Issues with brakes after engine swap - CNNA 3.6 Vr6 onto a Mk6 Gti
Jragusa
Coral Springs, FL, USA
C?ID=77591
Mk6 gti was swapped with a CNNA engine from a CC, immo was defeated, car runs great but i'm having issues with brakes. car will progressively apply pressure to the brakes to the point that they locked up and car won't even move. If we drive with the Abs pump unplugged it's even worse. At first I suspected a mechanical issue but everything checks out, it leads me to believe that the Abs module if not happy with the new engine installed or it might be something that can be fixed with coding. Abs pump is looking for a transmission module and parking brake module that never came installed on the car before the swap. it started looking for both modules after the swap.
Here's the last autoscan, it was doing the same before performing Basic Adaptation, I tired that but it gives me an error code every time I go over the process, Car is being towed to Vw tomorrow to match Key and cluster to new Ecu.
Sunday,15,March,2020,10:40:01:33094
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWHU7AN4DE505171   License Plate: MATTMK6
Mileage: 110300km-68537mi   Repair Order: mattmk6
Chassis Type: AN-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWHU7AN4DE505171   Mileage: 110300km-68537miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (0-32-CNNA)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 AJ    HW: 03H 907 309 A
   Component: 3,6 FSI ULEV2 H04 1812
   Revision: MFH04---    Serial number: 00000000000000
   Coding: 001A0012242400000000
   Shop #: WSC 00015 115 00015
   ASAM Dataset: EV_ECM36FSI01103H906023AJ 002003
   ROD: EV_ECM36FSI01103H906023AJ.rod
   VCID: 6A98E21F8DFEAF1F1B-803E
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:06
                    Coolant temperature: 27 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 12.698 V
                    Battery voltage: 12680 mV
                    Engine torque: 0.0 Nm
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [039] - -
          [Data bus on board diagnostic interface - J533Read out DTC]
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:06
                    Relative load value: 77.53 %
4716 - No Communications with Parking Brake Control Module
          U0128 00 [039] - -
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:06
                    Voltage terminal 30: 12.486 V
4718 - No Communication with Transmission Control Module
          U0101 00 [039] - -
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:06
5523 - Engine Start Blocked by Immobilizer
          P1570 00 [167] - -
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:05
                    Voltage terminal 30: 12.651 V
                    Battery voltage: 12640 mV
Readiness: 1110 0101
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: 114B600C492200FD881306ED92220041B70000
   VCID: 78BCC857CB520D8F9D-802C
                    Reset counter: 242
                    Mileage: 110309 km
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 16390
                    Count: 44032
                    Count: 509
                    Reset counter: 242
                    Mileage: 110309 km
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 320
                    Count: 44032
                    Count: 509
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 242
                    Mileage: 110309 km
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 143
                    Count: 44032
                    Count: 509
                    Reset counter: 242
                    Mileage: 110309 km
                    Count: 3
                    Count: 14
                    Count: 28672
                    Count: 8195
                    Count: 44032
                    Count: 509
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 75A2C163D44070E786-8020
          B10AB F0 [009] - Too Low
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:03
   Part No SW: 1K0 937 086 L    HW: 1K0 937 086 L
   Component: BCM PQ35  M   104 0615
   Revision: 00104 AE
   Coding: 6D180A3B80272A04000800816000008441611F86530C8D60648002200040
   VCID: 393A0D53B0D8D487A2-806C
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:02
                    Voltage: 12.25 V
                        Term 50 Off
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4R010NSC
   Coding: 00003031
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 393A0D53B8D8D487A2-806C
   Serial number: 3572MSME532F2356ZZZY
   Serial number: 3582MSME67262356ZZZV
   Serial number: 3512QSME2E35727DZZZ1
   Serial number: 3522QSME043E727AZZZ$
   Serial number: 35527SME24596520ZZZ9
   Serial number: 35627SME19460922ZZZA
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:06
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:06
9445937 - Seat occupied recognition control module
          B1022 31 [137] - No Signal
