2010 Jetta tdi gone haywire after cooling fan replacement
krazyk
Canada
C?ID=363048
Took of front clip to change passenger side cooling fan (from rock auto) and when i put it back together no start. After forever cranking it came alive but not without throwing all sorts of codes and erratic running. The common rail pressure is all over the place as well. I first thought it had something to do with the fuel system or fan replacement but I am now more inclined to think there is a major power issue somewhere. Good battery, good cranking speed, clean terminals, checked all the grounds engine bay, disconnected the new fan, not sure where to look now.
Perhaps inside dash, key switch, grounds? Can someone throw out some pointers?
2010 VW jetta 2.0 tdi, 6 speed
delete and stage 1 modifications
Not sure how i can add a picture of the pr codes here.
vcds double scan, before and after deleting dtc's
Tuesday,28,January,2020,09:36:45:20591
VIN: 3VWJL7AJ2AM029930   License Plate:
Mileage: 182700km-113524mi   Repair Order: 100
Chassis Type: AJ-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: 3VWJL7AJ2AM029930   Mileage: 182700km-113524miles
77-Telephone -- Status: Not registered 0011
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000SG  9971
   Revision: 12H02---    Serial number:
   Coding: 0350072
   Shop #: WSC 18816 935 674630
   VCID: F7BE636B869DABF716-80A2
001152 - Coolant Fan Control Circuit 1
               P0480 - 000 - Electrical Malfunction
                    Mileage: 182700 km
                    Date: 2019.12.29
                    Time: 02:31:30
                    RPM: 1978 /min
                    Temperature: 45.9°C
                    Temperature: 90.0°C
                    Temperature: 8.1°C
                    Lambda: 9.5 %
                    Lambda: 0.0 %
000135 - Fuel Rail/System Pressure
               P0087 - 004 - Too Low - Intermittent
                    Mileage: 182700 km
                    Date: 2019.12.29
                    Time: 02:31:26
                    RPM: 5037 /min
                    Inj. Quantity: 30.7 mg/str
                    (no units): 4.0
                    Pressure: 1400.0 bar
                    Pressure: 664.0 bar
                    Temperature: 25.2°C
                    Tank Cont.: 30.5 l
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 114B400C49240003881402E7921900423000
   Shop #: WSC 00066 000 00000
   VCID: FEB0764F69A79ABF55-80AA
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:42:12
                    Count: 2
                    Count: 2
                    Count: 4096
                    Count: 8194
                    Count: 48640
                    Count: 1
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.11.18
                    Time: 07:40:21
                    Count: 7
                    Count: 3
                    Count: 4096
                    Count: 128
                    Count: 28672
                    Count: 1
   Part No SW: 3C8 907 336 J    HW: 3C8 907 336 J
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00146
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: B42494671F6B80EFF3-80E0
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                    Fault Frequency: 35
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2019.12.29
                    Time: 00:05:29
   Part No SW: 5K0 937 084 A    HW: 5K0 937 084 A
   Component: BCM PQ35 B    008 0019
   Revision: BG008001
   Coding: 6D200B1A902F3EE4000000054000000001000086500085605C8020000000
   VCID: B02C9877E373BCCF97-80E4
   Subsystem 1 - Part No SW: 1K1 955 119 B    HW: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  12  0401
   Coding: 00FFD5
7 Faults Found:
                    Fault Frequency: 8
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.20
                    Time: 00:30:26
                        Term 15 Off
                    Voltage: 12.85 V
                    Fault Status: 00100001
                    Fault Frequency: 24
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.20
                    Time: 00:00:25
                        Term 15 Off
                    Voltage: 5.90 V
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.20
                    Time: 00:30:26
                        Term 15 Off
                    Voltage: 12.85 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 15
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:41:10
                        Term 15 On
                    Voltage: 12.75 V
                    Fault Frequency: 15
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:42:14
                        Term 15 On
                    Voltage: 13.60 V
01516 - Terminal 30; Left
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.20
                    Time: 00:30:26
                        Term 15 Off
                    Voltage: 12.85 V
02391 - Terminal 30 Reference
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.20
                    Time: 00:30:26
                        Term 15 Off
                    Voltage: 12.85 V
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 09 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM00ZJLG
   Coding: 0012345
   VCID: EE90460FF9C7EA3FC5-80BA
   Subsystem 1 - Serial number: 6332MSME49034620%
   Subsystem 2 - Serial number: 6342MSME48722C029
