VW T6 DSG torque limiter removal??
Sarge.
C?ID=384928
hi all
i have just purchaced VDCS to make some changes to my 2016 T6 DSG. one of the changes i would like to make is removal of the torque limiter within the DSG/engine. before i purchased VDCS i done some reasearch to see what i had to do:cool:, and seen most people de activated "start vibration control" or somthing along those lines. i received the vdcs lead today ran straight out to my van after i set it all up and im now sat here scratching my head as i cannot find the option i need?:banghead: i have found things similer to do with torque settings but the options seem to have to be a numerical value as apposed to activate/deactivate.
the reason for this is i currently have a CAFA 180 bi tdi engine with a stage 1 mapp. I would like to actually feel the added torque i released from the mapp!!!.
sorry if this has been covered many times but i could not find much about it.
Thanks
automech
C?ID=14925
Go to a good tuner, and make proper DSG remap. Removing limiter only will destroy your gearbox. Raise TQ limit, raise clutch pressures, change shift times and you will see a diference. And no, this is not possible with VCDS.
nazdaq100
London, United Kingdom
C?ID=314050
hi all
Thanks
You need to do extensive research in my opinion it a going to cause wear tear a lot more quicker the Usain lightning bolt. Had a golf Mk7.5 gone within 2 months car will not move an inch. luckily I was under warranty even than they haggled me over because Clutch and flywheel were not part of the warranty it’s a service requirement
Please post an Auto-Scan so we can see exactly what TCU you've got.
But please note: I'm not in any way endorsing this change. I believe the other folks are correct; it's not the right way to do this.
Sarge.
C?ID=384928
Wednesday,19,February,2020,17:27:00:01227
VIN: WV1ZZZ7HZGX014951   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZGX014951   Mileage: 219390km-136322miles
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 019 HL    HW: 03L 907 309 L
   Component: R4 2,0L EDC   X38 8372
   Revision: 22X38---    Serial number: 00000000000000
   Coding: 01254012232401080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20BTD01103L906019HL 003005
   ROD: EV_ECM20BTD_003.rod
   VCID: 7CA1F3AFF66B2B5795D-8028
Readiness: 0 0 0 0 X
   Part No SW: 0BT 300 045 T    HW: 0BH 927 711 G
   Component: DSG DQ500-7F  H11 2402
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 46D55147F827A187B39-8012
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 43465000001245
   Coding: 517E4098256384828A7E027BA48321D6390000
   Shop #: WSC 35110 790 50316
   VCID: 3FDB44A3A7FDF04FF0F-806A
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 02121513470383
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F9A7E0773947BB9-802A
   Part No SW: 7E0 907 047 T    HW: 7E0 907 047 T
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3B2330B3B3E5EC6FDC7-806E
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 342150432
   Coding: A0A4303A0A6134B393284F746EEB8E74BFA0708F60CC6960320400220800
   Shop #: WSC 02010 002 104857
   VCID: 6889BFFF927397F7615-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 161215 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU025111553297622
   Coding: 1400B1
   Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU018111553222421
   Coding: 0400A1
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29150002404690025486
   Coding: A4FFFF
   Part No SW: 7E0 919 475 R    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0210
   Revision: --------    Serial number: 32961530802427
   Coding: 10810A
   ASAM Dataset: EV_VW75XParkAssis4K 001012
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 41DF425BD10986BF86B-8014
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH0021HJ+
   Coding: 00000000000000000000000000000000304A
   VCID: 372B2C838FCDC80F38F-8062
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 470B010100
   VCID: 333318939BB5242F047-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042305
   Component: IMMO          H05 1008
   VCID: 6A8DC5F78CFFA5E7771-803E
   Part No SW: 1K8 035 150 E    HW: 1K8 035 150 E
   Component: MU-E-D-ER     857 6495
   Serial number: 07111500011376
   Coding: 065700003C00000041111101008000001F0000860000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   VCID: 270BFCC35F6D588FA8F-8072
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 35110 377 08192
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 62327414091261125510
End----(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Sarge.
C?ID=384928
thanks for replys, yes i understand the risks involved. when the van was mapped the company who did it offered to "match the torque of the mapp to the DSG" for a fee of course!!, quite high too!!. i was offered this as a option without the need for a remap of the dsg tune. i was told that if i had a DSG tune too then i would not be charged for the torque match as it would be part of the DSG remap. this is when i started to look into to it myself and realised/thought that what they were offering as a option was to plug in a VCDS and carry out the adjustment of the torque settings. The price of the torque match was just over half the price of a vcds cable!!
I see no option for anything like "start vibration control" in that TCU software.