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:14
9444629 - Safety belt switch - passenger side
          B101D 15 [137] - Open or Short to Plus
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:07
9483008 - Seat Occupied Recognition
          B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:22
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JID0005T
   Coding: 108A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72A8FA7FA52E67DFA3-8026
   Serial number: 0099878
   Coding: 820000
   Part No SW: 5K6 920 971 C    HW: 5K6 920 971 C
   Component: KOMBI         H04 0406
   Coding: 270900
   VCID: 3522016394C030E746-8060
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 180910F2001707
   Coding: E9801F0600161200000000
   VCID: 6D92E9037410B8277E-8038
03272 - Control Module for Audio Interface
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:08
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223RAD2B06
   VCID: 7EB0DE4F297633BFD7-802A
   Component: IMMO          H04 0406
Address 2E: Media Player 3
   Component: Tuer-SG         009 2117
   Coding: 0001078
   VCID: 312A3573A8A81CC71A-8064
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   Coding: 0001078
   VCID: 32283A7FADAE27DF63-8066
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2Q7105472
   Coding: 1600044004000A
   Shop #: WSC 127395 840 08317
   VCID: 46C076AFF126AB7FDF-8012
8 Faults Found:
00532 - Supply Voltage B+
                    Reset counter: 25
                    Mileage: 110309 km
                    Date: 2020.04.02
                    Time: 01:45:28
                    Reset counter: 25
                    Mileage: 110291 km
                    Date: 2020.03.17
                    Time: 00:00:51
                    Fault Status: 00101011
                    Reset counter: 16
                    Mileage: 110289 km
                    Date: 2021.03.02
                    Time: 00:07:15
                    Reset counter: 16
                    Mileage: 110289 km
                    Date: 2021.03.02
                    Time: 00:07:15
                    Reset counter: 16
                    Mileage: 110289 km
                    Date: 2021.03.02
                    Time: 00:07:15
                    Reset counter: 16
                    Mileage: 110289 km
                    Date: 2021.03.02
                    Time: 00:07:15
00625 - Vehicle Speed Signal
                    Reset counter: 16
                    Mileage: 110289 km
                    Date: 2021.03.02
                    Time: 00:00:18
                    Reset counter: 20
                    Mileage: 105311 km
                    Date: 2020.09.01
                    Time: 13:28:21
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668621423
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 32283A7F65AE27DF63-8066
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:05
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 242
                    Mileage: 110309 km
                    Date: 2020.03.15
                    Time: 17:49:05
End----------(Elapsed Time: 01:06, VBatt start/end: 12.6V/12.7V)-----------
I'm running out of ideas here, any help is greatly appreciated.
Well, the ABS module is definitely not happy with the this engine swap. It probably gets the notion that there should be an auto-trans from the ECU, which is also looking for it. Ideally, you'd put MT software in the ECU, but I'm not sure MT software exists for that ECU, since the cars that engine were installed in weren't sold with MTs (AFAIK).
However, none of this really explains how the brakes can be applying pressure and locking up. If this happens even with the ABS disconnected, it can't be the ABS doing that.
Jragusa
C?ID=77591
we tried unplugging the Abs module after it happened and it made it worse when driving, I never tried from the beginning to see if it will build pressure to the brakes. basically what it does is that when driving for a long distance it will progressively apply pressure to the brakes. I drove it while measuring brake pressure and it climbs up to 8 bar after 20 minutes of normal driving. it went up to 46 bar when we unplugged the abs module and drove it for an extra 5 mins. there are some considerable differences from this Abs system to the one fitted on the CC from where the donor engine is from (for example the abs system on the CC has a ABS return flow pump that is not fitted onto the Gti system). there is no MT software available for this ECU. I got it to make it run by 'tricking" the Ecu to think the car is in neutral to be able to start and run. I will try again with the abs module disconnected from the get go and post back results. I just had the hope that somebody had run into this issue before even with a non-swapped car but I can't seem to find anything even similar.
BerndR32
Michigan, USA
C?ID=369908
Jragusa, you have to change the coding to manual transmission:
