How to perform OPF reset procedure on audi rs3 400
AleMotorSport
Italy
C?ID=388595
Hello guys
what it would be OPF filter reset / replacement procedure on Audi RS3
how for cars disel?
thanks for your attention
Hello guys
how for cars disel?
Audi RS3 is a petrol/gasoline not diesel car, does even the newest model have a GPF?
AFAIK GPFs do not have a clean process as the exhaust of a petrol/gasoline car is hot enough to clean them without the need for the special clean cycle that diesel cars fitted with a DPF need.
AleMotorSport
Italy
C?ID=388595
exist the function (replacement-reset)
as in diesel cars
so I wonder if there is or not this reset function
rs3 400 has OPF since 2019
Why do I think the software in this car's ECU has major FOD damage? ;)
Looks to me like a "chip tuner" has been messing in places they shouldn't have been messing :facepalm:
AleMotorSport
Italy
C?ID=388595
REPLACING THE OPF
FOR THIS I AM ASKING IF A RESET PROCEDURE EXISTS FROM VCDS
OBVIOUSLY THEN THE OPF OFF FILE MUST BE DONE IN ECU!
AS IN THE DISEL CARS
Both cat and DPF/GPF delete are emissions "hacks" which require someone to (illegally in the EU for road use) modify the engine ECU.
AleMotorSport
Italy
C?ID=388595
car for use PISTA
I HAVE JUST REMOVED THE KAT AND THE OPF
The simple answer is no, you must find a tuner who can hack the engine ECU to remove the cat and GPF from the firmware.
AleMotorSport
Italy
C?ID=388595
thanks the response :)
