2017 Audi S3 Trouble Codes Help
hussain.ali15
C?ID=373132
Hi everyone,
I've got a S3 bought from a salvage yard that I'm repairing. Could someone help me by providing a list of what isn't working according to the autoscan?
Much Appreciated! :)
Saturday,01,February,2020,17:24:41:61881
VIN: WAUZZZ8V5H1023620   License Plate: YP66 MUC
Mileage: 70484km-43796mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 13 14 15 16 17 19 22 42 44 47 52 55 5F A9 BB
          BC
VIN: WAUZZZ8V5H1023620   Mileage: 70484km-43796miles
55-Headlight Range -- Status: Cannot be reached 0100
BB-Door Rear Drv -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: Malfunction 0010
Address 01: Engine (J623-DJHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A2500122466010B2004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001004
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 47CB5B01DF22EFAF48D-8012
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:49
                    Coolant temperature: 63 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 11.796 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 86.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 28 min
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Main switch CAN: operated
                    T_AST_SAE: 0 s
Readiness: 1010 0001
   Part No SW: 0GC 300 011     HW: 0DE 927 711 C
   Component: GSG DQ381     H12 0403
   Revision: 00H12V32
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 5F9BA36167B2876F90D-800A
   Part No SW: 8V0 907 379 B    HW: 8V0 907 379 B
   Component: ESC           H25 0610
   Revision: 00000000    Serial number: 62196000000302
   Coding: 319C938D549B1BAC8B970B664191698CC92AD8D1D0829677184150F4820812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   VCID: 43D34F11EB1AC38F945-8016
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 126
                    Date: 2020.02.01
                    Time: 12:24:51
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 86
                    Date: 2020.02.01
                    Time: 12:24:51
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 86
                    Date: 2020.02.01
                    Time: 12:24:51
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 126
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:25:03
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 126
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:25:03
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001035843
   Coding: 03100004000000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D9401DFA0CD897897-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: 29590A4800PAG0MUFU03
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:52
                    Outside air temperature: 10 °C
                    Temperature after evaporator: 27.0 °C
                    Refrigerant pressure: 1.0 bar
                    System run time-Terminal 15 on: 253 s
   Serial number: 02001624600677
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5FEE5C0786E67BBB-802A
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS371 160706  043 0585
   Serial number:         160714223621
   Coding: 0A47F7
   Serial number: 62222785
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 28 06 2016  00001745
   Serial number: 000000000ZY162182CYN
   Serial number: 00000000000036270187
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
                    Reset counter: 87
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 13:42:11
540693 - Databus
          [LWR_AFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:27
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 87
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 13:42:10
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Reset counter: 87
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 13:42:10
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:27
Address 13: Auto Dist. Reg
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       300716007
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
10522629 - Databus
          [init value steer angle]
                    Reset counter: 126
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
                    COM: 07 3E 07 1F 00 06 A2 E2 00 00
                    Voltage terminal 30: 11.9 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Steering angle: Not available
                    Steering rate: 0 rad/s
                    AMR state: 0
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    Fall-back level: 00 00 10 20
10522630 - Databus
          [old value steer angle]
                    Reset counter: 126
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
                    COM: 07 3E 07 1F 00 06 A2 E3 00 00
                    AMR state: 0
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR24JPJC
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B05DEAEC6817597-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 001 009 16
   Serial number: 3570000000010560CD1A
   Subsystem 2 - Part No SW: -----------    HW: 480 001 009 16
   Serial number: 358000000002FB15FD1-
   Subsystem 3 - Part No SW: -----------    HW: 480 400 309 16
   Serial number: 3510001AF2280CB366FE
   Subsystem 4 - Part No SW: -----------    HW: 480 400 309 16
   Serial number: 3520001A12280CB1C42X
   Subsystem 5 - Part No SW: -----------    HW: 480 402 605 17
   Serial number: 3550002A324F3843312U
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 906 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001C3260B4F52782
   Subsystem 7 - Part No SW: -----------    HW: 480 402 906 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001C3260B4F59724
   Subsystem 8 - Part No SW: -----------    HW: 480 002 006 17
   Serial number: I0M0000000088C35B427
   Subsystem 9 - Part No SW: -----------    HW: -----------
   Component: PedPSensor_P2  --- ----
   Serial number: -------------------$
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:25
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
9735701 - Pedestrian Protection Crash Sensor 2; Passenger Side
          B148E 15 [137] - Open or Short to Plus
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:27
   Part No SW: 8V0 953 521 JF    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 17071604400309
   Coding: E018
   VCID: 074B9B019FA22FAF88D-8052
227607 - Signal horn activation
          B1146 11 [009] - Short to Ground
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
                    Operating time: 100952 min
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H13 0045
   Coding: 248D18423F8026000181E8001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79AFEDF9D956495F8E9-802C
16776970 - Databus
          [LWR_AFS_01 communication error can_error_timeout]
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
16777107 - Databus
          [ACC_02 communication error can_error_timeout]
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:25
   Revision: --------    Serial number: 10091610520799
