2014 VW Caddy ABS Long Coding Lost? (MK60EC1)
nazdaq100
London, United Kingdom
C?ID=314050
Hi Everyone,
I have lost coding for ABS Pump after changing the engine, I would be grateful if you could some one please find me a long coding for this ABS Module,
(Control Module; Not Coded)
Thank you
nazdaq100
Thursday,06,February,2020,15:46:16:42869
VIN: WV1ZZZ2KZFX148667   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56
VIN: WV1ZZZ2KZFX148667   Mileage: 2600km-1615miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114014030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023TF 003002
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 7DA60856BD7B19BFA21-8028
6141 - Coolant Fan Control Circuit 1
          P0480 00 [032] - Electrical Malfunction
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:01:25
                    Coolant temperature: 8 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 11.972 V
                    Engine speed: 0 /min
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 9 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 7 °C
                    Outside air temperature-Ambient temperature: 9.00 °C
                    Coolant fan 1: activation-Radiator fan 1: activation: 9.8 %
9859 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [040] - Signal too High
                    Mileage: 2541 km
                    Date: 2018.03.17
                    Time: 15:36:17
                    Engine speed: 780.50 /min
                    Normed load value: 26.3 %
                    Coolant temperature: 20 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.231 V
                    Unlearning counter according OBD: 38
9860 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [032] - Malfunction
                    Mileage: 2545 km
                    Date: 2019.09.19
                    Time: 21:56:27
                    Coolant temperature: 4 °C
                    Intake air temperature: 5 °C
                    Voltage terminal 30: 11.746 V
Readiness: 0 1 0 0 0
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   Shop #: WSC 35110 377 08192
   VCID: 7EA40F5AB0FD02A7BBB-802A
6 Faults Found:
                    Reset counter: 39
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 01:58:11
                    Count: 7
                    Count: 3
                    Count: 20992
                    Count: 128
                    Count: 28928
                    Count: 65280
                    Reset counter: 253
                    Mileage: 2545 km
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 195
                    Count: 41472
                    Count: 253
                    Fault Status: 01100101
                    Reset counter: 253
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:01:24
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 212
                    Count: 41216
                    Count: 253
                    Reset counter: 253
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:01:24
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 279
                    Count: 41216
                    Count: 253
                    Reset counter: 253
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:01:24
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 270
                    Count: 41216
                    Count: 253
                    Reset counter: 253
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:01:24
                    Count: 2
                    Count: 2
                    Count: 20992
                    Count: 291
                    Count: 41216
                    Count: 253
   Part No SW: 7N0 907 426 CH    HW: 7N0 907 426 CH
   Component: AC Manuell    H20 0606
   Revision: 00001002
   Coding: 0010004002
   VCID: 7CA00552A66110B795F-8028
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2021.11.17
                    Time: 00:01:01
          B10AB F0 [009] - Too Low
                    Reset counter: 253
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 18:46:27
   Part No SW: 5K0 937 086 S    HW: 5K0 937 086 S
   Component: BCM PQ35 M+   122 0173
   Revision: BD122001
   Coding: 491A583A8025F16B08880082900001640301728852028060648000000040
   VCID: 44D0BDB29E91A877ADF-8010
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 23041  27  0512
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 172
   Component: Sensor, DWA 0  005 0502
22 Faults Found:
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 01:05:28
                    Voltage: 8.00 V
                    Reset counter: 38
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 17:51:22
                        Term 15 Off
                    Voltage: 12.35 V
00897 - Windshield Washer Pump (V5)
                    Reset counter: 254
                    Mileage: 127102 km
                    Date: 2021.07.01
                    Time: 23:37:10
                    Voltage: 14.10 V
                    Fault Status: 00101010
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:46
                    Voltage: 12.20 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:46
                    Voltage: 12.20 V
01134 - Alarm Horn (H12)
                    Reset counter: 38
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.45 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 01:05:60
                    Voltage: 9.00 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:46
                    Voltage: 12.20 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:46
                    Voltage: 12.20 V
                    Fault Status: 01101010
                    Reset counter: 14
                    Mileage: 124068 km
                    Date: 2021.05.09
