Hi guys, I have an issue with an 2008 Q7, level control won't work properly.
If car is parked for 2 or more days, it slowly lowers from front, front right faster that left. Changed Front Right air spring, but car won't cooperate.
I've calibrated all system, but I cannot get rid of 01772 .
Saturday,22,February,2020,22:05:39:31908
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4LX8D005438 License Plate: BT11RCP
Mileage: test1 Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 28 34 37 42 46 47 4F
52 55 56 61 62 6C 6D 6F 72 76
VIN: WAUZZZ4LX8D005438 Mileage: 217040km-134862miles
08-Auto HVAC -- Status: Cannot be reached 1100
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4L0 910 401 R HW: 4L0 907 401
Component: 3.0L V6TDI G001AG 0020
Revision: --H03--- Serial number:
Coding: 0011775
Shop #: WSC 00452 210 90529
VCID: 313FE8BC2D2E90CF76B-8064
8 Faults Found:
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Fault Status: 01100001
Fault Frequency: 19
Mileage: 217049 km
Date: 2020.02.21
Time: 11:16:35
Torque: 0.0 Nm
Voltage: 12.24 V
Duty Cycle: 20.5 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
005670 - Powertrain Data Bus
P1626 - 000 - Missing Message from TCU - Intermittent
Mileage: 217049 km
Date: 2020.02.22
Time: 12:51:49
Torque: 0.0 Nm
(no units): 11.0
Voltage: 13.60 V
Torque: 652.8 Nm
005685 - Powertrain Data Bus
P1635 - 001 - Missing Message from A/C Controller
Fault Frequency: 12
Mileage: 217049 km
Date: 2020.02.22
Time: 18:38:24
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 13.45 V
Bin. Bits: 00101011
005527 - Powertrain Databus
P1597 - 001 - Missing Message from Level Control System (J197) - Intermittent
Fault Status: 00100001
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 13.45 V
Bin. Bits: 00101000
Torque: 144.3 Nm
005705 - Powertrain Data Bus
P1649 - 001 - Missing Message from ABS Controller - Intermittent
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
Torque: 0.0 Nm
(no units): 11.0
Voltage: 13.45 V
(no units): 0.0
005686 - Powertrain Data Bus
P1636 - 001 - Missing Message from Airbag Controller - Intermittent
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 13.45 V
Bin. Bits: 00101000
Torque: -191.1 Nm
006464 - Powertrain Databus
P1940 - 001 - Missing Message from Control Module for Battery Monitoring - Intermittent
Mileage: 217049 km
Date: 2020.02.22
Time: 19:51:39
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 13.60 V
(no units): 0.0
005785 - Powertrain Data Bus
P1699 - 001 - Missing Message from Steering Wheel Electronics - Intermittent
Mileage: 217049 km
Date: 2020.02.22
Time: 19:51:39
Torque: 0.0 Nm
Duty Cycle: 1.0 %
Voltage: 13.60 V
Bin. Bits: 00101000
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 04517168C21CD567EDD-8050
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0103569
VCID: 290F00DC05FEE80FBEB-807C
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:39
Count: 321
Count: 166
Count: 47872
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0240
Revision: 07020801 Serial number: 10601500790088
Coding: 0000135
Shop #: WSC 02098 002 1048576
VCID: 639352F42752725FB47-8036
Subsystem 1 - Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
Subsystem 3 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0060
02639 - Antenna Reader for Keyless Access Authorization
Reset counter: 240
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:43
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 L HW: 4E0 035 729 A
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 387FT077552412
Coding: 0002002
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000367901
Subsystem 3 - Serial number: 0120.03.060000000100011003ÿ
Subsystem 4 - Serial number: 011003ÿ
Address 08: Auto HVAC
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0015121
Shop #: WSC 10122 599 83379
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 10122
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 10122
Reset counter: 200
Mileage: 217048 km
Date: 2020.02.22
Time: 22:13:00
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBG1065021
VCID: 1D67240C41B604AFC23-8048
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D033KL
Coding: 0014129
VCID: 2E05F3C03C108F376B9-807A
Subsystem 1 - Serial number: 6332QSME2E0D2F73V
Subsystem 2 - Serial number: 6342QSME2F2E300DP
Subsystem 3 - Serial number: 6352QSME2B294959S
Subsystem 4 - Serial number: 6362QSME2E0D3A6D$
Subsystem 5 - Serial number: 63734SME2C433B0F8
Subsystem 6 - Serial number: 63834SME2C6C4C27G
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Revision: 00H08000 Serial number: 90055071310123
Coding: 0002142
VCID: 66954BE0D4600777539-8032
Component: Lenkradmodul H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 930 H
Component: KOMBIINSTR. M73 H16 0070
Revision: 00400000 Serial number: 53J35V646