   Coding: 030100043F085A005B008278BC0B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA1F4EDD6647C7795F-8028
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160909145314 21632
   Serial number: 75410803001609011190
66566 - Extended CAN Bus (SAE Bus C)
          U0046 00 [009] - Malfunction
          [Bus defekt CAN-Extended]
                    Fault Frequency: 41
                    Reset counter: 87
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
          U1101 00 [008] - Active
                    Reset counter: 127
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:24
                    Terminal 15: On
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7755
   Serial number: HA1-00012.08.16
   Coding: 0001
   VCID: 45D75109E52EFDBFBA1-8010
   Serial number: 200816EHJ07265
   Coding: 005D8A204001040000001003
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D32F59CD08247C73-806E
16275 - Steering Angle Sensor
                    Reset counter: 91
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:53
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 21.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 11.75 V
                    uAdSensI_SwitchedKl30_xdu16: 11.74 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: activated
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAH5F010XJ3
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2411EC8D0E54E4B78DF-8070
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6200)]
                    Reset counter: 84
                    Mileage: 70485 km
                    Date: 2020.01.31
                    Time: 16:39:03
                    Voltage terminal 30: 11.5 V
0590 - Front Left Bass Speaker
          B105F 13 [008] - Open Circuit
          [Tieftonlautsprecher Kanal 13: Unterbrechung (DC-Diagnose)]
                    Reset counter: 127
                    Mileage: 21160 km
                    Date: 2018.07.18
                    Time: 11:22:41
                    Voltage terminal 30: 12.2 V
   Serial number: 100616EFA10613
   Coding: 005D82204001040000001003
   VCID: 42DD4A15F400CA879F3-8016
Address 55: Headlight Range
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 8V1 035 035     HW: 8V1 035 035
   Component: MU-P-LND-EU   052 0679
   Serial number: A698I0G7511804
   Coding: 017351010000000011111102000A00332F0027E701700100DE
   VCID: 6FBBD3A1971217EF20D-803A
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY207FLM
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL102061600010432
   Component: Gracenote2---  --- 1013
          B201A 00 [009] - -
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:33
                    Status_Software_Version_Management-module_name: BAMP16cA/AMP16cA
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:29
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 86
                    Mileage: 70484 km
                    Date: 2020.02.01
                    Time: 12:24:29
   Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
   Serial number: 160804200565
   VCID: 3E253EE580F8AE67FBB-806A
   Serial number: 280816CHR10242
   Coding: 000C82204001040000001002
65547 - Supply voltage
          U1012 00 [008] - Voltage too High
                    Reset counter: 121
                    Mileage: 70480 km
                    Date: 2020.01.07
                    Time: 15:15:46
65548 - Supply voltage
                    Reset counter: 118
                    Mileage: 70480 km
                    Date: 2019.08.27
                    Time: 14:01:57
   Serial number: 280816CHR10103
                    Reset counter: 121
                    Mileage: 70480 km
                    Date: 2020.01.07
                    Time: 15:15:55
                    Reset counter: 118
                    Mileage: 70480 km
                    Date: 2019.08.27
                    Time: 14:01:55
End----(Elapsed Time: 01:34, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
darkchina811
ITALY
C?ID=333184
ACC radar is disconnected, probably the wiring got chopped in the crash;
air conditioning circuit leaks somewhere, you lost refrigerant gas;
steering wheel and knee airbags need replacing;
something wrong with horn wiring;
Component Protection active in the gateway and sound amp (requires dealer);
steering angle sensor has to be reinitialized;
something wrong with headlight range module wiring, it's above the knee airbag, not surprised;
you can start with all this. oh, and the body works. good luck.
hussain.ali15
C?ID=373132
Thank You! That was really helpful!
Does the component protection have to get sorted? It’s probably there because the B&O amp was fried and sound wasn’t working so I replaced it. Sound is working again. Sorry if this is a dumb question but what is the Gateway?
darkchina811
ITALY
C?ID=333184
yes Component Protection has to be dealt with, and can ONLY be cleared by a dealer-level scan tool. it kicked in for sure after replacing the amplifier. doesn't matter if sound works, if you roam around the radio features you'll see some will be restricted for sure.
the gateway is a control module who connects to all the others in the car and let them talk with themselves and with a scan tool.
hussain.ali15
C?ID=373132
Thank you both, honestly appreciate it. Do you know how much the dealer usually charges for this service approximately?
darkchina811
ITALY
C?ID=333184
if honest should be half hour, I don't believe it takes more.
Many dealers have a 1-hour minimum charge -- at least here in the US.
hussain.ali15
C?ID=373132
One more thing; the indicators/blinkers work intermittently. Sometimes they work but sometimes they don’t and for both sides. The headlights were changed and are from another donor S3. Could this be because of component protection as well?
The auto scan from OP was done after change of headlights.
DV52
C?ID=194404
hussain: The headlights on a MQB platform vehicle (like the S3) is controlled by the BCM. The CP "constellation" does include the BCM, but on your auto-scan, neither the CAN Gateway (which is the CP master module), or the BCM have recorded a CP in the BCM. So it's highly unlikely that the indicator problem is related to CP error IMO.
That said, the interesting thing about your auto-scan (for me) - besides the DTC rich nature of the report- is why the hex55 module can't be reached. Did the retrofitted lights have a hex55 module?
Also - does the car have a hex13 module (i.e. a ACC radar) on the front grill?
hussain.ali15
C?ID=373132
Thank you for the reply. So just to clarify, you think it is related to component protection?
By the hex55 module, are you referring to the headlight range module? The headlights came with the modules that are attached to them but no other modules.
The ACC radar wiring had been cut off whether as a result of the crash or after the crash is unknown.
DV52
C?ID=194404
hussain: No - blinker problems likely not CP related
as for hex55 and hex13 modules - perhaps remove these from the Gateway installation list (also needs coding changes to tell the other related modules to no longer operate ACC)
