Update of 19.6.2 usb interface intermittent communications
CBZGTI
C?ID=311696
Yesterday my hex-v2 was operating properly.
Today I’m trying to upgrade my vin’s using a feature code. Every time I attempt to go into “config” I get blank boxes. Once in a while the adapter will show up, then the feature code I’m using says I must have CB: 04324+. Well my interface, when operational says CB: .4508.
I’m not sure why my interface is intermittent. I can see my interface sometimes but then I click update, and it stalls and loses comm with hex controller. I am directly connected to internet. Not WiFi, no change. I’ve switched USB ports many times with no help.
This seems to be an update error.
Thanks guys
Mike@Gendan
Swansea, UK
C?ID=57030
Have you tried another USB cable, just in case?
A standard USB printer cable will do
FWIW, the server thinks your VIN upgrade Feature Code has been successfully applied.
What does VCDS say about your license/VIN status?
