2013 Touareg Lux TDI Comfort Windows Enable.
Netechsys
C?ID=396194
New to the forums. Have use VCDS off and on for the last few years, but never mine, only a friends from the local shop.
I’m trying to enable the Comfort Windows on my T’Reg. I’ve done the coding and it shows in the radio now, but it doesn’t work. What am I missing?
Scan-all below for the truck. I did the coding via a windows computer, but I’m out now and don’t have it.
Thanks!
VCDS Mobile 0.4508.0.4
VIN: WVGEP9BP0DD004754
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
	 69 6C 6D 72
Address 01: Engine  (CNRB J623)	Labels: 059-907-401-V2.clb
	Part No SW: 7P0 907 401 K	HW: 7P0 907 401 K
	Component: 3.0TDI FSA    H19 0011
	Revision: 56H19---
	Coding: 292A4012233600050000
	Shop #: WSC 02146 444 00000
	ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
	ROD: N/A
	VCID: 3731B8DF74DD0CCCA538FC-8062
	No ASAM data for: "EV_ECM30TDI0117P0907401K"
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: 0C8-927-750.clb
	Part No SW: 0C8 927 750 AK	HW: 0C8 927 750 AK
	Component: AL1000 AISIN  001 3398
	Coding: 001368
	Shop #: WSC 21208 002 1048576
	ASAM Dataset: EV_TCMAL991031 002115
	ROD: N/A
	VCID: 75AD72D72E51BEDC778496-8020
	No ASAM data for: "EV_TCMAL991031"
Address 03: ABS Brakes  (J104)	Labels: 7P0-907-379.clb
	Part No SW: 7P0 907 379 M	HW: 7P0 907 379 A
	Component: MK25A         H36 0436
	Revision: --------
	Coding: 5B7613C349242557DAFBC89892D6A4407300
	Shop #: WSC 31414 790 00001
	ASAM Dataset: EV_MK25AXT 008001
	ROD: N/A
	VCID: 47D1C81F043D7C4CD5D88C-8012
	No ASAM data for: "EV_MK25AXT"
Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
	Part No SW: 4H0 907 064 CK	HW: 4H0 907 064 CK
	Component: BCM2 2.0      H32 0421
	Coding: 09860010000000000000
	VCID: 74AB4FD3252BBFD4409A63-8021
	Subsystem 1 - 	Part No SW: 7P6-959-754-AD
	Component: FBSTOUAREGIDGH04 0051
	Subsystem 2 - 	Part No SW: 4H0-905-852-B
Address 08: Auto HVAC  (J255)	Labels: 7P6-907-040.clb
	Part No SW: 7P6 907 040 BK	HW: 7P6 907 040 BK
	Component: Klima 2 Zonen H20 1305
	Coding: B606200A80
	ROD: N/A
	VCID: 7EBF6DFB1B67FD8426FEF1-802B
	No ASAM data for: "EV_AirCondiFront"
Address 09: Cent. Elect.  (J519)	Labels: 4H0-907-063-V1.clb
	Part No SW: 4H0 907 063 BL	HW: 4H0 907 063 D
	Component: BCM1 2.0      H12 0111
	Revision: 15012002
	Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
	VCID: 73A94CCF2025B8EC599068-8026
	Subsystem 1 - 	Part No SW: 7P0-955-119	Labels: 1Kx-955-119.clb
	Component: WWS    12070831  0020
	Coding: 004DBD
	Subsystem 2 - 	Part No SW: 7P0-955-559-D	Labels: 8K0-955-559.clb
	Component: RLFS         H09 0011
	Coding: 025223
	Subsystem 3 - 	Part No SW: 7P6-941-431-E
	Component: E1 - LDS     H04 0031
	Subsystem 4 - 	Part No SW: 4H0-907-410-A