   Subsystem 3 - Serial number: 6351HSME1D1751375
   Subsystem 4 - Serial number: 6361HSME1D175F69P
   Subsystem 5 - Serial number: 63727SME00020E42P
   Subsystem 6 - Serial number: 63827SME000F0E11Z
00532 - Supply Voltage B+
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0000031
   VCID: 824802BFDD5FFE5F31-80D6
   Part No SW: 5M0 920 860 C    HW: 5M0 920 860 C
   Component: KOMBI         H08 0020
   Revision: V0008011    Serial number:
   Coding: 370700
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: AE10860FF147AA3F85-80FA
13635840 - Supply voltage
          [Supply voltage too low]
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2029.06.27
                    Time: 07:30:06
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Fault Frequency: 36
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2029.06.03
                    Time: 00:42:10
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 130709F1002195
   Coding: E9807F06000202001002
   VCID: E6803E2FD137227FBD-80B2
                    Fault Frequency: 36
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:42:12
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:16:43
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H08 0020
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1525
   Revision: 72009005    Serial number: 00000640698811
   Coding: 0001205
   VCID: EFAE5B0BFECDE337CE-80BA
                    Fault Status: 01100101
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:16:41
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2019.10.01
                    Time: 15:59:29
                    Reset counter: 115
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: AF2E9B0B3E4DA3378E-80FA
                    Fault Frequency: 8
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.27
                    Time: 00:28:58
                    Voltage: 11.75 V
                        DU
                    Temperature: 26.0°C
                    RPM: 1498 /min
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1525
   Revision: 72009005    Serial number: 09052000424502
   Coding: 0001204
   VCID: F0AC5877E3F3FCCFD7-80A4
                    Reset counter: 75
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2019.11.07
                    Time: 23:43:55
                    Reset counter: 115
   Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3573047
   Coding: 01000400020006
   Shop #: WSC 00066 790 07025
   VCID: E4842427E70B506FA3-80B0
00856 - Radio Antenna
                    Fault Status: 01101011
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:16:41
02633 - Antenna for Satellite Tuner
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:16:41
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2023.10.25
                    Time: 00:16:41
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2023.11.18
                    Time: 07:36:43
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000004192013
   Coding: 0001168
   VCID: F6A06E6F8197D2FF0D-80A2
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000004207464
   Coding: 0001168
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007663671848
   Coding: 0210040000010110
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: BA38BA5F3D0F769F29-80EE
          [Klemme 30: unterer Grenzwert unterschritten]
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2029.06.27
                    Time: 07:36:08
          U1400 00 [008] - -
                    Reset counter: 115
                    Mileage: 182700 km
                    Date: 2029.06.27
                    Time: 07:36:08
End----------(Elapsed Time: 01:19, VBatt start/end: 12.4V/13.1V)-----------
77-Telephone -- Status: Not registered 0001
   Coding: 0350072
                    Mileage: 182700 km
                    Date: 2019.12.29
                    Time: 02:31:30
                    RPM: 1978 /min
                    Temperature: 45.9°C
                    Temperature: 90.0°C
                    Temperature: 8.1°C
                    Lambda: 9.5 %
                    Lambda: 0.0 %
                    Mileage: 182700 km
                    Date: 2019.12.29
                    Time: 02:31:26
                    RPM: 5037 /min
                    (no units): 4.0
                    Pressure: 664.0 bar
                    Temperature: 25.2°C
                    Tank Cont.: 30.5 l
   Revision: 00H45001
   Revision: 00006001
   Coding: 0000000000
          U1113 00 [009] - -
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:29
   Revision: BG008001
   Coding: 00FFD5
   Coding: 0012345
   Coding: 0000031
   Coding: 370700
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:29
   Coding: 0001205
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:27
   Revision: 00H17000
   Coding: 0001204
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:27
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:27
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:27
                    Reset counter: 75
                    Mileage: 182700 km
                    Date: 2020.01.28
                    Time: 19:10:27
   Coding: 0001168
   Coding: 0001168
End----------(Elapsed Time: 01:15, VBatt start/end: 14.1V/14.2V)-----------
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Pull out fuel filter and see do you have any rust, or metal shaving in it .
