MK7 Power Folding Mirror Mod Question!
Dr363305
OH, USA
C?ID=367732
Hello to all.
I've been following Humble Mechanic and I am considering doing the power folding mirror mod to my mk7 golf sportwagen tdi. However, when I went over to shopdap.com and went to the mirrors, it had a note stating that this mod may not work if you do not have the right door module. How do you know if you have the right door module? Is there a list somewhere that shows what modules support what? Does it mean anything if I have factory equipped heated mirrors?
Thank you!
Dr363305
OH, USA
C?ID=367732
Yes Sir, it is!
DV52
C?ID=194404
Dr363305: Being a citizen from the Antipodes, I'm not the correct person to reply to your question - but there's lots of dialogue on the net by "yanks" discussing this matter (for NAR model mk7's).
The crucial aspect of the mirror dip function is for the hex52 module to have a memory facility - which is needed to record the "X"/"Y" coordinates so that the mirror can return to the correct position when the car drives forward.
The table below may be of interest - it's for cars in your part of the world (its from bbjwvr6 on VWVortex site)
https://forums.vwvortex.com/showthr...st-for-USA&p=91865242&viewfull=1#post91865242
Dana
Western PA, USA
Per PL24 by VIN your 52 module appears to be 5Q0 959 592 B Z0U. That supers to a newer part number but this temp screen shot may be helpful:
https://media.trillian.im/media/?m=...jJBnPrcoYuVmTrvm0eapjDSXL1TeM/H/CjfJDFKEaNw==
If you intend on using that later make sure to save it because the link will expire at some point.
The PR-Codes for your vehicle are:
Vehicle Identification No.3VWFA7AU6FM508879
ModelGolf Variant 2.0 GOV
Date of production13.04.2015
Model year2015
Sales typeBX5212
Engine CodeCRUA
Transmission CodePFN
Axle drive6S
EquipmentTW
Roof color8E
Carpet color code
Exterior color / Paint Code8E / A7W
Seat combination no.
Number of Z-Orders
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PFStandard wheel bolts
Vehicle class differentiation units/platform components7IIVehicle class differentiation -5GM-
tail pipe0P1Rear side exhaust tailpipe
Hill start assistUG1Hill start assist
Emission standard7MUEmission standard LEV 3/Tier 3 125
Trailer hitch1D0Without trailer hitch
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E9without activated carbon canister with SCR
Storage compartment packageQE0Without storage compartment package/box
Storage compartment7N0Without overhead storage compartment
Aerials8L6"diversity" window antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SHLeft exterior mirror, flat (US)
Electronic engine sound measuresGM1Standard electronic engine sound
Right exterior mirror5RRRight exterior mirror, convex (US)
Alternative drive system0K0Without alternative drive system
Drive type1X0Front-wheel drive
Equipment levelsA8Bbasic outfit
Area monitoring systems6K0Without forward collision warning/ autonomous emergency braking
Brake type in rear1KQDisc brakes in rear
batteriesJ0NBattery 330 A (61 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DComponent parts set, complying with vehicle type for USA (without California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z212-V operating voltage and 115-V inverter
Brake pad wear indicator9U0Without brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD/DVD drive and SD card slotEC3With CD drive and SD card slot
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
"Charism"2H0Without "drive select"
Chrome packageQJ1Chrome package
General operating permit, alterationsC00Operating permit, initial registration
Roof rails/roof load rack3S2Black roof rails
Roof insert/convertible top3FUBig roof system
Suspension system in rear1JARear shock absorption, basic version 1
Suspension system in frontG07Shock absorption in front
Differential lock1Y3Differential lock (XDS) dynamic traction control
Insert for the filling up of unleaded fuel/fuel type2G5Filler neck module 1 without insert
ECO function for driving profiles and Drive selectEF0without ECO function
Installation differentiation for components0ENInstallation differentiation for transmission MQ 350 -- vehicle components --
Theft protection system7AAElectronic immobilizer
Inserts5MBDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Extended safety system7W0Without extended safety system
Electric interface for external useUQ3Electric interface for external use, with an iPhone4 adapter cable
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation9C9Separate daytime running light and automatic headlight control -NAR- with Coming Home and Leaving Home feature
Fresh air intake for passenger compartment (with particulate filter)2V5Fresh air intake system with combination filter
Parking brakeUH0Parking brake
Vehicle tracing system7G0Without preparation for VTS (Vehicle Tracing System)
Alternators8GUAlternator 140 A
Weight category rear axle0YJWeight range 9 installation control only, no requirement forecast
Weight category front axleL07Suspension range 07 installation control only, no requirement forecast
Base engineTR14-cylinder diesel engine 2.0 l unit 04L.A
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U2Sliding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Transmission specificationsG0K6-speed manual transmission