	Component: USHL4.2      H30 0020
Address 15: Airbags  (J234)	Labels: 7P0-959-655.clb
	Part No SW: 7P0 959 655 C	HW: 7P0 959 655 C
	Component: VW10Airbag025 H05 0025
	Revision: --------
	Coding: 000000000000000000000000000000003235
	ROD: N/A
	VCID: 41C5D6072A19427C1B9C52-8014
	No ASAM data for: "EV_AirbaVW10BPAVW526"
	Subsystem 1 - 	Part No SW: 7P6-959-339
	Component: BF-Gewichtss.003 0005
	Serial Number: 5850000R1242708VGXªª
	Subsystem 2 - 	Serial Number: 3575LRB40671EVLC9GD+
	Subsystem 3 - 	Serial Number: 3585LRB404T1C4LGFGNA
	Subsystem 4 - 	Serial Number: 3515RRB401A4UHC4OQ1/
	Subsystem 5 - 	Serial Number: 3525RRB401A4UHC4G9V3
	Subsystem 6 - 	Serial Number: 3555NRB40631GCDM5P8M
Address 16: Steering wheel  (J527)	Labels: 4H0-953-568.clb
	Part No SW: 4H0 953 568 F	HW: 7P6 953 507 L
	Revision: --------
	Coding: 000015
	VCID: 362FB5DB73D7EDC4BE0EC9-8063
	Subsystem 1 - 	Part No SW: 7P6-959-542
	Component: E221__MFL-TASH03 0027
Address 17: Instruments  (J285)	Labels: 7P6-920-xxx-17.clb
	Part No SW: 7P6 920 981 F	HW: 7P6 920 981 F
	Component: Kombi         H13 0318
	Revision: 13240077
	Coding: 837733022B00CF05020004
	ASAM Dataset: EV_KombiUDSRBVW526 001017
	ROD: N/A
	VCID: 40C3D30321134B7414925F-8015
	No ASAM data for: "EV_KombiUDSRBVW526"
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 7P6 907 530 F	HW: 7P6 907 530 F
	Component: GW-CAN-L-MOST H11 6028
	Revision: --------
	Coding: 0001037500
	ASAM Dataset: EV_GatewVW526UDS 001007
	ROD: N/A
	VCID: 3B39A4EF48F528AC414010-806E
	No ASAM data for: "EV_GatewVW526UDS"
	Subsystem 1 - 	Part No SW: 7P0-915-181-A
	Serial Number: 00000000005650862695
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	Part No SW: 4H0 959 760 D	HW: 4H0 959 760 D
	Revision: AA000000
	Coding: 0058130000004001000001010101202020202121202020
	VCID: 342B8FD365ABFFD4801AA3-8061
Address 42: Door Elect, Driver  (J386)	Labels: None
	Part No SW: 4H0 959 793 N	HW: 4H0 959 793 F
	Component: TSG FA        H07 0166
	Revision: --------
	Coding: 011D07205E00453005080000
	VCID: 44CBDF13350B4F5430BA73-8011
Address 46: Central Conv.  (J393)	Labels: 4H0-907-064-46.clb
	Coding: 0186163A28B9509480A00620210000000000000000000000000000000000
	Component: GTO BT       H19 0059
	Subsystem 2 - 	Part No SW: 1K0-951-605-C
	Component: LIN BACKUP HOH05 1501
	Subsystem 3 - 	Part No SW: 7P0-959-591-B
	Component: J245 PS30.055H01 0008
	Coding: 191100
	Subsystem 4 - 	Part No SW: 7P0-959-591-C
	Component: J394 PS30.055H01 0008
	Coding: 191100
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Part No SW: 4H0 959 792 F	HW: 4H0 959 792 F
	Component: TSG BF        H07 0166
	Revision: --------
	VCID: 3B39A4EF48F530AC414010-806E
02111 - Motor for Window Regulator
Address 53: Parking Brake  (J540-)	Labels: 7P0-907-801.clb
