- Joined
- Jun 2, 2019
- Messages
- 8
- Reaction score
- 1
- Location
- Dominican Republic
- VCDS Serial number
- C?ID=370947
Hello friends, I'm no mechanic and I've been playing around with the vcds Vag Com for a few days, this has left me with what used to be a perfectly working car with lots of new small problems.
Here's the latest scan, I really don't know if the 4wheell drive issue will be detailed since I tricked the the car to stop giving me that specific warning light
Tuesday,04,February,2020,14:35:40:03138
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: Fico's
VIN: WAUVVAFR9AA013227 License Plate:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 0F 15 16 17 19 20 22 36 42 46 47 52 53
55 56 5F
VIN: WAUVVAFR9AA013227 Mileage: 67590km-41998miles
04-Steering Angle -- Status: Not registered 0001
20-High Beam Assist. -- Status: Cannot be reached 1100
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAUB) Labels:. 079-907-560-CAU.clb
Part No SW: 8T0 907 560 T HW: 8T0 907 560
Component: 4.2l V8/4V H12 0002
Revision: 76H12---
Coding: 01140009190F0120
Shop #: WSC 06325 123 12345
VCID: 4BD6757EEAC9521702-801E
005715 - Please check DTC Memory of ABS Controller
P1653 - 001 -
Fault Status: 01100001
Mileage: 67597 km
Date: 2019.02.04
Time: 14:15:57
Temperature: 83.0°C
Temperature: 72.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
P1653 - 008 -
Mileage: 67597 km
Date: 2019.02.04
Time: 14:15:57
Temperature: 83.0°C
Temperature: 72.0°C
Voltage: 11.684 V
049456 - Steering Effort Control Module
U0130 - 008 - No Communications
Mileage: 67597 km
Date: 2019.02.04
Time: 14:15:57
Temperature: 83.0°C
Temperature: 72.0°C
Voltage: 11.684 V
001153 - Coolant Fan Control Circuit 2
P0481 - 004 - Electrical Malfunction
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:54
RPM: 165 /min
Load: 100.0 %
Temperature: 78.0°C
Temperature: 73.0°C
Voltage: 10.160 V
Readiness: 0110 1101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 H HW: 0B6 927 156
Component: 0B6 42 FSIUSA H05 0005
Revision: --H05---
Coding: 001012
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 3B3625BEB269E297B2-806E
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Coding: 126D1A
VCID: 7AB8E0BAF5D31B9FE9-802E
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:31:40
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0031
Hex Value: 0x3194
Hex Value: 0x00FF
03110 - Active Steering Control Module (J792)
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:31:40
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0029
Hex Value: 0x8594
Hex Value: 0x00FF
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:31:40
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0028
Hex Value: 0x8294
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0324
Coding: 052000
VCID: 78BCFAB2CBDF098F9F-802C
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000053882009
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01300720090642
Coding: 48120000
VCID: 004C9252930F414FA7-8054
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:33
Temperature: 37.0°C
Voltage: 11.60 V
Output: 0 W
Output: 0 W
Temperature: 29.0°C
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000434694
Coding: 0608D215063C9F212701000300003D3D4F9CD2C800010161000000
VCID: 3C3426A2BF67E5AFBB-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290709 H14 0070
Serial number: SWF09070290215
Coding: 00F911
Component: RLS H04 0003
Serial number: 10554023
Coding: 03532C
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Serial number: 00000000000307090030
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 0E: Media Player 1
Address 0F: Digital Radio
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Serial number: 003EGD0291U2
Coding: 303333334330303030304A55304C38543053
VCID: 42C8585AD583935FF1-8016
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0900004HBT
Serial number: 6334MSME407227544
Serial number: 6344MSME4956186BO
Serial number: 6352QSME3D352928M
Serial number: 6362QSME61350C027
Serial number: 63732SME18340908W
Serial number: 63832SME73332618X
12660736 - Steering Effort Control Module
U0130 00 [009] - No Communications
[Active Steering Control Unit no communication]
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:35
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IGM000JT
Coding: 000036
VCID: 3E302CAAA97BF7BF95-806A
Component: E221 - MFL H02 0003
Part No SW: 8T0 920 981 N HW: 8T0 920 981 N
Component: KOMBIINSTR. H33 0253
Revision: 00400000 Serial number: BYM23HR79
Coding: 82FD01000B005404820201
VCID: 47DE494EF6A1B67726-8012
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E097108073
Coding: 00C303
VCID: 52E8681A0DE303DF41-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 1908721D060709
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:34
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:38
Bin. Bits: 10111
Voltage: 11.60 V
Count: 6
Address 20: High Beam Assist.
