2018 RS3 lost ABS coding
Sharino
Canada
C?ID=135466
Helping a friend with his RS3, not sure what he did but lost the ABS coding. I found a similar scan online and tried applied the coding but it errors out.
Any ideas? I know my VCDS needs to be updated but hoping it will work for this ABS controller until i get the new one.
Here is scan:
Wednesday,04,March,2020,19:16:38:29920
VCDS Version: 19.6.2.2 (x64)
VIN: WUABWGFF8J1907136   License Plate:
Chassis Type  FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 4B 52 5F
          6C BB BC CF
VIN: WUABWGFF8J1907136   Mileage: 24720km-15360miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H22 0004
   Revision: 53H22000
   Coding: 0A250032242608053620
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D7B22A1AC054EA78E-8068
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [047] - -
                    Mileage: 24720 km
                    Time: 00:00:00
                    Coolant temperature: 15 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 13.480 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
4716 - No Communications with Parking Brake Control Module
          U0128 00 [047] - -
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:51:50
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 13.220 V
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 49
Readiness: 1110 0101
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07
   VCID: 2E5915ED7163A53F07-807A
21221 - No Communications with Parking Brake Control Module
          U0128 00 [047] - -
                    Fault Frequency: 8
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:51:51
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -48 Nm
                    Control Module temperature: 11 °C
                    Accelerator position: 16.0 %
                    DTC memory status: 73
   Part No SW: 8V0 614 517 E    HW: 8V0 614 517 C
   Component: ESC           H25 0625
   Revision: 00000000    Serial number: 61018000000038
   Coding: 00000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   VCID: 3B7F2CB9B2114097B0-806E
12 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
0295 - Steering angle sensor
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
4161 - Coding invalid
          U10DA 00 [008] - -
                    Reset counter: 225
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:29
8279 - Engine Control Module Incorrectly Coded
          P1612 00 [137] - -
                    Fault Frequency: 7
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
8280 - Engine Control Module Incorrectly Coded
          P1612 00 [137] - -
                    Fault Frequency: 7
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
8292 - Control Module Incorrectly Coded
          U1014 00 [137] - -
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
8299 - Databus
                    Fault Frequency: 6
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:23
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
                    Fault Frequency: 6
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:43:21
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0476943010
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C7D2FA5B71F47AFB9-8068
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001529018
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76E9FD8DC9B3DDFF8F-8022
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: 2E51532900PAG0MUFU03
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001808700157
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06098D4DB953CD7F9F-8052
   Component: WWS371 180316  043 0585
   Serial number:         180323002915
   Coding: 0A47F7
   Serial number: 21312970X81A955547A0
   Coding: 00006C
   Component: E1 - LDS MQB  H06 0032
   Serial number: 13 01 2018  00000428
   Serial number: 00000000000099667233
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST0021291F00000
   Coding: 101F00
204546 - Remote key 2
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 15:42:14
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018086
   Coding: 0470155011
   VCID: 4B9F7C79E2B1F01700-801E
12658704 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:51:50
13637426 - Databus
                    Reset counter: 184
                    Mileage: 24709 km
                    Date: 2020.02.29
                    Time: 11:37:06
   Serial number: 003GCR0A0C82
   Coding: 9DCCFCC0008000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47974049FED9147724-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34230167A12041820225
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34230168A12041820470
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001R080C
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 001 204 18
   Serial number: 35700000000AB95D7C2+
   Subsystem 5 - Part No SW: -----------    HW: 480 001 204 18
   Serial number: 35800000000C6D4D7C2%
   Subsystem 6 - Part No SW: -----------    HW: 480 400 904 18
   Serial number: 3510001A32968244941T
   Subsystem 7 - Part No SW: -----------    HW: 480 403 103 18
   Serial number: 3520001B92968244814-
   Subsystem 8 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3550002B3252D863119-
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3560002B3252D861F130
          B13BC F2 [137] - No function
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 19:16:59
1049093 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:58:11
1049094 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:58:11
1049095 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:58:11
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 12041804220591
   Coding: 2018
   VCID: 0D1BB261DC25BE27DE-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
   Component: FBenRDW       H16 0066
   Coding: 082D18532B8800080204EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3A7129BDBD2B799FAB-806E
16777014 - Tire Pressure Monitoring Module
          U0127 00 [009] - No Communications
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:58:13
16776973 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:51:54
   Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5323
   Serial number: 31031810520829
