Frequent DPF Regen
SkilledMilk
C?ID=384876
Hello everyone. Been monitoring a possible problem with dpf regen on my Seat Leon (EA288, CUPA) for at least a year now with a standard OBD Bluetooth dongle and VAGDPF android app. I was noticing the regens were a bit frequent for the extended long runs that I do everyday so decided to monitor them.
Using the app, I've noticed that the soot mass increases normally in relation to distance travelled, but the car seems to regen regardless around the 90-110 mile mark. At this point the soot mass jumps from around 10 grams to 20+ immediately, indicating the dpf is full of soot which surely cannot be the case. I'm thinking it could be a sensor somewhere but there are no engine fault codes stored and no lights on the dash.
Been looking at upgrading from standard obd dongle to VCDS fir a while and decided to take the plunge!
Auto-scan from last weekend below, is there more detail I can provide from the VCDS that would help in this instance?
Saturday,07,March,2020,15:27:09:27913
VIN: VSSZZZ5FZER013603   License Plate:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F A9
VIN: VSSZZZ5FZER013603   Mileage: 238905km-148448miles
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EL    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 6068
   Revision: 83H22---
   Coding: 01190012032501080000
   Shop #: WSC 00049 770 00126
   ASAM Dataset: EV_ECM20TDI01104L906021EL 002004
   ROD: EV_ECM20TDI01104L906021EL_SK37.rod
   VCID: 73B3D8967B33F80FC47-8026
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 61543000000BAC
   Coding: 20EE8A923421096F007D060041C62904512C9000608294F400610060C003
   Shop #: WSC 00049 770 00105
   ROD: EV_Brake1UDSContiMK100ESP_033_SE37.rod
   VCID: 4BC360764343C0CF6C7-801E
   Part No SW: 5F0 907 044 D    HW: 5F0 907 044 D
   Component: Climatronic   H03 0705
   Revision: 00001K07
   Coding: 00100104200100011005000000101000
   VCID: 270BFCC6FF6BC4AFA8F-8072
263426 - Air Quality Sensor
          B10AF 31 [008] - No Signal
                    Fault Frequency: 20
                    Reset counter: 4
                    Mileage: 237129 km
                    Date: 2020.02.23
                    Time: 15:51:24
                    Voltage terminal 30: 14.2 V
                    Outside air temperature: 8.0 °C
                    System run time-Engine running time: 255 s
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011315200967
   Coding: 0B000842C24100DB0BA44000B1040328102A000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 48C95F7A52352BD7415-801C
   Subsystem 1 - Part No SW: 5F2 955 119     HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130514  041 0574
   Serial number:         130523095548
   Coding: 0BC5FD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY131002E6Y
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000056876045
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Serial number: 20386568
0531 - Footwell Illumination
          B11FF 01 [009] - Electrical Failure
                    Reset counter: 189
                    Mileage: 237125 km
                    Date: 2020.02.22
                    Time: 17:28:44
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
                    Reset counter: 189
                    Mileage: 237125 km
                    Date: 2020.02.22
                    Time: 17:33:13
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231314001398
   Coding: 0031051001
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: 3A2D35B21CD94947C71-806E
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PAN29GV
   Coding: 98CCC000000000005C0000CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B04A6477BAC6FB0F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 706 13
   Serial number: 3576U0000002801CBC0B
   Subsystem 2 - Part No SW: -----------    HW: 454 000 606 13
   Serial number: 3586U000000C62092D0A
   Subsystem 3 - Part No SW: -----------    HW: 454 800 506 13
   Serial number: 3516R600F7C01000000/
   Subsystem 4 - Part No SW: -----------    HW: 454 800 606 13
   Serial number: 3526R5A957B010000005
   Subsystem 5 - Part No SW: -----------    HW: 454 802 304 13
   Serial number: 3556VDEAA4D01000000T
   Part No SW: 5Q0 953 507 AC    HW: 5Q0 953 549
