2004 Touareg air ride
rsms
C?ID=159458
I have a 2004 Touareg that has been sitting for a while due to other issues, finally had the time to resolve the previous problems but now I'm having a Level Control issue address 34. The car will not go into lift/jack lock mode and the compressor will not come on. I'm only showing a 01768 code which I can not locate anywhere showing a "sensor for vehicle leveling: right supply voltage short to ground. On measuring blocks 004 & 005 are showing max value reading on the rights side. Any thoughts on which way to go on diagnostics?
VCDS Version: 19.6.0.6 (x64)
VIN: WVGHH77L24D065947   License Plate: 1/21/20
Mileage: 243050km-151024mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGHH77L24D065947   Mileage: 243050km-151024miles
   Part No SW: 070 997 016 R    HW: 028 101 172 9
   Component: V10 5,0L EDCG000AGMª2813
   Revision: 5KO3        Serial number: VWZ3Z0D7168666
   Coding: 0060575
   Shop #: WSC 22136 444 65050
   VCID: 295946C883BF1607E2-515E
   Part No: 09D 927 750 BB
   Component: AL 600 6Q           0467
   Coding: 0004153
   Shop #: WSC 31414 000 00000
   VCID: 6FED68D07DDB38377C-515E
01045 - Tiptronic Switch (F189)
            008 - Implausible Signal - Intermittent - MIL ON
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 D
   Component: ESP ALLRAD MK25     0108
   Coding: 0022785
   VCID: 3A7B89847619AD9F9B-515E
   Part No SW: 3D0 909 135 R    HW: 5WK 470 19
   Component: 1E Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D7168666
   Coding: 0147688
   Shop #: WSC 22587 444 52433
   VCID: 3467A7BC547D5BEF41-5140
6 Faults Found:
00955 - Key 1
            002 - Lower Limit Exceeded
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
00183 - Interior Access/Start Authorization Antenna 1 (R138)
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77FD50B0058B70F7A4-515E
   Part No: 7L6 907 044 H
   Component: CLIMAtronic 2+2   X 3717
   Coding: 0000230
   Shop #: WSC 22587 444 52351
   VCID: 39799688731FA68792-515E
   Subsystem 1 - Part No: 7L6 907 049 C
   Component: CLIMAtronic FOND  X 0306
02597 - Rear Left Upper Body Vent Motor (V315)
00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
02598 - Rear Right Upper Body Vent Motor (V316)
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 L
   Component:                     2703
   Coding: 0111839
   VCID: 4581EA780FE7D267E6-515E
00060 - Foglight Lamps
Address 11: Engine II        Labels: None
   Component: V10 5,0L EDCG000AGSª2813
   Coding: 0060575
   Part No: 3D0 909 601 C
   Component: 05 Airbag 8.4E++H01 0352
   Revision: BB36963     Serial number: 00013704
   Coding: 0012341
   VCID: 234554E0E193CC57A8-515E
   Subsystem 1 - Part No: 7L0 959 339 B
   Component: BF-Gewichtsens. 005 0006
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                    Fault Status: 00101001
                    Reset counter: 39
                    Date: 2063.15.31
                    Time: 31:60:00
   Part No: 7L6 953 549 E
   Component: Lenksäulenmodul     3301
   Coding: 0000232
   VCID: 4189FE681BCFFE47DA-5140
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 980 P
   Component: KOMBIINSTRUMENT RB4 2935
   Coding: 0021231
   Shop #: WSC 22587 444 70532
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 B
   Component: Standheizung  E1MAC 0235
   Coding: 0000030
   VCID: 35619AB85F0742E776-5140
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70EF6BAC60E527CF65-5140
01302 - Control Module for Telematic (J499)
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 4581EA780FE7D267E6-5140
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F0DB8902DBB48B7EC-515E
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000003
   VCID: 66C30DF45221F97F0F-5140
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 B
   Component: SG-Quersperre       5018
   VCID: 377D90B0450BB0F764-515E
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 36639DB4420149FF7F-5140
01768 - Sensor for Vehicle Leveling; Right; Supply Voltage
            007 - Short to Ground
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7L6 919 887 D
   Component:      Navigation     0728
   Coding: 0000004
   Shop #: WSC 22587 444 84348
   VCID: 479DE07035EBC07714-515E
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  X012
   Coding: 0000003
   VCID: 67DD00F0552BE07734-515E
   Part No: 7L0 959 933 E
   Component: 2L HSG              0201
   Coding: 0000085
   Shop #: WSC 22587 444 54497
   VCID: 3E7385946A3181BFA7-4B02
   Subsystem 1 - Part No: 7L0 959 701 B
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 B
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 B
   Subsystem 4 - Part No: 7L0 959 704 B
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 7L6 035 466
   Component: 12K-AUDIOVERST      0108
   VCID: 71E96EA86BEF2EC76A-515E
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 A
   Component:        Radio        0728
   Coding: 0005055
   Shop #: WSC 22587 444 57716
   VCID: 3169AEA8AB6F6EC72A-5140
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No: 7L6 907 273
   Component: Reifendruckueberw.  0052
   Coding: 0211390
   VCID: 75E15AB81F8702E7B6-515E
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 31414 000 376832
   VCID: 377D90B0450BB0F764-5140
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 G
   Component: DACHDISPLAY         0535
   Revision: 7005    Serial number: #009268.03     B
   VCID: 3B758C807923949780-515E
Address 76: Park Assist        Labels: None
   Part No: 7L0 919 283 E
   Component: 0E Einparkhilfe     0907
   VCID: 387F938C4815BF8F6D-5140
7 Faults Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
00434 - Left Front Inner Parking Aid Sensor (G332)
00435 - Front Right Inner Parking Aid Sensor (G333)
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
01626 - Sensor for Parking-Aid; Front Right (G252)
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
End-------------------------(Elapsed Time: 07:55)--------------------------
Tuesday,21,January,2020,13:48:27:17972
                Address 34: Level Control  (7L0 907 553 F)
13:48:13 Group 005: Absolute Vehicle Height
  53.0  Left Front (G78) Absolute Height
  255.0  Right Front (G289) Absolute Height
  60.0  Left Rear (G76) Absolute Height
  255.0  Right Rear (G77) Absolute Height
13:48:13 Group 004: Deviation from Nominal Vehicle Height
  -84.0 mm  Left Front Height Deviation
  128.0 mm  Right Front Height Deviation
  -81.0 mm  Left Rear Height Deviation
  128.0 mm  Right Rear Height Deviation
Wiring diagrams and multimeter; compare what's going on left and right at the sensors?
Did you check for suspension sensor brine ingress & causing corrosion bridge at connector?
rsms
C?ID=159458
Thanks guys.... I figured today I would sit down with the wiring schematic and try to see if there was a "bridge" point or junction where power would split from right to left. When I posted I was mainly curious of the 01768 code as I see no reference to it anywhere. Any thoughts?
Did you start with measures of voltage and available current at sensor?