   Coding: 03010004340860005B00802E380B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 387533B583276B8F5D-806C
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180406154716 31314
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 1755497204
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00012.03.18
   Coding: 0601
   VCID: 4D9B72611CA5FE271E-8018
17505 - Databus
                    Fault Frequency: 8
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:51:50
   Revision: 00000000    Serial number: 18000107835004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346D07859F4F8FEF71-8060
   Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
   Component: MRR1Rear      H21 0610
   Revision: --------
   Coding: 040002
1192062 - Databus
                    Reset counter: 225
                    Mileage: 24709 km
                    Date: 2020.03.01
                    Time: 15:22:58
                    Control Module temperature: 24 °C
                    Voltage terminal 30: Measured value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 14.10 V
   Serial number: 200318ECJ19549
   Coding: 005D1B205C00048000000002
   VCID: 438F5459CAE13857F8-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 811E0000
   ROD: EV_SteerAssisMQB_015.rod
19204 - Databus
                    Reset counter: 225
                    Mileage: 24720 km
                    Date: 2020.03.02
                    Time: 18:37:57
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 12.00 V
                    Temperature: 23.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.22 V
                    uAdSensI_SwitchedKl30_xdu16: 12.14 V
                    NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
                    NoInitCause_RackPos_Rohwert: 00 00
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_KMN_RACKPOS_SET: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_WHLSPDPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
Address 47: Sound System (J525)       Labels:| 81A-035-466.clb
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5F01H6GZ
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 244DF7C52FAF1F6FE1-8070
Address 4B: Multifunc. Module
Interface not compatible.
   Serial number: 210318ECK25738
   Coding: 005D13205E00048000000002
   VCID: 4281515DD5FB315FF3-8016
   Part No SW: 8V1 035 880 D    HW: 8V1 035 880
   Component: MU-P-LNS-US   054 1196
   Serial number: A702C0JS007918
   Coding: 017361020000000011220002041A00002F0028E4017001047E
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Component: DU High  H49 0014
   Serial number: AUZ8Z9J1Y09TKV
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL130011800050025
   Component: Gracenote2  --- 3012
6919 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:58:12
                    Voltage terminal 30: 13.4 V
          U1111 00 [009] - -
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.01
                    Time: 18:58:15
                    BAP-BAP_Function_ID: 02
   Coding: 0273010102002001400040
   VCID: 397336B1B82D7287A2-806C
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 240318ECO01219
   Coding: 000C13204000048000000002
   Serial number: 240318ECO01258
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 05:20)--------------------------
Somnus
SLC, USA
C?ID=215931
First off, Did your friend/you run a scan prior to losing the coding? If so, it may be in VCDS' Scans folder
If not, looking at some RS3 scans, my best guess for the ABS code is
2EAA6B7DD4990BB089920B6740976974D62BD091D002963620415054828812
HOWEVER, not much is known about the 8V0 ABS modules, so use the above code knowing I can't guarantee it will be perfect or even be accepted.
If the car is untouched (unmodified). I HIGHLY recommend having the dealer run SVM to get you the 100% correct code.
DrPeter
16.4905° S, 151.7375° W
If the above does not work, please try the following ABS Coding:
2EAA6B7DD4990BB089920B6781976974D62BD091D081963602415054828812
If the coding is accepted, you will need to perform the Basic Settings in the ABS controller (see the fault codes) and use the [Security Access] code of (40168) to enable the Basic Setting function.
If you have any questions, please post a new Auto-Scan, so we can see if there was any progress.
Thanks and hope this helps, (Let us know how this works for you!)
drpeter
Sharino
Canada
C?ID=135466
Thanks, i will try the above 2 codes tonight. The owner's friend tried using a crappy 'Launch' tool which caused the coding to blank out, not sure at all what he did or why.
Sharino
Canada
C?ID=135466
Ok, so the second code above took, first one I got an out of range error. I did a full scan and cleared everything. This is what it shows now.
when you said to do Basic Settings do you mean the "resetting of all the adaption values"
Thursday,05,March,2020,18:52:12:29920
          6C BB BC CF
   Revision: 53H22000
   Revision: 00H06V07
   Coding: 2EAA6B7DD4990BB089920B6781976974D62BD091D081963602415054828812
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 18:46:29
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 18:46:29
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 18:46:29
32830 - Parking Brake Motors
          C10E1 29 [137] - Signal Implausible
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 18:46:29
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 18:46:29
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 18:46:29
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 101F00
   Coding: 0470155011
13637426 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 18:46:29
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303337
1049094 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 18:46:31
   Coding: 2018
   ROD: EV_GatewNF.rod
   Coding: 0601
   Revision: --------
   Coding: 040002
   Coding: 811E0000
19204 - Databus
                    Reset counter: 185
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 18:46:28
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 32.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 7F
                    uioUdNotFilt_xdu16: 12.41 V
                    uAdSensI_SwitchedKl30_xdu16: 12.34 V
End-------------------------(Elapsed Time: 05:05)--------------------------
No, definitely do not do that one!