handle for hand brake lever6PCHand brake lever handle in leather
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear axle0N1Standard rear axle
Molded headliner6NAUnsplit molded headliner
Rear seats3NURear bench seat, not split, split backrest, folding centre armrest
Heating and air-conditioning systemKH6Air conditioning system with electronic control
Headlamps8IMGas-discharge headlamps with cornering light
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Body styleK8DWagon/Avant
Camera/distance sensorQK0Without camera without distance sensor (driver assistance system)
Refrigerator1W2Glove compartment cooling system
Folding table1U8W/o folding table on front seat backrest
Climatic zones0Y4Cold and tropical climatic zones (US)
Compass/road sign displayQR8without road sign recognition
Rear head restraints3Q9Three rear head restraints
Head restraints5ZFFront head restraints
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems0F5Fuel system for diesel engine
Body measures5C1Body measures for increased safety requirements
Camera systems/accident sensorsKA1With rear view camera system (type 1)
Radiator grille6KCRadiator grille
refrigerantKK1Refrigerant R134a
License plate lightingKL1LED license plate lighting
Rear license plate carrier6P2Rear license plate carrier (NAR)
Front license plate carrier6W3Front license plate carrier (small, NAR)
Paint preservative/transit coating5K7Transport protection film (minimum protection) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GDPlane luggage/load compartment floor in rear
Light package (lighting)QQ3Interior ambient lighting and surround lighting
Vehicle inletES0Without vehicle inlet
Steering system arrangementL0LLeft-hand drive
Reading lamp8S62 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Light control systems8G0Without Light Assist
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2ZHLeather-wrapped multi-function steering wheel
Driving on the left/on the rightAV2Driving on the right (NAR)
Speaker installation8RUSound system with subwoofer "branded"
Headlight range control8Q5Dynamic headlight range control, with cornering light (AFS 1)
Center armrest6E3Center armrest in front
VersionsFM0Basic equipment variant
Multi-function display/trip computer9S5Multi-function display/trip computer "Medium"
Center console3D2Center console
Driver alert systemEM0Without driver alert system
Engine cooling8Z6Hot country
Engine specificationsDN44-cyl. turbo diesel engine 2.0 l/110 kW (4V) TDI common rail; b.engine T37/T6F TS1/TR1/T0P/T0N/T13/T29/TM4/TD1/TI9/T1I
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WHFront fog lamp and cornering lamp
Online servicesEL2Online service, with OCU, without head unit coding, without engine immobilizer interconnection
Rear of platform module base4P3Rear floor panel module, type 4
Hubcaps1NLTrims for alloy wheels
WheelsC7JAlloy wheels 7J x 17
RadiosI8DRadio Standard (Gen1)
Smoker's/non-smoker's package9JFNon-smoker's package (NAR)
Regional code for radioER3Regional code " NAR " for radio
Tire pressure monitoring system7K6Tire pressure monitoring system
tireH7KAll-season tires 225/45 R17 91H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G9Space-saving spare wheel for temporary use, radial tire (5-hole)
Wheelbases0B1Wheelbase
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
P01Light package TSI and TDI SE, USA
W01TDI SE package, USA
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SCLabels in English
Tail lamp assemblies8SJRear combination lamp, standard design (NAR)
Service indicatorQI7Service indicator 10 000 miles or 1 year (fix)
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN4QSeat trim covers in leatherette
Seat adjustment3PTManual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Horns8Y1Two-tone horn
sun visors5XXSun visors with mirror, illuminated (NAR)
Audio-response system/voice controlQH1voice control
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KCSide and rear windows in heat-insulating glass
power outlet7B312-volt outlet(s)
Bumper2JBStandard bumpers
Rear stabilizer bar0BAWithout rear stabilizer
Front stabilizer bar0ADFront stabilizer bar
Drawers under front seatsQN1Drawer under left front seat
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N6Windshield wiper intermittent control with light/rain sensor
Nameplate set1DGNameplate set "TDI"
Mass damper for steering wheels1Q2Mass damper for steering wheel, 36 Hz
Door and lid locking system4F6Central locking system "Keyless Entry" without deadlock (NAR)
Type approval countries/countries with special requirementsBU1Legal requirements for USA 1 States without CARB requirement
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A24 doors
TV reception/digital radio receptionQV4Satellite radio reception USA
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Front seatsQ2JComfort seats in front
Rear seat catchUK3Mechanical rear seat release
Telephone / telematics9ZXTelephone preparation for cellphone
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E6Electric auxiliary air heater
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZNBright decorative trims
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
Dr363305
OH, USA
C?ID=367732
DV52, I am referring to the folding mirror body, not the reverse mirror dip. Are we talking about the same thing?