Coding: 3681103
Shop #: WSC 50741 143 61874
VCID: 231312F467D2325FF47-8076
Address 18: Aux. Heat Labels: 4L0-910-105.lbl
Part No SW: 4L0 910 105 HW: 4L0 815 071 D
Component: Heizgeraet H08 0080
Revision: 0000000C Serial number: 00000009014264
VCID: 60995DF836446947A95-8034
33762 - Unknown Error Code
Unknown - 004 -
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B076028245
Coding: F57BFE7F30220200
VCID: 2D07F4CC3116F42F523-8078
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:40
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 C
Revision: 00---009 Serial number: 00000000117075
Coding: 0000006
VCID: 688945D8DE741107615-803C
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:43
02600 - Rear Right Temperature Flap Motor (V314)
003 - Mechanical Failure
Fault Status: 01100011
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:45
Voltage: 13.40 V
Temperature: -100.0°C
(no units): 62.0
(no units): 136.0
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
VCID: 2A0DFFD000F8E317B71-807E
03004 - Load Level Button (E539)
Fault Status: 11101100
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:31:25
Error Code: 156
013 - Check DTC Memory
Fault Status: 11101101
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:31:25
Error Code: 98
01772 - Signal from Level Control Pressure Sensor (G291)
Fault Status: 11101000
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:32:10
Error Code: 78
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H49 1060
Revision: 00000000 Serial number: 399E3077577555
Shop #: WSC 12345 141 70992
VCID: 3B23CA94FF626A9FDC7-806E
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00-00000
Coding: 0019019
VCID: 2F3BEEC43B1A863F60F-807A
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:38
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01536700970000
Coding: 7610501
VCID: 3537DCACD946BCEF2A3-8060
01697 - Footwell Lighting; Rear Right (W46)
Fault Frequency: 14
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 12:45:00
Fault Frequency: 10
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 18:38:30
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4L0 910 223 H HW: 4L0 035 223 C
Component: DSP-AU716-RD H07 0250
Revision: 06S00000
Coding: 080000
VCID: 290F00DC09FEE80FBEB-807C
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000264101
Coding: 0011001
VCID: 5EE563000C305FB79B9-800A
Reset counter: 200
Mileage: 217048 km
Date: 2020.02.22
Time: 22:13:00
Voltage: 13.300 V
Not Recogn.
02752 - Glovebox Unlocking Motor (V327)
Fault Status: 01101010
Reset counter: 200
Mileage: 217048 km
Date: 2020.02.22
Time: 22:13:00
Voltage: 13.300 V
Not Recogn.
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0019019
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:39
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000022
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Revision: 00000000 Serial number: 388E 077628309
00856 - Radio Antenna
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 21:46:29
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 21:46:29
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000004246
VCID: 25170CEC69E6CC6F9A3-8070
Subsystem 1 - Part No: 4F0 951 105 D
Component: von VA0 350159J17L
Coding: 34463039353131303544205641303335303135394A31374C
Shop #: WSC 60463 001 104857
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:38
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0018442
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J754089
Coding: 1021001
VCID: 241111E862DC35678DD-8070
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C8139C8CA8C3D2705D-8038
Subsystem 3 - Serial number: RD09.06.07--H21001001A0103ÿ
Subsystem 4 - Serial number: 1A0103ÿ
Reset counter: 240
Mileage: 217049 km
Date: 2020.02.22
Time: 20:22:54
Reset counter: 240
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
Reset counter: 240
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
00456 - Control Module for Access and Start Control (J518)
Reset counter: 240
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
Reset counter: 240
Mileage: 217049 km
Date: 2020.02.22
Time: 18:47:23
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002808791-----
Coding: 0003587
VCID: 26150BE014E0C777939-8072
Component: J_245_EE16_SKB09H10 0200
Component: J_394_EE16_SKB09H10 0200
Component: J_392_EE16_SKB09H10 0200
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:38
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:38
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
Reset counter: 200
Mileage: 217049 km
Date: 2020.02.22
Time: 22:13:38
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0018442
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06330714106276
Coding: 0221146
End----------(Elapsed Time: 02:11, VBatt start/end: 13.3V/13.4V)-----------