There are a number of others, but I'm not sure anyone has developed a detailed procedure for this car yet.
Sharino
Canada
C?ID=135466
Yes, I didn't reset. I did go through and adapt everything I could. I am left with only parking brake issues now. I can activate the parking brake through VCDS but these codes constantly come back.
Thursday,05,March,2020,20:56:36:29920
          6C BB BC CF
VIN: WUABWGFF8J1907136   Mileage: 24722km-15361miles
   Revision: 53H22000
          U0416 00 [040] - -
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 19:09:44
                    Coolant temperature: 30 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 12.300 V
Readiness: 0110 0101
   Revision: 00H06V07
                    Reset counter: 185
                    Date: 2020.03.05
                    Time: 20:40:09
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Sun Roof:
   Coding: 101F00
   Coding: 0470155011
13637120 - Databus
                    Reset counter: 225
                    Mileage: 24722 km
                    Date: 2020.03.05
                    Time: 20:34:32
   Coding: 333135
   Coding: 333135
   Occupant Detection:
   Coding: 303337
1050117 - Databus
                    Reset counter: 225
                    Mileage: 24722 km
                    Date: 2020.03.05
                    Time: 19:35:32
1049094 - Databus
                    Reset counter: 225
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 18:46:31
   Coding: 2018
   ROD: EV_GatewNF.rod
   Coding: 0601
   Revision: --------
   Coding: 040002
1188165 - Databus
                    Reset counter: 225
                    Mileage: 24722 km
                    Date: 2020.03.05
                    Time: 19:35:33
                    Control Module temperature: 47 °C
                    Voltage terminal 15: 14.30 V
1192062 - Databus
                    Reset counter: 225
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 19:14:38
                    Control Module temperature: 40 °C
                    Voltage terminal 15: 12.50 V
267010 - Databus
                    Reset counter: 225
                    Mileage: 24722 km
                    Date: 2020.03.05
                    Time: 19:35:33
                    Voltage terminal 15: 14.20 V
   Coding: 811E0000
19204 - Databus
                    Reset counter: 225
                    Mileage: 24720 km
                    Date: 2020.03.05
                    Time: 18:46:28
                    Motor status: 00
                    KFC: 4B
                    KFA: 00 04
16130 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 190
                    Mileage: 24722 km
                    Date: 2020.03.05
                    Time: 19:35:32
                    Motor status: 01
                    Supply voltage: 14.25 V
                    Temperature: 30.0 °C
                    KFC: 3F
                    KFA: 00 02
                    uioUdNotFilt_xdu16: 14.44 V
                    uAdSensI_SwitchedKl30_xdu16: 14.36 V
End-------------------------(Elapsed Time: 05:03)--------------------------
Sharino
Canada
C?ID=135466
Have you done this?
IDE05335-ENG114972 -- Electro-mechanical parking brake function test
Yes, I did that test, I hear it work and it passes. But then next time I activate the parking brake, it blinks red non stop and I receive the errors as I show in the scan?!?
DrPeter
Interesting.... Glad the coding was accepted. You actually should consider upgrading to a newer Ross-Tech interface because....
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE​
In the meantime did you try the Basic Settings in the [03-ABS Brakes]
[Electro-mechanical parking brake function test]
This Basic Settings may need to be done so that the ABS controller can 'see' the operation of the EPB motors, it maybe necessary to depress the EPB Button first. Also, have the engine running or a battery maintainer to avoid any low battery voltage conditions as this may damage the controller.
You have a lot of [U1123-Databus: Received Error Message] fault codes, I would try and find out what the "friend" did ... exactly and with what tool/tools..??
This vehicle may have other issues and may have to have the SVM Test plan (Actual vs Specified) run on the vehicle like "Somnus" said.
Let us know how this works out and if it does go to the dealer, post up a new Auto-Scan so we can see what was done.
Thanks,
drpeter
edit... looks I was late to the party....
ref:
