VW T6.1 Bulli
Ray67!
C?ID=313832
Hello there I’m looking for the access code to activate the rearviewcamera
Anyone can help me ?
Chassis Type: 7H-VN75 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 20 44 55 5F 65 69 75 D6 D7
VIN: WV1ZZZ7HZLX006016
Address 01: Engine (J623-CXHA)       Labels: None
   Part No SW: 04L 906 056 SA    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9697
   Revision: 23301001
   Coding: 002540144374050900000000000000000000000000000000
   Shop #: WSC 48555 001 1048576
   ASAM Dataset: EV_ECM20TDI03004L906056SA 004004
   ROD: EV_ECM20TDI03004L906056QF.rod
   VCID: 7EA40FDD807B4AD7BBB-802A
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0BT 300 046 N    HW: 0GC 927 711 H
   Component: GSG DQ500     H06 3107
   Revision: 00H06V09
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 41DEB421B105F52F869-8014
   Part No SW: 7LA 614 517 A    HW: 7LA 614 517
   Component: ESC_high      H01 0700
   Serial number: 08506771190903
   Coding: 305524524847EE8B0C5424A5126C770638272078
   Shop #: WSC 00035 377 00147
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
   ROD: EV_Brake1ESP90iBOSCHVN46X.rod
   VCID: 3D26C8D1CDFD91CFE21-8068
Address 08: Auto HVAC (J301)       Labels: None
   Part No SW: 7LA 907 426 B    HW: 7LA 907 426 B
   Component: AC Manuell    H01 0502
   Coding: A03010000810000001000800504001050000000000000000800000000000
   ASAM Dataset: EV_AirCondiBHTCT6PA 001004
   ROD: N/A
   VCID: 42DCBB2DB403EE379F3-8016
No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
   Part No SW: 2Q5 937 090     HW: 2Q5 937 090
   Component: BCM T6PA Std+ H10 0935
   Serial number: 01101930401462
   ASAM Dataset: EV_BCMA0 205001
   ROD: EV_BCMA0_204.rod
   VCID: 74B02DF5BE371087DDF-8020
   Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S5Y19M10D13H22M49S12
   Coding: 02B8EE
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000035235220
   Coding: 130007
   Subsystem 3 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000034301724
   Coding: 090007
   Serial number: 000000000ZY192803TGL
   Serial number: 00000000000047794889
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419294
   Coding: 0471051911
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_003.rod
   VCID: 50F881656A6F0CA7197-8004
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3200670A49FF8748949C815580508700000000000000000004
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   VCID: 43D2BE29AB19E73F945-8016
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    013 0506
   Revision: --------
   Coding: 8800C00000000000800000CF000C40000065
   Shop #: WSC 00035 377 00131
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F5AF2D9877143DFB0D-802A
Address 17: Instruments (J285)       Labels: None
   Part No SW: 7LA 920 320     HW: 7LA 920 320
   Component: KOMBI         503 4187
   Coding: 04A4088824800008018862051001000000601F02
   ASAM Dataset: EV_DashBoardVDDMQBA0 001041
   ROD: N/A
No ASAM data for: "EV_DashBoardVDDMQBA0" (VN75)
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 01111910800540
   Coding: 030100344F05730401100018100F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF.rod
   VCID: 70B821E5CA2F2CA7397-8024
   Component: 4-01-09-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036308190369
   Coding: 2C1D00
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 7734330100191017035B
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [008] - -
          [Timeout Knoten 0x47 / 69 - Steuergerät für Anhängererkennung]
                    Reset counter: 53
                    Mileage: 388 km
                    Date: 2019.12.20
                    Time: 09:41:15
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
   Part No SW: 565 857 511 B    HW: 7E0 857 511 C
   Component: FLA           H10 0010
   Revision: AA001001
   Coding: 040400E200000000000000
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: N/A
   VCID: 1D6628516D3DF1CFC21-8048
No ASAM data for: "EV_HighBeamAssisAU33X" (VN75)
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: N/A
   VCID: 45D6A031A52DD90FBA1-8010
No ASAM data for: "EV_SteerAssisMNB" (VN75)
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Coding: 0C8A020009210003
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: N/A
No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VN75)
   Part No SW: 3G5 035 816     HW: 3G5 035 816
   Component: MU-O-ND-EU    H12 0156
   Serial number: VWZAZ2W1153425
   Coding: 64600000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: N/A
   VCID: 669447BDF8EBF21753B-8032
No ASAM data for: "EV_MUOIMQB" (VN75)
   Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
   Component: RDKBERU30     H05 0010
   Serial number: 40000000345656
   ROD: EV_RDKBERU30_005.rod