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 001607090001155
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
VCID: 6D92DBE6BC9DBC277C-8038
0312 - invalid data record
B2005 00 [001] - -
[Ungültiger Datensatz DTC_DAT_INVALID]
Part No SW: 8T HW: 8T0 9
VCID: 0C54B662AF47152FCB-8058
No Faults Found
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009132872
Coding: 011F13220E00220100
VCID: 45C24346CCADA467D4-8010
Revision: 00002001 Serial number: 0120487913
Coding: 015F1E8300FE40070393008400000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000160244
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
01207 - Control Module for Auxiliary Heater (J364)
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:33
03156 - Sensor for Anti-Theft System (G578)
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:37
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AK HW: 8T0 035 223 AK
Component: DSP Prem H08 0170
Revision: 00008001 Serial number: 34881005038903
VCID: 77BEF98EC6C106F796-8022
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009100320
VCID: 44C45E42C7979D6FC3-8010
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 10000000288834
VCID: 34240E8297372DEF73-8060
Part No: 8K5 907 357
Shop #: WSC 06324 000 00000
VCID: 77BEF98E06C106F796-8022
Fault Status: 11100101
Reset counter: 42
Mileage: 67597 km
Date: 2019.02.04
Time: 14:30:33
00003 - Control Module
014 - Defective - MIL ON
Fault Status: 11101110
Reset counter: 36
Mileage: 65981 km
Date: 2019.06.03
Time: 17:57:28
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335GS097523009
Coding: 020000010000000001
VCID: 1D72CB2604BD8CA7AC-8048
Fault Status: 00101110
Mileage: 33955 km
Date: 2014.02.24
Time: 08:57:33
Bin. Bits: 00000000 00001000
Part No SW: 8T1 035 664 A HW: 8T1 035 664 A
Component: H-BN-NA H41 0042
Revision: -------- Serial number: 490GX097513580
Coding: 010100020206E1FCC7091F0C000000030000
VCID: 3620348A814B3FFF4D-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356GN091043631
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000333812
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Reset counter: 82
Mileage: 67597 km
Date: 2019.02.04
Time: 14:31:46
Bin. Bits: 00000000 00000000
Bin. Bits: 01000000 00000001
End----(Elapsed Time: 02:22, VBatt start/end: 12.1V/11.7V. VIgn 11.7V)-----
Controller Software Versions:
ECU 1 = Engine 0002
ECU 2 = Auto Trans 0005
ECU 3 = ABS Brakes 0010
ECU 4 = Acc/Start Auth. 0324
Sub ECU 4 > 1 = Acc/Start Auth. 0042
ECU 5 = Auto HVAC 0171
ECU 6 = Cent. Elect. 0380
Sub ECU 6 > 1 = Cent. Elect. 0070
Sub ECU 6 > 2 = Cent. Elect. 0003
Sub ECU 6 > 3 = Cent. Elect. 0090
Sub ECU 6 > 4 = Cent. Elect. 0010
ECU 7 =
ECU 8 =
ECU 9 = Airbags 0520
Sub ECU 9 > 1 = Airbags 0050
ECU 10 = Steering wheel 0014
Sub ECU 10 > 1 = Steering wheel 0003
ECU 11 = Instruments 0253
ECU 12 = CAN Gateway 0105
Sub ECU 12 > 1 = CAN Gateway 0160
ECU 13 =
ECU 14 = AWD 0004
ECU 15 =
ECU 16 = Door Elect, Driver 0306
ECU 17 = Central Conv. 0324
Sub ECU 17 > 1 = Central Conv. 0050
Sub ECU 17 > 2 = Central Conv. 1301
Sub ECU 17 > 3 = Central Conv. 0220
ECU 18 = Sound System 0170
ECU 19 = Door Elect, Pass. 0306
ECU 20 = Parking Brake 0090
ECU 21 = Headlight Range 001
ECU 22 = Radio 0021
ECU 23 = Information Electr. 0042
Sub ECU 23 > 1 = Information Electr. 5304
Sub ECU 23 > 2 = Information Electr. 0306
Sub ECU 23 > 3 = Information Electr. 0100
Sub ECU 23 > 4 = Information Electr. 1293