	Part No SW: 7P0 907 801 F	HW: 7P0 907 801 F
	Component: EPB           H51 1201
	Revision: 00000000
	Coding: 01040200
	ROD: N/A
	VCID: 362FB5DB73D7F5C4BE0EC9-8063
	No ASAM data for: "EV_ParkbA7"
	Subsystem 1 -
Address 55: Xenon Range  (J745)	Labels: 7P6-907-357.clb
	Part No SW: 7P6 907 357	HW: 7L6 907 357 C
	Component: AFS-ECU       H04 0110
	Revision: --------
	Coding: 010A00011D000000
	ROD: N/A
	VCID: FCBBE7F38D7B6F9488CA4B-80A9
	No ASAM data for: "EV_HeadlRegulVWAFS"
Address 56: Radio  (R)	Labels: None
	Part No SW: 4G0 035 082 D	HW: 4G0 035 082
	Component: Radio U SIRIU H60 0112
	Revision: AB001007
	Coding: 020007020100000001
	VCID: 21057687CA597A7C7B5CF2-8074
Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
	Part No SW: 7P6 035 664 C	HW: 7P6 035 664
	Component: H-BN-NA       H45 0544
	Revision: --------
	Coding: 010200050040E1EE41022B0C00000003F0000100
	VCID: 3833BBE379C31BB4AC22F7-806D
	Subsystem 1 - 	Part No SW: 8R0-060-884-AM
	Component: NAR 2012     0605
	Subsystem 2 - 	Part No SW: 7P6-919-603-C
	Component: DU8 SV Touch H26 0045
	Subsystem 3 - 	Part No SW: 7P6-919-603-C
	Subsystem 4 - 	Part No SW: 8R0-060-961
	Component: CD-Database  1886
Address 62: Door, Rear Left  (J388)	Labels: None
	Part No SW: 4H0 959 795 B	HW: 4H0 959 795 B
	Component: TSG HL        H09 0167
	Revision: --------
	Coding: 011C07200000253005080000
	VCID: 3A37A1EB47CF09A45A561D-806F
Address 65: Tire Pressure  (J502)	Labels: 3Y0-907-273.clb
	Part No SW: 7P6 907 273 F	HW: 7P6 907 273 F
	Component: RDKBERU25     H09 0008
	Shop #: WSC 00000 000
	ROD: N/A
	VCID: 3FC1D0FF5CED348C6D6824-806A
	No ASAM data for: "EV_RDKBERU25"
Address 69: Trailer  (J345)	Labels: None
	Part No SW: 7P0 907 383 F	HW: 7P0 907 383 B
	Component: Anhaenger     H09 0110
	Revision: 5A001001
	Coding: 020D000000000000
Address 6C: Back-up Cam.	Labels: 4L0-910-441.clb
	Part No SW: 7P6 907 441 A	HW: 4H0907441
	Component: SG Rueckfahrkamera   0020
	Revision: 00H06000	Serial Number: 525 PA8J270279
	Coding: 0110001
	VCID: 3731B8DF74DD94CCA538FC-8062
Address 6D: Trunk Elect.  (----)	Labels: 7N0-959-107.clb
	Part No SW: 7P6 959 107 A	HW: 7P6 959 107
	Component: HDSG-Modul    H10 0620
	Revision: 22010001
	Coding: 0533314003
	ASAM Dataset: EV_HeckkTouar 202137
	ROD: N/A
	VCID: 3D3DAAF756E1269C7F743E-8068
	No ASAM data for: "EV_HeckkTouar"
Address 72: Door, Rear Right  (J389)	Labels: None
	Component: TSG HR        H09 0167
	Revision: --------
End--(Elapsed Time: 02:56, VBatt start/end: 14.1/14.7 Vign: 0.0)-
Netechsys
C?ID=396194
Ok.. So now I am totally confused!
I gave up.. Came back after a few hours.. And the Down by remote works now. Just not the close by remote.. Maybe by morning, everything will work.. But I am doubtful..