This very common problem with CR engines.
HMC
C?ID=28246
Hi krazyk,
I am not sure what you mean by " Took of front clip to change passenger side cooling fan", I presume you are talking about the connector. If the non start happened immediately after the fan work I would be revisiting the area you were working, check for disturbed connectors, pins pulled out of connectors, corroded wires broken with the stress of moving.
What is your rail pressure?
Regards HMC
krazyk
Canada
C?ID=363048
It's all good, even checkd pump.
krazyk
Canada
C?ID=363048
Hi krazyk,
Regards HMC
took off front bumper headlights and all to drop radiators forward, i did revisit all that and unplugged the new cooling fan to make sure it wasn't causing havoc. The commonrail pressure is all over the place and so is the regulator, I even lose connection doing a log. However i might be onto something, I bought this car used a year ago and just found a gps tracker under the steering column
https://autoconnectgps.com/wp-content/uploads/2018/07/AC13003G-QUICK-INSTALL-REV050218.pdf Every wire connection was just taped, pretty severe butch job. I will fix this crap first and report back after everything is back to stock.
krazyk
Canada
C?ID=363048
So this tracker /immo was tied into the ignition switch wiring, one wire fell off barely pulling on it, copper somewhat corroded, some insulation appears discolored suggesting heat/bad connections. Removed all of it, but still having same problems. Should i be suspecting the ignition switch? Any way i can test it? Read before they can cause all sorts of electronic issues.
HMC
C?ID=28246
Hi krazyk,
Did you do any other work at the same time, service/fuel filter? I would be concentrating on the fuel system, start with the low pressure, check pressure etc and work through to the high pressure regulation, check the voltages on the FP regulator and FP sensor, preferably with an oscilloscope.
Regards HMC
MartinsX
Riga, Latvia
C?ID=268515
+ Check WD for shared tracks, common fuses etc, for example LP fuel pump and cooling fan control circuit.
krazyk
Canada
C?ID=363048
Hi krazyk,
Regards HMC
have fuel on low pressure, sorry don't have oscilloscope, am limited on tools. No didn't touch anything on the fuel side of things. The car will eventually start after long cranking and sometimes even runs with no engine light and idles normal for several minutes only top go back to bonkers mode cutting out, stalling, limited revs, glow light and engine light flashing. That's why i am more inclined to think i have a power/ ground issue. Also looks like vcds reports intermittent power /module problems. Unfortunately i am no pro with vcds either I have a video of it running but not sure where i can post it.
krazyk
Canada
C?ID=363048
Well after i kicked the damn thing into the corner for a while i brought it back out. The behavior of this thing wasn't getting any better, scans were problematic to do as it kept dropping connections. However after a lot of ff'in around with fusebox , battery, testing leads i've come to the conclusion the BCM/electric module is perhaps the cause of all of this. Did i mention i also lost power to top part fuse panel in the car, lost the horn also. gotta jump that stuff to make things light up. So the question is 1) can I use a used bcm and code with vcds? 2) what is the important part to know for a matching bcm? the part numbers on these change all the time it seems, is it just software number S0019 that's important? Then there is upgraded software numbers that i think are for the same car config like S2019 and S3019
From scanner; BCM PQ35 B 008 0019
krazyk
Canada
C?ID=363048
Well i'll answer my own question, went and found a different bcm, software was a match but partnumber wasn't. It was plug and play deal, matched old coding and all good