                    Time: 01:53:31
                    Voltage: 11.65 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:46
                    Voltage: 12.20 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:46
                    Voltage: 12.20 V
                    Reset counter: 213
                    Mileage: 117611 km
                    Date: 2020.11.19
                    Time: 22:25:10
                    Voltage: 11.70 V
                    Fault Status: 00100111
                    Reset counter: 36
                    Mileage: 130920 km
                    Date: 2016.03.04
                    Time: 11:12:32
                    Voltage: 13.95 V
                    Reset counter: 39
                    Mileage: 117611 km
                    Date: 2020.11.19
                    Time: 22:25:04
                    Voltage: 11.55 V
                    Reset counter: 3
                    Mileage: 117604 km
                    Date: 2020.11.19
                    Time: 21:58:05
                    Voltage: 11.35 V
01835 - Bulb for Side-Blinkers; Right (M19)
                    Reset counter: 3
                    Mileage: 117604 km
                    Date: 2020.11.19
                    Time: 21:58:05
                    Voltage: 11.35 V
                    Reset counter: 3
                    Mileage: 117604 km
                    Date: 2020.11.19
                    Time: 21:58:05
                    Voltage: 11.40 V
                    Reset counter: 1
                    Mileage: 117611 km
                    Date: 2020.11.19
                    Time: 22:20:16
                    Voltage: 13.95 V
02483 - Module for Locking of Rear Lid (F327)
                    Fault Frequency: 10
                    Reset counter: 38
                    Mileage: 127531 km
                    Date: 2021.07.11
                    Time: 01:56:07
                        Term 15 Off
                    Voltage: 12.25 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 00:00:49
                    Voltage: 12.10 V
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 01:05:57
                    Voltage: 9.00 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 2K0 919 475     HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0004
   Revision: --------    Serial number: 32901404800634
   Coding: 108002
   ASAM Dataset: EV_EPHVA14VN3370000 001006
   ROD: EV_EPHVA14VN3370000.rod
   VCID: 70B82162FA2964D7397-8024
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [008] - Open Circuit
                    Reset counter: 3
                    Mileage: 117604 km
                    Date: 2020.11.19
                    Time: 21:58:46
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2021.11.17
                    Time: 01:05:52
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 38
                    Mileage: 130961 km
                    Date: 2021.11.17
                    Time: 01:05:52
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag02Q H07 0013
   Revision: --------    Serial number: 003HL00N9F24
   Coding: 000000000000000000000000000000003251
   VCID: 3536D076C5CB01FF2A1-8060
                    Mileage: 117604 km
                    Date: 2020.11.19
                    Time: 03:52:18
   Part No SW: 1K5 953 521 BK    HW: 5K0 953 569 AC
   Revision: FF010042    Serial number: 20140221300560
   Coding: 4080160000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 77AA1A7E9F4733EFF8D-8022
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 38
   Part No SW: 2K0 920 976 E    HW: 2K0 920 976 E
   Component: KOMBI         H04 0905
   Coding: 480800
   VCID: 3332EE6ECBBF1FCF045-8066
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 80
                    Mileage: 2544 km
                    Date: 2019.03.14
                    Time: 21:44:18
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 38
                    Mileage: 2541 km
                    Date: 2018.03.17
                    Time: 15:36:23
12718592 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                    Reset counter: 38
                    Mileage: 2545 km
                    Date: 2019.03.16
                    Time: 00:00:03
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 260214F2001840
   Coding: 357401
   VCID: 79AE1C46A9D3259F8E9-802C
                    Fault Status: 00110100
                    Reset counter: 37
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 17:51:19
                    Reset counter: 2
                    Mileage: 117604 km
                    Date: 2020.11.19
                    Time: 03:52:17
00532 - Supply Voltage B+
                    Reset counter: 37
                    Mileage: 130961 km
                    Date: 2016.04.09
                    Time: 07:35:02
   Component: IMMO          H04 0905
   VCID: 6A8C330ADCF59E07773-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 2545 km
                    Date: 2020.02.05
                    Time: 00:01:25
Address 37: Navigation
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000560
   VCID: 48C8A982AEB98C17417-801C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   Shop #: WSC 35110 377 00190
   VCID: 392EDC46E553E59FCE9-806C
                    Fault Status: 11100101
                    Battery Volts: 12.2 V
                        PD
                    Temperature: 11.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000560
   VCID: 47CAAABEA3A7836F48D-8012
Address 56: Radio
End----------(Elapsed Time: 01:05, VBatt start/end: 12.9V/12.6V)-----------
Vehicle Identification No.WV1ZZZ2KZFX148667
Modelcaddy panel van
CA
Date of production15.05.2015
Model year2015
Sales type2CAA82
Engine CodeCAYD
Transmission CodeLZY
FOD CHECK!
