New to the forums. Have use VCDS off and on for the last few years, but never mine, only a friends from the local shop.
I’m trying to enable the Comfort Windows on my T’Reg. I’ve done the coding and it shows in the radio now, but it doesn’t work. What am I missing?
Scan-all below for the truck. I did the coding via a windows computer, but I’m out now and don’t have it.
Thanks!
Thanks!
VCDS Mobile 0.4508.0.4
VIN: WVGEP9BP0DD004754
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
69 6C 6D 72
Address 01: Engine (CNRB J623) Labels: 059-907-401-V2.clb
Part No SW: 7P0 907 401 K HW: 7P0 907 401 K
Component: 3.0TDI FSA H19 0011
Revision: 56H19---
Coding: 292A4012233600050000
Shop #: WSC 02146 444 00000
ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
ROD: N/A
VCID: 3731B8DF74DD0CCCA538FC-8062
No ASAM data for: "EV_ECM30TDI0117P0907401K"
No fault codes found.
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 AK HW: 0C8 927 750 AK
Component: AL1000 AISIN 001 3398
Coding: 001368
Shop #: WSC 21208 002 1048576
ASAM Dataset: EV_TCMAL991031 002115
ROD: N/A
VCID: 75AD72D72E51BEDC778496-8020
No ASAM data for: "EV_TCMAL991031"
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 M HW: 7P0 907 379 A
Component: MK25A H36 0436
Revision: --------
Coding: 5B7613C349242557DAFBC89892D6A4407300
Shop #: WSC 31414 790 00001
ROD: N/A
VCID: 47D1C81F043D7C4CD5D88C-8012
No ASAM data for: "EV_MK25AXT"
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CK HW: 4H0 907 064 CK
Component: BCM2 2.0 H32 0421
Coding: 09860010000000000000
VCID: 74AB4FD3252BBFD4409A63-8021
Subsystem 1 - Part No SW: 7P6-959-754-AD
Component: FBSTOUAREGIDGH04 0051
Subsystem 2 - Part No SW: 4H0-905-852-B
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 BK HW: 7P6 907 040 BK
Component: Klima 2 Zonen H20 1305
Coding: B606200A80
ROD: N/A
VCID: 7EBF6DFB1B67FD8426FEF1-802B
No ASAM data for: "EV_AirCondiFront"
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BL HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0111
Revision: 15012002
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 73A94CCF2025B8EC599068-8026
Subsystem 1 - Part No SW: 7P0-955-119 Labels: 1Kx-955-119.clb
Component: WWS 12070831 0020
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0-955-559-D Labels: 8K0-955-559.clb
Component: RLFS H09 0011
Coding: 025223
Subsystem 3 - Part No SW: 7P6-941-431-E
Component: E1 - LDS H04 0031
Subsystem 4 - Part No SW: 4H0-907-410-A
Component: USHL4.2 H30 0020
Address 15: Airbags (J234) Labels: 7P0-959-655.clb
Part No SW: 7P0 959 655 C HW: 7P0 959 655 C
Component: VW10Airbag025 H05 0025
Revision: --------
Coding: 000000000000000000000000000000003235
ROD: N/A
VCID: 41C5D6072A19427C1B9C52-8014
No ASAM data for: "EV_AirbaVW10BPAVW526"
Subsystem 1 - Part No SW: 7P6-959-339
Component: BF-Gewichtss.003 0005
Serial Number: 5850000R1242708VGXªª
Subsystem 2 - Serial Number: 3575LRB40671EVLC9GD+
Subsystem 3 - Serial Number: 3585LRB404T1C4LGFGNA
Subsystem 4 - Serial Number: 3515RRB401A4UHC4OQ1/
Subsystem 5 - Serial Number: 3525RRB401A4UHC4G9V3
Subsystem 6 - Serial Number: 3555NRB40631GCDM5P8M
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Revision: --------
Coding: 000015
VCID: 362FB5DB73D7EDC4BE0EC9-8063
Subsystem 1 - Part No SW: 7P6-959-542
Component: E221__MFL-TASH03 0027
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 981 F HW: 7P6 920 981 F
Component: Kombi H13 0318
Revision: 13240077
Coding: 837733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001017
ROD: N/A
VCID: 40C3D30321134B7414925F-8015
No ASAM data for: "EV_KombiUDSRBVW526"
Part No SW: 7P6 907 530 F HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H11 6028
Revision: --------
Coding: 0001037500
ROD: N/A
VCID: 3B39A4EF48F528AC414010-806E
No ASAM data for: "EV_GatewVW526UDS"
Subsystem 1 - Part No SW: 7P0-915-181-A
Component: Batt_Sensor H07 0140
Serial Number: 00000000005650862695
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000
Coding: 0058130000004001000001010101202020202121202020
VCID: 342B8FD365ABFFD4801AA3-8061
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: --------
Coding: 011D07205E00453005080000
VCID: 44CBDF13350B4F5430BA73-8011
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Coding: 0186163A28B9509480A00620210000000000000000000000000000000000
Component: GTO BT H19 0059
Subsystem 2 - Part No SW: 1K0-951-605-C
Component: LIN BACKUP HOH05 1501
Subsystem 3 - Part No SW: 7P0-959-591-B
Component: J245 PS30.055H01 0008
Coding: 191100
Subsystem 4 - Part No SW: 7P0-959-591-C
Component: J394 PS30.055H01 0008
Coding: 191100
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: --------
VCID: 3B39A4EF48F530AC414010-806E
02111 - Motor for Window Regulator
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000
Coding: 01040200
ROD: N/A
VCID: 362FB5DB73D7F5C4BE0EC9-8063
No ASAM data for: "EV_ParkbA7"
Subsystem 1 -
Address 55: Xenon Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: --------
Coding: 010A00011D000000
ROD: N/A
VCID: FCBBE7F38D7B6F9488CA4B-80A9
No ASAM data for: "EV_HeadlRegulVWAFS"
Address 56: Radio (R) Labels: None
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007
Coding: 020007020100000001
VCID: 21057687CA597A7C7B5CF2-8074
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 C HW: 7P6 035 664
Component: H-BN-NA H45 0544
Revision: --------
Coding: 010200050040E1EE41022B0C00000003F0000100
VCID: 3833BBE379C31BB4AC22F7-806D
Subsystem 1 - Part No SW: 8R0-060-884-AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 7P6-919-603-C
Component: DU8 SV Touch H26 0045
Subsystem 3 - Part No SW: 7P6-919-603-C
Subsystem 4 - Part No SW: 8R0-060-961
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0167
Revision: --------
Coding: 011C07200000253005080000
VCID: 3A37A1EB47CF09A45A561D-806F
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Shop #: WSC 00000 000
ROD: N/A
VCID: 3FC1D0FF5CED348C6D6824-806A
No ASAM data for: "EV_RDKBERU25"
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001
Coding: 020D000000000000
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0907441
Component: SG Rueckfahrkamera 0020
Revision: 00H06000 Serial Number: 525 PA8J270279
Coding: 0110001
VCID: 3731B8DF74DD94CCA538FC-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 A HW: 7P6 959 107
Component: HDSG-Modul H10 0620
Revision: 22010001
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202137
ROD: N/A
VCID: 3D3DAAF756E1269C7F743E-8068
No ASAM data for: "EV_HeckkTouar"
Component: TSG HR H09 0167
Revision: --------
End--(Elapsed Time: 02:56, VBatt start/end: 14.1/14.7 Vign: 0.0)-