Any input would be greatly appreciated! This is the only coding that hasn't worked first time, the way it should..
-Terry
PetrolDave
Westbury, UK
C?ID=1423
A delay before some tweaks work isn't a new thing, even back into the mid 2000's it wasn't unusual for some tweaks to require the CAN message header index to "overflow" before the tweak would work - the advice given then was to wait up to 24 hours and see if the tweak has taken.
Netechsys
C?ID=396194
Thanks. I’ll wait and see as now neither works again. Only change from before to now was I turned the sunroof off, as I don’t want that to open.
PetrolDave
Westbury, UK
C?ID=1423
On older platforms even if you enabled sunroof open it didn't work, not sure if that's true of the newer platforms though :confused:
Netechsys
C?ID=396194
Ok. So waiting for a bit. And the windows down is working fine. Not up. I can’t find it again, but I thought there was a bit to enable up and down separate somewhere else.
What do you have in Adaptation Channels 061 and 062 of the Central Convenience module?
Netechsys
C?ID=396194
Uwe, 061 is 12287. 062 is 65535.
Well, those both have "Power Windows via Remote Control" enabled for Opening (061) and closing (062).
So I'm not sure what to make of your symptoms.
Netechsys
C?ID=396194
Hmm. Thanks for checking. Not sure why it won’t work. Maybe I’ll play a bit. Is there anywhere that explains the adaptation values?
TBAx
C?ID=287144
I found this:
061 - Comfort Operation for opening:
+0001 = Windows w/ Remote Control
+0002 = Windows w/ Door Locks
+0004 = Windows w/ Power Window Switch
+0008 = Sliding Roof w/ Remote Control
+0016 = Sliding Roof w/ Door Locks
+0032 = Sliding Roof w/ Power Window Switch
+0064 = Rear Sliding Roof w/ Remote Control
+0128 = Rear Sliding Roof w/ Door Locks
+0256 = Rear Sliding Roof w/ Power Window Switch
+0512 = Blinds w/ Remote Control
+1024 = Blinds w/ Door Locks
+2048 = Blinds w/ Window Switch
+4096 = ONLY Driver's Door Window
+8192 = Sliding Roof moves to Tilt Position
062 - Comfort Operation for closing:
+00001 = Windows w/ Remote Control
+00002 = Windows w/ Door Locks
+00004 = Windows w/ Power Window Switch
+00008 = Windows w/ KESSY
+00016 = Sliding Roof w/ Remote Control
+00032 = Sliding Roof w/ Door Locks
+00064 = Sliding Roof w/ Power Window Switch
+00128 = Sliding Roof w/ KESSY
+00256 = Rear Sliding Roof w/ Remote Control
+00512 = Rear Sliding Roof w/ Door Locks
+01024 = Rear Sliding Roof w/ Power Window Switch
+02048 = Rear Sliding Roof w/ KESSY
+04096 = Blinds w/ Remote Control
+08192 = Blinds w/ Door Locks
+16384 = Blinds w/ Power Window Switch
+32768 = Blinds w/ KESSY
Netechsys
C?ID=396194
Thanks for that! One thing I notice is the close, adaption 62, includes KESSY, and the open does not. Since my truck doesn’t have the button start, I wonder if that is causing problems.
Uwe, you have one of these, right? Can I ask what your option 62 is set to?
Thanks for your help!!
Well, technically it's my wife's, and it isn't always handy. Plus it's a 2015, so it has some "facelift" differences, and it does have push-button start.
Here's the CCM:
   Part No SW: 4H0 907 064 FK    HW: 4H0 907 064 EK
   Component: BCM2 2.0      H36 0551
   Revision: 00002001    Serial number: 0350252359
   Coding: 0187123A68A9509580A00620210A18000000000000000000000000000000
   VCID: 77A8E4D92FCCB7531F1-8022
   Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
   Component: GTO BT  H20 0059
   Serial number: 23414636
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.062  H01 0008
   Serial number:     WOO33408181
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.062  H01 0008
   Serial number:     WOO33578426
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65010184
And here's an Adaptation channel map from it:
;SW:4H0-907-064-FK   HW:4H0-907-064-EK ---  Central Conv.