Part No SW: 03L 906 023 TF HW: 03L 907 425 C <<<<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD CHECK PASS!
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM <<<<<<<<<<<<<<<<<<<<<<<<<<<< FOD FAIL!
Revision: 00H46001
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components0HDVehicle class differentiation -2K0/2KC-
Hill start assistUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard7MJEmission standard EU5 plus
Trailer hitch1D0Without trailer hitch
airbag4UCdriver airbag
Storage compartment packageQE0Without storage compartment package/box
Exterior mirror setting6XAExterior mirrors, adjustable from outside
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA9LPanel van
batteriesJ0NBattery 330 A (61 Ah)
Brake type, front1ZEDisc brakes in front (Geomet D)
Components with special surface6FAComponents without special surface appearance
Floor coverings in cab5ACRubber floor covering in cab
Floor covering in passenger/luggage compartment5BAWithout floor covering in passenger/ load compartment
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0Abuild parts set without county specific documentatio
Owner's manuals0VFInformation kit in English
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC45Operating permit, alteration
Shock absorption/suspension, chassis1BAStandard suspension/shock absorption
Roof rails/roof load rack3S6Roof rails preparation
Roof insert/convertible top3FAWithout roof insert (standard roof)
Roof trim5CLRoof trim in cab as comfort headliner, in load compartment with hardboard
Insert for the filling up of unleaded fuel/fuel type2G2Without insert for the filling up (diesel) without fluorination (not RME-resistant)
Installation differentiation for components0EJInstallation differentiation for transmission MQ 250 -- vehicle components --
Theft protection system7AAElectronic immobilizer
Inserts5TCNo trim inlay
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
chassis/running gear2E215-inch chassis
window regulator4R0Window regulator, mechanical
fire extinguisher6A0without fire extinguisher
Headlight activation8K1Separate daytime running light
Fresh air intake for passenger compartment (with particulate filter)2V1dust-pollen filter
Antifreeze1C1Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Interior noise suppression measures3W0Without additional noise suppression measures for passenger compartment
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G4Cable gearshift
Weight category rear axle0YAWeight range 1 installation control only, no requirement forecast
Weight category front axleL15Suspension range 15 installation control only, no requirement forecast
Base engineTF34-cylinder diesel engine 1.6 l unit 03L.1
Luggage compartment cover3U0Without luggage compartment cover
cruise control system8T0Without cruise control system (CCS)
Transmission specificationsG0C5-speed manual transmission
glove box4Z1Standard glove compartment
Rear gates/tailgate3RERear wing door with window aperture
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear window insert4HHHeated rear window
Rear seats5KSwithout rear seats
Heating and air-conditioning systemKH6Air conditioning system with electronic control
Rear side window for load or passenger compartment, left4FAWithout side window opening in the rear left luggage compartment
Rear side window for load or passenger compartment, right4JAWithout side window opening in the rear luggage compartment on the right
Headlamps8IAHalogen headlamps
Labels1HZLabels without country group
Interior lighting9MFInterior lighting
Instrument clustersU5BInstrument cluster, mph speedometer -Great Britain-
Instrument panel4N0Standard dashboard (Leather trimmed minor gauges + Ipod drawer)
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Body styleK4APanel Van
Climatic zones0Y1Standard climatic zones
Fuel quantity for initial filling1Z0Initial standard fuel filling
Radiator grille6KARadiator grille
Rear license plate carrier6P9Rear license plate carrier
Paint preservative/transit coating5K0Without surface protection, with additional transport protection measures
Steering system arrangementL0RRight-hand drive
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Lumbar support7P0Without lumbar support in seat backrests
steering wheels2PGSteering wheel
Driving on the left/on the rightAV0Driving on the left
Speaker installation8RD2 speakers (passive)
Leather parts3HAWithout leather parts scope
Headlight range control8Q1Headlight range control
VersionsFM0Basic equipment variant
