Hello all, i have a customer whos wanting me to fit a MFSW Into a caddy, it all fits but nothing works and it wont let me code the MFSW in the coding boxs
i have seen this ( http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions )
and am i correct in thinking, that .....
5K0-953-569-BB Midline Yes Yes Yes No No this is what is fitted and
i will need anything that says highline and that has MFSW (Yes) to be able to to make this work?
i have attached the auto scan
any help would be great,
the scan was taken with the MFSW installed
Thursday,20,February,2020,16:41:43:14161
VCDS Version: 19.6.2.2 (x64)
VIN: WV1ZZZ2KZGX061265 License Plate: WAYNE CADDY
Mileage: 123640km-76826mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZGX061265 Mileage: 123640km-76826miles
Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 GT HW: 04L 907 309 K
Component: R4 2,0L EDC X20 1774
Revision: 8AX20---
Coding: 0111001204250D090000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM20TDI01104L906016GT 001003
ROD: EV_ECM20TDI01104L906016GR_001_VN35.rod
VCID: 010E3238903E5B47AA-8054
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 42885000002859
Coding: 1079409B9268A47F0877027C498725E37900F0
VCID: 3F8AF4C0A64AEDB79C-806A
0297 - Steering angle sensor
B1168 54 [008] - Missing Calibration / Basic Setting
Reset counter: 127
Mileage: 123027 km
Date: 2020.01.15
Time: 00:00:00
Part No SW: 1K8 907 426 AH HW: 1K8 907 426 AH
Component: AC Manuell H20 0808
Revision: 00001002
Coding: 0010004003
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 79FE5AD8F8EE0387E2-802C
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0183
Revision: BD122001
Coding: 431A5A3E8021E16A08800082940081EC03D1000842228220648087000041
Shop #: WSC 35110 377 08192
VCID: 73E268F0D28279D7A8-8026
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 05101 27 0512
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 101115 03 37 0059
Coding: 0228DD
Subsystem 3 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0479
Revision: -------- Serial number: 39291529600546
Coding: 0001050001
ASAM Dataset: EV_EPHVA14VW364GP00 001006
ROD: EV_EPHVA14VW364GP00_VW36.rod
VCID: 76E451E4C9F06CFF8F-8022
Part No SW: 2K5 959 655 HW: 2K5 959 655
Component: VW10Airbag00K 008 0016
Revision: -------- Serial number: 003QV000YDS6
Coding: 00000000000000000000000000000000304B
Serial number: 3497ARB40653H71S8OVX
Serial number: 3507ARB401A54UJMN3P.
Part No SW: 1K5 953 521 CL HW: 5K0 953 569 BB
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20151022300456
Coding: 4080160010
ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
ROD: EV_SMLSNGVOLWSR8C.rod
Part No SW: 2K5 920 966 A HW: 2K5 920 966 A
Component: KOMBI H04 1009
Coding: 480A001200
VCID: 3362A8F09A0239D768-8066
13654544 - Databus
Fault Frequency: 47
Reset counter: 122
Mileage: 123026 km
Date: 2020.01.15
Time: 12:27:51
Part No SW: 7N0 907 530 BE HW: 7N0 907 530 AL
Component: J533 Gateway H58 1674
Revision: H58 Serial number: 301015F1000492
Coding: 357421
Shop #: WSC 00000 288 08067
VCID: 74E06BECD78C7EEFB1-8020
Reset counter: 122
Mileage: 123645 km
Date: 2020.02.20
Time: 16:12:17
Component: IMMO H04 1009
VCID: 6ADC75948D48B81F1B-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0131632
VCID: 71EE62F8689E4BC75A-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 397E9AD8706EC387A2-806C
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0131632
VCID: 72EC6DF46D9870DFA3-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1674
Coding: 030F1873
VCID: 71EE62F8A89E4BC75A-8024
Component: J367-BDM H07 0180
Serial number: 42296430321491940824
End-------------------------(Elapsed Time: 02:36)--------------------------