Dr363305
OH, USA
C?ID=367732
Also, please pardon my ignorance. While I am an advocate of "Google It", this to me is serious and I really do not want to adversely affect my car. I use this car as my daily and I really only want to alter a few things. So, once again, please pardon my ignorance.
TBAx
C?ID=287144
Since you didn't state what modification you want to perform, it was hard to answer any questions. Even now to me it is not absolutely clear what you're trying to accomplish.
If those mirrors already can fold, then tweaks including anything folding related should work. You can just try, it will not break anything and you should be able to revert it if it does not work or has unwanted side effects.
Dr363305
OH, USA
C?ID=367732
My apologies, I was under the assumption that "power folding mirrors" were separate from "reverse mirror dip" function. Please see below:
https://www.youtube.com/watch?v=R4N3i5xRGU8
Now, when I head over to here https://www.shopdap.com/make-model-...or/mirrors/mk7-gti-golfr-folding-mirrors.html , there is a note saying that a lower line door module will prevent this modification from functioning. All I wanted to do was verify if my door module supports this function before spending $350 on mirrors that will not work.
Sorry for the confusion.
TBAx
C?ID=287144
Thanks for your thorough description.
From the auto-scan in the post Uwe linked above I see this:
   Serial number: 141015BJD17145
   Coding: 003A13200000040000000000
   Shop #: WSC 28797 003 1048576
   VCID: 40D94179CA0AE657DED-8014
   Serial number: 00000000000000890109
   Coding: 011000
   Serial number: 030315060509XZ
   Shop #: WSC 01383 790 50316
   VCID: 3FDB4285B7F499AFA77-806A
   Serial number: 00000000000000852986
   Coding: 091000
I only copied the door module information. When you look at the ASAM Dataset for both of the modules, you see these being used:
Driver side (42): EV_DCUDriveSideEWMAXKLO 006003
Pass. side (52): EV_DCUPasseSideEWMAXKLO 006003
I marked the important part, which describe these door modules as "MAX" modules. Those to my knowledge support folding mirrors. The parts that do not support it have the letters "MIN" at the exact same position, see this example:
Adresse 42: Türelektr. Fahrer (J386) Labeldatei:| 5QX-959-X93-42.clb
  Teilenummer SW: 5Q0 959 393 B HW: 5Q0 959 393 B
  Bauteil: TSG FS 020 0025
  Seriennummer: 07111304080152
  Codierung: 00100E204100040000001002
  Betriebsnr.: WSC 06314 790 00021
  ASAM Datensatz: EV_DCUDriveSideEWMINKLO 006003
  VCID: 3E7751BDA18654BAEF-806A
  Türsteuergerät Fahrerseite hinten:
  Subsystem 1 - Teilenummer SW: 5Q0 959 811 HW: 5Q0 959 811 Labeldatei: DRV\5QX-959-81X-V1.CLB
  Bauteil: FOND_FHSG_DRV 005 0005
  Seriennummer: 00000000000001027413
  Codierung: 110000
So I guess you are good to go!
Dana
Western PA, USA
Thanks for the MIN/MAX tip Daniel. I also believe he will be OK but it might not hurt to firstly see if coding is accepted at all (Ref to the https://youtu.be/R4N3i5xRGU8?t=511 mark of that video) and results in the proper fault code(s) because the hardware isn't installed yet.
For instance, if either address won't even accept the coding changes then I would be less optimistic than that retrofit will be successful with the existing modules.
Dr363305
OH, USA
C?ID=367732
I cannot thank you gentlemen enough and the ross-tech community as well. You guys are all gentlemen and scholars.
Dr363305
OH, USA
C?ID=367732
If we assume that the door module isn't the correct one, do VW dealerships do module upgrades if paid for by the customer? I am clearly not intelligent enough to handle buying the correct module and coding myself.
PetrolDave
Westbury, UK
C?ID=1423
Not usually, their normal assumption that that retrofits and upgrades are impossible - except where the factory makes available a specific kit.
DV52
C?ID=194404
:) I really need to change that to an actual photo of me at some point.
Dana: no offense intended, but please don't - I like the semblance of steely determination on the "lego -girl": it kind-of suits my image of RT employees and their never-ending fight for truth, justice and the American way (or am I getting this mixed-up with something I saw on TV?)!! :)
TBAx
C?ID=287144
(I'm sorry for "off-topicing" this thread)
...then I propose this to be the new avatar for Dana:
