Need help with Audi A3 8p remote key fob programming
hondaman900
C?ID=395495
So in VCDS with my HEX-V2 I selected 46 Central Convenience group to reprogram my key fob that hasn't been working. When looking at measuring blocks, for group 10, the key gave no response indicating it wasn't recognized.
In group 11 it recognized pressing a remote button, but it came up as "Not OK".
Group 12 verifies that the immobilizer recognizes the key in the ignition I'm trying to program (which I expected as it starts the car).
So I then followed the reprogramming process. I clicked the Adaptation button (still under (46) Central Convenience), read and saved channel 00. I then chose channel 01, entered 1 as the new number of keys, clicked save, held the fob door open key for a second and the car flashed the hazard lights on car and dash, and to confirm. Now I'm excited that I finally have a working key remote for my car!:thumbs: I then clicked go back and closed out VCDS. However, the key fob still didn't operate thereafter and trying the measuring block again, the key fob still reads "Not OK" in group 11.:banghead:
I think I'm doing the procedure correctly, so what's up with my remote and why does it appear to work momentarily and then stop? I have new batteries in the remote and the red LED indicates operation of the fob when I press the buttons.
Any suggestions...?
Here's my Autoscan:
Friday,14,February,2020,09:04:32:39323
VIN: WAUMF78P16A171124   License Plate:
Mileage: 295180km-183416mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUMF78P16A171124   Mileage: 295180km-183416miles
08-Auto HVAC -- Status: Sporadic communication error 1000
   Part No SW: 8P0 907 115 B    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0080
   Revision: --H14---    Serial number: AUX7Z0F1FNK0E3
   Coding: 0103010A1C070160
   Shop #: WSC 26105 444 82971
   VCID: 313F13802D20C33F769-8064
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 002 - Signal too High - Intermittent
                    Mileage: 294970 km
                    Date: 2020.02.09
                    Time: 13:46:02
                    RPM: 806 /min
                    Load: 18.0 %
                    Temperature: -40.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 920.0 mbar
                    Voltage: 13.716 V
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1125
   Revision: 04507000    Serial number: 00000602080984
   Shop #: WSC 06314 000 00000
   VCID: 1471BA14B27216177DF-8040
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H13001
   Coding: 0053890
   VCID: 6889BEE4DE7A42F7617-803C
   Part No SW: 8P0 820 043 M    HW: 8P0 820 043 M
   Component: KlimavollautomatH18 0260
   Revision: 306332      Serial number: 8P0820043M
   VCID: 3635209CC44EE40723B-8062
Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
   Component: Bordnetz-SG     H43 1201
   Revision: 00H43000    Serial number: 00000005484621
   Coding: 018C4F81C014100000181800180000000028FE175C1100
   Shop #: WSC 06314 000 08192
   VCID: 40D94644968A5AB7897-8014
   Subsystem 1 - Part No: 8P1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
8 Faults Found:
                    Reset counter: 9
                    Mileage: 287775 km
                    Date: 2019.06.23
                    Time: 00:57:00
                    Voltage: 12.15 V
                    Reset counter: 9
                    Mileage: 287775 km
                    Date: 2019.06.23
                    Time: 00:57:00
                    Voltage: 12.15 V
                    Fault Status: 01111100
                    Reset counter: 9
                    Mileage: 292041 km
                    Date: 2019.12.30
                    Time: 14:48:00
                    Voltage: 10.90 V
01117 - Generator Terminal DF Load Signal
                    Reset counter: 49
                    Mileage: 287788 km
                    Date: 2019.06.26
                    Time: 18:45:00
                    Voltage: 12.45 V
                    Reset counter: 45
                    Mileage: 294970 km
                    Date: 2020.02.08
                    Time: 13:49:00
                    Voltage: 12.50 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00100110
                    Reset counter: 49
                    Mileage: 287784 km
                    Date: 2019.06.23
                    Time: 05:48:00
                    Voltage: 11.80 V
                    Fault Frequency: 38
                    Reset counter: 9
                    Mileage: 287775 km
                    Date: 2019.06.23
                    Time: 00:57:00
                    Voltage: 12.15 V
                    Reset counter: 9
                    Mileage: 287775 km
                    Date: 2019.06.23
                    Time: 00:57:00
                    Voltage: 12.15 V
