cked if you do, and f#cked if you don't" (again, my apology for the expletives) - but really, if this is your biggest problem with the retrofit - you aren't doing too bad!!;)
I wouldn't worry about that too much. As Don pointed out, it's not gonna be "right" whether you do or don't, so IMO, you'd be better off making sure it has the correct battery parameters for the battery that's actually in the car.
In addition, I'll mention we have cars at RT that have repeatedly (and falsely) been led to believe that they've had a new battery installed during the course of our development and testing of VCDS and doing this doesn't seem to have had any negative effect on the battery or the car.
MAJones89
C?ID=373177
Thanks for you help.
I’ll change all the coding and battery data across
andyhud
C?ID=32695
You might find the SWaP codes will get wiped from the new CAN gateway when you remove CP.. (so things like Charisma and other "features" may get disabled).
I'm not sure on that for certain, but heard things like that before.
MAJones89
C?ID=373177
I'm not aware of any features on my car that require payment to VW to enable?
Charisma (ADS) has been retrofitted to the car but as far as i'm away didn't require activation from VW.
Is SWaP a new thing they've implemented to cash in on people adding features to their cars?
PetrolDave
Westbury, UK
C?ID=1423
Quite a few features on MQB platform cars are SWaP controlled.
MAJones89
C?ID=373177
I assume any features that the car came from the factory with will all be there once the CP is removed?
None of the retrofits on the car have required anything from VW, just enabling and coding with VCDS
PetrolDave
Westbury, UK
C?ID=1423
I assume any features that the car came from the factory with will all be there once thP is removed?
That's not true, there are many examples where people have fitted a new CAN gateway and the dealer only did CP removal which resulted in some features that were "fitted" at the factory being lost - so when CP removal is done it's important to insist that ALL FeC codes are also restored.
MAJones89
C?ID=373177
Good to know, thanks
DV52
C?ID=194404
MAJones: Your assumption will be correct if the master-tech (or more likely, her apprentice) @ the dealer correctly completes the CP error removal process! AFAIK, CP removal is a 2 x pass process involving the registration of the new module identity in the car's "CP constellation" list (and the removal of the old module from the list) and second, the re-establishment of FeC s (if needed) in the new module - which I suspect is pulled from data about the car's VIN from the FAZIT database.
But I agree that andy's suggestion is worth mentioning because it's not unknown for part two of the CP process to be missed (it happens!!). Perhaps it might be prudent to confirm that the SWAP authorization licenses have been re-established in the new module before paying what I'm certain will be an exorbitant amount of your money to the dealer for the CP error removal process - it can't harm
Powernut
C?ID=384686
Oppss posted wrong person
Powernut
C?ID=384686
Oppss posted on wrong post