Multi-function display/trip computer9Q5Multi-function display with control
Center console3D2Center console
Engine cooling8Z5not hot country
Engine specificationsD274-cyl. diesel engine 1.6 l/75 kW (4V) TDI common rail base engine is TF3
Market-specific vehicle versionAW5Standard version
Left vanity mirror4SAWithout left-hand vanity mirror
Right vanity mirror4TAWithout right-hand vanity mirror
Navigation device7Q0without navigation system
Front fog lamp/additional headlamp8WAWithout fog lights
Payloads0J2Standard payload
Upgrading measuresGP0Vehicles without special upgrade measures
Hubcaps1NEHub cap
WheelsC4BSteel wheels 6J x 15
Radios8UARadio with CD player
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K0Without tyre pressure monitor
tireHD2Tires 195/65 R15 91T
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Steel spare wheel with original equipment tire
Wheelbases0E1Short wheelbase
PZ2Cell phone preparation (without voice control)
WF3Great Britain
Side airbag4X0without side airbag
Special labels/plates0SAno special stickers/labels
Pane type (except windshield)QL3Heat-insulating glass (green)
Service indicatorQI6Service indicator 30 000 km or 2 years ( variable )
Front seat, left3TBStandard seat in front, left
Front seat, right3SBStandard seat in front, right
Seat belt check9P0without press button buckle with warning contact
seat coversN2DSeat trim covers in woven fabric
Seat adjustment3L2Manual height adjustment for right front seat
seat heater4A0without seat heater
Side interior lighting passenger/luggage compartment5DCStandard side trim panel in passenger compartment
Key for locking system8QJKey for locking system with remote control
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Control number (no PR family)S073.5 t permissible traction weight
power outlet7B0without socket
Bumper2JBStandard bumpers
Drawers under front seatsQN0Without drawers under front seats
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N1Windshield wiper intermittent control
Special approval measures3M2Light truck design
Nameplate set0NBNameplate set in basic style
Doors in cab0D1Driver compartment doors
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Doors, passenger/load compartment, left5Q2Sliding door left in load/passenger compartment
Doors, passenger/load compartment, right5R0Without doors in passenger/load compartment right (closed sideboard)
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition5WCPartition, high, plastic, grille in upper part
Door and side trim panels3LDdoor and side trim panels
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EVSpecial identification label for EC for commercial vehicles
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T0Without first aid kit and warning triangle
Front side window for load or passenger compartment, left4DAWithout side window aperture in load compartment, front left
Front side window for load or passenger compartment, right4EAWithout side window aperture in load compartment, front right
Telephone / telematics9ZNPreparation for telephone without voice control, without 3-button module
LongLife Service RegimeQG1LongLife Service Regime
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional dust seals6U0Without additional seals outside
Auxiliary heating system9M0Without auxiliary heater/parking heater
Dana
Western PA, USA
I agree with Jack and came up with the same based on VIN. This vehicle should have had 1K0 907 379 BS factory installed and the BM is another VIN split. Temp screen shot here:
https://media.trillian.im/media/?m=...a9F08m/wRwZP+5tFisDT2+cxkqMgpxxhyEz1YSGlXtQ==
nazdaq100, Are you positive WV1ZZZ2KZFX148667 is the correct VIN rather than the incorrect VIN due to used Immo related modules?
P.S. I built the coding based on the VIN provided and believe golfi_vend is correct.
nazdaq100
C?ID=314050
Hi Everyone,
Thank you for quick response I have noticed last 2 letters are 1K0 907 379 BM from scan. However I can see from part search you have found 1K0 907 379 BS. If the coding does not work? what is my next option?
I am completely lost with Jacks post I am sure its useful post I have gone thoroughly seen chart/table. I don't know how to work out or what to do with it? but if there is a video or guide I am very intrigued to learn VCDS
nazdaq100
Hi Everyone,
nazdaq100
Yeah I'm often misunderstood..... :p
That list is a detail of the codes on white tag in trunk/jam area/service book to make sense of it.
http://wiki.ross-tech.com/wiki/inde...Codes)_can_be_found_on_the_Vehicle_Data_Label
Dana
Western PA, USA
