Throttle Body Alignment Group no, on a VW Crafter?
Lightboy
C?ID=382313
Been advised that i might need to do a throttle body alignment and having been though all the groups in basic settings, including 060 and 098, i have not found anything? Only about a dozen or so groups actually seem to be live or have the potential to perform a task.
Questions:
Does anyone know the group for a throttle body alignment?
Do the groups in basic setting relate to the groups in the measuring blocks?
Is it within output tests?
Can an output test make changes? so contain something like the throttle body alignment ?
All help welcome
James
HMC
C?ID=28246
Hi James,
We need a full Auto Scan, but I am assuming you have a diesel Crafter so no throttle body to align.
Regards HMC
Lightboy
C?ID=382313
Hi MHC,
will post the auto scan in the next reply but as the vcds does not fully communicate with the crafter (yes diesel) it does not show much, the vcds system does not always read properly, stating Redir Fail!!!
The main point was that before i got the vcds, a mechanic read codes p2112 and P2111 - Throttle actuator control system open/closed which was the first time it was read post loosing power and engine light coming on.
From own research and actually running the output test in vcds to open and close it, i am fairly sure i have a throttle body or throttle valve control element as it might be know, this one to be precise - OEM 076 128 063.
Having seen many folk posting about loss of power etc with other cars etc, and about this part losing settings if power is lost or if the ECM is detached, i thought it might need to re align.
James
Auto scan bellow
Lightboy
C?ID=382313
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
          B0 B1 B2 B3 B4 B5 B6 C1
VIN: WV1ZZZ2EZB6010913
Address 91: LT3 Engine        Labels: Redir Fail!
   Part No SW: 076 906 022 P    HW: 076 906 022 G
   Component: R5 2,5L EDC A0A0SG  7730
   Coding: 0003032
   Shop #: WSC 80093 222 71269
   VCID: 2019E796C6CC54B7E97-8074
No Faults Found
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serial number: VWXDZ0J1023775
   VCID: 6D87CEA2419E49DF121-8038
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F78642C58EE11FCA1-8000
Address 95: LT3 ESP
   Part No SW: 9069022800    HW: 0004460153
   ASAM Dataset: 3 4101
   ROD: CRFT_ESP_3_36946.rod (*)
   VCID: 04518B067E94A897EDF-8050
Address 96: LT3 Instruments
   Part No SW: 9069026400    HW: 9069012000
   ASAM Dataset: 32 787
   ROD: CRFT_KOMBI_32_787.rod
Address 99: LT3 Ign. Switch
   Part No HW: 9065455808
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serial number: 12345678901234
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3F0FA036AD76F9C5-802E
Address B4: LT3 Central Elec.
   Part No SW: 9064420700    HW: 9065453801
   ASAM Dataset: 33 772
   ROD: CRFT_EZE_33_772.rod (*)
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 0655910E48A89A87F3B-8052
End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.2V)-----------
Lightboy
C?ID=382313
This is OBD2
Tuesday,28,January,2020,12:18:11:64379
VIN: WV1ZZZ2EZB6010913   License Plate:
Mode 03: Emission related fault codes
Address 7E8: 3 Faults Found:
P2BAC - NOx Emissions Exceeded:  Deactivation of EGR
P2BAB - NOx Emissions Exceeded:  Incorrect EGR Flow
P2458 - Diesel Particulate Filter: Regeneration Duration
Mode 07: Pending emission related fault codes
Address 7E8: 2 Faults Found:
P22A7 - NOx Sensor 2 Bank 1; Heating Circuit: Implausible Signal
Freeze Frame Data for address 7E8
    PID02 DTC that caused freeze frame data storage: P2BAC
    PID04 Calculated load value: 47.1 %
    PID05 Engine coolant temperature: 89 °C
    PID0B Intake Manifold Absolute Pressure: 107 kPa abs
    PID0C Engine RPM: 1595 /min
    PID0D Vehicle speed: 16 km/h
    PID0F Intake air temperature: 16 °C
    PID10 Mass Air Flow: 32.69 g/s
    PID11 Throttle position sensor: 79.2 %
For the "Throttle module", try Basic Settings, Group 124. Prerequisites:
* Connect a battery charger!
* Ignition ON, engine not running.
* Check faults directly in 01-Engine both before and after.
Lightboy
C?ID=382313
Cheers Uwe but the engine is on Group 91 on the LT3/Crafter and there is nothing available on Group 124 in basic settings sadly.
MartinsX
Riga, Latvia
C?ID=268515
According OBD mode fault codes there is nothing TB related.
Try to access module 91 directly, as in autoscan mode it doesn't want to show fault codes. There should be some more accurate fault code descriptions and additional FF data available.
My bad. :facepalm:
Then the German documentation I looked at is wrong. Not sure what to tell you.
Are you able to read fault codes when you access 91-Engine directly?
NEtech
C?ID=56995
What do you mean with "engine is on Group 91", you are communicating with Engine, every Group is engine.
I think Basic Setting in Group 124 should be possible.
Charger connected
[Fault codes-02] Clear codes if any
In engine ([01] or [91])
[Basic Settings-04]
Write 124 in Group
Press [Go!]
Show a screenshot of that here.
This Basic Setting is used if "Throttle module" or Engine controller is exchanged!
So I don't think this will help on you problem, whatever that is.
Lightboy
C?ID=382313
sorry that is what i mean
Lightboy
C?ID=382313
cheers will check group 124 in morning