;Component:BCM2 2.0      H36 0551, Coding:0187123A68A9509580A00620210A18000000000000000000000000000000
;Sunday,08,March,2020,15:15:56:07998
Channel,,Field 1,Field 2,Field 3,Field 4,
01,36929,N/A,N/A,N/A,N/A,
02,36864,N/A,N/A,N/A,N/A,
03,36928,N/A,N/A,N/A,N/A,
04,36929,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,0,N/A,N/A,N/A,N/A,
09,36929,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
13,87,N/A,N/A,N/A,N/A,
16,5,N/A,N/A,N/A,N/A,
60,0,N/A,N/A,N/A,N/A,
61,9947,N/A,N/A,N/A,N/A,
62,48059,N/A,N/A,N/A,N/A,
63,184,N/A,N/A,N/A,N/A,
64,40,N/A,N/A,N/A,N/A,
65,63,N/A,N/A,N/A,N/A,
66,21,N/A,N/A,N/A,N/A,
67,6425,N/A,N/A,N/A,N/A,
69,0,N/A,N/A,N/A,N/A,
95,3,N/A,N/A,N/A,N/A,
96,30,N/A,N/A,N/A,N/A,
97,50,N/A,N/A,N/A,N/A,
98,1,N/A,N/A,N/A,N/A,
103,0,N/A,N/A,N/A,N/A,
104,190,N/A,N/A,N/A,N/A,
105,23,N/A,N/A,N/A,N/A,
110,16,N/A,N/A,N/A,N/A,
111,16,N/A,N/A,N/A,N/A,
112,16,N/A,N/A,N/A,N/A,
113,16,N/A,N/A,N/A,N/A,
114,16,N/A,N/A,N/A,N/A,
115,16,N/A,N/A,N/A,N/A,
116,16,N/A,N/A,N/A,N/A,
117,16,N/A,N/A,N/A,N/A,
118,16,N/A,N/A,N/A,N/A,
119,16,N/A,N/A,N/A,N/A,
120,0,N/A,N/A,N/A,N/A,
121,64,N/A,N/A,N/A,N/A,
122,2,N/A,N/A,N/A,N/A,
123,31,N/A,N/A,N/A,N/A,
124,0,N/A,N/A,N/A,N/A,
125,224,N/A,N/A,N/A,N/A,
126,66,N/A,N/A,N/A,N/A,
127,31,N/A,N/A,N/A,N/A,
128,45,N/A,N/A,N/A,N/A,
129,0,N/A,N/A,N/A,N/A,
130,17,N/A,N/A,N/A,N/A,
131,192,N/A,N/A,N/A,N/A,
132,0,N/A,N/A,N/A,N/A,
133,48,N/A,N/A,N/A,N/A,
134,10,N/A,N/A,N/A,N/A,
135,9,N/A,N/A,N/A,N/A,
136,255,N/A,N/A,N/A,N/A,
137,255,N/A,N/A,N/A,N/A,
138,65535,N/A,N/A,N/A,N/A,
139,224,N/A,N/A,N/A,N/A,
140,6,N/A,N/A,N/A,N/A,
141,25,N/A,N/A,N/A,N/A,
142,255,N/A,N/A,N/A,N/A,
143,5,N/A,N/A,N/A,N/A,
144,60,N/A,N/A,N/A,N/A,
145,5,N/A,N/A,N/A,N/A,
146,5,N/A,N/A,N/A,N/A,
150,0,N/A,N/A,N/A,N/A,
194,7,N/A,N/A,N/A,N/A,
Note: I don't recall having done any tweaks to module, but can't promise that it's "factory" either.