   Revision: --------    Serial number: 13061304221806
   Coding: 9400
   VCID: 77ABEC866F4B942FF8F-8022
   Part No SW: 5F0 920 961 H    HW: 5F0 920 961 H
   Component: KOMBI         203 2210
   Coding: 27A501002180260001083A00000000
   ROD: EV_DashBoardVDDMQBAB_008_VW26.rod
   VCID: 2E0509E2D09195E76B9-807A
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000718871
   Coding: 030100F40B087600EF0002E8080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear_009.rod
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Component: E221__MFL-PR6  H03 0100
   Serial number: 000000000A0428210513
   Coding: 002000
   Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
   Component: J367-BDM  H08 0192
   Serial number: 00000000004051588216
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000063455383
   Coding: 00100220D001020000001000
   VCID: 025D8D523489C187DF1-8056
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000260527
   Coding: 2D0000
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D273EAE0DF77E7FE23-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000063241395
   Coding: 00100220DC01020000001000
   VCID: 015F825E318FDA9FC6B-8054
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000235518
   Coding: 350000
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 5F0 035 869 A    HW: 5F0 035 869 A
   Component: MU-E--ER      635 5740
   Serial number: 30051300010498
   Coding: 04730000FF00000011110001000000002F0007860000010000
   ASAM Dataset: EV_MUEnt4CLGE 001025
   ROD: EV_MUEnt4CLGE_VW26.rod
   VCID: 2B0300F6E383E0CF4C7-807E
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 130514201902
   VCID: 6A8DC5F22CF939C7771-803E
End----------(Elapsed Time: 01:14, VBatt start/end: 14.9V/14.9V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Hello SkilledMilk and Welcome aboard!
Nice first post! :thumbs: :cool:
Rollux
New Zealand
C?ID=380572
Few things we would check here in our workshop that may not show up on a scan as preliminary:
Fuel Filter - when last changed? (every 2 years MAX)
Check for any minor boost/vacuum leaks
Check to make sure injectors are coded correctly
Any of these can affect how clean the fuel is burning and hence soot mass.
Also, the soot mass is not constantly measured, only every XX number of miles/minutes running, so it is possible you have a bad sensor. We do replace a lot of DPF sensors causing soot reading errors on VAG vehicles.
Hope that helps
Regards
Dan
HMC
C?ID=28246
Hi SkilledMilk,
What are the readings from the Differential Pressure Sensor KOEO and at idle?
Regards HMC
SkilledMilk
C?ID=384876
Thank you all for quick replies and suggestions.
I'm at work currently and will get the differential pressure sensor outputs from VCDS when home. As an update, I monitored the mode-6 non-continuous tests using the Torque app on my phone on the commute in this morning (approx 65miles, almost all on motorway at 50+mph) and the following screenshots are the results. I've used the app to do this in the past and those tests have never been ok in the time I've been monitoring. I have tried googling the codes but have come up short with what the failed values relate to.
As an aside, the mode-6 button on the VCDS software is greyed out and unclickable so for the time being I cant use VCDS for these tests.
Uhm, this is not the Torque App forum. ;)
Please post Measuring Value data from VCDS.
SkilledMilk
C?ID=384876
Noted, just an attempt to provide context! Home with VCDS in hand and the below are the outputs from the differential pressure sensor at KOEO, and at idle.
KOEO:
Wednesday,11,March,2020,20:22:49:27913
                Address 01: Engine  (04L 906 021 EL)
20:22:23
  IDE00433   Particle filter: oil ash volume 0.12 l
  IDE00434   Particle filter: soot mass calculated 5.36 g
  IDE00435   Particle filter: soot mass measured 8.72 g
  IDE07744   Particle filter: air pressure sensor 1 bank 1: raw value 4 hPa
  IDE07745   Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 0 hPa
Idle:
Wednesday,11,March,2020,20:23:44:27913
20:23:28
  IDE00434   Particle filter: soot mass calculated 5.37 g
  IDE07744   Particle filter: air pressure sensor 1 bank 1: raw value 23 hPa
  IDE07745   Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 19 hPa