   VCID: 3634D7FDE8CB429723B-8062
Address 69: Trailer (J345)       Labels: None
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0039
   Serial number: 000000000005290
   Coding: 0100000202001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: N/A
   VCID: 6B823689E309CF7F0C5-803E
No ASAM data for: "EV_TrailFunctGener3Hella" (VN75)
336920 - ROD - Unknown Error Code
          - 00 [040]
                    Fault Frequency: 9
                    Reset counter: 40
                    Mileage: 189 km
                    Date: 2019.12.18
                    Time: 10:53:06
Address 75: Telematics (J949)       Labels: None
   Part No SW: 5WA 035 284     HW: 5WA 035 284
   Component: OCUGen3High   H20 0083
   Serial number: 0000000908VITD0
   Coding: 06462000196898209005460160000607
   ASAM Dataset: EV_OCUGen3High 002115
   ROD: N/A
   VCID: 03527E29EB99273FD45-8056
No ASAM data for: "EV_OCUGen3High" (VN75)
1644017 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 37
                    Mileage: 388 km
                    Date: 2019.12.20
                    Time: 11:04:51
0081 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 37
                    Mileage: 7 km
                    Date: 2019.12.11
                    Time: 09:49:04
1190912 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 34
                    Mileage: 209 km
                    Date: 2019.12.18
                    Time: 15:53:38
2566 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 26
                    Time: 00:00:00
   Part No SW: 992 941 571 AA    HW: 992 941 571 A
   Component: LED1L         H08 9002
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X.rod
   VCID: 619E54A111C5952FA69-8034
   Component: LED1R         H08 9002
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:33, VBatt start/end: 12.1V/12.1V)-----------
Does this van actually have a camera installed?
DV52
C?ID=194404
hmm........ given the question - I assume that the RVC has been retrofitted (if so, perhaps the thread should be somewhere else).
Anyway, taking a giant leap of faith and based entirely on the MQB -ish nature of the auto-scan - then it's entirely possible that the RVC on this van is a low-line version: meaning that it's not directly part of the CAN network (albeit it uses CAN stuff like steering angle, vehicle speed etc ). Instead, it's energized by a reversing light and it's directly connected to the rear quad-connector on the hex 5F module via a video cable.
Again, if so and continuing to connect together a set of imaginary dots -perhaps the software switch to tell the hex 5F module to start operating the RVC is the same as in other MQB models: Byte 19, Bit 4.
But as for the actual question posed: "the access code to activate the rearviewcamera" , then the answer could be the venerable magic number 20103 (perhaps?).
But gee-wiz Ray, ... there is certainly an economy of information in your inaugural post (no offense intended). Clarification would be welcomed!!
hadez16
C?ID=289891
Hi Uwe,
I quickly raid this thread to task when better data coverage will be maintained for VW T6.1 in VCDS?
Or in general when will be a next beta available for public? I heard something about 19.11 but that seems to be not very official.
Hi Uwe,
Is there something in particular you are looking for in terms of "better data coverage"?
hadez16
C?ID=289891
Nothing in particular, it just came to my attention that there are some modules with missing data
Ray67!
C?ID=313832
Hi guys
The camera is connected by canbus and connected at the quadlock connector, it is vissible but it comew withe the fault not calibrated but also no access withe the code 31347 I will try in the meantime the other code that is given after trying I will for sure let you know the result😃
Ray67!
C?ID=313832
Sorry guys I’m getting “controller refused to send a seed Error 7F: Service not supported in active session “ I do not know what to do now
darkchina811
ITALY
C?ID=333184
if the camera is not calibrated, it won't work and won't show an image. dealer-level tools are required for calibration.
Ray67!
C?ID=313832
Thanks darkchina made an appointment at the dealer for calibration hopes it works after that will let you know
Ray67!
C?ID=313832
Hi guys got it working later today I’ll let you know the solution
Ray67!
C?ID=313832
In the 5F module you have to activate the pos 15 of the bap vps and the gen2 also Then perform a reset of the radio by pressing and keep holding the power button untill the vw logo is coming up again then its working, I figured that when connected the RVC it had to give an image anyway regardless the calibration done or not, the only fault is only now the calibration of the camera that I will perform later on but that won’t interfere the working of the camera