Address 15: Airbags        Labels: 8P0-959-655-94.lbl
   Part No SW: 8P0 959 655 A    HW: 8P0 959 655 A
   Component:    Airbag 9.41  H12 3890
   Revision: 91H12389    Serial number: 0035W000DU0/
   Coding: 0032605
   Subsystem 1 - Part No: 8P0 910 339
   Component: BF-Gewichtsens. 001 0020
   Subsystem 2 - Serial number: 35KHV
   Subsystem 3 - Serial number: 0001.01.000000100000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB402E9C80F0ÿ†63
   Subsystem 5 - Serial number: 9C80F0ÿ†6342DRB402E9CC0B1ÿ†63
   Subsystem 6 - Serial number: 9CC0B1ÿ†63528RB400FEB29B%ÿ†63
   Subsystem 7 - Serial number: EB29B%ÿ†63628RB40107D2A0Eÿ†63
   Subsystem 8 - Serial number: 7D2A0Eÿ†63729RB400F3A472Oÿ†63
   Subsystem 9 - Serial number: 3A472Oÿ†63829RB400F398FB2ÿ
   Subsystem 10 - Serial number: 398FB2ÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H34 0070
   Coding: 0012122
   VCID: 41DF43409D8053BF869-8014
   Component: E0221           H07 0090
01304 - Radio
   Part No SW: 8P0 920 981 E    HW: 8P0 920 981 E
   Component: KOMBIINSTR. VDO H80 0420
   Revision: D06         Serial number: 2241FD06008809
   Coding: 0002263
   Shop #: WSC 58152 001 1048576
   VCID: 3A2D34ACF0560067C73-806E
16346 - Control Module - ROM Error
            014 - Defective
                    Fault Status: 00000011
                    Mileage: 171032 km
                    Date: 2014.11.04
                    Time: 20:45:40
   Part No SW: 1K0 907 530 G    HW: 1K0 907 951
   Component: J533__Gateway   H10 0140
   Revision:   H10       Serial number: 300010621194D8
   Coding: 3F3F034207002102
   VCID: 2B0301E80F0CA9EF4C5-807E
01304 - Radio
                    Reset counter: 9
                    Mileage: 291831 km
                    Date: 2019.12.22
                    Time: 16:16:48
                    Reset counter: 45
                    Mileage: 294970 km
                    Date: 2020.02.08
                    Time: 13:49:26
   Revision: D06         Serial number: AUX7Z0F1FNK0E3
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
   Part No: 8P0 959 801 H
   Component: Tuer-SG         020 0090
   Coding: 0001177
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 233    3201
   Revision: 00H20000
   Shop #: WSC 26105 444 999999
   VCID: 34311A94D232F6171DF-8060
   Part No: 8P0 959 433 D
   Component: 02 KSG          H04 0050
   Coding: 9AC003382D08850FC88F047300
   Shop #: WSC 26105 444 68434
   VCID: 3D273FB0E178375FE21-8068
   Part No SW: 8P4 035 382     HW: 8P4 035 382
   Component: AB2 SUBWOOFERBOXH04 0180
   Revision: 00003       Serial number: 30674548472080
   VCID: 71BFD380EDA0833F369-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN2.lbl
   Part No: 8P0 959 802 H
   Coding: 0001177
Address 56: Radio
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No: 8P4 959 801 D
   Component: Tuer-SG         020 0070
   Coding: 0001176
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No: 8P4 959 802 D
   Coding: 0001176
End----------(Elapsed Time: 01:11, VBatt start/end: 12.2V/12.2V)-----------
hondaman900
C?ID=395495
Anyone....?
Do you have a working remote for this car?
hondaman900
C?ID=395495
Thank you for the reply! :)
Not for opening/closing doors. I'm trying to program the car's original remote that came with it. I do have a second one I bought online, but just for now trying to get the original working.
VCDS confirms that the fob matches and is read by the car for starting it (RFID immobilizer works and the car starts), and VCDS also shows that pressing a button on the remote is recognized (neither of which is true for the new fob I bought). So it would seem that the fob is good to go if I could get the car to register it as the fob for lock control. I do get the flashing dash lights confirmation of adaptation, but it doesn't function. Doors function using the buttons in the door and the key locks and unlocks all doors at once when used in the driver's door lock.
NEtech
C?ID=56995
Maybe after entering 1 try:
Press and hold "Open button"
[Test]
[Save]
Release "Open button"
What is the saved value when you access channel 01 ?
hondaman900
C?ID=395495
I'll check that and let you know - thank you
hondaman900
C?ID=395495
[Test]
[Save]
Hi NEtech, I tried your suggestion but, alas, to no avail. I get the same results. Once I let go of the button (after the channel 00 erase, entering "1" then TEST & SAVE) and clicking the button again gets the confirmation blink of all turn signals again, but then nothing. The stored value for channel 01 is 1. Measuring blocks still same as described above and the fob doesn't do anything thereafter.
Strange that the fob/buttons are recognized (I see a response in VCDS) but it won't accept the fob for adaptation. What's my next move...?
marvin1980
C?ID=171833
Did you ever found the solution for this problem? Dealing with the same.
Best regards,
Marvin
