Lost abs coding help please (2006 3C Passat)
MezTech
Trinidad and Tobago
C?ID=380032
Hello everyone the customer attempted to change a comfort control module on his b6 passat in order to fix a door lock issue it did not fix the problem so he reinstalled his original unit and lost the coding for the abs module any assistance in getting it back would be nice I used the long coding helper to code it back but it keeps saying incorrect coding when I scan for faults.
Wednesday,19,February,2020,15:42:55:50820
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZ3CZ6P187205   License Plate: B6PASSAT
Mileage: 171540km-106590mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 36 42 44 46 52 53 56 62 72 76
VIN: WVWZZZ3CZ6P187205   Mileage: 171540km-106590miles
   Part No SW: 3C0 907 115 R    HW: 3C0 907 115 D
   Revision: --H14---    Serial number: VWZCZ000000000
   Coding: 0404001019070160
   Shop #: WSC 00001 898 62730
   VCID: 2F672870BEDBC8370E-807A
               P1653 - 004 -  - Intermittent
                    Fault Frequency: 23
                    Mileage: 171540 km
                    Date: 2019.07.11
                    Time: 02:14:43
                    Load: 0.0 %
                    Temperature: 33.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.684 V
012555 - Low Pressure Fuel regulation
               P310B - 002 - Fuel Pressure Outside Specification
                    Fault Status: 01100010
                    Mileage: 171540 km
                    Date: 2019.07.11
                    Time: 02:16:07
                    RPM: 1171 /min
                    Load: 36.8 %
                    Temperature: 33.0°C
                    Temperature: 33.0°C
                    Voltage: 13.970 V
000135 - Fuel Rail/System Pressure
               P0087 - 002 - Too Low
                    Mileage: 171540 km
                    Date: 2019.07.11
                    Time: 02:27:49
                    RPM: 1289 /min
                    Load: 22.3 %
                    Temperature: 47.0°C
                    Temperature: 35.0°C
                    Voltage: 13.843 V
Readiness: 0110 0101
   Part No SW: 09G 927 750 T    HW: 09G 927 750 T
   Component: AQ 250 6F           0832
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 428171C41D49555FF1-8016
                    Fault Status: 00101101
                    Reset counter: 155
                    Reset counter: 155
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
   Component: ESP 440 C2     H015 0003
   Revision:  H015       Serial number: 0667160376
   Coding: 0001425
   VCID: 30652B0CA3E5D7CF17-8064
                    Reset counter: 52
                    Mileage: 171540 km
                    Date: 2019.07.11
                    Time: 02:48:02
                    Reset counter: 52
                    Mileage: 171540 km
                    Date: 2019.07.11
                    Time: 02:48:02
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
   Component: ClimatronicPQ46 050 0404
   Revision: 00050005    Serial number: 00000000000000
   VCID: 62C19144BD89355FD1-8036
01810 - Actuating Motor for Temperature Flap; Right (V159)
                    Fault Status: 00110000
                    Reset counter: 93
                    Mileage: 171539 km
                    Date: 2019.07.06
                    Time: 04:39:25
   Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000003915328
   Coding: E5848F0700041A00000A00000F00000000085D435C0000
   Shop #: WSC 07737 898 999999
   Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00063445
   Shop #: WSC 07737
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 07737
01506 - Bulb for Rear Fog; Right (L47)
                    Fault Status: 01101100
                    Reset counter: 53
                    Mileage: 171529 km
                    Date: 2019.06.11
                    Time: 00:27:00
                    Voltage: 13.05 V
                    Reset counter: 88
                    Mileage: 171532 km
                    Date: 2019.06.12
                    Time: 04:04:00
                    Voltage: 12.55 V
                    Reset counter: 88
                    Mileage: 171532 km
                    Date: 2019.06.12
                    Time: 04:04:00
                    Voltage: 12.55 V
   Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
   Component: 05 AIRBAG VW8   029 2521
   Revision: 09029000    Serial number: 003A2P3SRE5V
   Coding: 0012341
   VCID: 2D5B3278B4D7BA273C-8078
   Subsystem 1 - Serial number: 00000000000000000
   Subsystem 2 - Serial number: 6342MSME100B311F
   Subsystem 3 - Serial number: 6351HTS64IK6B5M2
   Subsystem 4 - Serial number: 6361HTS63IKEL5F2
01221 - Crash Sensor Side Airbag; Driver Side (G179)
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AH    HW: 3C0 953 549 AH
   Component: J0527               0030
   Revision: 00035000    Serial number: 3C0953507
   Coding: 0001112
   VCID: 72E1E1046D69A5DFA1-8026
   Part No SW: 3C0 920 970 P    HW: 3C0 920 970 P
   Component: KOMBIINSTRUMENT VD1 4240
   Revision: X0033000    Serial number: 00000000000000
   Coding: 0006405
   Shop #: WSC 07736 611 00993
   VCID: 31632E08A8EFDEC718-8064
                    Reset counter: 91
                    Mileage: 171532 km
                    Date: 2019.06.12
                    Time: 04:04:24
                    Reset counter: 91
                    Mileage: 171533 km
                    Date: 2019.06.15
                    Time: 00:42:41
                    Fault Frequency: 6
                    Reset counter: 91
                    Mileage: 171533 km
                    Date: 2019.06.15
                    Time: 00:37:17
Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C062181227
   Coding: 3FFD1D04C21003
   VCID: 2143DE48F80F6E4788-8074
                    Reset counter: 48
                    Mileage: 171529 km
                    Date: 2019.06.11
                    Time: 01:30:34
01304 - Radio
                    Reset counter: 48
                    Mileage: 171529 km
                    Date: 2019.06.11
                    Time: 01:30:37
                    Reset counter: 88
                    Mileage: 171532 km
                    Date: 2019.06.12
                    Time: 04:04:25
                    Reset counter: 88
                    Mileage: 171532 km
                    Date: 2019.06.12
                    Time: 04:04:26
                    Reset counter: 88
                    Mileage: 171533 km
                    Date: 2019.06.15
                    Time: 00:42:42
   Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
   Component:    IMMO         038 0367
   Revision: 00038000    Serial number: VWZCZ000000000
   VCID: 32612104ADE9E5DF61-8066
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
02325 - Switch for Front Seat Height Adjustment (E451)
02346 - Switch for Memory Position 2 (E219)
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2802
   Coding: 0001015
   VCID: 37771010468B00F756-8062
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 346D271C57FDEBEF73-8060
   Component:    KSG PQ46 ELV 038 0455
   Coding: 00910A0801860E76380494157008DF0E103900
   Subsystem 1 - Component:   Sounder No Answer
01134 - Alarm Horn (H12)
                    Fault Frequency: 12
                    Reset counter: 51
                    Mileage: 171529 km
                    Date: 2019.06.11
                    Time: 00:14:55
                    Reset counter: 88
                    Mileage: 171529 km
                    Date: 2019.06.11
                    Time: 00:23:58
00955 - Key 1
                    Fault Status: 00110101
                    Reset counter: 91
                    Mileage: 171529 km
                    Date: 2019.06.11
                    Time: 00:31:18
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0001014
   VCID: 3875132C4B950F8F5F-806C
00121 - Outside Warning Light/Door exit Light Passenger Side
   Revision:   013
   Coding: 0000012
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 40
                    Reset counter: 48
                    Voltage: 9.94 V
                    Count: 170
Address 56: Radio
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2436
   Coding: 0000144
   VCID: 336F240052F3ECD76A-8066
   Part No: 1K0 959 704 F
   Coding: 0000144
Address 76: Park Assist        Labels: 3C0-919-283.lbl
   Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
   Component: Parkhilfe 8-Kan 004 0011
   Revision: 00004000    Serial number: 82930605308156
   Coding: 0001014
   VCID: 2855C36C9B359F0FCF-807C
End-------------------------(Elapsed Time: 02:09)--------------------------
kamold
Australia
C?ID=241363
Try:
013728
NEtech
C?ID=56995
I think it should be:
0013731
kamold
Australia
C?ID=241363
yes you are correct NEtech...I chose BWA engine from PR code, but that is only for 6 speed manual, not 09G automatic.
MezTech
Trinidad and Tobago
C?ID=380032
ok guys thanks will try and report back
